RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_pio.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_PIO_COMPONENT_
31
#define _SAMV71_PIO_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t PIO_PER;
43
__O
uint32_t PIO_PDR;
44
__I
uint32_t PIO_PSR;
45
__I
uint32_t Reserved1[1];
46
__O
uint32_t PIO_OER;
47
__O
uint32_t PIO_ODR;
48
__I
uint32_t PIO_OSR;
49
__I
uint32_t Reserved2[1];
50
__O
uint32_t PIO_IFER;
51
__O
uint32_t PIO_IFDR;
52
__I
uint32_t PIO_IFSR;
53
__I
uint32_t Reserved3[1];
54
__O
uint32_t PIO_SODR;
55
__O
uint32_t PIO_CODR;
56
__IO
uint32_t PIO_ODSR;
57
__I
uint32_t PIO_PDSR;
58
__O
uint32_t PIO_IER;
59
__O
uint32_t PIO_IDR;
60
__I
uint32_t PIO_IMR;
61
__I
uint32_t PIO_ISR;
62
__O
uint32_t PIO_MDER;
63
__O
uint32_t PIO_MDDR;
64
__I
uint32_t PIO_MDSR;
65
__I
uint32_t Reserved4[1];
66
__O
uint32_t PIO_PUDR;
67
__O
uint32_t PIO_PUER;
68
__I
uint32_t PIO_PUSR;
69
__I
uint32_t Reserved5[1];
70
__IO
uint32_t PIO_ABCDSR[2];
71
__I
uint32_t Reserved6[2];
72
__O
uint32_t PIO_IFSCDR;
73
__O
uint32_t PIO_IFSCER;
74
__I
uint32_t PIO_IFSCSR;
75
__IO
uint32_t PIO_SCDR;
76
__O
uint32_t PIO_PPDDR;
77
__O
uint32_t PIO_PPDER;
78
__I
uint32_t PIO_PPDSR;
79
__I
uint32_t Reserved7[1];
80
__O
uint32_t PIO_OWER;
81
__O
uint32_t PIO_OWDR;
82
__I
uint32_t PIO_OWSR;
83
__I
uint32_t Reserved8[1];
84
__O
uint32_t PIO_AIMER;
85
__O
uint32_t PIO_AIMDR;
86
__I
uint32_t PIO_AIMMR;
87
__I
uint32_t Reserved9[1];
88
__O
uint32_t PIO_ESR;
89
__O
uint32_t PIO_LSR;
90
__I
uint32_t PIO_ELSR;
91
__I
uint32_t Reserved10[1];
92
__O
uint32_t PIO_FELLSR;
93
__O
uint32_t PIO_REHLSR;
94
__I
uint32_t PIO_FRLHSR;
95
__I
uint32_t Reserved11[1];
96
__I
uint32_t PIO_LOCKSR;
97
__IO
uint32_t PIO_WPMR;
98
__I
uint32_t PIO_WPSR;
99
__I
uint32_t Reserved12[4];
100
__I
uint32_t
PIO_VERSION
101
__IO
uint32_t
PIO_SCHMITT
102
__I
uint32_t Reserved13[5];
103
__IO
uint32_t
PIO_DRIVER
104
__I
uint32_t Reserved14[13];
105
__IO
uint32_t
PIO_PCMR
106
__O
uint32_t
PIO_PCIER
107
__O
uint32_t
PIO_PCIDR
108
__I
uint32_t
PIO_PCIMR
109
__I
uint32_t
PIO_PCISR
110
__I
uint32_t
PIO_PCRHR
111
Pio
112
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
113
/* -------- PIO_PER : (PIO Offset: 0x0000) PIO Enable Register -------- */
114
#define PIO_PER_P0 (0x1u << 0)
115
#define PIO_PER_P1 (0x1u << 1)
116
#define PIO_PER_P2 (0x1u << 2)
117
#define PIO_PER_P3 (0x1u << 3)
118
#define PIO_PER_P4 (0x1u << 4)
119
#define PIO_PER_P5 (0x1u << 5)
120
#define PIO_PER_P6 (0x1u << 6)
121
#define PIO_PER_P7 (0x1u << 7)
122
#define PIO_PER_P8 (0x1u << 8)
123
#define PIO_PER_P9 (0x1u << 9)
124
#define PIO_PER_P10 (0x1u << 10)
125
#define PIO_PER_P11 (0x1u << 11)
126
#define PIO_PER_P12 (0x1u << 12)
127
#define PIO_PER_P13 (0x1u << 13)
128
#define PIO_PER_P14 (0x1u << 14)
129
#define PIO_PER_P15 (0x1u << 15)
130
#define PIO_PER_P16 (0x1u << 16)
131
#define PIO_PER_P17 (0x1u << 17)
132
#define PIO_PER_P18 (0x1u << 18)
133
#define PIO_PER_P19 (0x1u << 19)
134
#define PIO_PER_P20 (0x1u << 20)
135
#define PIO_PER_P21 (0x1u << 21)
136
#define PIO_PER_P22 (0x1u << 22)
137
#define PIO_PER_P23 (0x1u << 23)
138
#define PIO_PER_P24 (0x1u << 24)
139
#define PIO_PER_P25 (0x1u << 25)
140
#define PIO_PER_P26 (0x1u << 26)
141
#define PIO_PER_P27 (0x1u << 27)
142
#define PIO_PER_P28 (0x1u << 28)
143
#define PIO_PER_P29 (0x1u << 29)
144
#define PIO_PER_P30 (0x1u << 30)
145
#define PIO_PER_P31 (0x1u << 31)
146
/* -------- PIO_PDR : (PIO Offset: 0x0004) PIO Disable Register -------- */
147
#define PIO_PDR_P0 (0x1u << 0)
148
#define PIO_PDR_P1 (0x1u << 1)
149
#define PIO_PDR_P2 (0x1u << 2)
150
#define PIO_PDR_P3 (0x1u << 3)
151
#define PIO_PDR_P4 (0x1u << 4)
152
#define PIO_PDR_P5 (0x1u << 5)
153
#define PIO_PDR_P6 (0x1u << 6)
154
#define PIO_PDR_P7 (0x1u << 7)
155
#define PIO_PDR_P8 (0x1u << 8)
156
#define PIO_PDR_P9 (0x1u << 9)
157
#define PIO_PDR_P10 (0x1u << 10)
158
#define PIO_PDR_P11 (0x1u << 11)
159
#define PIO_PDR_P12 (0x1u << 12)
160
#define PIO_PDR_P13 (0x1u << 13)
161
#define PIO_PDR_P14 (0x1u << 14)
162
#define PIO_PDR_P15 (0x1u << 15)
163
#define PIO_PDR_P16 (0x1u << 16)
164
#define PIO_PDR_P17 (0x1u << 17)
165
#define PIO_PDR_P18 (0x1u << 18)
166
#define PIO_PDR_P19 (0x1u << 19)
167
#define PIO_PDR_P20 (0x1u << 20)
168
#define PIO_PDR_P21 (0x1u << 21)
169
#define PIO_PDR_P22 (0x1u << 22)
170
#define PIO_PDR_P23 (0x1u << 23)
171
#define PIO_PDR_P24 (0x1u << 24)
172
#define PIO_PDR_P25 (0x1u << 25)
173
#define PIO_PDR_P26 (0x1u << 26)
174
#define PIO_PDR_P27 (0x1u << 27)
175
#define PIO_PDR_P28 (0x1u << 28)
176
#define PIO_PDR_P29 (0x1u << 29)
177
#define PIO_PDR_P30 (0x1u << 30)
178
#define PIO_PDR_P31 (0x1u << 31)
179
/* -------- PIO_PSR : (PIO Offset: 0x0008) PIO Status Register -------- */
180
#define PIO_PSR_P0 (0x1u << 0)
181
#define PIO_PSR_P1 (0x1u << 1)
182
#define PIO_PSR_P2 (0x1u << 2)
183
#define PIO_PSR_P3 (0x1u << 3)
184
#define PIO_PSR_P4 (0x1u << 4)
185
#define PIO_PSR_P5 (0x1u << 5)
186
#define PIO_PSR_P6 (0x1u << 6)
187
#define PIO_PSR_P7 (0x1u << 7)
188
#define PIO_PSR_P8 (0x1u << 8)
189
#define PIO_PSR_P9 (0x1u << 9)
190
#define PIO_PSR_P10 (0x1u << 10)
191
#define PIO_PSR_P11 (0x1u << 11)
192
#define PIO_PSR_P12 (0x1u << 12)
193
#define PIO_PSR_P13 (0x1u << 13)
194
#define PIO_PSR_P14 (0x1u << 14)
195
#define PIO_PSR_P15 (0x1u << 15)
196
#define PIO_PSR_P16 (0x1u << 16)
197
#define PIO_PSR_P17 (0x1u << 17)
198
#define PIO_PSR_P18 (0x1u << 18)
199
#define PIO_PSR_P19 (0x1u << 19)
200
#define PIO_PSR_P20 (0x1u << 20)
201
#define PIO_PSR_P21 (0x1u << 21)
202
#define PIO_PSR_P22 (0x1u << 22)
203
#define PIO_PSR_P23 (0x1u << 23)
204
#define PIO_PSR_P24 (0x1u << 24)
205
#define PIO_PSR_P25 (0x1u << 25)
206
#define PIO_PSR_P26 (0x1u << 26)
207
#define PIO_PSR_P27 (0x1u << 27)
208
#define PIO_PSR_P28 (0x1u << 28)
209
#define PIO_PSR_P29 (0x1u << 29)
210
#define PIO_PSR_P30 (0x1u << 30)
211
#define PIO_PSR_P31 (0x1u << 31)
212
/* -------- PIO_OER : (PIO Offset: 0x0010) Output Enable Register -------- */
213
#define PIO_OER_P0 (0x1u << 0)
214
#define PIO_OER_P1 (0x1u << 1)
215
#define PIO_OER_P2 (0x1u << 2)
216
#define PIO_OER_P3 (0x1u << 3)
217
#define PIO_OER_P4 (0x1u << 4)
218
#define PIO_OER_P5 (0x1u << 5)
219
#define PIO_OER_P6 (0x1u << 6)
220
#define PIO_OER_P7 (0x1u << 7)
221
#define PIO_OER_P8 (0x1u << 8)
222
#define PIO_OER_P9 (0x1u << 9)
223
#define PIO_OER_P10 (0x1u << 10)
224
#define PIO_OER_P11 (0x1u << 11)
225
#define PIO_OER_P12 (0x1u << 12)
226
#define PIO_OER_P13 (0x1u << 13)
227
#define PIO_OER_P14 (0x1u << 14)
228
#define PIO_OER_P15 (0x1u << 15)
229
#define PIO_OER_P16 (0x1u << 16)
230
#define PIO_OER_P17 (0x1u << 17)
231
#define PIO_OER_P18 (0x1u << 18)
232
#define PIO_OER_P19 (0x1u << 19)
233
#define PIO_OER_P20 (0x1u << 20)
234
#define PIO_OER_P21 (0x1u << 21)
235
#define PIO_OER_P22 (0x1u << 22)
236
#define PIO_OER_P23 (0x1u << 23)
237
#define PIO_OER_P24 (0x1u << 24)
238
#define PIO_OER_P25 (0x1u << 25)
239
#define PIO_OER_P26 (0x1u << 26)
240
#define PIO_OER_P27 (0x1u << 27)
241
#define PIO_OER_P28 (0x1u << 28)
242
#define PIO_OER_P29 (0x1u << 29)
243
#define PIO_OER_P30 (0x1u << 30)
244
#define PIO_OER_P31 (0x1u << 31)
245
/* -------- PIO_ODR : (PIO Offset: 0x0014) Output Disable Register -------- */
246
#define PIO_ODR_P0 (0x1u << 0)
247
#define PIO_ODR_P1 (0x1u << 1)
248
#define PIO_ODR_P2 (0x1u << 2)
249
#define PIO_ODR_P3 (0x1u << 3)
250
#define PIO_ODR_P4 (0x1u << 4)
251
#define PIO_ODR_P5 (0x1u << 5)
252
#define PIO_ODR_P6 (0x1u << 6)
253
#define PIO_ODR_P7 (0x1u << 7)
254
#define PIO_ODR_P8 (0x1u << 8)
255
#define PIO_ODR_P9 (0x1u << 9)
256
#define PIO_ODR_P10 (0x1u << 10)
257
#define PIO_ODR_P11 (0x1u << 11)
258
#define PIO_ODR_P12 (0x1u << 12)
259
#define PIO_ODR_P13 (0x1u << 13)
260
#define PIO_ODR_P14 (0x1u << 14)
261
#define PIO_ODR_P15 (0x1u << 15)
262
#define PIO_ODR_P16 (0x1u << 16)
263
#define PIO_ODR_P17 (0x1u << 17)
264
#define PIO_ODR_P18 (0x1u << 18)
265
#define PIO_ODR_P19 (0x1u << 19)
266
#define PIO_ODR_P20 (0x1u << 20)
267
#define PIO_ODR_P21 (0x1u << 21)
268
#define PIO_ODR_P22 (0x1u << 22)
269
#define PIO_ODR_P23 (0x1u << 23)
270
#define PIO_ODR_P24 (0x1u << 24)
271
#define PIO_ODR_P25 (0x1u << 25)
272
#define PIO_ODR_P26 (0x1u << 26)
273
#define PIO_ODR_P27 (0x1u << 27)
274
#define PIO_ODR_P28 (0x1u << 28)
275
#define PIO_ODR_P29 (0x1u << 29)
276
#define PIO_ODR_P30 (0x1u << 30)
277
#define PIO_ODR_P31 (0x1u << 31)
278
/* -------- PIO_OSR : (PIO Offset: 0x0018) Output Status Register -------- */
279
#define PIO_OSR_P0 (0x1u << 0)
280
#define PIO_OSR_P1 (0x1u << 1)
281
#define PIO_OSR_P2 (0x1u << 2)
282
#define PIO_OSR_P3 (0x1u << 3)
283
#define PIO_OSR_P4 (0x1u << 4)
284
#define PIO_OSR_P5 (0x1u << 5)
285
#define PIO_OSR_P6 (0x1u << 6)
286
#define PIO_OSR_P7 (0x1u << 7)
287
#define PIO_OSR_P8 (0x1u << 8)
288
#define PIO_OSR_P9 (0x1u << 9)
289
#define PIO_OSR_P10 (0x1u << 10)
290
#define PIO_OSR_P11 (0x1u << 11)
291
#define PIO_OSR_P12 (0x1u << 12)
292
#define PIO_OSR_P13 (0x1u << 13)
293
#define PIO_OSR_P14 (0x1u << 14)
294
#define PIO_OSR_P15 (0x1u << 15)
295
#define PIO_OSR_P16 (0x1u << 16)
296
#define PIO_OSR_P17 (0x1u << 17)
297
#define PIO_OSR_P18 (0x1u << 18)
298
#define PIO_OSR_P19 (0x1u << 19)
299
#define PIO_OSR_P20 (0x1u << 20)
300
#define PIO_OSR_P21 (0x1u << 21)
301
#define PIO_OSR_P22 (0x1u << 22)
302
#define PIO_OSR_P23 (0x1u << 23)
303
#define PIO_OSR_P24 (0x1u << 24)
304
#define PIO_OSR_P25 (0x1u << 25)
305
#define PIO_OSR_P26 (0x1u << 26)
306
#define PIO_OSR_P27 (0x1u << 27)
307
#define PIO_OSR_P28 (0x1u << 28)
308
#define PIO_OSR_P29 (0x1u << 29)
309
#define PIO_OSR_P30 (0x1u << 30)
310
#define PIO_OSR_P31 (0x1u << 31)
311
/* -------- PIO_IFER : (PIO Offset: 0x0020) Glitch Input Filter Enable Register -------- */
312
#define PIO_IFER_P0 (0x1u << 0)
313
#define PIO_IFER_P1 (0x1u << 1)
314
#define PIO_IFER_P2 (0x1u << 2)
315
#define PIO_IFER_P3 (0x1u << 3)
316
#define PIO_IFER_P4 (0x1u << 4)
317
#define PIO_IFER_P5 (0x1u << 5)
318
#define PIO_IFER_P6 (0x1u << 6)
319
#define PIO_IFER_P7 (0x1u << 7)
320
#define PIO_IFER_P8 (0x1u << 8)
321
#define PIO_IFER_P9 (0x1u << 9)
322
#define PIO_IFER_P10 (0x1u << 10)
323
#define PIO_IFER_P11 (0x1u << 11)
324
#define PIO_IFER_P12 (0x1u << 12)
325
#define PIO_IFER_P13 (0x1u << 13)
326
#define PIO_IFER_P14 (0x1u << 14)
327
#define PIO_IFER_P15 (0x1u << 15)
328
#define PIO_IFER_P16 (0x1u << 16)
329
#define PIO_IFER_P17 (0x1u << 17)
330
#define PIO_IFER_P18 (0x1u << 18)
331
#define PIO_IFER_P19 (0x1u << 19)
332
#define PIO_IFER_P20 (0x1u << 20)
333
#define PIO_IFER_P21 (0x1u << 21)
334
#define PIO_IFER_P22 (0x1u << 22)
335
#define PIO_IFER_P23 (0x1u << 23)
336
#define PIO_IFER_P24 (0x1u << 24)
337
#define PIO_IFER_P25 (0x1u << 25)
338
#define PIO_IFER_P26 (0x1u << 26)
339
#define PIO_IFER_P27 (0x1u << 27)
340
#define PIO_IFER_P28 (0x1u << 28)
341
#define PIO_IFER_P29 (0x1u << 29)
342
#define PIO_IFER_P30 (0x1u << 30)
343
#define PIO_IFER_P31 (0x1u << 31)
344
/* -------- PIO_IFDR : (PIO Offset: 0x0024) Glitch Input Filter Disable Register -------- */
345
#define PIO_IFDR_P0 (0x1u << 0)
346
#define PIO_IFDR_P1 (0x1u << 1)
347
#define PIO_IFDR_P2 (0x1u << 2)
348
#define PIO_IFDR_P3 (0x1u << 3)
349
#define PIO_IFDR_P4 (0x1u << 4)
350
#define PIO_IFDR_P5 (0x1u << 5)
351
#define PIO_IFDR_P6 (0x1u << 6)
352
#define PIO_IFDR_P7 (0x1u << 7)
353
#define PIO_IFDR_P8 (0x1u << 8)
354
#define PIO_IFDR_P9 (0x1u << 9)
355
#define PIO_IFDR_P10 (0x1u << 10)
356
#define PIO_IFDR_P11 (0x1u << 11)
357
#define PIO_IFDR_P12 (0x1u << 12)
358
#define PIO_IFDR_P13 (0x1u << 13)
359
#define PIO_IFDR_P14 (0x1u << 14)
360
#define PIO_IFDR_P15 (0x1u << 15)
361
#define PIO_IFDR_P16 (0x1u << 16)
362
#define PIO_IFDR_P17 (0x1u << 17)
363
#define PIO_IFDR_P18 (0x1u << 18)
364
#define PIO_IFDR_P19 (0x1u << 19)
365
#define PIO_IFDR_P20 (0x1u << 20)
366
#define PIO_IFDR_P21 (0x1u << 21)
367
#define PIO_IFDR_P22 (0x1u << 22)
368
#define PIO_IFDR_P23 (0x1u << 23)
369
#define PIO_IFDR_P24 (0x1u << 24)
370
#define PIO_IFDR_P25 (0x1u << 25)
371
#define PIO_IFDR_P26 (0x1u << 26)
372
#define PIO_IFDR_P27 (0x1u << 27)
373
#define PIO_IFDR_P28 (0x1u << 28)
374
#define PIO_IFDR_P29 (0x1u << 29)
375
#define PIO_IFDR_P30 (0x1u << 30)
376
#define PIO_IFDR_P31 (0x1u << 31)
377
/* -------- PIO_IFSR : (PIO Offset: 0x0028) Glitch Input Filter Status Register -------- */
378
#define PIO_IFSR_P0 (0x1u << 0)
379
#define PIO_IFSR_P1 (0x1u << 1)
380
#define PIO_IFSR_P2 (0x1u << 2)
381
#define PIO_IFSR_P3 (0x1u << 3)
382
#define PIO_IFSR_P4 (0x1u << 4)
383
#define PIO_IFSR_P5 (0x1u << 5)
384
#define PIO_IFSR_P6 (0x1u << 6)
385
#define PIO_IFSR_P7 (0x1u << 7)
386
#define PIO_IFSR_P8 (0x1u << 8)
387
#define PIO_IFSR_P9 (0x1u << 9)
388
#define PIO_IFSR_P10 (0x1u << 10)
389
#define PIO_IFSR_P11 (0x1u << 11)
390
#define PIO_IFSR_P12 (0x1u << 12)
391
#define PIO_IFSR_P13 (0x1u << 13)
392
#define PIO_IFSR_P14 (0x1u << 14)
393
#define PIO_IFSR_P15 (0x1u << 15)
394
#define PIO_IFSR_P16 (0x1u << 16)
395
#define PIO_IFSR_P17 (0x1u << 17)
396
#define PIO_IFSR_P18 (0x1u << 18)
397
#define PIO_IFSR_P19 (0x1u << 19)
398
#define PIO_IFSR_P20 (0x1u << 20)
399
#define PIO_IFSR_P21 (0x1u << 21)
400
#define PIO_IFSR_P22 (0x1u << 22)
401
#define PIO_IFSR_P23 (0x1u << 23)
402
#define PIO_IFSR_P24 (0x1u << 24)
403
#define PIO_IFSR_P25 (0x1u << 25)
404
#define PIO_IFSR_P26 (0x1u << 26)
405
#define PIO_IFSR_P27 (0x1u << 27)
406
#define PIO_IFSR_P28 (0x1u << 28)
407
#define PIO_IFSR_P29 (0x1u << 29)
408
#define PIO_IFSR_P30 (0x1u << 30)
409
#define PIO_IFSR_P31 (0x1u << 31)
410
/* -------- PIO_SODR : (PIO Offset: 0x0030) Set Output Data Register -------- */
411
#define PIO_SODR_P0 (0x1u << 0)
412
#define PIO_SODR_P1 (0x1u << 1)
413
#define PIO_SODR_P2 (0x1u << 2)
414
#define PIO_SODR_P3 (0x1u << 3)
415
#define PIO_SODR_P4 (0x1u << 4)
416
#define PIO_SODR_P5 (0x1u << 5)
417
#define PIO_SODR_P6 (0x1u << 6)
418
#define PIO_SODR_P7 (0x1u << 7)
419
#define PIO_SODR_P8 (0x1u << 8)
420
#define PIO_SODR_P9 (0x1u << 9)
421
#define PIO_SODR_P10 (0x1u << 10)
422
#define PIO_SODR_P11 (0x1u << 11)
423
#define PIO_SODR_P12 (0x1u << 12)
424
#define PIO_SODR_P13 (0x1u << 13)
425
#define PIO_SODR_P14 (0x1u << 14)
426
#define PIO_SODR_P15 (0x1u << 15)
427
#define PIO_SODR_P16 (0x1u << 16)
428
#define PIO_SODR_P17 (0x1u << 17)
429
#define PIO_SODR_P18 (0x1u << 18)
430
#define PIO_SODR_P19 (0x1u << 19)
431
#define PIO_SODR_P20 (0x1u << 20)
432
#define PIO_SODR_P21 (0x1u << 21)
433
#define PIO_SODR_P22 (0x1u << 22)
434
#define PIO_SODR_P23 (0x1u << 23)
435
#define PIO_SODR_P24 (0x1u << 24)
436
#define PIO_SODR_P25 (0x1u << 25)
437
#define PIO_SODR_P26 (0x1u << 26)
438
#define PIO_SODR_P27 (0x1u << 27)
439
#define PIO_SODR_P28 (0x1u << 28)
440
#define PIO_SODR_P29 (0x1u << 29)
441
#define PIO_SODR_P30 (0x1u << 30)
442
#define PIO_SODR_P31 (0x1u << 31)
443
/* -------- PIO_CODR : (PIO Offset: 0x0034) Clear Output Data Register -------- */
444
#define PIO_CODR_P0 (0x1u << 0)
445
#define PIO_CODR_P1 (0x1u << 1)
446
#define PIO_CODR_P2 (0x1u << 2)
447
#define PIO_CODR_P3 (0x1u << 3)
448
#define PIO_CODR_P4 (0x1u << 4)
449
#define PIO_CODR_P5 (0x1u << 5)
450
#define PIO_CODR_P6 (0x1u << 6)
451
#define PIO_CODR_P7 (0x1u << 7)
452
#define PIO_CODR_P8 (0x1u << 8)
453
#define PIO_CODR_P9 (0x1u << 9)
454
#define PIO_CODR_P10 (0x1u << 10)
455
#define PIO_CODR_P11 (0x1u << 11)
456
#define PIO_CODR_P12 (0x1u << 12)
457
#define PIO_CODR_P13 (0x1u << 13)
458
#define PIO_CODR_P14 (0x1u << 14)
459
#define PIO_CODR_P15 (0x1u << 15)
460
#define PIO_CODR_P16 (0x1u << 16)
461
#define PIO_CODR_P17 (0x1u << 17)
462
#define PIO_CODR_P18 (0x1u << 18)
463
#define PIO_CODR_P19 (0x1u << 19)
464
#define PIO_CODR_P20 (0x1u << 20)
465
#define PIO_CODR_P21 (0x1u << 21)
466
#define PIO_CODR_P22 (0x1u << 22)
467
#define PIO_CODR_P23 (0x1u << 23)
468
#define PIO_CODR_P24 (0x1u << 24)
469
#define PIO_CODR_P25 (0x1u << 25)
470
#define PIO_CODR_P26 (0x1u << 26)
471
#define PIO_CODR_P27 (0x1u << 27)
472
#define PIO_CODR_P28 (0x1u << 28)
473
#define PIO_CODR_P29 (0x1u << 29)
474
#define PIO_CODR_P30 (0x1u << 30)
475
#define PIO_CODR_P31 (0x1u << 31)
476
/* -------- PIO_ODSR : (PIO Offset: 0x0038) Output Data Status Register -------- */
477
#define PIO_ODSR_P0 (0x1u << 0)
478
#define PIO_ODSR_P1 (0x1u << 1)
479
#define PIO_ODSR_P2 (0x1u << 2)
480
#define PIO_ODSR_P3 (0x1u << 3)
481
#define PIO_ODSR_P4 (0x1u << 4)
482
#define PIO_ODSR_P5 (0x1u << 5)
483
#define PIO_ODSR_P6 (0x1u << 6)
484
#define PIO_ODSR_P7 (0x1u << 7)
485
#define PIO_ODSR_P8 (0x1u << 8)
486
#define PIO_ODSR_P9 (0x1u << 9)
487
#define PIO_ODSR_P10 (0x1u << 10)
488
#define PIO_ODSR_P11 (0x1u << 11)
489
#define PIO_ODSR_P12 (0x1u << 12)
490
#define PIO_ODSR_P13 (0x1u << 13)
491
#define PIO_ODSR_P14 (0x1u << 14)
492
#define PIO_ODSR_P15 (0x1u << 15)
493
#define PIO_ODSR_P16 (0x1u << 16)
494
#define PIO_ODSR_P17 (0x1u << 17)
495
#define PIO_ODSR_P18 (0x1u << 18)
496
#define PIO_ODSR_P19 (0x1u << 19)
497
#define PIO_ODSR_P20 (0x1u << 20)
498
#define PIO_ODSR_P21 (0x1u << 21)
499
#define PIO_ODSR_P22 (0x1u << 22)
500
#define PIO_ODSR_P23 (0x1u << 23)
501
#define PIO_ODSR_P24 (0x1u << 24)
502
#define PIO_ODSR_P25 (0x1u << 25)
503
#define PIO_ODSR_P26 (0x1u << 26)
504
#define PIO_ODSR_P27 (0x1u << 27)
505
#define PIO_ODSR_P28 (0x1u << 28)
506
#define PIO_ODSR_P29 (0x1u << 29)
507
#define PIO_ODSR_P30 (0x1u << 30)
508
#define PIO_ODSR_P31 (0x1u << 31)
509
/* -------- PIO_PDSR : (PIO Offset: 0x003C) Pin Data Status Register -------- */
510
#define PIO_PDSR_P0 (0x1u << 0)
511
#define PIO_PDSR_P1 (0x1u << 1)
512
#define PIO_PDSR_P2 (0x1u << 2)
513
#define PIO_PDSR_P3 (0x1u << 3)
514
#define PIO_PDSR_P4 (0x1u << 4)
515
#define PIO_PDSR_P5 (0x1u << 5)
516
#define PIO_PDSR_P6 (0x1u << 6)
517
#define PIO_PDSR_P7 (0x1u << 7)
518
#define PIO_PDSR_P8 (0x1u << 8)
519
#define PIO_PDSR_P9 (0x1u << 9)
520
#define PIO_PDSR_P10 (0x1u << 10)
521
#define PIO_PDSR_P11 (0x1u << 11)
522
#define PIO_PDSR_P12 (0x1u << 12)
523
#define PIO_PDSR_P13 (0x1u << 13)
524
#define PIO_PDSR_P14 (0x1u << 14)
525
#define PIO_PDSR_P15 (0x1u << 15)
526
#define PIO_PDSR_P16 (0x1u << 16)
527
#define PIO_PDSR_P17 (0x1u << 17)
528
#define PIO_PDSR_P18 (0x1u << 18)
529
#define PIO_PDSR_P19 (0x1u << 19)
530
#define PIO_PDSR_P20 (0x1u << 20)
531
#define PIO_PDSR_P21 (0x1u << 21)
532
#define PIO_PDSR_P22 (0x1u << 22)
533
#define PIO_PDSR_P23 (0x1u << 23)
534
#define PIO_PDSR_P24 (0x1u << 24)
535
#define PIO_PDSR_P25 (0x1u << 25)
536
#define PIO_PDSR_P26 (0x1u << 26)
537
#define PIO_PDSR_P27 (0x1u << 27)
538
#define PIO_PDSR_P28 (0x1u << 28)
539
#define PIO_PDSR_P29 (0x1u << 29)
540
#define PIO_PDSR_P30 (0x1u << 30)
541
#define PIO_PDSR_P31 (0x1u << 31)
542
/* -------- PIO_IER : (PIO Offset: 0x0040) Interrupt Enable Register -------- */
543
#define PIO_IER_P0 (0x1u << 0)
544
#define PIO_IER_P1 (0x1u << 1)
545
#define PIO_IER_P2 (0x1u << 2)
546
#define PIO_IER_P3 (0x1u << 3)
547
#define PIO_IER_P4 (0x1u << 4)
548
#define PIO_IER_P5 (0x1u << 5)
549
#define PIO_IER_P6 (0x1u << 6)
550
#define PIO_IER_P7 (0x1u << 7)
551
#define PIO_IER_P8 (0x1u << 8)
552
#define PIO_IER_P9 (0x1u << 9)
553
#define PIO_IER_P10 (0x1u << 10)
554
#define PIO_IER_P11 (0x1u << 11)
555
#define PIO_IER_P12 (0x1u << 12)
556
#define PIO_IER_P13 (0x1u << 13)
557
#define PIO_IER_P14 (0x1u << 14)
558
#define PIO_IER_P15 (0x1u << 15)
559
#define PIO_IER_P16 (0x1u << 16)
560
#define PIO_IER_P17 (0x1u << 17)
561
#define PIO_IER_P18 (0x1u << 18)
562
#define PIO_IER_P19 (0x1u << 19)
563
#define PIO_IER_P20 (0x1u << 20)
564
#define PIO_IER_P21 (0x1u << 21)
565
#define PIO_IER_P22 (0x1u << 22)
566
#define PIO_IER_P23 (0x1u << 23)
567
#define PIO_IER_P24 (0x1u << 24)
568
#define PIO_IER_P25 (0x1u << 25)
569
#define PIO_IER_P26 (0x1u << 26)
570
#define PIO_IER_P27 (0x1u << 27)
571
#define PIO_IER_P28 (0x1u << 28)
572
#define PIO_IER_P29 (0x1u << 29)
573
#define PIO_IER_P30 (0x1u << 30)
574
#define PIO_IER_P31 (0x1u << 31)
575
/* -------- PIO_IDR : (PIO Offset: 0x0044) Interrupt Disable Register -------- */
576
#define PIO_IDR_P0 (0x1u << 0)
577
#define PIO_IDR_P1 (0x1u << 1)
578
#define PIO_IDR_P2 (0x1u << 2)
579
#define PIO_IDR_P3 (0x1u << 3)
580
#define PIO_IDR_P4 (0x1u << 4)
581
#define PIO_IDR_P5 (0x1u << 5)
582
#define PIO_IDR_P6 (0x1u << 6)
583
#define PIO_IDR_P7 (0x1u << 7)
584
#define PIO_IDR_P8 (0x1u << 8)
585
#define PIO_IDR_P9 (0x1u << 9)
586
#define PIO_IDR_P10 (0x1u << 10)
587
#define PIO_IDR_P11 (0x1u << 11)
588
#define PIO_IDR_P12 (0x1u << 12)
589
#define PIO_IDR_P13 (0x1u << 13)
590
#define PIO_IDR_P14 (0x1u << 14)
591
#define PIO_IDR_P15 (0x1u << 15)
592
#define PIO_IDR_P16 (0x1u << 16)
593
#define PIO_IDR_P17 (0x1u << 17)
594
#define PIO_IDR_P18 (0x1u << 18)
595
#define PIO_IDR_P19 (0x1u << 19)
596
#define PIO_IDR_P20 (0x1u << 20)
597
#define PIO_IDR_P21 (0x1u << 21)
598
#define PIO_IDR_P22 (0x1u << 22)
599
#define PIO_IDR_P23 (0x1u << 23)
600
#define PIO_IDR_P24 (0x1u << 24)
601
#define PIO_IDR_P25 (0x1u << 25)
602
#define PIO_IDR_P26 (0x1u << 26)
603
#define PIO_IDR_P27 (0x1u << 27)
604
#define PIO_IDR_P28 (0x1u << 28)
605
#define PIO_IDR_P29 (0x1u << 29)
606
#define PIO_IDR_P30 (0x1u << 30)
607
#define PIO_IDR_P31 (0x1u << 31)
608
/* -------- PIO_IMR : (PIO Offset: 0x0048) Interrupt Mask Register -------- */
609
#define PIO_IMR_P0 (0x1u << 0)
610
#define PIO_IMR_P1 (0x1u << 1)
611
#define PIO_IMR_P2 (0x1u << 2)
612
#define PIO_IMR_P3 (0x1u << 3)
613
#define PIO_IMR_P4 (0x1u << 4)
614
#define PIO_IMR_P5 (0x1u << 5)
615
#define PIO_IMR_P6 (0x1u << 6)
616
#define PIO_IMR_P7 (0x1u << 7)
617
#define PIO_IMR_P8 (0x1u << 8)
618
#define PIO_IMR_P9 (0x1u << 9)
619
#define PIO_IMR_P10 (0x1u << 10)
620
#define PIO_IMR_P11 (0x1u << 11)
621
#define PIO_IMR_P12 (0x1u << 12)
622
#define PIO_IMR_P13 (0x1u << 13)
623
#define PIO_IMR_P14 (0x1u << 14)
624
#define PIO_IMR_P15 (0x1u << 15)
625
#define PIO_IMR_P16 (0x1u << 16)
626
#define PIO_IMR_P17 (0x1u << 17)
627
#define PIO_IMR_P18 (0x1u << 18)
628
#define PIO_IMR_P19 (0x1u << 19)
629
#define PIO_IMR_P20 (0x1u << 20)
630
#define PIO_IMR_P21 (0x1u << 21)
631
#define PIO_IMR_P22 (0x1u << 22)
632
#define PIO_IMR_P23 (0x1u << 23)
633
#define PIO_IMR_P24 (0x1u << 24)
634
#define PIO_IMR_P25 (0x1u << 25)
635
#define PIO_IMR_P26 (0x1u << 26)
636
#define PIO_IMR_P27 (0x1u << 27)
637
#define PIO_IMR_P28 (0x1u << 28)
638
#define PIO_IMR_P29 (0x1u << 29)
639
#define PIO_IMR_P30 (0x1u << 30)
640
#define PIO_IMR_P31 (0x1u << 31)
641
/* -------- PIO_ISR : (PIO Offset: 0x004C) Interrupt Status Register -------- */
642
#define PIO_ISR_P0 (0x1u << 0)
643
#define PIO_ISR_P1 (0x1u << 1)
644
#define PIO_ISR_P2 (0x1u << 2)
645
#define PIO_ISR_P3 (0x1u << 3)
646
#define PIO_ISR_P4 (0x1u << 4)
647
#define PIO_ISR_P5 (0x1u << 5)
648
#define PIO_ISR_P6 (0x1u << 6)
649
#define PIO_ISR_P7 (0x1u << 7)
650
#define PIO_ISR_P8 (0x1u << 8)
651
#define PIO_ISR_P9 (0x1u << 9)
652
#define PIO_ISR_P10 (0x1u << 10)
653
#define PIO_ISR_P11 (0x1u << 11)
654
#define PIO_ISR_P12 (0x1u << 12)
655
#define PIO_ISR_P13 (0x1u << 13)
656
#define PIO_ISR_P14 (0x1u << 14)
657
#define PIO_ISR_P15 (0x1u << 15)
658
#define PIO_ISR_P16 (0x1u << 16)
659
#define PIO_ISR_P17 (0x1u << 17)
660
#define PIO_ISR_P18 (0x1u << 18)
661
#define PIO_ISR_P19 (0x1u << 19)
662
#define PIO_ISR_P20 (0x1u << 20)
663
#define PIO_ISR_P21 (0x1u << 21)
664
#define PIO_ISR_P22 (0x1u << 22)
665
#define PIO_ISR_P23 (0x1u << 23)
666
#define PIO_ISR_P24 (0x1u << 24)
667
#define PIO_ISR_P25 (0x1u << 25)
668
#define PIO_ISR_P26 (0x1u << 26)
669
#define PIO_ISR_P27 (0x1u << 27)
670
#define PIO_ISR_P28 (0x1u << 28)
671
#define PIO_ISR_P29 (0x1u << 29)
672
#define PIO_ISR_P30 (0x1u << 30)
673
#define PIO_ISR_P31 (0x1u << 31)
674
/* -------- PIO_MDER : (PIO Offset: 0x0050) Multi-driver Enable Register -------- */
675
#define PIO_MDER_P0 (0x1u << 0)
676
#define PIO_MDER_P1 (0x1u << 1)
677
#define PIO_MDER_P2 (0x1u << 2)
678
#define PIO_MDER_P3 (0x1u << 3)
679
#define PIO_MDER_P4 (0x1u << 4)
680
#define PIO_MDER_P5 (0x1u << 5)
681
#define PIO_MDER_P6 (0x1u << 6)
682
#define PIO_MDER_P7 (0x1u << 7)
683
#define PIO_MDER_P8 (0x1u << 8)
684
#define PIO_MDER_P9 (0x1u << 9)
685
#define PIO_MDER_P10 (0x1u << 10)
686
#define PIO_MDER_P11 (0x1u << 11)
687
#define PIO_MDER_P12 (0x1u << 12)
688
#define PIO_MDER_P13 (0x1u << 13)
689
#define PIO_MDER_P14 (0x1u << 14)
690
#define PIO_MDER_P15 (0x1u << 15)
691
#define PIO_MDER_P16 (0x1u << 16)
692
#define PIO_MDER_P17 (0x1u << 17)
693
#define PIO_MDER_P18 (0x1u << 18)
694
#define PIO_MDER_P19 (0x1u << 19)
695
#define PIO_MDER_P20 (0x1u << 20)
696
#define PIO_MDER_P21 (0x1u << 21)
697
#define PIO_MDER_P22 (0x1u << 22)
698
#define PIO_MDER_P23 (0x1u << 23)
699
#define PIO_MDER_P24 (0x1u << 24)
700
#define PIO_MDER_P25 (0x1u << 25)
701
#define PIO_MDER_P26 (0x1u << 26)
702
#define PIO_MDER_P27 (0x1u << 27)
703
#define PIO_MDER_P28 (0x1u << 28)
704
#define PIO_MDER_P29 (0x1u << 29)
705
#define PIO_MDER_P30 (0x1u << 30)
706
#define PIO_MDER_P31 (0x1u << 31)
707
/* -------- PIO_MDDR : (PIO Offset: 0x0054) Multi-driver Disable Register -------- */
708
#define PIO_MDDR_P0 (0x1u << 0)
709
#define PIO_MDDR_P1 (0x1u << 1)
710
#define PIO_MDDR_P2 (0x1u << 2)
711
#define PIO_MDDR_P3 (0x1u << 3)
712
#define PIO_MDDR_P4 (0x1u << 4)
713
#define PIO_MDDR_P5 (0x1u << 5)
714
#define PIO_MDDR_P6 (0x1u << 6)
715
#define PIO_MDDR_P7 (0x1u << 7)
716
#define PIO_MDDR_P8 (0x1u << 8)
717
#define PIO_MDDR_P9 (0x1u << 9)
718
#define PIO_MDDR_P10 (0x1u << 10)
719
#define PIO_MDDR_P11 (0x1u << 11)
720
#define PIO_MDDR_P12 (0x1u << 12)
721
#define PIO_MDDR_P13 (0x1u << 13)
722
#define PIO_MDDR_P14 (0x1u << 14)
723
#define PIO_MDDR_P15 (0x1u << 15)
724
#define PIO_MDDR_P16 (0x1u << 16)
725
#define PIO_MDDR_P17 (0x1u << 17)
726
#define PIO_MDDR_P18 (0x1u << 18)
727
#define PIO_MDDR_P19 (0x1u << 19)
728
#define PIO_MDDR_P20 (0x1u << 20)
729
#define PIO_MDDR_P21 (0x1u << 21)
730
#define PIO_MDDR_P22 (0x1u << 22)
731
#define PIO_MDDR_P23 (0x1u << 23)
732
#define PIO_MDDR_P24 (0x1u << 24)
733
#define PIO_MDDR_P25 (0x1u << 25)
734
#define PIO_MDDR_P26 (0x1u << 26)
735
#define PIO_MDDR_P27 (0x1u << 27)
736
#define PIO_MDDR_P28 (0x1u << 28)
737
#define PIO_MDDR_P29 (0x1u << 29)
738
#define PIO_MDDR_P30 (0x1u << 30)
739
#define PIO_MDDR_P31 (0x1u << 31)
740
/* -------- PIO_MDSR : (PIO Offset: 0x0058) Multi-driver Status Register -------- */
741
#define PIO_MDSR_P0 (0x1u << 0)
742
#define PIO_MDSR_P1 (0x1u << 1)
743
#define PIO_MDSR_P2 (0x1u << 2)
744
#define PIO_MDSR_P3 (0x1u << 3)
745
#define PIO_MDSR_P4 (0x1u << 4)
746
#define PIO_MDSR_P5 (0x1u << 5)
747
#define PIO_MDSR_P6 (0x1u << 6)
748
#define PIO_MDSR_P7 (0x1u << 7)
749
#define PIO_MDSR_P8 (0x1u << 8)
750
#define PIO_MDSR_P9 (0x1u << 9)
751
#define PIO_MDSR_P10 (0x1u << 10)
752
#define PIO_MDSR_P11 (0x1u << 11)
753
#define PIO_MDSR_P12 (0x1u << 12)
754
#define PIO_MDSR_P13 (0x1u << 13)
755
#define PIO_MDSR_P14 (0x1u << 14)
756
#define PIO_MDSR_P15 (0x1u << 15)
757
#define PIO_MDSR_P16 (0x1u << 16)
758
#define PIO_MDSR_P17 (0x1u << 17)
759
#define PIO_MDSR_P18 (0x1u << 18)
760
#define PIO_MDSR_P19 (0x1u << 19)
761
#define PIO_MDSR_P20 (0x1u << 20)
762
#define PIO_MDSR_P21 (0x1u << 21)
763
#define PIO_MDSR_P22 (0x1u << 22)
764
#define PIO_MDSR_P23 (0x1u << 23)
765
#define PIO_MDSR_P24 (0x1u << 24)
766
#define PIO_MDSR_P25 (0x1u << 25)
767
#define PIO_MDSR_P26 (0x1u << 26)
768
#define PIO_MDSR_P27 (0x1u << 27)
769
#define PIO_MDSR_P28 (0x1u << 28)
770
#define PIO_MDSR_P29 (0x1u << 29)
771
#define PIO_MDSR_P30 (0x1u << 30)
772
#define PIO_MDSR_P31 (0x1u << 31)
773
/* -------- PIO_PUDR : (PIO Offset: 0x0060) Pull-up Disable Register -------- */
774
#define PIO_PUDR_P0 (0x1u << 0)
775
#define PIO_PUDR_P1 (0x1u << 1)
776
#define PIO_PUDR_P2 (0x1u << 2)
777
#define PIO_PUDR_P3 (0x1u << 3)
778
#define PIO_PUDR_P4 (0x1u << 4)
779
#define PIO_PUDR_P5 (0x1u << 5)
780
#define PIO_PUDR_P6 (0x1u << 6)
781
#define PIO_PUDR_P7 (0x1u << 7)
782
#define PIO_PUDR_P8 (0x1u << 8)
783
#define PIO_PUDR_P9 (0x1u << 9)
784
#define PIO_PUDR_P10 (0x1u << 10)
785
#define PIO_PUDR_P11 (0x1u << 11)
786
#define PIO_PUDR_P12 (0x1u << 12)
787
#define PIO_PUDR_P13 (0x1u << 13)
788
#define PIO_PUDR_P14 (0x1u << 14)
789
#define PIO_PUDR_P15 (0x1u << 15)
790
#define PIO_PUDR_P16 (0x1u << 16)
791
#define PIO_PUDR_P17 (0x1u << 17)
792
#define PIO_PUDR_P18 (0x1u << 18)
793
#define PIO_PUDR_P19 (0x1u << 19)
794
#define PIO_PUDR_P20 (0x1u << 20)
795
#define PIO_PUDR_P21 (0x1u << 21)
796
#define PIO_PUDR_P22 (0x1u << 22)
797
#define PIO_PUDR_P23 (0x1u << 23)
798
#define PIO_PUDR_P24 (0x1u << 24)
799
#define PIO_PUDR_P25 (0x1u << 25)
800
#define PIO_PUDR_P26 (0x1u << 26)
801
#define PIO_PUDR_P27 (0x1u << 27)
802
#define PIO_PUDR_P28 (0x1u << 28)
803
#define PIO_PUDR_P29 (0x1u << 29)
804
#define PIO_PUDR_P30 (0x1u << 30)
805
#define PIO_PUDR_P31 (0x1u << 31)
806
/* -------- PIO_PUER : (PIO Offset: 0x0064) Pull-up Enable Register -------- */
807
#define PIO_PUER_P0 (0x1u << 0)
808
#define PIO_PUER_P1 (0x1u << 1)
809
#define PIO_PUER_P2 (0x1u << 2)
810
#define PIO_PUER_P3 (0x1u << 3)
811
#define PIO_PUER_P4 (0x1u << 4)
812
#define PIO_PUER_P5 (0x1u << 5)
813
#define PIO_PUER_P6 (0x1u << 6)
814
#define PIO_PUER_P7 (0x1u << 7)
815
#define PIO_PUER_P8 (0x1u << 8)
816
#define PIO_PUER_P9 (0x1u << 9)
817
#define PIO_PUER_P10 (0x1u << 10)
818
#define PIO_PUER_P11 (0x1u << 11)
819
#define PIO_PUER_P12 (0x1u << 12)
820
#define PIO_PUER_P13 (0x1u << 13)
821
#define PIO_PUER_P14 (0x1u << 14)
822
#define PIO_PUER_P15 (0x1u << 15)
823
#define PIO_PUER_P16 (0x1u << 16)
824
#define PIO_PUER_P17 (0x1u << 17)
825
#define PIO_PUER_P18 (0x1u << 18)
826
#define PIO_PUER_P19 (0x1u << 19)
827
#define PIO_PUER_P20 (0x1u << 20)
828
#define PIO_PUER_P21 (0x1u << 21)
829
#define PIO_PUER_P22 (0x1u << 22)
830
#define PIO_PUER_P23 (0x1u << 23)
831
#define PIO_PUER_P24 (0x1u << 24)
832
#define PIO_PUER_P25 (0x1u << 25)
833
#define PIO_PUER_P26 (0x1u << 26)
834
#define PIO_PUER_P27 (0x1u << 27)
835
#define PIO_PUER_P28 (0x1u << 28)
836
#define PIO_PUER_P29 (0x1u << 29)
837
#define PIO_PUER_P30 (0x1u << 30)
838
#define PIO_PUER_P31 (0x1u << 31)
839
/* -------- PIO_PUSR : (PIO Offset: 0x0068) Pad Pull-up Status Register -------- */
840
#define PIO_PUSR_P0 (0x1u << 0)
841
#define PIO_PUSR_P1 (0x1u << 1)
842
#define PIO_PUSR_P2 (0x1u << 2)
843
#define PIO_PUSR_P3 (0x1u << 3)
844
#define PIO_PUSR_P4 (0x1u << 4)
845
#define PIO_PUSR_P5 (0x1u << 5)
846
#define PIO_PUSR_P6 (0x1u << 6)
847
#define PIO_PUSR_P7 (0x1u << 7)
848
#define PIO_PUSR_P8 (0x1u << 8)
849
#define PIO_PUSR_P9 (0x1u << 9)
850
#define PIO_PUSR_P10 (0x1u << 10)
851
#define PIO_PUSR_P11 (0x1u << 11)
852
#define PIO_PUSR_P12 (0x1u << 12)
853
#define PIO_PUSR_P13 (0x1u << 13)
854
#define PIO_PUSR_P14 (0x1u << 14)
855
#define PIO_PUSR_P15 (0x1u << 15)
856
#define PIO_PUSR_P16 (0x1u << 16)
857
#define PIO_PUSR_P17 (0x1u << 17)
858
#define PIO_PUSR_P18 (0x1u << 18)
859
#define PIO_PUSR_P19 (0x1u << 19)
860
#define PIO_PUSR_P20 (0x1u << 20)
861
#define PIO_PUSR_P21 (0x1u << 21)
862
#define PIO_PUSR_P22 (0x1u << 22)
863
#define PIO_PUSR_P23 (0x1u << 23)
864
#define PIO_PUSR_P24 (0x1u << 24)
865
#define PIO_PUSR_P25 (0x1u << 25)
866
#define PIO_PUSR_P26 (0x1u << 26)
867
#define PIO_PUSR_P27 (0x1u << 27)
868
#define PIO_PUSR_P28 (0x1u << 28)
869
#define PIO_PUSR_P29 (0x1u << 29)
870
#define PIO_PUSR_P30 (0x1u << 30)
871
#define PIO_PUSR_P31 (0x1u << 31)
872
/* -------- PIO_ABCDSR[2] : (PIO Offset: 0x0070) Peripheral Select Register -------- */
873
#define PIO_ABCDSR_P0 (0x1u << 0)
874
#define PIO_ABCDSR_P1 (0x1u << 1)
875
#define PIO_ABCDSR_P2 (0x1u << 2)
876
#define PIO_ABCDSR_P3 (0x1u << 3)
877
#define PIO_ABCDSR_P4 (0x1u << 4)
878
#define PIO_ABCDSR_P5 (0x1u << 5)
879
#define PIO_ABCDSR_P6 (0x1u << 6)
880
#define PIO_ABCDSR_P7 (0x1u << 7)
881
#define PIO_ABCDSR_P8 (0x1u << 8)
882
#define PIO_ABCDSR_P9 (0x1u << 9)
883
#define PIO_ABCDSR_P10 (0x1u << 10)
884
#define PIO_ABCDSR_P11 (0x1u << 11)
885
#define PIO_ABCDSR_P12 (0x1u << 12)
886
#define PIO_ABCDSR_P13 (0x1u << 13)
887
#define PIO_ABCDSR_P14 (0x1u << 14)
888
#define PIO_ABCDSR_P15 (0x1u << 15)
889
#define PIO_ABCDSR_P16 (0x1u << 16)
890
#define PIO_ABCDSR_P17 (0x1u << 17)
891
#define PIO_ABCDSR_P18 (0x1u << 18)
892
#define PIO_ABCDSR_P19 (0x1u << 19)
893
#define PIO_ABCDSR_P20 (0x1u << 20)
894
#define PIO_ABCDSR_P21 (0x1u << 21)
895
#define PIO_ABCDSR_P22 (0x1u << 22)
896
#define PIO_ABCDSR_P23 (0x1u << 23)
897
#define PIO_ABCDSR_P24 (0x1u << 24)
898
#define PIO_ABCDSR_P25 (0x1u << 25)
899
#define PIO_ABCDSR_P26 (0x1u << 26)
900
#define PIO_ABCDSR_P27 (0x1u << 27)
901
#define PIO_ABCDSR_P28 (0x1u << 28)
902
#define PIO_ABCDSR_P29 (0x1u << 29)
903
#define PIO_ABCDSR_P30 (0x1u << 30)
904
#define PIO_ABCDSR_P31 (0x1u << 31)
905
/* -------- PIO_IFSCDR : (PIO Offset: 0x0080) Input Filter Slow Clock Disable Register -------- */
906
#define PIO_IFSCDR_P0 (0x1u << 0)
907
#define PIO_IFSCDR_P1 (0x1u << 1)
908
#define PIO_IFSCDR_P2 (0x1u << 2)
909
#define PIO_IFSCDR_P3 (0x1u << 3)
910
#define PIO_IFSCDR_P4 (0x1u << 4)
911
#define PIO_IFSCDR_P5 (0x1u << 5)
912
#define PIO_IFSCDR_P6 (0x1u << 6)
913
#define PIO_IFSCDR_P7 (0x1u << 7)
914
#define PIO_IFSCDR_P8 (0x1u << 8)
915
#define PIO_IFSCDR_P9 (0x1u << 9)
916
#define PIO_IFSCDR_P10 (0x1u << 10)
917
#define PIO_IFSCDR_P11 (0x1u << 11)
918
#define PIO_IFSCDR_P12 (0x1u << 12)
919
#define PIO_IFSCDR_P13 (0x1u << 13)
920
#define PIO_IFSCDR_P14 (0x1u << 14)
921
#define PIO_IFSCDR_P15 (0x1u << 15)
922
#define PIO_IFSCDR_P16 (0x1u << 16)
923
#define PIO_IFSCDR_P17 (0x1u << 17)
924
#define PIO_IFSCDR_P18 (0x1u << 18)
925
#define PIO_IFSCDR_P19 (0x1u << 19)
926
#define PIO_IFSCDR_P20 (0x1u << 20)
927
#define PIO_IFSCDR_P21 (0x1u << 21)
928
#define PIO_IFSCDR_P22 (0x1u << 22)
929
#define PIO_IFSCDR_P23 (0x1u << 23)
930
#define PIO_IFSCDR_P24 (0x1u << 24)
931
#define PIO_IFSCDR_P25 (0x1u << 25)
932
#define PIO_IFSCDR_P26 (0x1u << 26)
933
#define PIO_IFSCDR_P27 (0x1u << 27)
934
#define PIO_IFSCDR_P28 (0x1u << 28)
935
#define PIO_IFSCDR_P29 (0x1u << 29)
936
#define PIO_IFSCDR_P30 (0x1u << 30)
937
#define PIO_IFSCDR_P31 (0x1u << 31)
938
/* -------- PIO_IFSCER : (PIO Offset: 0x0084) Input Filter Slow Clock Enable Register -------- */
939
#define PIO_IFSCER_P0 (0x1u << 0)
940
#define PIO_IFSCER_P1 (0x1u << 1)
941
#define PIO_IFSCER_P2 (0x1u << 2)
942
#define PIO_IFSCER_P3 (0x1u << 3)
943
#define PIO_IFSCER_P4 (0x1u << 4)
944
#define PIO_IFSCER_P5 (0x1u << 5)
945
#define PIO_IFSCER_P6 (0x1u << 6)
946
#define PIO_IFSCER_P7 (0x1u << 7)
947
#define PIO_IFSCER_P8 (0x1u << 8)
948
#define PIO_IFSCER_P9 (0x1u << 9)
949
#define PIO_IFSCER_P10 (0x1u << 10)
950
#define PIO_IFSCER_P11 (0x1u << 11)
951
#define PIO_IFSCER_P12 (0x1u << 12)
952
#define PIO_IFSCER_P13 (0x1u << 13)
953
#define PIO_IFSCER_P14 (0x1u << 14)
954
#define PIO_IFSCER_P15 (0x1u << 15)
955
#define PIO_IFSCER_P16 (0x1u << 16)
956
#define PIO_IFSCER_P17 (0x1u << 17)
957
#define PIO_IFSCER_P18 (0x1u << 18)
958
#define PIO_IFSCER_P19 (0x1u << 19)
959
#define PIO_IFSCER_P20 (0x1u << 20)
960
#define PIO_IFSCER_P21 (0x1u << 21)
961
#define PIO_IFSCER_P22 (0x1u << 22)
962
#define PIO_IFSCER_P23 (0x1u << 23)
963
#define PIO_IFSCER_P24 (0x1u << 24)
964
#define PIO_IFSCER_P25 (0x1u << 25)
965
#define PIO_IFSCER_P26 (0x1u << 26)
966
#define PIO_IFSCER_P27 (0x1u << 27)
967
#define PIO_IFSCER_P28 (0x1u << 28)
968
#define PIO_IFSCER_P29 (0x1u << 29)
969
#define PIO_IFSCER_P30 (0x1u << 30)
970
#define PIO_IFSCER_P31 (0x1u << 31)
971
/* -------- PIO_IFSCSR : (PIO Offset: 0x0088) Input Filter Slow Clock Status Register -------- */
972
#define PIO_IFSCSR_P0 (0x1u << 0)
973
#define PIO_IFSCSR_P1 (0x1u << 1)
974
#define PIO_IFSCSR_P2 (0x1u << 2)
975
#define PIO_IFSCSR_P3 (0x1u << 3)
976
#define PIO_IFSCSR_P4 (0x1u << 4)
977
#define PIO_IFSCSR_P5 (0x1u << 5)
978
#define PIO_IFSCSR_P6 (0x1u << 6)
979
#define PIO_IFSCSR_P7 (0x1u << 7)
980
#define PIO_IFSCSR_P8 (0x1u << 8)
981
#define PIO_IFSCSR_P9 (0x1u << 9)
982
#define PIO_IFSCSR_P10 (0x1u << 10)
983
#define PIO_IFSCSR_P11 (0x1u << 11)
984
#define PIO_IFSCSR_P12 (0x1u << 12)
985
#define PIO_IFSCSR_P13 (0x1u << 13)
986
#define PIO_IFSCSR_P14 (0x1u << 14)
987
#define PIO_IFSCSR_P15 (0x1u << 15)
988
#define PIO_IFSCSR_P16 (0x1u << 16)
989
#define PIO_IFSCSR_P17 (0x1u << 17)
990
#define PIO_IFSCSR_P18 (0x1u << 18)
991
#define PIO_IFSCSR_P19 (0x1u << 19)
992
#define PIO_IFSCSR_P20 (0x1u << 20)
993
#define PIO_IFSCSR_P21 (0x1u << 21)
994
#define PIO_IFSCSR_P22 (0x1u << 22)
995
#define PIO_IFSCSR_P23 (0x1u << 23)
996
#define PIO_IFSCSR_P24 (0x1u << 24)
997
#define PIO_IFSCSR_P25 (0x1u << 25)
998
#define PIO_IFSCSR_P26 (0x1u << 26)
999
#define PIO_IFSCSR_P27 (0x1u << 27)
1000
#define PIO_IFSCSR_P28 (0x1u << 28)
1001
#define PIO_IFSCSR_P29 (0x1u << 29)
1002
#define PIO_IFSCSR_P30 (0x1u << 30)
1003
#define PIO_IFSCSR_P31 (0x1u << 31)
1004
/* -------- PIO_SCDR : (PIO Offset: 0x008C) Slow Clock Divider Debouncing Register -------- */
1005
#define PIO_SCDR_DIV_Pos 0
1006
#define PIO_SCDR_DIV_Msk (0x3fffu << PIO_SCDR_DIV_Pos)
1007
#define PIO_SCDR_DIV(value) ((PIO_SCDR_DIV_Msk & ((value) << PIO_SCDR_DIV_Pos)))
1008
/* -------- PIO_PPDDR : (PIO Offset: 0x0090) Pad Pull-down Disable Register -------- */
1009
#define PIO_PPDDR_P0 (0x1u << 0)
1010
#define PIO_PPDDR_P1 (0x1u << 1)
1011
#define PIO_PPDDR_P2 (0x1u << 2)
1012
#define PIO_PPDDR_P3 (0x1u << 3)
1013
#define PIO_PPDDR_P4 (0x1u << 4)
1014
#define PIO_PPDDR_P5 (0x1u << 5)
1015
#define PIO_PPDDR_P6 (0x1u << 6)
1016
#define PIO_PPDDR_P7 (0x1u << 7)
1017
#define PIO_PPDDR_P8 (0x1u << 8)
1018
#define PIO_PPDDR_P9 (0x1u << 9)
1019
#define PIO_PPDDR_P10 (0x1u << 10)
1020
#define PIO_PPDDR_P11 (0x1u << 11)
1021
#define PIO_PPDDR_P12 (0x1u << 12)
1022
#define PIO_PPDDR_P13 (0x1u << 13)
1023
#define PIO_PPDDR_P14 (0x1u << 14)
1024
#define PIO_PPDDR_P15 (0x1u << 15)
1025
#define PIO_PPDDR_P16 (0x1u << 16)
1026
#define PIO_PPDDR_P17 (0x1u << 17)
1027
#define PIO_PPDDR_P18 (0x1u << 18)
1028
#define PIO_PPDDR_P19 (0x1u << 19)
1029
#define PIO_PPDDR_P20 (0x1u << 20)
1030
#define PIO_PPDDR_P21 (0x1u << 21)
1031
#define PIO_PPDDR_P22 (0x1u << 22)
1032
#define PIO_PPDDR_P23 (0x1u << 23)
1033
#define PIO_PPDDR_P24 (0x1u << 24)
1034
#define PIO_PPDDR_P25 (0x1u << 25)
1035
#define PIO_PPDDR_P26 (0x1u << 26)
1036
#define PIO_PPDDR_P27 (0x1u << 27)
1037
#define PIO_PPDDR_P28 (0x1u << 28)
1038
#define PIO_PPDDR_P29 (0x1u << 29)
1039
#define PIO_PPDDR_P30 (0x1u << 30)
1040
#define PIO_PPDDR_P31 (0x1u << 31)
1041
/* -------- PIO_PPDER : (PIO Offset: 0x0094) Pad Pull-down Enable Register -------- */
1042
#define PIO_PPDER_P0 (0x1u << 0)
1043
#define PIO_PPDER_P1 (0x1u << 1)
1044
#define PIO_PPDER_P2 (0x1u << 2)
1045
#define PIO_PPDER_P3 (0x1u << 3)
1046
#define PIO_PPDER_P4 (0x1u << 4)
1047
#define PIO_PPDER_P5 (0x1u << 5)
1048
#define PIO_PPDER_P6 (0x1u << 6)
1049
#define PIO_PPDER_P7 (0x1u << 7)
1050
#define PIO_PPDER_P8 (0x1u << 8)
1051
#define PIO_PPDER_P9 (0x1u << 9)
1052
#define PIO_PPDER_P10 (0x1u << 10)
1053
#define PIO_PPDER_P11 (0x1u << 11)
1054
#define PIO_PPDER_P12 (0x1u << 12)
1055
#define PIO_PPDER_P13 (0x1u << 13)
1056
#define PIO_PPDER_P14 (0x1u << 14)
1057
#define PIO_PPDER_P15 (0x1u << 15)
1058
#define PIO_PPDER_P16 (0x1u << 16)
1059
#define PIO_PPDER_P17 (0x1u << 17)
1060
#define PIO_PPDER_P18 (0x1u << 18)
1061
#define PIO_PPDER_P19 (0x1u << 19)
1062
#define PIO_PPDER_P20 (0x1u << 20)
1063
#define PIO_PPDER_P21 (0x1u << 21)
1064
#define PIO_PPDER_P22 (0x1u << 22)
1065
#define PIO_PPDER_P23 (0x1u << 23)
1066
#define PIO_PPDER_P24 (0x1u << 24)
1067
#define PIO_PPDER_P25 (0x1u << 25)
1068
#define PIO_PPDER_P26 (0x1u << 26)
1069
#define PIO_PPDER_P27 (0x1u << 27)
1070
#define PIO_PPDER_P28 (0x1u << 28)
1071
#define PIO_PPDER_P29 (0x1u << 29)
1072
#define PIO_PPDER_P30 (0x1u << 30)
1073
#define PIO_PPDER_P31 (0x1u << 31)
1074
/* -------- PIO_PPDSR : (PIO Offset: 0x0098) Pad Pull-down Status Register -------- */
1075
#define PIO_PPDSR_P0 (0x1u << 0)
1076
#define PIO_PPDSR_P1 (0x1u << 1)
1077
#define PIO_PPDSR_P2 (0x1u << 2)
1078
#define PIO_PPDSR_P3 (0x1u << 3)
1079
#define PIO_PPDSR_P4 (0x1u << 4)
1080
#define PIO_PPDSR_P5 (0x1u << 5)
1081
#define PIO_PPDSR_P6 (0x1u << 6)
1082
#define PIO_PPDSR_P7 (0x1u << 7)
1083
#define PIO_PPDSR_P8 (0x1u << 8)
1084
#define PIO_PPDSR_P9 (0x1u << 9)
1085
#define PIO_PPDSR_P10 (0x1u << 10)
1086
#define PIO_PPDSR_P11 (0x1u << 11)
1087
#define PIO_PPDSR_P12 (0x1u << 12)
1088
#define PIO_PPDSR_P13 (0x1u << 13)
1089
#define PIO_PPDSR_P14 (0x1u << 14)
1090
#define PIO_PPDSR_P15 (0x1u << 15)
1091
#define PIO_PPDSR_P16 (0x1u << 16)
1092
#define PIO_PPDSR_P17 (0x1u << 17)
1093
#define PIO_PPDSR_P18 (0x1u << 18)
1094
#define PIO_PPDSR_P19 (0x1u << 19)
1095
#define PIO_PPDSR_P20 (0x1u << 20)
1096
#define PIO_PPDSR_P21 (0x1u << 21)
1097
#define PIO_PPDSR_P22 (0x1u << 22)
1098
#define PIO_PPDSR_P23 (0x1u << 23)
1099
#define PIO_PPDSR_P24 (0x1u << 24)
1100
#define PIO_PPDSR_P25 (0x1u << 25)
1101
#define PIO_PPDSR_P26 (0x1u << 26)
1102
#define PIO_PPDSR_P27 (0x1u << 27)
1103
#define PIO_PPDSR_P28 (0x1u << 28)
1104
#define PIO_PPDSR_P29 (0x1u << 29)
1105
#define PIO_PPDSR_P30 (0x1u << 30)
1106
#define PIO_PPDSR_P31 (0x1u << 31)
1107
/* -------- PIO_OWER : (PIO Offset: 0x00A0) Output Write Enable -------- */
1108
#define PIO_OWER_P0 (0x1u << 0)
1109
#define PIO_OWER_P1 (0x1u << 1)
1110
#define PIO_OWER_P2 (0x1u << 2)
1111
#define PIO_OWER_P3 (0x1u << 3)
1112
#define PIO_OWER_P4 (0x1u << 4)
1113
#define PIO_OWER_P5 (0x1u << 5)
1114
#define PIO_OWER_P6 (0x1u << 6)
1115
#define PIO_OWER_P7 (0x1u << 7)
1116
#define PIO_OWER_P8 (0x1u << 8)
1117
#define PIO_OWER_P9 (0x1u << 9)
1118
#define PIO_OWER_P10 (0x1u << 10)
1119
#define PIO_OWER_P11 (0x1u << 11)
1120
#define PIO_OWER_P12 (0x1u << 12)
1121
#define PIO_OWER_P13 (0x1u << 13)
1122
#define PIO_OWER_P14 (0x1u << 14)
1123
#define PIO_OWER_P15 (0x1u << 15)
1124
#define PIO_OWER_P16 (0x1u << 16)
1125
#define PIO_OWER_P17 (0x1u << 17)
1126
#define PIO_OWER_P18 (0x1u << 18)
1127
#define PIO_OWER_P19 (0x1u << 19)
1128
#define PIO_OWER_P20 (0x1u << 20)
1129
#define PIO_OWER_P21 (0x1u << 21)
1130
#define PIO_OWER_P22 (0x1u << 22)
1131
#define PIO_OWER_P23 (0x1u << 23)
1132
#define PIO_OWER_P24 (0x1u << 24)
1133
#define PIO_OWER_P25 (0x1u << 25)
1134
#define PIO_OWER_P26 (0x1u << 26)
1135
#define PIO_OWER_P27 (0x1u << 27)
1136
#define PIO_OWER_P28 (0x1u << 28)
1137
#define PIO_OWER_P29 (0x1u << 29)
1138
#define PIO_OWER_P30 (0x1u << 30)
1139
#define PIO_OWER_P31 (0x1u << 31)
1140
/* -------- PIO_OWDR : (PIO Offset: 0x00A4) Output Write Disable -------- */
1141
#define PIO_OWDR_P0 (0x1u << 0)
1142
#define PIO_OWDR_P1 (0x1u << 1)
1143
#define PIO_OWDR_P2 (0x1u << 2)
1144
#define PIO_OWDR_P3 (0x1u << 3)
1145
#define PIO_OWDR_P4 (0x1u << 4)
1146
#define PIO_OWDR_P5 (0x1u << 5)
1147
#define PIO_OWDR_P6 (0x1u << 6)
1148
#define PIO_OWDR_P7 (0x1u << 7)
1149
#define PIO_OWDR_P8 (0x1u << 8)
1150
#define PIO_OWDR_P9 (0x1u << 9)
1151
#define PIO_OWDR_P10 (0x1u << 10)
1152
#define PIO_OWDR_P11 (0x1u << 11)
1153
#define PIO_OWDR_P12 (0x1u << 12)
1154
#define PIO_OWDR_P13 (0x1u << 13)
1155
#define PIO_OWDR_P14 (0x1u << 14)
1156
#define PIO_OWDR_P15 (0x1u << 15)
1157
#define PIO_OWDR_P16 (0x1u << 16)
1158
#define PIO_OWDR_P17 (0x1u << 17)
1159
#define PIO_OWDR_P18 (0x1u << 18)
1160
#define PIO_OWDR_P19 (0x1u << 19)
1161
#define PIO_OWDR_P20 (0x1u << 20)
1162
#define PIO_OWDR_P21 (0x1u << 21)
1163
#define PIO_OWDR_P22 (0x1u << 22)
1164
#define PIO_OWDR_P23 (0x1u << 23)
1165
#define PIO_OWDR_P24 (0x1u << 24)
1166
#define PIO_OWDR_P25 (0x1u << 25)
1167
#define PIO_OWDR_P26 (0x1u << 26)
1168
#define PIO_OWDR_P27 (0x1u << 27)
1169
#define PIO_OWDR_P28 (0x1u << 28)
1170
#define PIO_OWDR_P29 (0x1u << 29)
1171
#define PIO_OWDR_P30 (0x1u << 30)
1172
#define PIO_OWDR_P31 (0x1u << 31)
1173
/* -------- PIO_OWSR : (PIO Offset: 0x00A8) Output Write Status Register -------- */
1174
#define PIO_OWSR_P0 (0x1u << 0)
1175
#define PIO_OWSR_P1 (0x1u << 1)
1176
#define PIO_OWSR_P2 (0x1u << 2)
1177
#define PIO_OWSR_P3 (0x1u << 3)
1178
#define PIO_OWSR_P4 (0x1u << 4)
1179
#define PIO_OWSR_P5 (0x1u << 5)
1180
#define PIO_OWSR_P6 (0x1u << 6)
1181
#define PIO_OWSR_P7 (0x1u << 7)
1182
#define PIO_OWSR_P8 (0x1u << 8)
1183
#define PIO_OWSR_P9 (0x1u << 9)
1184
#define PIO_OWSR_P10 (0x1u << 10)
1185
#define PIO_OWSR_P11 (0x1u << 11)
1186
#define PIO_OWSR_P12 (0x1u << 12)
1187
#define PIO_OWSR_P13 (0x1u << 13)
1188
#define PIO_OWSR_P14 (0x1u << 14)
1189
#define PIO_OWSR_P15 (0x1u << 15)
1190
#define PIO_OWSR_P16 (0x1u << 16)
1191
#define PIO_OWSR_P17 (0x1u << 17)
1192
#define PIO_OWSR_P18 (0x1u << 18)
1193
#define PIO_OWSR_P19 (0x1u << 19)
1194
#define PIO_OWSR_P20 (0x1u << 20)
1195
#define PIO_OWSR_P21 (0x1u << 21)
1196
#define PIO_OWSR_P22 (0x1u << 22)
1197
#define PIO_OWSR_P23 (0x1u << 23)
1198
#define PIO_OWSR_P24 (0x1u << 24)
1199
#define PIO_OWSR_P25 (0x1u << 25)
1200
#define PIO_OWSR_P26 (0x1u << 26)
1201
#define PIO_OWSR_P27 (0x1u << 27)
1202
#define PIO_OWSR_P28 (0x1u << 28)
1203
#define PIO_OWSR_P29 (0x1u << 29)
1204
#define PIO_OWSR_P30 (0x1u << 30)
1205
#define PIO_OWSR_P31 (0x1u << 31)
1206
/* -------- PIO_AIMER : (PIO Offset: 0x00B0) Additional Interrupt Modes Enable Register -------- */
1207
#define PIO_AIMER_P0 (0x1u << 0)
1208
#define PIO_AIMER_P1 (0x1u << 1)
1209
#define PIO_AIMER_P2 (0x1u << 2)
1210
#define PIO_AIMER_P3 (0x1u << 3)
1211
#define PIO_AIMER_P4 (0x1u << 4)
1212
#define PIO_AIMER_P5 (0x1u << 5)
1213
#define PIO_AIMER_P6 (0x1u << 6)
1214
#define PIO_AIMER_P7 (0x1u << 7)
1215
#define PIO_AIMER_P8 (0x1u << 8)
1216
#define PIO_AIMER_P9 (0x1u << 9)
1217
#define PIO_AIMER_P10 (0x1u << 10)
1218
#define PIO_AIMER_P11 (0x1u << 11)
1219
#define PIO_AIMER_P12 (0x1u << 12)
1220
#define PIO_AIMER_P13 (0x1u << 13)
1221
#define PIO_AIMER_P14 (0x1u << 14)
1222
#define PIO_AIMER_P15 (0x1u << 15)
1223
#define PIO_AIMER_P16 (0x1u << 16)
1224
#define PIO_AIMER_P17 (0x1u << 17)
1225
#define PIO_AIMER_P18 (0x1u << 18)
1226
#define PIO_AIMER_P19 (0x1u << 19)
1227
#define PIO_AIMER_P20 (0x1u << 20)
1228
#define PIO_AIMER_P21 (0x1u << 21)
1229
#define PIO_AIMER_P22 (0x1u << 22)
1230
#define PIO_AIMER_P23 (0x1u << 23)
1231
#define PIO_AIMER_P24 (0x1u << 24)
1232
#define PIO_AIMER_P25 (0x1u << 25)
1233
#define PIO_AIMER_P26 (0x1u << 26)
1234
#define PIO_AIMER_P27 (0x1u << 27)
1235
#define PIO_AIMER_P28 (0x1u << 28)
1236
#define PIO_AIMER_P29 (0x1u << 29)
1237
#define PIO_AIMER_P30 (0x1u << 30)
1238
#define PIO_AIMER_P31 (0x1u << 31)
1239
/* -------- PIO_AIMDR : (PIO Offset: 0x00B4) Additional Interrupt Modes Disable Register -------- */
1240
#define PIO_AIMDR_P0 (0x1u << 0)
1241
#define PIO_AIMDR_P1 (0x1u << 1)
1242
#define PIO_AIMDR_P2 (0x1u << 2)
1243
#define PIO_AIMDR_P3 (0x1u << 3)
1244
#define PIO_AIMDR_P4 (0x1u << 4)
1245
#define PIO_AIMDR_P5 (0x1u << 5)
1246
#define PIO_AIMDR_P6 (0x1u << 6)
1247
#define PIO_AIMDR_P7 (0x1u << 7)
1248
#define PIO_AIMDR_P8 (0x1u << 8)
1249
#define PIO_AIMDR_P9 (0x1u << 9)
1250
#define PIO_AIMDR_P10 (0x1u << 10)
1251
#define PIO_AIMDR_P11 (0x1u << 11)
1252
#define PIO_AIMDR_P12 (0x1u << 12)
1253
#define PIO_AIMDR_P13 (0x1u << 13)
1254
#define PIO_AIMDR_P14 (0x1u << 14)
1255
#define PIO_AIMDR_P15 (0x1u << 15)
1256
#define PIO_AIMDR_P16 (0x1u << 16)
1257
#define PIO_AIMDR_P17 (0x1u << 17)
1258
#define PIO_AIMDR_P18 (0x1u << 18)
1259
#define PIO_AIMDR_P19 (0x1u << 19)
1260
#define PIO_AIMDR_P20 (0x1u << 20)
1261
#define PIO_AIMDR_P21 (0x1u << 21)
1262
#define PIO_AIMDR_P22 (0x1u << 22)
1263
#define PIO_AIMDR_P23 (0x1u << 23)
1264
#define PIO_AIMDR_P24 (0x1u << 24)
1265
#define PIO_AIMDR_P25 (0x1u << 25)
1266
#define PIO_AIMDR_P26 (0x1u << 26)
1267
#define PIO_AIMDR_P27 (0x1u << 27)
1268
#define PIO_AIMDR_P28 (0x1u << 28)
1269
#define PIO_AIMDR_P29 (0x1u << 29)
1270
#define PIO_AIMDR_P30 (0x1u << 30)
1271
#define PIO_AIMDR_P31 (0x1u << 31)
1272
/* -------- PIO_AIMMR : (PIO Offset: 0x00B8) Additional Interrupt Modes Mask Register -------- */
1273
#define PIO_AIMMR_P0 (0x1u << 0)
1274
#define PIO_AIMMR_P1 (0x1u << 1)
1275
#define PIO_AIMMR_P2 (0x1u << 2)
1276
#define PIO_AIMMR_P3 (0x1u << 3)
1277
#define PIO_AIMMR_P4 (0x1u << 4)
1278
#define PIO_AIMMR_P5 (0x1u << 5)
1279
#define PIO_AIMMR_P6 (0x1u << 6)
1280
#define PIO_AIMMR_P7 (0x1u << 7)
1281
#define PIO_AIMMR_P8 (0x1u << 8)
1282
#define PIO_AIMMR_P9 (0x1u << 9)
1283
#define PIO_AIMMR_P10 (0x1u << 10)
1284
#define PIO_AIMMR_P11 (0x1u << 11)
1285
#define PIO_AIMMR_P12 (0x1u << 12)
1286
#define PIO_AIMMR_P13 (0x1u << 13)
1287
#define PIO_AIMMR_P14 (0x1u << 14)
1288
#define PIO_AIMMR_P15 (0x1u << 15)
1289
#define PIO_AIMMR_P16 (0x1u << 16)
1290
#define PIO_AIMMR_P17 (0x1u << 17)
1291
#define PIO_AIMMR_P18 (0x1u << 18)
1292
#define PIO_AIMMR_P19 (0x1u << 19)
1293
#define PIO_AIMMR_P20 (0x1u << 20)
1294
#define PIO_AIMMR_P21 (0x1u << 21)
1295
#define PIO_AIMMR_P22 (0x1u << 22)
1296
#define PIO_AIMMR_P23 (0x1u << 23)
1297
#define PIO_AIMMR_P24 (0x1u << 24)
1298
#define PIO_AIMMR_P25 (0x1u << 25)
1299
#define PIO_AIMMR_P26 (0x1u << 26)
1300
#define PIO_AIMMR_P27 (0x1u << 27)
1301
#define PIO_AIMMR_P28 (0x1u << 28)
1302
#define PIO_AIMMR_P29 (0x1u << 29)
1303
#define PIO_AIMMR_P30 (0x1u << 30)
1304
#define PIO_AIMMR_P31 (0x1u << 31)
1305
/* -------- PIO_ESR : (PIO Offset: 0x00C0) Edge Select Register -------- */
1306
#define PIO_ESR_P0 (0x1u << 0)
1307
#define PIO_ESR_P1 (0x1u << 1)
1308
#define PIO_ESR_P2 (0x1u << 2)
1309
#define PIO_ESR_P3 (0x1u << 3)
1310
#define PIO_ESR_P4 (0x1u << 4)
1311
#define PIO_ESR_P5 (0x1u << 5)
1312
#define PIO_ESR_P6 (0x1u << 6)
1313
#define PIO_ESR_P7 (0x1u << 7)
1314
#define PIO_ESR_P8 (0x1u << 8)
1315
#define PIO_ESR_P9 (0x1u << 9)
1316
#define PIO_ESR_P10 (0x1u << 10)
1317
#define PIO_ESR_P11 (0x1u << 11)
1318
#define PIO_ESR_P12 (0x1u << 12)
1319
#define PIO_ESR_P13 (0x1u << 13)
1320
#define PIO_ESR_P14 (0x1u << 14)
1321
#define PIO_ESR_P15 (0x1u << 15)
1322
#define PIO_ESR_P16 (0x1u << 16)
1323
#define PIO_ESR_P17 (0x1u << 17)
1324
#define PIO_ESR_P18 (0x1u << 18)
1325
#define PIO_ESR_P19 (0x1u << 19)
1326
#define PIO_ESR_P20 (0x1u << 20)
1327
#define PIO_ESR_P21 (0x1u << 21)
1328
#define PIO_ESR_P22 (0x1u << 22)
1329
#define PIO_ESR_P23 (0x1u << 23)
1330
#define PIO_ESR_P24 (0x1u << 24)
1331
#define PIO_ESR_P25 (0x1u << 25)
1332
#define PIO_ESR_P26 (0x1u << 26)
1333
#define PIO_ESR_P27 (0x1u << 27)
1334
#define PIO_ESR_P28 (0x1u << 28)
1335
#define PIO_ESR_P29 (0x1u << 29)
1336
#define PIO_ESR_P30 (0x1u << 30)
1337
#define PIO_ESR_P31 (0x1u << 31)
1338
/* -------- PIO_LSR : (PIO Offset: 0x00C4) Level Select Register -------- */
1339
#define PIO_LSR_P0 (0x1u << 0)
1340
#define PIO_LSR_P1 (0x1u << 1)
1341
#define PIO_LSR_P2 (0x1u << 2)
1342
#define PIO_LSR_P3 (0x1u << 3)
1343
#define PIO_LSR_P4 (0x1u << 4)
1344
#define PIO_LSR_P5 (0x1u << 5)
1345
#define PIO_LSR_P6 (0x1u << 6)
1346
#define PIO_LSR_P7 (0x1u << 7)
1347
#define PIO_LSR_P8 (0x1u << 8)
1348
#define PIO_LSR_P9 (0x1u << 9)
1349
#define PIO_LSR_P10 (0x1u << 10)
1350
#define PIO_LSR_P11 (0x1u << 11)
1351
#define PIO_LSR_P12 (0x1u << 12)
1352
#define PIO_LSR_P13 (0x1u << 13)
1353
#define PIO_LSR_P14 (0x1u << 14)
1354
#define PIO_LSR_P15 (0x1u << 15)
1355
#define PIO_LSR_P16 (0x1u << 16)
1356
#define PIO_LSR_P17 (0x1u << 17)
1357
#define PIO_LSR_P18 (0x1u << 18)
1358
#define PIO_LSR_P19 (0x1u << 19)
1359
#define PIO_LSR_P20 (0x1u << 20)
1360
#define PIO_LSR_P21 (0x1u << 21)
1361
#define PIO_LSR_P22 (0x1u << 22)
1362
#define PIO_LSR_P23 (0x1u << 23)
1363
#define PIO_LSR_P24 (0x1u << 24)
1364
#define PIO_LSR_P25 (0x1u << 25)
1365
#define PIO_LSR_P26 (0x1u << 26)
1366
#define PIO_LSR_P27 (0x1u << 27)
1367
#define PIO_LSR_P28 (0x1u << 28)
1368
#define PIO_LSR_P29 (0x1u << 29)
1369
#define PIO_LSR_P30 (0x1u << 30)
1370
#define PIO_LSR_P31 (0x1u << 31)
1371
/* -------- PIO_ELSR : (PIO Offset: 0x00C8) Edge/Level Status Register -------- */
1372
#define PIO_ELSR_P0 (0x1u << 0)
1373
#define PIO_ELSR_P1 (0x1u << 1)
1374
#define PIO_ELSR_P2 (0x1u << 2)
1375
#define PIO_ELSR_P3 (0x1u << 3)
1376
#define PIO_ELSR_P4 (0x1u << 4)
1377
#define PIO_ELSR_P5 (0x1u << 5)
1378
#define PIO_ELSR_P6 (0x1u << 6)
1379
#define PIO_ELSR_P7 (0x1u << 7)
1380
#define PIO_ELSR_P8 (0x1u << 8)
1381
#define PIO_ELSR_P9 (0x1u << 9)
1382
#define PIO_ELSR_P10 (0x1u << 10)
1383
#define PIO_ELSR_P11 (0x1u << 11)
1384
#define PIO_ELSR_P12 (0x1u << 12)
1385
#define PIO_ELSR_P13 (0x1u << 13)
1386
#define PIO_ELSR_P14 (0x1u << 14)
1387
#define PIO_ELSR_P15 (0x1u << 15)
1388
#define PIO_ELSR_P16 (0x1u << 16)
1389
#define PIO_ELSR_P17 (0x1u << 17)
1390
#define PIO_ELSR_P18 (0x1u << 18)
1391
#define PIO_ELSR_P19 (0x1u << 19)
1392
#define PIO_ELSR_P20 (0x1u << 20)
1393
#define PIO_ELSR_P21 (0x1u << 21)
1394
#define PIO_ELSR_P22 (0x1u << 22)
1395
#define PIO_ELSR_P23 (0x1u << 23)
1396
#define PIO_ELSR_P24 (0x1u << 24)
1397
#define PIO_ELSR_P25 (0x1u << 25)
1398
#define PIO_ELSR_P26 (0x1u << 26)
1399
#define PIO_ELSR_P27 (0x1u << 27)
1400
#define PIO_ELSR_P28 (0x1u << 28)
1401
#define PIO_ELSR_P29 (0x1u << 29)
1402
#define PIO_ELSR_P30 (0x1u << 30)
1403
#define PIO_ELSR_P31 (0x1u << 31)
1404
/* -------- PIO_FELLSR : (PIO Offset: 0x00D0) Falling Edge/Low-Level Select Register -------- */
1405
#define PIO_FELLSR_P0 (0x1u << 0)
1406
#define PIO_FELLSR_P1 (0x1u << 1)
1407
#define PIO_FELLSR_P2 (0x1u << 2)
1408
#define PIO_FELLSR_P3 (0x1u << 3)
1409
#define PIO_FELLSR_P4 (0x1u << 4)
1410
#define PIO_FELLSR_P5 (0x1u << 5)
1411
#define PIO_FELLSR_P6 (0x1u << 6)
1412
#define PIO_FELLSR_P7 (0x1u << 7)
1413
#define PIO_FELLSR_P8 (0x1u << 8)
1414
#define PIO_FELLSR_P9 (0x1u << 9)
1415
#define PIO_FELLSR_P10 (0x1u << 10)
1416
#define PIO_FELLSR_P11 (0x1u << 11)
1417
#define PIO_FELLSR_P12 (0x1u << 12)
1418
#define PIO_FELLSR_P13 (0x1u << 13)
1419
#define PIO_FELLSR_P14 (0x1u << 14)
1420
#define PIO_FELLSR_P15 (0x1u << 15)
1421
#define PIO_FELLSR_P16 (0x1u << 16)
1422
#define PIO_FELLSR_P17 (0x1u << 17)
1423
#define PIO_FELLSR_P18 (0x1u << 18)
1424
#define PIO_FELLSR_P19 (0x1u << 19)
1425
#define PIO_FELLSR_P20 (0x1u << 20)
1426
#define PIO_FELLSR_P21 (0x1u << 21)
1427
#define PIO_FELLSR_P22 (0x1u << 22)
1428
#define PIO_FELLSR_P23 (0x1u << 23)
1429
#define PIO_FELLSR_P24 (0x1u << 24)
1430
#define PIO_FELLSR_P25 (0x1u << 25)
1431
#define PIO_FELLSR_P26 (0x1u << 26)
1432
#define PIO_FELLSR_P27 (0x1u << 27)
1433
#define PIO_FELLSR_P28 (0x1u << 28)
1434
#define PIO_FELLSR_P29 (0x1u << 29)
1435
#define PIO_FELLSR_P30 (0x1u << 30)
1436
#define PIO_FELLSR_P31 (0x1u << 31)
1437
/* -------- PIO_REHLSR : (PIO Offset: 0x00D4) Rising Edge/High-Level Select Register -------- */
1438
#define PIO_REHLSR_P0 (0x1u << 0)
1439
#define PIO_REHLSR_P1 (0x1u << 1)
1440
#define PIO_REHLSR_P2 (0x1u << 2)
1441
#define PIO_REHLSR_P3 (0x1u << 3)
1442
#define PIO_REHLSR_P4 (0x1u << 4)
1443
#define PIO_REHLSR_P5 (0x1u << 5)
1444
#define PIO_REHLSR_P6 (0x1u << 6)
1445
#define PIO_REHLSR_P7 (0x1u << 7)
1446
#define PIO_REHLSR_P8 (0x1u << 8)
1447
#define PIO_REHLSR_P9 (0x1u << 9)
1448
#define PIO_REHLSR_P10 (0x1u << 10)
1449
#define PIO_REHLSR_P11 (0x1u << 11)
1450
#define PIO_REHLSR_P12 (0x1u << 12)
1451
#define PIO_REHLSR_P13 (0x1u << 13)
1452
#define PIO_REHLSR_P14 (0x1u << 14)
1453
#define PIO_REHLSR_P15 (0x1u << 15)
1454
#define PIO_REHLSR_P16 (0x1u << 16)
1455
#define PIO_REHLSR_P17 (0x1u << 17)
1456
#define PIO_REHLSR_P18 (0x1u << 18)
1457
#define PIO_REHLSR_P19 (0x1u << 19)
1458
#define PIO_REHLSR_P20 (0x1u << 20)
1459
#define PIO_REHLSR_P21 (0x1u << 21)
1460
#define PIO_REHLSR_P22 (0x1u << 22)
1461
#define PIO_REHLSR_P23 (0x1u << 23)
1462
#define PIO_REHLSR_P24 (0x1u << 24)
1463
#define PIO_REHLSR_P25 (0x1u << 25)
1464
#define PIO_REHLSR_P26 (0x1u << 26)
1465
#define PIO_REHLSR_P27 (0x1u << 27)
1466
#define PIO_REHLSR_P28 (0x1u << 28)
1467
#define PIO_REHLSR_P29 (0x1u << 29)
1468
#define PIO_REHLSR_P30 (0x1u << 30)
1469
#define PIO_REHLSR_P31 (0x1u << 31)
1470
/* -------- PIO_FRLHSR : (PIO Offset: 0x00D8) Fall/Rise - Low/High Status Register -------- */
1471
#define PIO_FRLHSR_P0 (0x1u << 0)
1472
#define PIO_FRLHSR_P1 (0x1u << 1)
1473
#define PIO_FRLHSR_P2 (0x1u << 2)
1474
#define PIO_FRLHSR_P3 (0x1u << 3)
1475
#define PIO_FRLHSR_P4 (0x1u << 4)
1476
#define PIO_FRLHSR_P5 (0x1u << 5)
1477
#define PIO_FRLHSR_P6 (0x1u << 6)
1478
#define PIO_FRLHSR_P7 (0x1u << 7)
1479
#define PIO_FRLHSR_P8 (0x1u << 8)
1480
#define PIO_FRLHSR_P9 (0x1u << 9)
1481
#define PIO_FRLHSR_P10 (0x1u << 10)
1482
#define PIO_FRLHSR_P11 (0x1u << 11)
1483
#define PIO_FRLHSR_P12 (0x1u << 12)
1484
#define PIO_FRLHSR_P13 (0x1u << 13)
1485
#define PIO_FRLHSR_P14 (0x1u << 14)
1486
#define PIO_FRLHSR_P15 (0x1u << 15)
1487
#define PIO_FRLHSR_P16 (0x1u << 16)
1488
#define PIO_FRLHSR_P17 (0x1u << 17)
1489
#define PIO_FRLHSR_P18 (0x1u << 18)
1490
#define PIO_FRLHSR_P19 (0x1u << 19)
1491
#define PIO_FRLHSR_P20 (0x1u << 20)
1492
#define PIO_FRLHSR_P21 (0x1u << 21)
1493
#define PIO_FRLHSR_P22 (0x1u << 22)
1494
#define PIO_FRLHSR_P23 (0x1u << 23)
1495
#define PIO_FRLHSR_P24 (0x1u << 24)
1496
#define PIO_FRLHSR_P25 (0x1u << 25)
1497
#define PIO_FRLHSR_P26 (0x1u << 26)
1498
#define PIO_FRLHSR_P27 (0x1u << 27)
1499
#define PIO_FRLHSR_P28 (0x1u << 28)
1500
#define PIO_FRLHSR_P29 (0x1u << 29)
1501
#define PIO_FRLHSR_P30 (0x1u << 30)
1502
#define PIO_FRLHSR_P31 (0x1u << 31)
1503
/* -------- PIO_LOCKSR : (PIO Offset: 0x00E0) Lock Status -------- */
1504
#define PIO_LOCKSR_P0 (0x1u << 0)
1505
#define PIO_LOCKSR_P1 (0x1u << 1)
1506
#define PIO_LOCKSR_P2 (0x1u << 2)
1507
#define PIO_LOCKSR_P3 (0x1u << 3)
1508
#define PIO_LOCKSR_P4 (0x1u << 4)
1509
#define PIO_LOCKSR_P5 (0x1u << 5)
1510
#define PIO_LOCKSR_P6 (0x1u << 6)
1511
#define PIO_LOCKSR_P7 (0x1u << 7)
1512
#define PIO_LOCKSR_P8 (0x1u << 8)
1513
#define PIO_LOCKSR_P9 (0x1u << 9)
1514
#define PIO_LOCKSR_P10 (0x1u << 10)
1515
#define PIO_LOCKSR_P11 (0x1u << 11)
1516
#define PIO_LOCKSR_P12 (0x1u << 12)
1517
#define PIO_LOCKSR_P13 (0x1u << 13)
1518
#define PIO_LOCKSR_P14 (0x1u << 14)
1519
#define PIO_LOCKSR_P15 (0x1u << 15)
1520
#define PIO_LOCKSR_P16 (0x1u << 16)
1521
#define PIO_LOCKSR_P17 (0x1u << 17)
1522
#define PIO_LOCKSR_P18 (0x1u << 18)
1523
#define PIO_LOCKSR_P19 (0x1u << 19)
1524
#define PIO_LOCKSR_P20 (0x1u << 20)
1525
#define PIO_LOCKSR_P21 (0x1u << 21)
1526
#define PIO_LOCKSR_P22 (0x1u << 22)
1527
#define PIO_LOCKSR_P23 (0x1u << 23)
1528
#define PIO_LOCKSR_P24 (0x1u << 24)
1529
#define PIO_LOCKSR_P25 (0x1u << 25)
1530
#define PIO_LOCKSR_P26 (0x1u << 26)
1531
#define PIO_LOCKSR_P27 (0x1u << 27)
1532
#define PIO_LOCKSR_P28 (0x1u << 28)
1533
#define PIO_LOCKSR_P29 (0x1u << 29)
1534
#define PIO_LOCKSR_P30 (0x1u << 30)
1535
#define PIO_LOCKSR_P31 (0x1u << 31)
1536
/* -------- PIO_WPMR : (PIO Offset: 0x00E4) Write Protection Mode Register -------- */
1537
#define PIO_WPMR_WPEN (0x1u << 0)
1538
#define PIO_WPMR_WPKEY_Pos 8
1539
#define PIO_WPMR_WPKEY_Msk (0xffffffu << PIO_WPMR_WPKEY_Pos)
1540
#define PIO_WPMR_WPKEY(value) ((PIO_WPMR_WPKEY_Msk & ((value) << PIO_WPMR_WPKEY_Pos)))
1541
#define PIO_WPMR_WPKEY_PASSWD (0x50494Fu << 8)
1542
/* -------- PIO_WPSR : (PIO Offset: 0x00E8) Write Protection Status Register -------- */
1543
#define PIO_WPSR_WPVS (0x1u << 0)
1544
#define PIO_WPSR_WPVSRC_Pos 8
1545
#define PIO_WPSR_WPVSRC_Msk (0xffffu << PIO_WPSR_WPVSRC_Pos)
1546
/* -------- PIO_VERSION : (PIO Offset: 0x00FC) Version Register -------- */
1547
#define PIO_VERSION_VERSION_Pos 0
1548
#define PIO_VERSION_VERSION_Msk (0xfffu << PIO_VERSION_VERSION_Pos)
1549
#define PIO_VERSION_MFN_Pos 16
1550
#define PIO_VERSION_MFN_Msk (0x7u << PIO_VERSION_MFN_Pos)
1551
/* -------- PIO_SCHMITT : (PIO Offset: 0x0100) Schmitt Trigger Register -------- */
1552
#define PIO_SCHMITT_SCHMITT0 (0x1u << 0)
1553
#define PIO_SCHMITT_SCHMITT1 (0x1u << 1)
1554
#define PIO_SCHMITT_SCHMITT2 (0x1u << 2)
1555
#define PIO_SCHMITT_SCHMITT3 (0x1u << 3)
1556
#define PIO_SCHMITT_SCHMITT4 (0x1u << 4)
1557
#define PIO_SCHMITT_SCHMITT5 (0x1u << 5)
1558
#define PIO_SCHMITT_SCHMITT6 (0x1u << 6)
1559
#define PIO_SCHMITT_SCHMITT7 (0x1u << 7)
1560
#define PIO_SCHMITT_SCHMITT8 (0x1u << 8)
1561
#define PIO_SCHMITT_SCHMITT9 (0x1u << 9)
1562
#define PIO_SCHMITT_SCHMITT10 (0x1u << 10)
1563
#define PIO_SCHMITT_SCHMITT11 (0x1u << 11)
1564
#define PIO_SCHMITT_SCHMITT12 (0x1u << 12)
1565
#define PIO_SCHMITT_SCHMITT13 (0x1u << 13)
1566
#define PIO_SCHMITT_SCHMITT14 (0x1u << 14)
1567
#define PIO_SCHMITT_SCHMITT15 (0x1u << 15)
1568
#define PIO_SCHMITT_SCHMITT16 (0x1u << 16)
1569
#define PIO_SCHMITT_SCHMITT17 (0x1u << 17)
1570
#define PIO_SCHMITT_SCHMITT18 (0x1u << 18)
1571
#define PIO_SCHMITT_SCHMITT19 (0x1u << 19)
1572
#define PIO_SCHMITT_SCHMITT20 (0x1u << 20)
1573
#define PIO_SCHMITT_SCHMITT21 (0x1u << 21)
1574
#define PIO_SCHMITT_SCHMITT22 (0x1u << 22)
1575
#define PIO_SCHMITT_SCHMITT23 (0x1u << 23)
1576
#define PIO_SCHMITT_SCHMITT24 (0x1u << 24)
1577
#define PIO_SCHMITT_SCHMITT25 (0x1u << 25)
1578
#define PIO_SCHMITT_SCHMITT26 (0x1u << 26)
1579
#define PIO_SCHMITT_SCHMITT27 (0x1u << 27)
1580
#define PIO_SCHMITT_SCHMITT28 (0x1u << 28)
1581
#define PIO_SCHMITT_SCHMITT29 (0x1u << 29)
1582
#define PIO_SCHMITT_SCHMITT30 (0x1u << 30)
1583
#define PIO_SCHMITT_SCHMITT31 (0x1u << 31)
1584
/* -------- PIO_DRIVER : (PIO Offset: 0x0118) I/O Drive Register -------- */
1585
#define PIO_DRIVER_LINE0 (0x1u << 0)
1586
#define PIO_DRIVER_LINE0_LOW_DRIVE (0x0u << 0)
1587
#define PIO_DRIVER_LINE0_HIGH_DRIVE (0x1u << 0)
1588
#define PIO_DRIVER_LINE1 (0x1u << 1)
1589
#define PIO_DRIVER_LINE1_LOW_DRIVE (0x0u << 1)
1590
#define PIO_DRIVER_LINE1_HIGH_DRIVE (0x1u << 1)
1591
#define PIO_DRIVER_LINE2 (0x1u << 2)
1592
#define PIO_DRIVER_LINE2_LOW_DRIVE (0x0u << 2)
1593
#define PIO_DRIVER_LINE2_HIGH_DRIVE (0x1u << 2)
1594
#define PIO_DRIVER_LINE3 (0x1u << 3)
1595
#define PIO_DRIVER_LINE3_LOW_DRIVE (0x0u << 3)
1596
#define PIO_DRIVER_LINE3_HIGH_DRIVE (0x1u << 3)
1597
#define PIO_DRIVER_LINE4 (0x1u << 4)
1598
#define PIO_DRIVER_LINE4_LOW_DRIVE (0x0u << 4)
1599
#define PIO_DRIVER_LINE4_HIGH_DRIVE (0x1u << 4)
1600
#define PIO_DRIVER_LINE5 (0x1u << 5)
1601
#define PIO_DRIVER_LINE5_LOW_DRIVE (0x0u << 5)
1602
#define PIO_DRIVER_LINE5_HIGH_DRIVE (0x1u << 5)
1603
#define PIO_DRIVER_LINE6 (0x1u << 6)
1604
#define PIO_DRIVER_LINE6_LOW_DRIVE (0x0u << 6)
1605
#define PIO_DRIVER_LINE6_HIGH_DRIVE (0x1u << 6)
1606
#define PIO_DRIVER_LINE7 (0x1u << 7)
1607
#define PIO_DRIVER_LINE7_LOW_DRIVE (0x0u << 7)
1608
#define PIO_DRIVER_LINE7_HIGH_DRIVE (0x1u << 7)
1609
#define PIO_DRIVER_LINE8 (0x1u << 8)
1610
#define PIO_DRIVER_LINE8_LOW_DRIVE (0x0u << 8)
1611
#define PIO_DRIVER_LINE8_HIGH_DRIVE (0x1u << 8)
1612
#define PIO_DRIVER_LINE9 (0x1u << 9)
1613
#define PIO_DRIVER_LINE9_LOW_DRIVE (0x0u << 9)
1614
#define PIO_DRIVER_LINE9_HIGH_DRIVE (0x1u << 9)
1615
#define PIO_DRIVER_LINE10 (0x1u << 10)
1616
#define PIO_DRIVER_LINE10_LOW_DRIVE (0x0u << 10)
1617
#define PIO_DRIVER_LINE10_HIGH_DRIVE (0x1u << 10)
1618
#define PIO_DRIVER_LINE11 (0x1u << 11)
1619
#define PIO_DRIVER_LINE11_LOW_DRIVE (0x0u << 11)
1620
#define PIO_DRIVER_LINE11_HIGH_DRIVE (0x1u << 11)
1621
#define PIO_DRIVER_LINE12 (0x1u << 12)
1622
#define PIO_DRIVER_LINE12_LOW_DRIVE (0x0u << 12)
1623
#define PIO_DRIVER_LINE12_HIGH_DRIVE (0x1u << 12)
1624
#define PIO_DRIVER_LINE13 (0x1u << 13)
1625
#define PIO_DRIVER_LINE13_LOW_DRIVE (0x0u << 13)
1626
#define PIO_DRIVER_LINE13_HIGH_DRIVE (0x1u << 13)
1627
#define PIO_DRIVER_LINE14 (0x1u << 14)
1628
#define PIO_DRIVER_LINE14_LOW_DRIVE (0x0u << 14)
1629
#define PIO_DRIVER_LINE14_HIGH_DRIVE (0x1u << 14)
1630
#define PIO_DRIVER_LINE15 (0x1u << 15)
1631
#define PIO_DRIVER_LINE15_LOW_DRIVE (0x0u << 15)
1632
#define PIO_DRIVER_LINE15_HIGH_DRIVE (0x1u << 15)
1633
#define PIO_DRIVER_LINE16 (0x1u << 16)
1634
#define PIO_DRIVER_LINE16_LOW_DRIVE (0x0u << 16)
1635
#define PIO_DRIVER_LINE16_HIGH_DRIVE (0x1u << 16)
1636
#define PIO_DRIVER_LINE17 (0x1u << 17)
1637
#define PIO_DRIVER_LINE17_LOW_DRIVE (0x0u << 17)
1638
#define PIO_DRIVER_LINE17_HIGH_DRIVE (0x1u << 17)
1639
#define PIO_DRIVER_LINE18 (0x1u << 18)
1640
#define PIO_DRIVER_LINE18_LOW_DRIVE (0x0u << 18)
1641
#define PIO_DRIVER_LINE18_HIGH_DRIVE (0x1u << 18)
1642
#define PIO_DRIVER_LINE19 (0x1u << 19)
1643
#define PIO_DRIVER_LINE19_LOW_DRIVE (0x0u << 19)
1644
#define PIO_DRIVER_LINE19_HIGH_DRIVE (0x1u << 19)
1645
#define PIO_DRIVER_LINE20 (0x1u << 20)
1646
#define PIO_DRIVER_LINE20_LOW_DRIVE (0x0u << 20)
1647
#define PIO_DRIVER_LINE20_HIGH_DRIVE (0x1u << 20)
1648
#define PIO_DRIVER_LINE21 (0x1u << 21)
1649
#define PIO_DRIVER_LINE21_LOW_DRIVE (0x0u << 21)
1650
#define PIO_DRIVER_LINE21_HIGH_DRIVE (0x1u << 21)
1651
#define PIO_DRIVER_LINE22 (0x1u << 22)
1652
#define PIO_DRIVER_LINE22_LOW_DRIVE (0x0u << 22)
1653
#define PIO_DRIVER_LINE22_HIGH_DRIVE (0x1u << 22)
1654
#define PIO_DRIVER_LINE23 (0x1u << 23)
1655
#define PIO_DRIVER_LINE23_LOW_DRIVE (0x0u << 23)
1656
#define PIO_DRIVER_LINE23_HIGH_DRIVE (0x1u << 23)
1657
#define PIO_DRIVER_LINE24 (0x1u << 24)
1658
#define PIO_DRIVER_LINE24_LOW_DRIVE (0x0u << 24)
1659
#define PIO_DRIVER_LINE24_HIGH_DRIVE (0x1u << 24)
1660
#define PIO_DRIVER_LINE25 (0x1u << 25)
1661
#define PIO_DRIVER_LINE25_LOW_DRIVE (0x0u << 25)
1662
#define PIO_DRIVER_LINE25_HIGH_DRIVE (0x1u << 25)
1663
#define PIO_DRIVER_LINE26 (0x1u << 26)
1664
#define PIO_DRIVER_LINE26_LOW_DRIVE (0x0u << 26)
1665
#define PIO_DRIVER_LINE26_HIGH_DRIVE (0x1u << 26)
1666
#define PIO_DRIVER_LINE27 (0x1u << 27)
1667
#define PIO_DRIVER_LINE27_LOW_DRIVE (0x0u << 27)
1668
#define PIO_DRIVER_LINE27_HIGH_DRIVE (0x1u << 27)
1669
#define PIO_DRIVER_LINE28 (0x1u << 28)
1670
#define PIO_DRIVER_LINE28_LOW_DRIVE (0x0u << 28)
1671
#define PIO_DRIVER_LINE28_HIGH_DRIVE (0x1u << 28)
1672
#define PIO_DRIVER_LINE29 (0x1u << 29)
1673
#define PIO_DRIVER_LINE29_LOW_DRIVE (0x0u << 29)
1674
#define PIO_DRIVER_LINE29_HIGH_DRIVE (0x1u << 29)
1675
#define PIO_DRIVER_LINE30 (0x1u << 30)
1676
#define PIO_DRIVER_LINE30_LOW_DRIVE (0x0u << 30)
1677
#define PIO_DRIVER_LINE30_HIGH_DRIVE (0x1u << 30)
1678
#define PIO_DRIVER_LINE31 (0x1u << 31)
1679
#define PIO_DRIVER_LINE31_LOW_DRIVE (0x0u << 31)
1680
#define PIO_DRIVER_LINE31_HIGH_DRIVE (0x1u << 31)
1681
/* -------- PIO_PCMR : (PIO Offset: 0x0150) Parallel Capture Mode Register -------- */
1682
#define PIO_PCMR_PCEN (0x1u << 0)
1683
#define PIO_PCMR_DSIZE_Pos 4
1684
#define PIO_PCMR_DSIZE_Msk (0x3u << PIO_PCMR_DSIZE_Pos)
1685
#define PIO_PCMR_DSIZE(value) ((PIO_PCMR_DSIZE_Msk & ((value) << PIO_PCMR_DSIZE_Pos)))
1686
#define PIO_PCMR_DSIZE_BYTE (0x0u << 4)
1687
#define PIO_PCMR_DSIZE_HALFWORD (0x1u << 4)
1688
#define PIO_PCMR_DSIZE_WORD (0x2u << 4)
1689
#define PIO_PCMR_ALWYS (0x1u << 9)
1690
#define PIO_PCMR_HALFS (0x1u << 10)
1691
#define PIO_PCMR_FRSTS (0x1u << 11)
1692
/* -------- PIO_PCIER : (PIO Offset: 0x0154) Parallel Capture Interrupt Enable Register -------- */
1693
#define PIO_PCIER_DRDY (0x1u << 0)
1694
#define PIO_PCIER_OVRE (0x1u << 1)
1695
#define PIO_PCIER_ENDRX (0x1u << 2)
1696
#define PIO_PCIER_RXBUFF (0x1u << 3)
1697
/* -------- PIO_PCIDR : (PIO Offset: 0x0158) Parallel Capture Interrupt Disable Register -------- */
1698
#define PIO_PCIDR_DRDY (0x1u << 0)
1699
#define PIO_PCIDR_OVRE (0x1u << 1)
1700
#define PIO_PCIDR_ENDRX (0x1u << 2)
1701
#define PIO_PCIDR_RXBUFF (0x1u << 3)
1702
/* -------- PIO_PCIMR : (PIO Offset: 0x015C) Parallel Capture Interrupt Mask Register -------- */
1703
#define PIO_PCIMR_DRDY (0x1u << 0)
1704
#define PIO_PCIMR_OVRE (0x1u << 1)
1705
#define PIO_PCIMR_ENDRX (0x1u << 2)
1706
#define PIO_PCIMR_RXBUFF (0x1u << 3)
1707
/* -------- PIO_PCISR : (PIO Offset: 0x0160) Parallel Capture Interrupt Status Register -------- */
1708
#define PIO_PCISR_DRDY (0x1u << 0)
1709
#define PIO_PCISR_OVRE (0x1u << 1)
1710
/* -------- PIO_PCRHR : (PIO Offset: 0x0164) Parallel Capture Reception Holding Register -------- */
1711
#define PIO_PCRHR_RDATA_Pos 0
1712
#define PIO_PCRHR_RDATA_Msk (0xffffffffu << PIO_PCRHR_RDATA_Pos)
1713
1715
1716
1717
#endif
/* _SAMV71_PIO_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Pio
Pio hardware registers.
Definition
component_pio.h:41
Pio::PIO_PCISR
__I uint32_t PIO_PCISR
(Pio Offset: 0x0160) Parallel Capture Interrupt Status Register
Definition
component_pio.h:108
Pio::PIO_VERSION
__I uint32_t PIO_VERSION
(Pio Offset: 0x00FC) Version Register
Definition
component_pio.h:100
Pio::PIO_PCMR
__IO uint32_t PIO_PCMR
(Pio Offset: 0x0150) Parallel Capture Mode Register
Definition
component_pio.h:104
Pio::PIO_DRIVER
__IO uint32_t PIO_DRIVER
(Pio Offset: 0x0118) I/O Drive Register
Definition
component_pio.h:102
Pio::PIO_PCRHR
__I uint32_t PIO_PCRHR
(Pio Offset: 0x0164) Parallel Capture Reception Holding Register
Definition
component_pio.h:109
Pio::PIO_PCIMR
__I uint32_t PIO_PCIMR
(Pio Offset: 0x015C) Parallel Capture Interrupt Mask Register
Definition
component_pio.h:107
Pio::PIO_PCIDR
__O uint32_t PIO_PCIDR
(Pio Offset: 0x0158) Parallel Capture Interrupt Disable Register
Definition
component_pio.h:106
Pio::PIO_SCHMITT
__IO uint32_t PIO_SCHMITT
(Pio Offset: 0x0100) Schmitt Trigger Register
Definition
component_pio.h:100
Pio::PIO_PCIER
__O uint32_t PIO_PCIER
(Pio Offset: 0x0154) Parallel Capture Interrupt Enable Register
Definition
component_pio.h:105
