RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_smc.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_SMC_COMPONENT_
31
#define _SAMV71_SMC_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__IO
uint32_t SMC_SETUP;
43
__IO
uint32_t SMC_PULSE;
44
__IO
uint32_t SMC_CYCLE;
45
__IO
uint32_t SMC_MODE;
46
SmcCs_number
48
#define SMCCS_NUMBER_NUMBER 4
49
typedef
struct
50
SmcCs_number
SMC_CS_NUMBER[SMCCS_NUMBER_NUMBER];
51
__I
uint32_t Reserved1[16];
52
__IO
uint32_t SMC_OCMS;
53
__O
uint32_t SMC_KEY1;
54
__O
uint32_t SMC_KEY2;
55
__I
uint32_t Reserved2[22];
56
__IO
uint32_t SMC_WPMR;
57
__I
uint32_t SMC_WPSR;
58
__I
uint32_t Reserved3[4];
59
__I
uint32_t
SMC_VERSION
60
Smc
61
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
62
/* -------- SMC_SETUP : (SMC Offset: N/A) SMC Setup Register -------- */
63
#define SMC_SETUP_NWE_SETUP_Pos 0
64
#define SMC_SETUP_NWE_SETUP_Msk (0x3fu << SMC_SETUP_NWE_SETUP_Pos)
65
#define SMC_SETUP_NWE_SETUP(value) ((SMC_SETUP_NWE_SETUP_Msk & ((value) << SMC_SETUP_NWE_SETUP_Pos)))
66
#define SMC_SETUP_NCS_WR_SETUP_Pos 8
67
#define SMC_SETUP_NCS_WR_SETUP_Msk (0x3fu << SMC_SETUP_NCS_WR_SETUP_Pos)
68
#define SMC_SETUP_NCS_WR_SETUP(value) ((SMC_SETUP_NCS_WR_SETUP_Msk & ((value) << SMC_SETUP_NCS_WR_SETUP_Pos)))
69
#define SMC_SETUP_NRD_SETUP_Pos 16
70
#define SMC_SETUP_NRD_SETUP_Msk (0x3fu << SMC_SETUP_NRD_SETUP_Pos)
71
#define SMC_SETUP_NRD_SETUP(value) ((SMC_SETUP_NRD_SETUP_Msk & ((value) << SMC_SETUP_NRD_SETUP_Pos)))
72
#define SMC_SETUP_NCS_RD_SETUP_Pos 24
73
#define SMC_SETUP_NCS_RD_SETUP_Msk (0x3fu << SMC_SETUP_NCS_RD_SETUP_Pos)
74
#define SMC_SETUP_NCS_RD_SETUP(value) ((SMC_SETUP_NCS_RD_SETUP_Msk & ((value) << SMC_SETUP_NCS_RD_SETUP_Pos)))
75
/* -------- SMC_PULSE : (SMC Offset: N/A) SMC Pulse Register -------- */
76
#define SMC_PULSE_NWE_PULSE_Pos 0
77
#define SMC_PULSE_NWE_PULSE_Msk (0x7fu << SMC_PULSE_NWE_PULSE_Pos)
78
#define SMC_PULSE_NWE_PULSE(value) ((SMC_PULSE_NWE_PULSE_Msk & ((value) << SMC_PULSE_NWE_PULSE_Pos)))
79
#define SMC_PULSE_NCS_WR_PULSE_Pos 8
80
#define SMC_PULSE_NCS_WR_PULSE_Msk (0x7fu << SMC_PULSE_NCS_WR_PULSE_Pos)
81
#define SMC_PULSE_NCS_WR_PULSE(value) ((SMC_PULSE_NCS_WR_PULSE_Msk & ((value) << SMC_PULSE_NCS_WR_PULSE_Pos)))
82
#define SMC_PULSE_NRD_PULSE_Pos 16
83
#define SMC_PULSE_NRD_PULSE_Msk (0x7fu << SMC_PULSE_NRD_PULSE_Pos)
84
#define SMC_PULSE_NRD_PULSE(value) ((SMC_PULSE_NRD_PULSE_Msk & ((value) << SMC_PULSE_NRD_PULSE_Pos)))
85
#define SMC_PULSE_NCS_RD_PULSE_Pos 24
86
#define SMC_PULSE_NCS_RD_PULSE_Msk (0x7fu << SMC_PULSE_NCS_RD_PULSE_Pos)
87
#define SMC_PULSE_NCS_RD_PULSE(value) ((SMC_PULSE_NCS_RD_PULSE_Msk & ((value) << SMC_PULSE_NCS_RD_PULSE_Pos)))
88
/* -------- SMC_CYCLE : (SMC Offset: N/A) SMC Cycle Register -------- */
89
#define SMC_CYCLE_NWE_CYCLE_Pos 0
90
#define SMC_CYCLE_NWE_CYCLE_Msk (0x1ffu << SMC_CYCLE_NWE_CYCLE_Pos)
91
#define SMC_CYCLE_NWE_CYCLE(value) ((SMC_CYCLE_NWE_CYCLE_Msk & ((value) << SMC_CYCLE_NWE_CYCLE_Pos)))
92
#define SMC_CYCLE_NRD_CYCLE_Pos 16
93
#define SMC_CYCLE_NRD_CYCLE_Msk (0x1ffu << SMC_CYCLE_NRD_CYCLE_Pos)
94
#define SMC_CYCLE_NRD_CYCLE(value) ((SMC_CYCLE_NRD_CYCLE_Msk & ((value) << SMC_CYCLE_NRD_CYCLE_Pos)))
95
/* -------- SMC_MODE : (SMC Offset: N/A) SMC MODE Register -------- */
96
#define SMC_MODE_READ_MODE (0x1u << 0)
97
#define SMC_MODE_WRITE_MODE (0x1u << 1)
98
#define SMC_MODE_EXNW_MODE_Pos 4
99
#define SMC_MODE_EXNW_MODE_Msk (0x3u << SMC_MODE_EXNW_MODE_Pos)
100
#define SMC_MODE_EXNW_MODE(value) ((SMC_MODE_EXNW_MODE_Msk & ((value) << SMC_MODE_EXNW_MODE_Pos)))
101
#define SMC_MODE_EXNW_MODE_DISABLED (0x0u << 4)
102
#define SMC_MODE_EXNW_MODE_FROZEN (0x2u << 4)
103
#define SMC_MODE_EXNW_MODE_READY (0x3u << 4)
104
#define SMC_MODE_BAT (0x1u << 8)
105
#define SMC_MODE_BAT_BYTE_SELECT (0x0u << 8)
106
#define SMC_MODE_BAT_BYTE_WRITE (0x1u << 8)
107
#define SMC_MODE_DBW (0x1u << 12)
108
#define SMC_MODE_DBW_8_BIT (0x0u << 12)
109
#define SMC_MODE_DBW_16_BIT (0x1u << 12)
110
#define SMC_MODE_TDF_CYCLES_Pos 16
111
#define SMC_MODE_TDF_CYCLES_Msk (0xfu << SMC_MODE_TDF_CYCLES_Pos)
112
#define SMC_MODE_TDF_CYCLES(value) ((SMC_MODE_TDF_CYCLES_Msk & ((value) << SMC_MODE_TDF_CYCLES_Pos)))
113
#define SMC_MODE_TDF_MODE (0x1u << 20)
114
#define SMC_MODE_PMEN (0x1u << 24)
115
#define SMC_MODE_PS_Pos 28
116
#define SMC_MODE_PS_Msk (0x3u << SMC_MODE_PS_Pos)
117
#define SMC_MODE_PS(value) ((SMC_MODE_PS_Msk & ((value) << SMC_MODE_PS_Pos)))
118
#define SMC_MODE_PS_4_BYTE (0x0u << 28)
119
#define SMC_MODE_PS_8_BYTE (0x1u << 28)
120
#define SMC_MODE_PS_16_BYTE (0x2u << 28)
121
#define SMC_MODE_PS_32_BYTE (0x3u << 28)
122
/* -------- SMC_OCMS : (SMC Offset: 0x80) SMC OCMS MODE Register -------- */
123
#define SMC_OCMS_SMSE (0x1u << 0)
124
/* -------- SMC_KEY1 : (SMC Offset: 0x84) SMC OCMS KEY1 Register -------- */
125
#define SMC_KEY1_KEY1_Pos 0
126
#define SMC_KEY1_KEY1_Msk (0xffffffffu << SMC_KEY1_KEY1_Pos)
127
#define SMC_KEY1_KEY1(value) ((SMC_KEY1_KEY1_Msk & ((value) << SMC_KEY1_KEY1_Pos)))
128
/* -------- SMC_KEY2 : (SMC Offset: 0x88) SMC OCMS KEY2 Register -------- */
129
#define SMC_KEY2_KEY2_Pos 0
130
#define SMC_KEY2_KEY2_Msk (0xffffffffu << SMC_KEY2_KEY2_Pos)
131
#define SMC_KEY2_KEY2(value) ((SMC_KEY2_KEY2_Msk & ((value) << SMC_KEY2_KEY2_Pos)))
132
/* -------- SMC_WPMR : (SMC Offset: 0xE4) SMC Write Protection Mode Register -------- */
133
#define SMC_WPMR_WPEN (0x1u << 0)
134
#define SMC_WPMR_WPKEY_Pos 8
135
#define SMC_WPMR_WPKEY_Msk (0xffffffu << SMC_WPMR_WPKEY_Pos)
136
#define SMC_WPMR_WPKEY(value) ((SMC_WPMR_WPKEY_Msk & ((value) << SMC_WPMR_WPKEY_Pos)))
137
#define SMC_WPMR_WPKEY_PASSWD (0x534D43u << 8)
138
/* -------- SMC_WPSR : (SMC Offset: 0xE8) SMC Write Protection Status Register -------- */
139
#define SMC_WPSR_WPVS (0x1u << 0)
140
#define SMC_WPSR_WPVSRC_Pos 8
141
#define SMC_WPSR_WPVSRC_Msk (0xffffu << SMC_WPSR_WPVSRC_Pos)
142
/* -------- SMC_VERSION : (SMC Offset: 0xFC) SMC Version Register -------- */
143
#define SMC_VERSION_VERSION_Pos 0
144
#define SMC_VERSION_VERSION_Msk (0xfffu << SMC_VERSION_VERSION_Pos)
145
#define SMC_VERSION_MFN_Pos 16
146
#define SMC_VERSION_MFN_Msk (0x7u << SMC_VERSION_MFN_Pos)
147
149
150
151
#endif
/* _SAMV71_SMC_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
SmcCs_number
SmcCs_number hardware registers.
Definition
component_smc.h:41
Smc
Definition
component_smc.h:49
Smc::SMC_VERSION
__I uint32_t SMC_VERSION
(Smc Offset: 0xFC) SMC Version Register
Definition
component_smc.h:59
