RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_efc.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_EFC_COMPONENT_
31
#define _SAMV71_EFC_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__IO
uint32_t EEFC_FMR;
43
__O
uint32_t EEFC_FCR;
44
__I
uint32_t EEFC_FSR;
45
__I
uint32_t EEFC_FRR;
46
__I
uint32_t Reserved1[1];
47
__I
uint32_t
EEFC_VERSION
48
__I
uint32_t Reserved2[51];
49
__IO
uint32_t
EEFC_WPMR
50
Efc
51
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
52
/* -------- EEFC_FMR : (EFC Offset: 0x00) EEFC Flash Mode Register -------- */
53
#define EEFC_FMR_FRDY (0x1u << 0)
54
#define EEFC_FMR_FWS_Pos 8
55
#define EEFC_FMR_FWS_Msk (0xfu << EEFC_FMR_FWS_Pos)
56
#define EEFC_FMR_FWS(value) ((EEFC_FMR_FWS_Msk & ((value) << EEFC_FMR_FWS_Pos)))
57
#define EEFC_FMR_SCOD (0x1u << 16)
58
#define EEFC_FMR_CLOE (0x1u << 26)
59
/* -------- EEFC_FCR : (EFC Offset: 0x04) EEFC Flash Command Register -------- */
60
#define EEFC_FCR_FCMD_Pos 0
61
#define EEFC_FCR_FCMD_Msk (0xffu << EEFC_FCR_FCMD_Pos)
62
#define EEFC_FCR_FCMD(value) ((EEFC_FCR_FCMD_Msk & ((value) << EEFC_FCR_FCMD_Pos)))
63
#define EEFC_FCR_FCMD_GETD (0x0u << 0)
64
#define EEFC_FCR_FCMD_WP (0x1u << 0)
65
#define EEFC_FCR_FCMD_WPL (0x2u << 0)
66
#define EEFC_FCR_FCMD_EWP (0x3u << 0)
67
#define EEFC_FCR_FCMD_EWPL (0x4u << 0)
68
#define EEFC_FCR_FCMD_EA (0x5u << 0)
69
#define EEFC_FCR_FCMD_EPA (0x7u << 0)
70
#define EEFC_FCR_FCMD_SLB (0x8u << 0)
71
#define EEFC_FCR_FCMD_CLB (0x9u << 0)
72
#define EEFC_FCR_FCMD_GLB (0xAu << 0)
73
#define EEFC_FCR_FCMD_SGPB (0xBu << 0)
74
#define EEFC_FCR_FCMD_CGPB (0xCu << 0)
75
#define EEFC_FCR_FCMD_GGPB (0xDu << 0)
76
#define EEFC_FCR_FCMD_STUI (0xEu << 0)
77
#define EEFC_FCR_FCMD_SPUI (0xFu << 0)
78
#define EEFC_FCR_FCMD_GCALB (0x10u << 0)
79
#define EEFC_FCR_FCMD_ES (0x11u << 0)
80
#define EEFC_FCR_FCMD_WUS (0x12u << 0)
81
#define EEFC_FCR_FCMD_EUS (0x13u << 0)
82
#define EEFC_FCR_FCMD_STUS (0x14u << 0)
83
#define EEFC_FCR_FCMD_SPUS (0x15u << 0)
84
#define EEFC_FCR_FARG_Pos 8
85
#define EEFC_FCR_FARG_Msk (0xffffu << EEFC_FCR_FARG_Pos)
86
#define EEFC_FCR_FARG(value) ((EEFC_FCR_FARG_Msk & ((value) << EEFC_FCR_FARG_Pos)))
87
#define EEFC_FCR_FKEY_Pos 24
88
#define EEFC_FCR_FKEY_Msk (0xffu << EEFC_FCR_FKEY_Pos)
89
#define EEFC_FCR_FKEY(value) ((EEFC_FCR_FKEY_Msk & ((value) << EEFC_FCR_FKEY_Pos)))
90
#define EEFC_FCR_FKEY_PASSWD (0x5Au << 24)
91
/* -------- EEFC_FSR : (EFC Offset: 0x08) EEFC Flash Status Register -------- */
92
#define EEFC_FSR_FRDY (0x1u << 0)
93
#define EEFC_FSR_FCMDE (0x1u << 1)
94
#define EEFC_FSR_FLOCKE (0x1u << 2)
95
#define EEFC_FSR_FLERR (0x1u << 3)
96
#define EEFC_FSR_UECCELSB (0x1u << 16)
97
#define EEFC_FSR_MECCELSB (0x1u << 17)
98
#define EEFC_FSR_UECCEMSB (0x1u << 18)
99
#define EEFC_FSR_MECCEMSB (0x1u << 19)
100
/* -------- EEFC_FRR : (EFC Offset: 0x0C) EEFC Flash Result Register -------- */
101
#define EEFC_FRR_FVALUE_Pos 0
102
#define EEFC_FRR_FVALUE_Msk (0xffffffffu << EEFC_FRR_FVALUE_Pos)
103
/* -------- EEFC_VERSION : (EFC Offset: 0x14) EEFC Version Register -------- */
104
#define EEFC_VERSION_VERSION_Pos 0
105
#define EEFC_VERSION_VERSION_Msk (0xfffu << EEFC_VERSION_VERSION_Pos)
106
#define EEFC_VERSION_MFN_Pos 16
107
#define EEFC_VERSION_MFN_Msk (0x7u << EEFC_VERSION_MFN_Pos)
108
/* -------- EEFC_WPMR : (EFC Offset: 0xE4) Write Protection Mode Register -------- */
109
#define EEFC_WPMR_WPEN (0x1u << 0)
110
#define EEFC_WPMR_WPKEY_Pos 8
111
#define EEFC_WPMR_WPKEY_Msk (0xffffffu << EEFC_WPMR_WPKEY_Pos)
112
#define EEFC_WPMR_WPKEY(value) ((EEFC_WPMR_WPKEY_Msk & ((value) << EEFC_WPMR_WPKEY_Pos)))
113
#define EEFC_WPMR_WPKEY_PASSWD (0x454643u << 8)
114
116
117
118
#endif
/* _SAMV71_EFC_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Efc
Efc hardware registers.
Definition
component_efc.h:41
Efc::EEFC_VERSION
__I uint32_t EEFC_VERSION
(Efc Offset: 0x14) EEFC Version Register
Definition
component_efc.h:47
Efc::EEFC_WPMR
__IO uint32_t EEFC_WPMR
(Efc Offset: 0xE4) Write Protection Mode Register
Definition
component_efc.h:47
