RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_uart.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_UART_COMPONENT_
31
#define _SAMV71_UART_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t UART_CR;
43
__IO
uint32_t UART_MR;
44
__O
uint32_t UART_IER;
45
__O
uint32_t UART_IDR;
46
__I
uint32_t UART_IMR;
47
__I
uint32_t UART_SR;
48
__I
uint32_t UART_RHR;
49
__O
uint32_t UART_THR;
50
__IO
uint32_t UART_BRGR;
51
__IO
uint32_t UART_CMPR;
52
__I
uint32_t Reserved1[47];
53
__IO
uint32_t UART_WPMR;
54
__I
uint32_t Reserved2[5];
55
__I
uint32_t
UART_VERSION
56
Uart
57
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
58
/* -------- UART_CR : (UART Offset: 0x0000) Control Register -------- */
59
#define UART_CR_RSTRX (0x1u << 2)
60
#define UART_CR_RSTTX (0x1u << 3)
61
#define UART_CR_RXEN (0x1u << 4)
62
#define UART_CR_RXDIS (0x1u << 5)
63
#define UART_CR_TXEN (0x1u << 6)
64
#define UART_CR_TXDIS (0x1u << 7)
65
#define UART_CR_RSTSTA (0x1u << 8)
66
#define UART_CR_REQCLR (0x1u << 12)
67
#define UART_CR_DBGE (0x1u << 15)
68
/* -------- UART_MR : (UART Offset: 0x0004) Mode Register -------- */
69
#define UART_MR_FILTER (0x1u << 4)
70
#define UART_MR_FILTER_DISABLED (0x0u << 4)
71
#define UART_MR_FILTER_ENABLED (0x1u << 4)
72
#define UART_MR_PAR_Pos 9
73
#define UART_MR_PAR_Msk (0x7u << UART_MR_PAR_Pos)
74
#define UART_MR_PAR(value) ((UART_MR_PAR_Msk & ((value) << UART_MR_PAR_Pos)))
75
#define UART_MR_PAR_EVEN (0x0u << 9)
76
#define UART_MR_PAR_ODD (0x1u << 9)
77
#define UART_MR_PAR_SPACE (0x2u << 9)
78
#define UART_MR_PAR_MARK (0x3u << 9)
79
#define UART_MR_PAR_NO (0x4u << 9)
80
#define UART_MR_BRSRCCK (0x1u << 12)
81
#define UART_MR_BRSRCCK_PERIPH_CLK (0x0u << 12)
82
#define UART_MR_BRSRCCK_PMC_PCK (0x1u << 12)
83
#define UART_MR_CHMODE_Pos 14
84
#define UART_MR_CHMODE_Msk (0x3u << UART_MR_CHMODE_Pos)
85
#define UART_MR_CHMODE(value) ((UART_MR_CHMODE_Msk & ((value) << UART_MR_CHMODE_Pos)))
86
#define UART_MR_CHMODE_NORMAL (0x0u << 14)
87
#define UART_MR_CHMODE_AUTOMATIC (0x1u << 14)
88
#define UART_MR_CHMODE_LOCAL_LOOPBACK (0x2u << 14)
89
#define UART_MR_CHMODE_REMOTE_LOOPBACK (0x3u << 14)
90
/* -------- UART_IER : (UART Offset: 0x0008) Interrupt Enable Register -------- */
91
#define UART_IER_RXRDY (0x1u << 0)
92
#define UART_IER_TXRDY (0x1u << 1)
93
#define UART_IER_OVRE (0x1u << 5)
94
#define UART_IER_FRAME (0x1u << 6)
95
#define UART_IER_PARE (0x1u << 7)
96
#define UART_IER_TXEMPTY (0x1u << 9)
97
#define UART_IER_CMP (0x1u << 15)
98
/* -------- UART_IDR : (UART Offset: 0x000C) Interrupt Disable Register -------- */
99
#define UART_IDR_RXRDY (0x1u << 0)
100
#define UART_IDR_TXRDY (0x1u << 1)
101
#define UART_IDR_OVRE (0x1u << 5)
102
#define UART_IDR_FRAME (0x1u << 6)
103
#define UART_IDR_PARE (0x1u << 7)
104
#define UART_IDR_TXEMPTY (0x1u << 9)
105
#define UART_IDR_CMP (0x1u << 15)
106
/* -------- UART_IMR : (UART Offset: 0x0010) Interrupt Mask Register -------- */
107
#define UART_IMR_RXRDY (0x1u << 0)
108
#define UART_IMR_TXRDY (0x1u << 1)
109
#define UART_IMR_OVRE (0x1u << 5)
110
#define UART_IMR_FRAME (0x1u << 6)
111
#define UART_IMR_PARE (0x1u << 7)
112
#define UART_IMR_TXEMPTY (0x1u << 9)
113
#define UART_IMR_CMP (0x1u << 15)
114
/* -------- UART_SR : (UART Offset: 0x0014) Status Register -------- */
115
#define UART_SR_RXRDY (0x1u << 0)
116
#define UART_SR_TXRDY (0x1u << 1)
117
#define UART_SR_OVRE (0x1u << 5)
118
#define UART_SR_FRAME (0x1u << 6)
119
#define UART_SR_PARE (0x1u << 7)
120
#define UART_SR_TXEMPTY (0x1u << 9)
121
#define UART_SR_CMP (0x1u << 15)
122
#define UART_SR_SWES (0x1u << 21)
123
#define UART_SR_CLKREQ (0x1u << 22)
124
#define UART_SR_WKUPREQ (0x1u << 23)
125
/* -------- UART_RHR : (UART Offset: 0x0018) Receive Holding Register -------- */
126
#define UART_RHR_RXCHR_Pos 0
127
#define UART_RHR_RXCHR_Msk (0xffu << UART_RHR_RXCHR_Pos)
128
/* -------- UART_THR : (UART Offset: 0x001C) Transmit Holding Register -------- */
129
#define UART_THR_TXCHR_Pos 0
130
#define UART_THR_TXCHR_Msk (0xffu << UART_THR_TXCHR_Pos)
131
#define UART_THR_TXCHR(value) ((UART_THR_TXCHR_Msk & ((value) << UART_THR_TXCHR_Pos)))
132
/* -------- UART_BRGR : (UART Offset: 0x0020) Baud Rate Generator Register -------- */
133
#define UART_BRGR_CD_Pos 0
134
#define UART_BRGR_CD_Msk (0xffffu << UART_BRGR_CD_Pos)
135
#define UART_BRGR_CD(value) ((UART_BRGR_CD_Msk & ((value) << UART_BRGR_CD_Pos)))
136
/* -------- UART_CMPR : (UART Offset: 0x0024) Comparison Register -------- */
137
#define UART_CMPR_VAL1_Pos 0
138
#define UART_CMPR_VAL1_Msk (0xffu << UART_CMPR_VAL1_Pos)
139
#define UART_CMPR_VAL1(value) ((UART_CMPR_VAL1_Msk & ((value) << UART_CMPR_VAL1_Pos)))
140
#define UART_CMPR_CMPMODE (0x1u << 12)
141
#define UART_CMPR_CMPMODE_FLAG_ONLY (0x0u << 12)
142
#define UART_CMPR_CMPMODE_START_CONDITION (0x1u << 12)
143
#define UART_CMPR_CMPPAR (0x1u << 14)
144
#define UART_CMPR_VAL2_Pos 16
145
#define UART_CMPR_VAL2_Msk (0xffu << UART_CMPR_VAL2_Pos)
146
#define UART_CMPR_VAL2(value) ((UART_CMPR_VAL2_Msk & ((value) << UART_CMPR_VAL2_Pos)))
147
/* -------- UART_WPMR : (UART Offset: 0x00E4) Write Protection Mode Register -------- */
148
#define UART_WPMR_WPEN (0x1u << 0)
149
#define UART_WPMR_WPKEY_Pos 8
150
#define UART_WPMR_WPKEY_Msk (0xffffffu << UART_WPMR_WPKEY_Pos)
151
#define UART_WPMR_WPKEY(value) ((UART_WPMR_WPKEY_Msk & ((value) << UART_WPMR_WPKEY_Pos)))
152
#define UART_WPMR_WPKEY_PASSWD (0x554152u << 8)
153
/* -------- UART_VERSION : (UART Offset: 0x00FC) Version Register -------- */
154
#define UART_VERSION_VERSION_Pos 0
155
#define UART_VERSION_VERSION_Msk (0xfffu << UART_VERSION_VERSION_Pos)
156
#define UART_VERSION_MFN_Pos 16
157
#define UART_VERSION_MFN_Msk (0x7u << UART_VERSION_MFN_Pos)
158
160
161
162
#endif
/* _SAMV71_UART_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Uart
Uart hardware registers.
Definition
component_uart.h:41
Uart::UART_VERSION
__I uint32_t UART_VERSION
(Uart Offset: 0x00FC) Version Register
Definition
component_uart.h:55
