RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_icm.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_ICM_COMPONENT_
31
#define _SAMV71_ICM_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__IO
uint32_t ICM_CFG;
43
__O
uint32_t ICM_CTRL;
44
__O
uint32_t ICM_SR;
45
__I
uint32_t Reserved1[1];
46
__O
uint32_t ICM_IER;
47
__O
uint32_t ICM_IDR;
48
__I
uint32_t ICM_IMR;
49
__I
uint32_t ICM_ISR;
50
__I
uint32_t ICM_UASR;
51
__I
uint32_t Reserved2[3];
52
__IO
uint32_t ICM_DSCR;
53
__IO
uint32_t ICM_HASH;
54
__O
uint32_t ICM_UIHVAL[8];
55
__I
uint32_t Reserved3[37];
56
__I
uint32_t
ICM_ADDRSIZE
57
__I
uint32_t
ICM_IPNAME
[2];
58
__I
uint32_t
ICM_FEATURES
59
__I
uint32_t
ICM_VERSION
60
Icm
61
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
62
/* -------- ICM_CFG : (ICM Offset: 0x00) Configuration Register -------- */
63
#define ICM_CFG_WBDIS (0x1u << 0)
64
#define ICM_CFG_EOMDIS (0x1u << 1)
65
#define ICM_CFG_SLBDIS (0x1u << 2)
66
#define ICM_CFG_BBC_Pos 4
67
#define ICM_CFG_BBC_Msk (0xfu << ICM_CFG_BBC_Pos)
68
#define ICM_CFG_BBC(value) ((ICM_CFG_BBC_Msk & ((value) << ICM_CFG_BBC_Pos)))
69
#define ICM_CFG_ASCD (0x1u << 8)
70
#define ICM_CFG_DUALBUFF (0x1u << 9)
71
#define ICM_CFG_UIHASH (0x1u << 12)
72
#define ICM_CFG_UALGO_Pos 13
73
#define ICM_CFG_UALGO_Msk (0x7u << ICM_CFG_UALGO_Pos)
74
#define ICM_CFG_UALGO(value) ((ICM_CFG_UALGO_Msk & ((value) << ICM_CFG_UALGO_Pos)))
75
#define ICM_CFG_UALGO_SHA1 (0x0u << 13)
76
#define ICM_CFG_UALGO_SHA256 (0x1u << 13)
77
#define ICM_CFG_UALGO_SHA224 (0x4u << 13)
78
#define ICM_CFG_HAPROT_Pos 16
79
#define ICM_CFG_HAPROT_Msk (0x3fu << ICM_CFG_HAPROT_Pos)
80
#define ICM_CFG_HAPROT(value) ((ICM_CFG_HAPROT_Msk & ((value) << ICM_CFG_HAPROT_Pos)))
81
#define ICM_CFG_DAPROT_Pos 24
82
#define ICM_CFG_DAPROT_Msk (0x3fu << ICM_CFG_DAPROT_Pos)
83
#define ICM_CFG_DAPROT(value) ((ICM_CFG_DAPROT_Msk & ((value) << ICM_CFG_DAPROT_Pos)))
84
/* -------- ICM_CTRL : (ICM Offset: 0x04) Control Register -------- */
85
#define ICM_CTRL_ENABLE (0x1u << 0)
86
#define ICM_CTRL_DISABLE (0x1u << 1)
87
#define ICM_CTRL_SWRST (0x1u << 2)
88
#define ICM_CTRL_REHASH_Pos 4
89
#define ICM_CTRL_REHASH_Msk (0xfu << ICM_CTRL_REHASH_Pos)
90
#define ICM_CTRL_REHASH(value) ((ICM_CTRL_REHASH_Msk & ((value) << ICM_CTRL_REHASH_Pos)))
91
#define ICM_CTRL_RMDIS_Pos 8
92
#define ICM_CTRL_RMDIS_Msk (0xfu << ICM_CTRL_RMDIS_Pos)
93
#define ICM_CTRL_RMDIS(value) ((ICM_CTRL_RMDIS_Msk & ((value) << ICM_CTRL_RMDIS_Pos)))
94
#define ICM_CTRL_RMEN_Pos 12
95
#define ICM_CTRL_RMEN_Msk (0xfu << ICM_CTRL_RMEN_Pos)
96
#define ICM_CTRL_RMEN(value) ((ICM_CTRL_RMEN_Msk & ((value) << ICM_CTRL_RMEN_Pos)))
97
/* -------- ICM_SR : (ICM Offset: 0x08) Status Register -------- */
98
#define ICM_SR_ENABLE (0x1u << 0)
99
#define ICM_SR_RAWRMDIS_Pos 8
100
#define ICM_SR_RAWRMDIS_Msk (0xfu << ICM_SR_RAWRMDIS_Pos)
101
#define ICM_SR_RAWRMDIS(value) ((ICM_SR_RAWRMDIS_Msk & ((value) << ICM_SR_RAWRMDIS_Pos)))
102
#define ICM_SR_RMDIS_Pos 12
103
#define ICM_SR_RMDIS_Msk (0xfu << ICM_SR_RMDIS_Pos)
104
#define ICM_SR_RMDIS(value) ((ICM_SR_RMDIS_Msk & ((value) << ICM_SR_RMDIS_Pos)))
105
/* -------- ICM_IER : (ICM Offset: 0x10) Interrupt Enable Register -------- */
106
#define ICM_IER_RHC_Pos 0
107
#define ICM_IER_RHC_Msk (0xfu << ICM_IER_RHC_Pos)
108
#define ICM_IER_RHC(value) ((ICM_IER_RHC_Msk & ((value) << ICM_IER_RHC_Pos)))
109
#define ICM_IER_RDM_Pos 4
110
#define ICM_IER_RDM_Msk (0xfu << ICM_IER_RDM_Pos)
111
#define ICM_IER_RDM(value) ((ICM_IER_RDM_Msk & ((value) << ICM_IER_RDM_Pos)))
112
#define ICM_IER_RBE_Pos 8
113
#define ICM_IER_RBE_Msk (0xfu << ICM_IER_RBE_Pos)
114
#define ICM_IER_RBE(value) ((ICM_IER_RBE_Msk & ((value) << ICM_IER_RBE_Pos)))
115
#define ICM_IER_RWC_Pos 12
116
#define ICM_IER_RWC_Msk (0xfu << ICM_IER_RWC_Pos)
117
#define ICM_IER_RWC(value) ((ICM_IER_RWC_Msk & ((value) << ICM_IER_RWC_Pos)))
118
#define ICM_IER_REC_Pos 16
119
#define ICM_IER_REC_Msk (0xfu << ICM_IER_REC_Pos)
120
#define ICM_IER_REC(value) ((ICM_IER_REC_Msk & ((value) << ICM_IER_REC_Pos)))
121
#define ICM_IER_RSU_Pos 20
122
#define ICM_IER_RSU_Msk (0xfu << ICM_IER_RSU_Pos)
123
#define ICM_IER_RSU(value) ((ICM_IER_RSU_Msk & ((value) << ICM_IER_RSU_Pos)))
124
#define ICM_IER_URAD (0x1u << 24)
125
/* -------- ICM_IDR : (ICM Offset: 0x14) Interrupt Disable Register -------- */
126
#define ICM_IDR_RHC_Pos 0
127
#define ICM_IDR_RHC_Msk (0xfu << ICM_IDR_RHC_Pos)
128
#define ICM_IDR_RHC(value) ((ICM_IDR_RHC_Msk & ((value) << ICM_IDR_RHC_Pos)))
129
#define ICM_IDR_RDM_Pos 4
130
#define ICM_IDR_RDM_Msk (0xfu << ICM_IDR_RDM_Pos)
131
#define ICM_IDR_RDM(value) ((ICM_IDR_RDM_Msk & ((value) << ICM_IDR_RDM_Pos)))
132
#define ICM_IDR_RBE_Pos 8
133
#define ICM_IDR_RBE_Msk (0xfu << ICM_IDR_RBE_Pos)
134
#define ICM_IDR_RBE(value) ((ICM_IDR_RBE_Msk & ((value) << ICM_IDR_RBE_Pos)))
135
#define ICM_IDR_RWC_Pos 12
136
#define ICM_IDR_RWC_Msk (0xfu << ICM_IDR_RWC_Pos)
137
#define ICM_IDR_RWC(value) ((ICM_IDR_RWC_Msk & ((value) << ICM_IDR_RWC_Pos)))
138
#define ICM_IDR_REC_Pos 16
139
#define ICM_IDR_REC_Msk (0xfu << ICM_IDR_REC_Pos)
140
#define ICM_IDR_REC(value) ((ICM_IDR_REC_Msk & ((value) << ICM_IDR_REC_Pos)))
141
#define ICM_IDR_RSU_Pos 20
142
#define ICM_IDR_RSU_Msk (0xfu << ICM_IDR_RSU_Pos)
143
#define ICM_IDR_RSU(value) ((ICM_IDR_RSU_Msk & ((value) << ICM_IDR_RSU_Pos)))
144
#define ICM_IDR_URAD (0x1u << 24)
145
/* -------- ICM_IMR : (ICM Offset: 0x18) Interrupt Mask Register -------- */
146
#define ICM_IMR_RHC_Pos 0
147
#define ICM_IMR_RHC_Msk (0xfu << ICM_IMR_RHC_Pos)
148
#define ICM_IMR_RDM_Pos 4
149
#define ICM_IMR_RDM_Msk (0xfu << ICM_IMR_RDM_Pos)
150
#define ICM_IMR_RBE_Pos 8
151
#define ICM_IMR_RBE_Msk (0xfu << ICM_IMR_RBE_Pos)
152
#define ICM_IMR_RWC_Pos 12
153
#define ICM_IMR_RWC_Msk (0xfu << ICM_IMR_RWC_Pos)
154
#define ICM_IMR_REC_Pos 16
155
#define ICM_IMR_REC_Msk (0xfu << ICM_IMR_REC_Pos)
156
#define ICM_IMR_RSU_Pos 20
157
#define ICM_IMR_RSU_Msk (0xfu << ICM_IMR_RSU_Pos)
158
#define ICM_IMR_URAD (0x1u << 24)
159
/* -------- ICM_ISR : (ICM Offset: 0x1C) Interrupt Status Register -------- */
160
#define ICM_ISR_RHC_Pos 0
161
#define ICM_ISR_RHC_Msk (0xfu << ICM_ISR_RHC_Pos)
162
#define ICM_ISR_RDM_Pos 4
163
#define ICM_ISR_RDM_Msk (0xfu << ICM_ISR_RDM_Pos)
164
#define ICM_ISR_RBE_Pos 8
165
#define ICM_ISR_RBE_Msk (0xfu << ICM_ISR_RBE_Pos)
166
#define ICM_ISR_RWC_Pos 12
167
#define ICM_ISR_RWC_Msk (0xfu << ICM_ISR_RWC_Pos)
168
#define ICM_ISR_REC_Pos 16
169
#define ICM_ISR_REC_Msk (0xfu << ICM_ISR_REC_Pos)
170
#define ICM_ISR_RSU_Pos 20
171
#define ICM_ISR_RSU_Msk (0xfu << ICM_ISR_RSU_Pos)
172
#define ICM_ISR_URAD (0x1u << 24)
173
/* -------- ICM_UASR : (ICM Offset: 0x20) Undefined Access Status Register -------- */
174
#define ICM_UASR_URAT_Pos 0
175
#define ICM_UASR_URAT_Msk (0x7u << ICM_UASR_URAT_Pos)
176
#define ICM_UASR_URAT_UNSPEC_STRUCT_MEMBER (0x0u << 0)
177
#define ICM_UASR_URAT_ICM_CFG_MODIFIED (0x1u << 0)
178
#define ICM_UASR_URAT_ICM_DSCR_MODIFIED (0x2u << 0)
179
#define ICM_UASR_URAT_ICM_HASH_MODIFIED (0x3u << 0)
180
#define ICM_UASR_URAT_READ_ACCESS (0x4u << 0)
181
/* -------- ICM_DSCR : (ICM Offset: 0x30) Region Descriptor Area Start Address Register -------- */
182
#define ICM_DSCR_DASA_Pos 6
183
#define ICM_DSCR_DASA_Msk (0x3ffffffu << ICM_DSCR_DASA_Pos)
184
#define ICM_DSCR_DASA(value) ((ICM_DSCR_DASA_Msk & ((value) << ICM_DSCR_DASA_Pos)))
185
/* -------- ICM_HASH : (ICM Offset: 0x34) Region Hash Area Start Address Register -------- */
186
#define ICM_HASH_HASA_Pos 7
187
#define ICM_HASH_HASA_Msk (0x1ffffffu << ICM_HASH_HASA_Pos)
188
#define ICM_HASH_HASA(value) ((ICM_HASH_HASA_Msk & ((value) << ICM_HASH_HASA_Pos)))
189
/* -------- ICM_UIHVAL[8] : (ICM Offset: 0x38) User Initial Hash Value 0 Register -------- */
190
#define ICM_UIHVAL_VAL_Pos 0
191
#define ICM_UIHVAL_VAL_Msk (0xffffffffu << ICM_UIHVAL_VAL_Pos)
192
#define ICM_UIHVAL_VAL(value) ((ICM_UIHVAL_VAL_Msk & ((value) << ICM_UIHVAL_VAL_Pos)))
193
/* -------- ICM_ADDRSIZE : (ICM Offset: 0xEC) Address Size Register -------- */
194
#define ICM_ADDRSIZE_ADDRSIZE_Pos 0
195
#define ICM_ADDRSIZE_ADDRSIZE_Msk (0xffffu << ICM_ADDRSIZE_ADDRSIZE_Pos)
196
/* -------- ICM_IPNAME[2] : (ICM Offset: 0xF0) IP Name 1 Register -------- */
197
#define ICM_IPNAME_IPNAME_Pos 0
198
#define ICM_IPNAME_IPNAME_Msk (0xffffffffu << ICM_IPNAME_IPNAME_Pos)
199
/* -------- ICM_FEATURES : (ICM Offset: 0xF8) Feature Register -------- */
200
#define ICM_FEATURES_CFGALGO (0x1u << 0)
201
#define ICM_FEATURES_RFU (0x1u << 1)
202
#define ICM_FEATURES_CFGPP (0x1u << 2)
203
#define ICM_FEATURES_HDPP (0x1u << 3)
204
#define ICM_FEATURES_PDC (0x1u << 4)
205
#define ICM_FEATURES_NAIS (0x1u << 5)
206
#define ICM_FEATURES_EF (0x1u << 6)
207
#define ICM_FEATURES_SI (0x1u << 7)
208
#define ICM_FEATURES_BTYP (0x1u << 8)
209
#define ICM_FEATURES_PDCOFF0C (0x1u << 9)
210
#define ICM_FEATURES_HSHA1 (0x1u << 16)
211
#define ICM_FEATURES_HSHA224 (0x1u << 17)
212
#define ICM_FEATURES_HSHA256 (0x1u << 18)
213
#define ICM_FEATURES_HSHA384 (0x1u << 19)
214
#define ICM_FEATURES_HSHA512 (0x1u << 20)
215
/* -------- ICM_VERSION : (ICM Offset: 0xFC) Version Register -------- */
216
#define ICM_VERSION_VERSION_Pos 0
217
#define ICM_VERSION_VERSION_Msk (0xfffu << ICM_VERSION_VERSION_Pos)
218
#define ICM_VERSION_MFN_Pos 16
219
#define ICM_VERSION_MFN_Msk (0x7u << ICM_VERSION_MFN_Pos)
220
222
223
224
#endif
/* _SAMV71_ICM_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Icm
Icm hardware registers.
Definition
component_icm.h:41
Icm::ICM_FEATURES
__I uint32_t ICM_FEATURES
(Icm Offset: 0xF8) Feature Register
Definition
component_icm.h:58
Icm::ICM_IPNAME
__I uint32_t ICM_IPNAME[2]
(Icm Offset: 0xF0) IP Name 1 Register
Definition
component_icm.h:57
Icm::ICM_VERSION
__I uint32_t ICM_VERSION
(Icm Offset: 0xFC) Version Register
Definition
component_icm.h:59
Icm::ICM_ADDRSIZE
__I uint32_t ICM_ADDRSIZE
(Icm Offset: 0xEC) Address Size Register
Definition
component_icm.h:56
