RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_hsmci.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_HSMCI_COMPONENT_
31
#define _SAMV71_HSMCI_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t HSMCI_CR;
43
__IO
uint32_t HSMCI_MR;
44
__IO
uint32_t HSMCI_DTOR;
45
__IO
uint32_t HSMCI_SDCR;
46
__IO
uint32_t HSMCI_ARGR;
47
__O
uint32_t HSMCI_CMDR;
48
__IO
uint32_t HSMCI_BLKR;
49
__IO
uint32_t HSMCI_CSTOR;
50
__I
uint32_t HSMCI_RSPR[4];
51
__I
uint32_t HSMCI_RDR;
52
__O
uint32_t HSMCI_TDR;
53
__I
uint32_t Reserved1[2];
54
__I
uint32_t HSMCI_SR;
55
__O
uint32_t HSMCI_IER;
56
__O
uint32_t HSMCI_IDR;
57
__I
uint32_t HSMCI_IMR;
58
__IO
uint32_t HSMCI_DMA;
59
__IO
uint32_t HSMCI_CFG;
60
__I
uint32_t Reserved2[35];
61
__IO
uint32_t HSMCI_WPMR;
62
__I
uint32_t HSMCI_WPSR;
63
__I
uint32_t Reserved3[4];
64
__I
uint32_t
HSMCI_VERSION
65
__I
uint32_t Reserved4[64];
66
__IO
uint32_t
HSMCI_FIFO
[256];
67
Hsmci
68
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
69
/* -------- HSMCI_CR : (HSMCI Offset: 0x00) Control Register -------- */
70
#define HSMCI_CR_MCIEN (0x1u << 0)
71
#define HSMCI_CR_MCIDIS (0x1u << 1)
72
#define HSMCI_CR_PWSEN (0x1u << 2)
73
#define HSMCI_CR_PWSDIS (0x1u << 3)
74
#define HSMCI_CR_SWRST (0x1u << 7)
75
/* -------- HSMCI_MR : (HSMCI Offset: 0x04) Mode Register -------- */
76
#define HSMCI_MR_CLKDIV_Pos 0
77
#define HSMCI_MR_CLKDIV_Msk (0xffu << HSMCI_MR_CLKDIV_Pos)
78
#define HSMCI_MR_CLKDIV(value) ((HSMCI_MR_CLKDIV_Msk & ((value) << HSMCI_MR_CLKDIV_Pos)))
79
#define HSMCI_MR_PWSDIV_Pos 8
80
#define HSMCI_MR_PWSDIV_Msk (0x7u << HSMCI_MR_PWSDIV_Pos)
81
#define HSMCI_MR_PWSDIV(value) ((HSMCI_MR_PWSDIV_Msk & ((value) << HSMCI_MR_PWSDIV_Pos)))
82
#define HSMCI_MR_RDPROOF (0x1u << 11)
83
#define HSMCI_MR_WRPROOF (0x1u << 12)
84
#define HSMCI_MR_FBYTE (0x1u << 13)
85
#define HSMCI_MR_PADV (0x1u << 14)
86
#define HSMCI_MR_CLKODD (0x1u << 16)
87
/* -------- HSMCI_DTOR : (HSMCI Offset: 0x08) Data Timeout Register -------- */
88
#define HSMCI_DTOR_DTOCYC_Pos 0
89
#define HSMCI_DTOR_DTOCYC_Msk (0xfu << HSMCI_DTOR_DTOCYC_Pos)
90
#define HSMCI_DTOR_DTOCYC(value) ((HSMCI_DTOR_DTOCYC_Msk & ((value) << HSMCI_DTOR_DTOCYC_Pos)))
91
#define HSMCI_DTOR_DTOMUL_Pos 4
92
#define HSMCI_DTOR_DTOMUL_Msk (0x7u << HSMCI_DTOR_DTOMUL_Pos)
93
#define HSMCI_DTOR_DTOMUL(value) ((HSMCI_DTOR_DTOMUL_Msk & ((value) << HSMCI_DTOR_DTOMUL_Pos)))
94
#define HSMCI_DTOR_DTOMUL_1 (0x0u << 4)
95
#define HSMCI_DTOR_DTOMUL_16 (0x1u << 4)
96
#define HSMCI_DTOR_DTOMUL_128 (0x2u << 4)
97
#define HSMCI_DTOR_DTOMUL_256 (0x3u << 4)
98
#define HSMCI_DTOR_DTOMUL_1024 (0x4u << 4)
99
#define HSMCI_DTOR_DTOMUL_4096 (0x5u << 4)
100
#define HSMCI_DTOR_DTOMUL_65536 (0x6u << 4)
101
#define HSMCI_DTOR_DTOMUL_1048576 (0x7u << 4)
102
/* -------- HSMCI_SDCR : (HSMCI Offset: 0x0C) SD/SDIO Card Register -------- */
103
#define HSMCI_SDCR_SDCSEL_Pos 0
104
#define HSMCI_SDCR_SDCSEL_Msk (0x3u << HSMCI_SDCR_SDCSEL_Pos)
105
#define HSMCI_SDCR_SDCSEL(value) ((HSMCI_SDCR_SDCSEL_Msk & ((value) << HSMCI_SDCR_SDCSEL_Pos)))
106
#define HSMCI_SDCR_SDCSEL_SLOTA (0x0u << 0)
107
#define HSMCI_SDCR_SDCBUS_Pos 6
108
#define HSMCI_SDCR_SDCBUS_Msk (0x3u << HSMCI_SDCR_SDCBUS_Pos)
109
#define HSMCI_SDCR_SDCBUS(value) ((HSMCI_SDCR_SDCBUS_Msk & ((value) << HSMCI_SDCR_SDCBUS_Pos)))
110
#define HSMCI_SDCR_SDCBUS_1 (0x0u << 6)
111
#define HSMCI_SDCR_SDCBUS_4 (0x2u << 6)
112
#define HSMCI_SDCR_SDCBUS_8 (0x3u << 6)
113
/* -------- HSMCI_ARGR : (HSMCI Offset: 0x10) Argument Register -------- */
114
#define HSMCI_ARGR_ARG_Pos 0
115
#define HSMCI_ARGR_ARG_Msk (0xffffffffu << HSMCI_ARGR_ARG_Pos)
116
#define HSMCI_ARGR_ARG(value) ((HSMCI_ARGR_ARG_Msk & ((value) << HSMCI_ARGR_ARG_Pos)))
117
/* -------- HSMCI_CMDR : (HSMCI Offset: 0x14) Command Register -------- */
118
#define HSMCI_CMDR_CMDNB_Pos 0
119
#define HSMCI_CMDR_CMDNB_Msk (0x3fu << HSMCI_CMDR_CMDNB_Pos)
120
#define HSMCI_CMDR_CMDNB(value) ((HSMCI_CMDR_CMDNB_Msk & ((value) << HSMCI_CMDR_CMDNB_Pos)))
121
#define HSMCI_CMDR_RSPTYP_Pos 6
122
#define HSMCI_CMDR_RSPTYP_Msk (0x3u << HSMCI_CMDR_RSPTYP_Pos)
123
#define HSMCI_CMDR_RSPTYP(value) ((HSMCI_CMDR_RSPTYP_Msk & ((value) << HSMCI_CMDR_RSPTYP_Pos)))
124
#define HSMCI_CMDR_RSPTYP_NORESP (0x0u << 6)
125
#define HSMCI_CMDR_RSPTYP_48_BIT (0x1u << 6)
126
#define HSMCI_CMDR_RSPTYP_136_BIT (0x2u << 6)
127
#define HSMCI_CMDR_RSPTYP_R1B (0x3u << 6)
128
#define HSMCI_CMDR_SPCMD_Pos 8
129
#define HSMCI_CMDR_SPCMD_Msk (0x7u << HSMCI_CMDR_SPCMD_Pos)
130
#define HSMCI_CMDR_SPCMD(value) ((HSMCI_CMDR_SPCMD_Msk & ((value) << HSMCI_CMDR_SPCMD_Pos)))
131
#define HSMCI_CMDR_SPCMD_STD (0x0u << 8)
132
#define HSMCI_CMDR_SPCMD_INIT (0x1u << 8)
133
#define HSMCI_CMDR_SPCMD_SYNC (0x2u << 8)
134
#define HSMCI_CMDR_SPCMD_CE_ATA (0x3u << 8)
135
#define HSMCI_CMDR_SPCMD_IT_CMD (0x4u << 8)
136
#define HSMCI_CMDR_SPCMD_IT_RESP (0x5u << 8)
137
#define HSMCI_CMDR_SPCMD_BOR (0x6u << 8)
138
#define HSMCI_CMDR_SPCMD_EBO (0x7u << 8)
139
#define HSMCI_CMDR_OPDCMD (0x1u << 11)
140
#define HSMCI_CMDR_OPDCMD_PUSHPULL (0x0u << 11)
141
#define HSMCI_CMDR_OPDCMD_OPENDRAIN (0x1u << 11)
142
#define HSMCI_CMDR_MAXLAT (0x1u << 12)
143
#define HSMCI_CMDR_MAXLAT_5 (0x0u << 12)
144
#define HSMCI_CMDR_MAXLAT_64 (0x1u << 12)
145
#define HSMCI_CMDR_TRCMD_Pos 16
146
#define HSMCI_CMDR_TRCMD_Msk (0x3u << HSMCI_CMDR_TRCMD_Pos)
147
#define HSMCI_CMDR_TRCMD(value) ((HSMCI_CMDR_TRCMD_Msk & ((value) << HSMCI_CMDR_TRCMD_Pos)))
148
#define HSMCI_CMDR_TRCMD_NO_DATA (0x0u << 16)
149
#define HSMCI_CMDR_TRCMD_START_DATA (0x1u << 16)
150
#define HSMCI_CMDR_TRCMD_STOP_DATA (0x2u << 16)
151
#define HSMCI_CMDR_TRDIR (0x1u << 18)
152
#define HSMCI_CMDR_TRDIR_WRITE (0x0u << 18)
153
#define HSMCI_CMDR_TRDIR_READ (0x1u << 18)
154
#define HSMCI_CMDR_TRTYP_Pos 19
155
#define HSMCI_CMDR_TRTYP_Msk (0x7u << HSMCI_CMDR_TRTYP_Pos)
156
#define HSMCI_CMDR_TRTYP(value) ((HSMCI_CMDR_TRTYP_Msk & ((value) << HSMCI_CMDR_TRTYP_Pos)))
157
#define HSMCI_CMDR_TRTYP_SINGLE (0x0u << 19)
158
#define HSMCI_CMDR_TRTYP_MULTIPLE (0x1u << 19)
159
#define HSMCI_CMDR_TRTYP_STREAM (0x2u << 19)
160
#define HSMCI_CMDR_TRTYP_BYTE (0x4u << 19)
161
#define HSMCI_CMDR_TRTYP_BLOCK (0x5u << 19)
162
#define HSMCI_CMDR_IOSPCMD_Pos 24
163
#define HSMCI_CMDR_IOSPCMD_Msk (0x3u << HSMCI_CMDR_IOSPCMD_Pos)
164
#define HSMCI_CMDR_IOSPCMD(value) ((HSMCI_CMDR_IOSPCMD_Msk & ((value) << HSMCI_CMDR_IOSPCMD_Pos)))
165
#define HSMCI_CMDR_IOSPCMD_STD (0x0u << 24)
166
#define HSMCI_CMDR_IOSPCMD_SUSPEND (0x1u << 24)
167
#define HSMCI_CMDR_IOSPCMD_RESUME (0x2u << 24)
168
#define HSMCI_CMDR_ATACS (0x1u << 26)
169
#define HSMCI_CMDR_ATACS_NORMAL (0x0u << 26)
170
#define HSMCI_CMDR_ATACS_COMPLETION (0x1u << 26)
171
#define HSMCI_CMDR_BOOT_ACK (0x1u << 27)
172
/* -------- HSMCI_BLKR : (HSMCI Offset: 0x18) Block Register -------- */
173
#define HSMCI_BLKR_BCNT_Pos 0
174
#define HSMCI_BLKR_BCNT_Msk (0xffffu << HSMCI_BLKR_BCNT_Pos)
175
#define HSMCI_BLKR_BCNT(value) ((HSMCI_BLKR_BCNT_Msk & ((value) << HSMCI_BLKR_BCNT_Pos)))
176
#define HSMCI_BLKR_BLKLEN_Pos 16
177
#define HSMCI_BLKR_BLKLEN_Msk (0xffffu << HSMCI_BLKR_BLKLEN_Pos)
178
#define HSMCI_BLKR_BLKLEN(value) ((HSMCI_BLKR_BLKLEN_Msk & ((value) << HSMCI_BLKR_BLKLEN_Pos)))
179
/* -------- HSMCI_CSTOR : (HSMCI Offset: 0x1C) Completion Signal Timeout Register -------- */
180
#define HSMCI_CSTOR_CSTOCYC_Pos 0
181
#define HSMCI_CSTOR_CSTOCYC_Msk (0xfu << HSMCI_CSTOR_CSTOCYC_Pos)
182
#define HSMCI_CSTOR_CSTOCYC(value) ((HSMCI_CSTOR_CSTOCYC_Msk & ((value) << HSMCI_CSTOR_CSTOCYC_Pos)))
183
#define HSMCI_CSTOR_CSTOMUL_Pos 4
184
#define HSMCI_CSTOR_CSTOMUL_Msk (0x7u << HSMCI_CSTOR_CSTOMUL_Pos)
185
#define HSMCI_CSTOR_CSTOMUL(value) ((HSMCI_CSTOR_CSTOMUL_Msk & ((value) << HSMCI_CSTOR_CSTOMUL_Pos)))
186
#define HSMCI_CSTOR_CSTOMUL_1 (0x0u << 4)
187
#define HSMCI_CSTOR_CSTOMUL_16 (0x1u << 4)
188
#define HSMCI_CSTOR_CSTOMUL_128 (0x2u << 4)
189
#define HSMCI_CSTOR_CSTOMUL_256 (0x3u << 4)
190
#define HSMCI_CSTOR_CSTOMUL_1024 (0x4u << 4)
191
#define HSMCI_CSTOR_CSTOMUL_4096 (0x5u << 4)
192
#define HSMCI_CSTOR_CSTOMUL_65536 (0x6u << 4)
193
#define HSMCI_CSTOR_CSTOMUL_1048576 (0x7u << 4)
194
/* -------- HSMCI_RSPR[4] : (HSMCI Offset: 0x20) Response Register -------- */
195
#define HSMCI_RSPR_RSP_Pos 0
196
#define HSMCI_RSPR_RSP_Msk (0xffffffffu << HSMCI_RSPR_RSP_Pos)
197
/* -------- HSMCI_RDR : (HSMCI Offset: 0x30) Receive Data Register -------- */
198
#define HSMCI_RDR_DATA_Pos 0
199
#define HSMCI_RDR_DATA_Msk (0xffffffffu << HSMCI_RDR_DATA_Pos)
200
/* -------- HSMCI_TDR : (HSMCI Offset: 0x34) Transmit Data Register -------- */
201
#define HSMCI_TDR_DATA_Pos 0
202
#define HSMCI_TDR_DATA_Msk (0xffffffffu << HSMCI_TDR_DATA_Pos)
203
#define HSMCI_TDR_DATA(value) ((HSMCI_TDR_DATA_Msk & ((value) << HSMCI_TDR_DATA_Pos)))
204
/* -------- HSMCI_SR : (HSMCI Offset: 0x40) Status Register -------- */
205
#define HSMCI_SR_CMDRDY (0x1u << 0)
206
#define HSMCI_SR_RXRDY (0x1u << 1)
207
#define HSMCI_SR_TXRDY (0x1u << 2)
208
#define HSMCI_SR_BLKE (0x1u << 3)
209
#define HSMCI_SR_DTIP (0x1u << 4)
210
#define HSMCI_SR_NOTBUSY (0x1u << 5)
211
#define HSMCI_SR_SDIOIRQA (0x1u << 8)
212
#define HSMCI_SR_SDIOWAIT (0x1u << 12)
213
#define HSMCI_SR_CSRCV (0x1u << 13)
214
#define HSMCI_SR_RINDE (0x1u << 16)
215
#define HSMCI_SR_RDIRE (0x1u << 17)
216
#define HSMCI_SR_RCRCE (0x1u << 18)
217
#define HSMCI_SR_RENDE (0x1u << 19)
218
#define HSMCI_SR_RTOE (0x1u << 20)
219
#define HSMCI_SR_DCRCE (0x1u << 21)
220
#define HSMCI_SR_DTOE (0x1u << 22)
221
#define HSMCI_SR_CSTOE (0x1u << 23)
222
#define HSMCI_SR_BLKOVRE (0x1u << 24)
223
#define HSMCI_SR_FIFOEMPTY (0x1u << 26)
224
#define HSMCI_SR_XFRDONE (0x1u << 27)
225
#define HSMCI_SR_ACKRCV (0x1u << 28)
226
#define HSMCI_SR_ACKRCVE (0x1u << 29)
227
#define HSMCI_SR_OVRE (0x1u << 30)
228
#define HSMCI_SR_UNRE (0x1u << 31)
229
/* -------- HSMCI_IER : (HSMCI Offset: 0x44) Interrupt Enable Register -------- */
230
#define HSMCI_IER_CMDRDY (0x1u << 0)
231
#define HSMCI_IER_RXRDY (0x1u << 1)
232
#define HSMCI_IER_TXRDY (0x1u << 2)
233
#define HSMCI_IER_BLKE (0x1u << 3)
234
#define HSMCI_IER_DTIP (0x1u << 4)
235
#define HSMCI_IER_NOTBUSY (0x1u << 5)
236
#define HSMCI_IER_SDIOIRQA (0x1u << 8)
237
#define HSMCI_IER_SDIOWAIT (0x1u << 12)
238
#define HSMCI_IER_CSRCV (0x1u << 13)
239
#define HSMCI_IER_RINDE (0x1u << 16)
240
#define HSMCI_IER_RDIRE (0x1u << 17)
241
#define HSMCI_IER_RCRCE (0x1u << 18)
242
#define HSMCI_IER_RENDE (0x1u << 19)
243
#define HSMCI_IER_RTOE (0x1u << 20)
244
#define HSMCI_IER_DCRCE (0x1u << 21)
245
#define HSMCI_IER_DTOE (0x1u << 22)
246
#define HSMCI_IER_CSTOE (0x1u << 23)
247
#define HSMCI_IER_BLKOVRE (0x1u << 24)
248
#define HSMCI_IER_FIFOEMPTY (0x1u << 26)
249
#define HSMCI_IER_XFRDONE (0x1u << 27)
250
#define HSMCI_IER_ACKRCV (0x1u << 28)
251
#define HSMCI_IER_ACKRCVE (0x1u << 29)
252
#define HSMCI_IER_OVRE (0x1u << 30)
253
#define HSMCI_IER_UNRE (0x1u << 31)
254
/* -------- HSMCI_IDR : (HSMCI Offset: 0x48) Interrupt Disable Register -------- */
255
#define HSMCI_IDR_CMDRDY (0x1u << 0)
256
#define HSMCI_IDR_RXRDY (0x1u << 1)
257
#define HSMCI_IDR_TXRDY (0x1u << 2)
258
#define HSMCI_IDR_BLKE (0x1u << 3)
259
#define HSMCI_IDR_DTIP (0x1u << 4)
260
#define HSMCI_IDR_NOTBUSY (0x1u << 5)
261
#define HSMCI_IDR_SDIOIRQA (0x1u << 8)
262
#define HSMCI_IDR_SDIOWAIT (0x1u << 12)
263
#define HSMCI_IDR_CSRCV (0x1u << 13)
264
#define HSMCI_IDR_RINDE (0x1u << 16)
265
#define HSMCI_IDR_RDIRE (0x1u << 17)
266
#define HSMCI_IDR_RCRCE (0x1u << 18)
267
#define HSMCI_IDR_RENDE (0x1u << 19)
268
#define HSMCI_IDR_RTOE (0x1u << 20)
269
#define HSMCI_IDR_DCRCE (0x1u << 21)
270
#define HSMCI_IDR_DTOE (0x1u << 22)
271
#define HSMCI_IDR_CSTOE (0x1u << 23)
272
#define HSMCI_IDR_BLKOVRE (0x1u << 24)
273
#define HSMCI_IDR_FIFOEMPTY (0x1u << 26)
274
#define HSMCI_IDR_XFRDONE (0x1u << 27)
275
#define HSMCI_IDR_ACKRCV (0x1u << 28)
276
#define HSMCI_IDR_ACKRCVE (0x1u << 29)
277
#define HSMCI_IDR_OVRE (0x1u << 30)
278
#define HSMCI_IDR_UNRE (0x1u << 31)
279
/* -------- HSMCI_IMR : (HSMCI Offset: 0x4C) Interrupt Mask Register -------- */
280
#define HSMCI_IMR_CMDRDY (0x1u << 0)
281
#define HSMCI_IMR_RXRDY (0x1u << 1)
282
#define HSMCI_IMR_TXRDY (0x1u << 2)
283
#define HSMCI_IMR_BLKE (0x1u << 3)
284
#define HSMCI_IMR_DTIP (0x1u << 4)
285
#define HSMCI_IMR_NOTBUSY (0x1u << 5)
286
#define HSMCI_IMR_SDIOIRQA (0x1u << 8)
287
#define HSMCI_IMR_SDIOWAIT (0x1u << 12)
288
#define HSMCI_IMR_CSRCV (0x1u << 13)
289
#define HSMCI_IMR_RINDE (0x1u << 16)
290
#define HSMCI_IMR_RDIRE (0x1u << 17)
291
#define HSMCI_IMR_RCRCE (0x1u << 18)
292
#define HSMCI_IMR_RENDE (0x1u << 19)
293
#define HSMCI_IMR_RTOE (0x1u << 20)
294
#define HSMCI_IMR_DCRCE (0x1u << 21)
295
#define HSMCI_IMR_DTOE (0x1u << 22)
296
#define HSMCI_IMR_CSTOE (0x1u << 23)
297
#define HSMCI_IMR_BLKOVRE (0x1u << 24)
298
#define HSMCI_IMR_FIFOEMPTY (0x1u << 26)
299
#define HSMCI_IMR_XFRDONE (0x1u << 27)
300
#define HSMCI_IMR_ACKRCV (0x1u << 28)
301
#define HSMCI_IMR_ACKRCVE (0x1u << 29)
302
#define HSMCI_IMR_OVRE (0x1u << 30)
303
#define HSMCI_IMR_UNRE (0x1u << 31)
304
/* -------- HSMCI_DMA : (HSMCI Offset: 0x50) DMA Configuration Register -------- */
305
#define HSMCI_DMA_CHKSIZE_Pos 4
306
#define HSMCI_DMA_CHKSIZE_Msk (0x7u << HSMCI_DMA_CHKSIZE_Pos)
307
#define HSMCI_DMA_CHKSIZE(value) ((HSMCI_DMA_CHKSIZE_Msk & ((value) << HSMCI_DMA_CHKSIZE_Pos)))
308
#define HSMCI_DMA_CHKSIZE_1 (0x0u << 4)
309
#define HSMCI_DMA_CHKSIZE_2 (0x1u << 4)
310
#define HSMCI_DMA_CHKSIZE_4 (0x2u << 4)
311
#define HSMCI_DMA_CHKSIZE_8 (0x3u << 4)
312
#define HSMCI_DMA_CHKSIZE_16 (0x4u << 4)
313
#define HSMCI_DMA_DMAEN (0x1u << 8)
314
/* -------- HSMCI_CFG : (HSMCI Offset: 0x54) Configuration Register -------- */
315
#define HSMCI_CFG_FIFOMODE (0x1u << 0)
316
#define HSMCI_CFG_FERRCTRL (0x1u << 4)
317
#define HSMCI_CFG_HSMODE (0x1u << 8)
318
#define HSMCI_CFG_LSYNC (0x1u << 12)
319
/* -------- HSMCI_WPMR : (HSMCI Offset: 0xE4) Write Protection Mode Register -------- */
320
#define HSMCI_WPMR_WPEN (0x1u << 0)
321
#define HSMCI_WPMR_WPKEY_Pos 8
322
#define HSMCI_WPMR_WPKEY_Msk (0xffffffu << HSMCI_WPMR_WPKEY_Pos)
323
#define HSMCI_WPMR_WPKEY(value) ((HSMCI_WPMR_WPKEY_Msk & ((value) << HSMCI_WPMR_WPKEY_Pos)))
324
#define HSMCI_WPMR_WPKEY_PASSWD (0x4D4349u << 8)
325
/* -------- HSMCI_WPSR : (HSMCI Offset: 0xE8) Write Protection Status Register -------- */
326
#define HSMCI_WPSR_WPVS (0x1u << 0)
327
#define HSMCI_WPSR_WPVSRC_Pos 8
328
#define HSMCI_WPSR_WPVSRC_Msk (0xffffu << HSMCI_WPSR_WPVSRC_Pos)
329
/* -------- HSMCI_VERSION : (HSMCI Offset: 0xFC) Version Register -------- */
330
#define HSMCI_VERSION_VERSION_Pos 0
331
#define HSMCI_VERSION_VERSION_Msk (0xfffu << HSMCI_VERSION_VERSION_Pos)
332
#define HSMCI_VERSION_MFN_Pos 16
333
#define HSMCI_VERSION_MFN_Msk (0x7u << HSMCI_VERSION_MFN_Pos)
334
/* -------- HSMCI_FIFO[256] : (HSMCI Offset: 0x200) FIFO Memory Aperture0 -------- */
335
#define HSMCI_FIFO_DATA_Pos 0
336
#define HSMCI_FIFO_DATA_Msk (0xffffffffu << HSMCI_FIFO_DATA_Pos)
337
#define HSMCI_FIFO_DATA(value) ((HSMCI_FIFO_DATA_Msk & ((value) << HSMCI_FIFO_DATA_Pos)))
338
340
341
342
#endif
/* _SAMV71_HSMCI_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Hsmci
Hsmci hardware registers.
Definition
component_hsmci.h:41
Hsmci::HSMCI_FIFO
__IO uint32_t HSMCI_FIFO[256]
(Hsmci Offset: 0x200) FIFO Memory Aperture0
Definition
component_hsmci.h:64
Hsmci::HSMCI_VERSION
__I uint32_t HSMCI_VERSION
(Hsmci Offset: 0xFC) Version Register
Definition
