RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_utmi.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_UTMI_COMPONENT_
31
#define _SAMV71_UTMI_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__I
uint32_t Reserved1[4];
43
__IO
uint32_t UTMI_OHCIICR;
44
__I
uint32_t Reserved2[7];
45
__IO
uint32_t UTMI_CKTRIM;
46
Utmi
47
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
48
/* -------- UTMI_OHCIICR : (UTMI Offset: 0x10) OHCI Interrupt Configuration Register -------- */
49
#define UTMI_OHCIICR_RES0 (0x1u << 0)
50
#define UTMI_OHCIICR_ARIE (0x1u << 4)
51
#define UTMI_OHCIICR_APPSTART (0x1u << 5)
52
#define UTMI_OHCIICR_UDPPUDIS (0x1u << 23)
53
/* -------- UTMI_CKTRIM : (UTMI Offset: 0x30) UTMI Clock Trimming Register -------- */
54
#define UTMI_CKTRIM_FREQ_Pos 0
55
#define UTMI_CKTRIM_FREQ_Msk (0x3u << UTMI_CKTRIM_FREQ_Pos)
56
#define UTMI_CKTRIM_FREQ(value) ((UTMI_CKTRIM_FREQ_Msk & ((value) << UTMI_CKTRIM_FREQ_Pos)))
57
#define UTMI_CKTRIM_FREQ_XTAL12 (0x0u << 0)
58
#define UTMI_CKTRIM_FREQ_XTAL16 (0x1u << 0)
59
61
62
63
#endif
/* _SAMV71_UTMI_COMPONENT_ */
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Utmi
Utmi hardware registers.
Definition
component_utmi.h:41
