RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_qspi.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_QSPI_COMPONENT_
31
#define _SAMV71_QSPI_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t QSPI_CR;
43
__IO
uint32_t QSPI_MR;
44
__I
uint32_t QSPI_RDR;
45
__O
uint32_t QSPI_TDR;
46
__I
uint32_t QSPI_SR;
47
__O
uint32_t QSPI_IER;
48
__O
uint32_t QSPI_IDR;
49
__I
uint32_t QSPI_IMR;
50
__IO
uint32_t QSPI_SCR;
51
__I
uint32_t Reserved1[3];
52
__IO
uint32_t QSPI_IAR;
53
__IO
uint32_t QSPI_ICR;
54
__IO
uint32_t QSPI_IFR;
55
__I
uint32_t Reserved2[1];
56
__IO
uint32_t QSPI_SMR;
57
__O
uint32_t QSPI_SKR;
58
__I
uint32_t Reserved3[39];
59
__IO
uint32_t QSPI_WPMR;
60
__I
uint32_t QSPI_WPSR;
61
__I
uint32_t Reserved4[4];
62
__I
uint32_t
QSPI_VERSION
63
Qspi
64
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
65
/* -------- QSPI_CR : (QSPI Offset: 0x00) Control Register -------- */
66
#define QSPI_CR_QSPIEN (0x1u << 0)
67
#define QSPI_CR_QSPIDIS (0x1u << 1)
68
#define QSPI_CR_SWRST (0x1u << 7)
69
#define QSPI_CR_LASTXFER (0x1u << 24)
70
/* -------- QSPI_MR : (QSPI Offset: 0x04) Mode Register -------- */
71
#define QSPI_MR_SMM (0x1u << 0)
72
#define QSPI_MR_SMM_SPI (0x0u << 0)
73
#define QSPI_MR_SMM_MEMORY (0x1u << 0)
74
#define QSPI_MR_LLB (0x1u << 1)
75
#define QSPI_MR_LLB_DISABLED (0x0u << 1)
76
#define QSPI_MR_LLB_ENABLED (0x1u << 1)
77
#define QSPI_MR_WDRBT (0x1u << 2)
78
#define QSPI_MR_WDRBT_DISABLED (0x0u << 2)
79
#define QSPI_MR_WDRBT_ENABLED (0x1u << 2)
80
#define QSPI_MR_CSMODE_Pos 4
81
#define QSPI_MR_CSMODE_Msk (0x3u << QSPI_MR_CSMODE_Pos)
82
#define QSPI_MR_CSMODE(value) ((QSPI_MR_CSMODE_Msk & ((value) << QSPI_MR_CSMODE_Pos)))
83
#define QSPI_MR_CSMODE_NOT_RELOADED (0x0u << 4)
84
#define QSPI_MR_CSMODE_LASTXFER (0x1u << 4)
85
#define QSPI_MR_CSMODE_SYSTEMATICALLY (0x2u << 4)
86
#define QSPI_MR_NBBITS_Pos 8
87
#define QSPI_MR_NBBITS_Msk (0xfu << QSPI_MR_NBBITS_Pos)
88
#define QSPI_MR_NBBITS(value) ((QSPI_MR_NBBITS_Msk & ((value) << QSPI_MR_NBBITS_Pos)))
89
#define QSPI_MR_NBBITS_8_BIT (0x0u << 8)
90
#define QSPI_MR_NBBITS_16_BIT (0x8u << 8)
91
#define QSPI_MR_DLYBCT_Pos 16
92
#define QSPI_MR_DLYBCT_Msk (0xffu << QSPI_MR_DLYBCT_Pos)
93
#define QSPI_MR_DLYBCT(value) ((QSPI_MR_DLYBCT_Msk & ((value) << QSPI_MR_DLYBCT_Pos)))
94
#define QSPI_MR_DLYCS_Pos 24
95
#define QSPI_MR_DLYCS_Msk (0xffu << QSPI_MR_DLYCS_Pos)
96
#define QSPI_MR_DLYCS(value) ((QSPI_MR_DLYCS_Msk & ((value) << QSPI_MR_DLYCS_Pos)))
97
/* -------- QSPI_RDR : (QSPI Offset: 0x08) Receive Data Register -------- */
98
#define QSPI_RDR_RD_Pos 0
99
#define QSPI_RDR_RD_Msk (0xffffu << QSPI_RDR_RD_Pos)
100
/* -------- QSPI_TDR : (QSPI Offset: 0x0C) Transmit Data Register -------- */
101
#define QSPI_TDR_TD_Pos 0
102
#define QSPI_TDR_TD_Msk (0xffffu << QSPI_TDR_TD_Pos)
103
#define QSPI_TDR_TD(value) ((QSPI_TDR_TD_Msk & ((value) << QSPI_TDR_TD_Pos)))
104
/* -------- QSPI_SR : (QSPI Offset: 0x10) Status Register -------- */
105
#define QSPI_SR_RDRF (0x1u << 0)
106
#define QSPI_SR_TDRE (0x1u << 1)
107
#define QSPI_SR_TXEMPTY (0x1u << 2)
108
#define QSPI_SR_OVRES (0x1u << 3)
109
#define QSPI_SR_CSR (0x1u << 8)
110
#define QSPI_SR_CSS (0x1u << 9)
111
#define QSPI_SR_INSTRE (0x1u << 10)
112
#define QSPI_SR_QSPIENS (0x1u << 24)
113
/* -------- QSPI_IER : (QSPI Offset: 0x14) Interrupt Enable Register -------- */
114
#define QSPI_IER_RDRF (0x1u << 0)
115
#define QSPI_IER_TDRE (0x1u << 1)
116
#define QSPI_IER_TXEMPTY (0x1u << 2)
117
#define QSPI_IER_OVRES (0x1u << 3)
118
#define QSPI_IER_CSR (0x1u << 8)
119
#define QSPI_IER_CSS (0x1u << 9)
120
#define QSPI_IER_INSTRE (0x1u << 10)
121
/* -------- QSPI_IDR : (QSPI Offset: 0x18) Interrupt Disable Register -------- */
122
#define QSPI_IDR_RDRF (0x1u << 0)
123
#define QSPI_IDR_TDRE (0x1u << 1)
124
#define QSPI_IDR_TXEMPTY (0x1u << 2)
125
#define QSPI_IDR_OVRES (0x1u << 3)
126
#define QSPI_IDR_CSR (0x1u << 8)
127
#define QSPI_IDR_CSS (0x1u << 9)
128
#define QSPI_IDR_INSTRE (0x1u << 10)
129
/* -------- QSPI_IMR : (QSPI Offset: 0x1C) Interrupt Mask Register -------- */
130
#define QSPI_IMR_RDRF (0x1u << 0)
131
#define QSPI_IMR_TDRE (0x1u << 1)
132
#define QSPI_IMR_TXEMPTY (0x1u << 2)
133
#define QSPI_IMR_OVRES (0x1u << 3)
134
#define QSPI_IMR_CSR (0x1u << 8)
135
#define QSPI_IMR_CSS (0x1u << 9)
136
#define QSPI_IMR_INSTRE (0x1u << 10)
137
/* -------- QSPI_SCR : (QSPI Offset: 0x20) Serial Clock Register -------- */
138
#define QSPI_SCR_CPOL (0x1u << 0)
139
#define QSPI_SCR_CPHA (0x1u << 1)
140
#define QSPI_SCR_SCBR_Pos 8
141
#define QSPI_SCR_SCBR_Msk (0xffu << QSPI_SCR_SCBR_Pos)
142
#define QSPI_SCR_SCBR(value) ((QSPI_SCR_SCBR_Msk & ((value) << QSPI_SCR_SCBR_Pos)))
143
#define QSPI_SCR_DLYBS_Pos 16
144
#define QSPI_SCR_DLYBS_Msk (0xffu << QSPI_SCR_DLYBS_Pos)
145
#define QSPI_SCR_DLYBS(value) ((QSPI_SCR_DLYBS_Msk & ((value) << QSPI_SCR_DLYBS_Pos)))
146
/* -------- QSPI_IAR : (QSPI Offset: 0x30) Instruction Address Register -------- */
147
#define QSPI_IAR_ADDR_Pos 0
148
#define QSPI_IAR_ADDR_Msk (0xffffffffu << QSPI_IAR_ADDR_Pos)
149
#define QSPI_IAR_ADDR(value) ((QSPI_IAR_ADDR_Msk & ((value) << QSPI_IAR_ADDR_Pos)))
150
/* -------- QSPI_ICR : (QSPI Offset: 0x34) Instruction Code Register -------- */
151
#define QSPI_ICR_INST_Pos 0
152
#define QSPI_ICR_INST_Msk (0xffu << QSPI_ICR_INST_Pos)
153
#define QSPI_ICR_INST(value) ((QSPI_ICR_INST_Msk & ((value) << QSPI_ICR_INST_Pos)))
154
#define QSPI_ICR_OPT_Pos 16
155
#define QSPI_ICR_OPT_Msk (0xffu << QSPI_ICR_OPT_Pos)
156
#define QSPI_ICR_OPT(value) ((QSPI_ICR_OPT_Msk & ((value) << QSPI_ICR_OPT_Pos)))
157
/* -------- QSPI_IFR : (QSPI Offset: 0x38) Instruction Frame Register -------- */
158
#define QSPI_IFR_WIDTH_Pos 0
159
#define QSPI_IFR_WIDTH_Msk (0x7u << QSPI_IFR_WIDTH_Pos)
160
#define QSPI_IFR_WIDTH(value) ((QSPI_IFR_WIDTH_Msk & ((value) << QSPI_IFR_WIDTH_Pos)))
161
#define QSPI_IFR_WIDTH_SINGLE_BIT_SPI (0x0u << 0)
162
#define QSPI_IFR_WIDTH_DUAL_OUTPUT (0x1u << 0)
163
#define QSPI_IFR_WIDTH_QUAD_OUTPUT (0x2u << 0)
164
#define QSPI_IFR_WIDTH_DUAL_IO (0x3u << 0)
165
#define QSPI_IFR_WIDTH_QUAD_IO (0x4u << 0)
166
#define QSPI_IFR_WIDTH_DUAL_CMD (0x5u << 0)
167
#define QSPI_IFR_WIDTH_QUAD_CMD (0x6u << 0)
168
#define QSPI_IFR_INSTEN (0x1u << 4)
169
#define QSPI_IFR_ADDREN (0x1u << 5)
170
#define QSPI_IFR_OPTEN (0x1u << 6)
171
#define QSPI_IFR_DATAEN (0x1u << 7)
172
#define QSPI_IFR_OPTL_Pos 8
173
#define QSPI_IFR_OPTL_Msk (0x3u << QSPI_IFR_OPTL_Pos)
174
#define QSPI_IFR_OPTL(value) ((QSPI_IFR_OPTL_Msk & ((value) << QSPI_IFR_OPTL_Pos)))
175
#define QSPI_IFR_OPTL_OPTION_1BIT (0x0u << 8)
176
#define QSPI_IFR_OPTL_OPTION_2BIT (0x1u << 8)
177
#define QSPI_IFR_OPTL_OPTION_4BIT (0x2u << 8)
178
#define QSPI_IFR_OPTL_OPTION_8BIT (0x3u << 8)
179
#define QSPI_IFR_ADDRL (0x1u << 10)
180
#define QSPI_IFR_ADDRL_24_BIT (0x0u << 10)
181
#define QSPI_IFR_ADDRL_32_BIT (0x1u << 10)
182
#define QSPI_IFR_TFRTYP_Pos 12
183
#define QSPI_IFR_TFRTYP_Msk (0x3u << QSPI_IFR_TFRTYP_Pos)
184
#define QSPI_IFR_TFRTYP(value) ((QSPI_IFR_TFRTYP_Msk & ((value) << QSPI_IFR_TFRTYP_Pos)))
185
#define QSPI_IFR_TFRTYP_TRSFR_READ (0x0u << 12)
186
#define QSPI_IFR_TFRTYP_TRSFR_READ_MEMORY (0x1u << 12)
187
#define QSPI_IFR_TFRTYP_TRSFR_WRITE (0x2u << 12)
188
#define QSPI_IFR_TFRTYP_TRSFR_WRITE_MEMORY (0x3u << 12)
189
#define QSPI_IFR_CRM (0x1u << 14)
190
#define QSPI_IFR_CRM_DISABLED (0x0u << 14)
191
#define QSPI_IFR_CRM_ENABLED (0x1u << 14)
192
#define QSPI_IFR_NBDUM_Pos 16
193
#define QSPI_IFR_NBDUM_Msk (0x1fu << QSPI_IFR_NBDUM_Pos)
194
#define QSPI_IFR_NBDUM(value) ((QSPI_IFR_NBDUM_Msk & ((value) << QSPI_IFR_NBDUM_Pos)))
195
/* -------- QSPI_SMR : (QSPI Offset: 0x40) Scrambling Mode Register -------- */
196
#define QSPI_SMR_SCREN (0x1u << 0)
197
#define QSPI_SMR_SCREN_DISABLED (0x0u << 0)
198
#define QSPI_SMR_SCREN_ENABLED (0x1u << 0)
199
#define QSPI_SMR_RVDIS (0x1u << 1)
200
/* -------- QSPI_SKR : (QSPI Offset: 0x44) Scrambling Key Register -------- */
201
#define QSPI_SKR_USRK_Pos 0
202
#define QSPI_SKR_USRK_Msk (0xffffffffu << QSPI_SKR_USRK_Pos)
203
#define QSPI_SKR_USRK(value) ((QSPI_SKR_USRK_Msk & ((value) << QSPI_SKR_USRK_Pos)))
204
/* -------- QSPI_WPMR : (QSPI Offset: 0xE4) Write Protection Mode Register -------- */
205
#define QSPI_WPMR_WPEN (0x1u << 0)
206
#define QSPI_WPMR_WPKEY_Pos 8
207
#define QSPI_WPMR_WPKEY_Msk (0xffffffu << QSPI_WPMR_WPKEY_Pos)
208
#define QSPI_WPMR_WPKEY(value) ((QSPI_WPMR_WPKEY_Msk & ((value) << QSPI_WPMR_WPKEY_Pos)))
209
#define QSPI_WPMR_WPKEY_PASSWD (0x515350u << 8)
210
/* -------- QSPI_WPSR : (QSPI Offset: 0xE8) Write Protection Status Register -------- */
211
#define QSPI_WPSR_WPVS (0x1u << 0)
212
#define QSPI_WPSR_WPVSRC_Pos 8
213
#define QSPI_WPSR_WPVSRC_Msk (0xffu << QSPI_WPSR_WPVSRC_Pos)
214
/* -------- QSPI_VERSION : (QSPI Offset: 0x00FC) Version Register -------- */
215
#define QSPI_VERSION_VERSION_Pos 0
216
#define QSPI_VERSION_VERSION_Msk (0xfffu << QSPI_VERSION_VERSION_Pos)
217
#define QSPI_VERSION_MFN_Pos 16
218
#define QSPI_VERSION_MFN_Msk (0x7u << QSPI_VERSION_MFN_Pos)
219
221
222
223
#endif
/* _SAMV71_QSPI_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Qspi
Qspi hardware registers.
Definition
component_qspi.h:41
Qspi::QSPI_VERSION
__I uint32_t QSPI_VERSION
(Qspi Offset: 0x00FC) Version Register
Definition
component_qspi.h:62
