RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_afec.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_AFEC_COMPONENT_
31
#define _SAMV71_AFEC_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t AFEC_CR;
43
__IO
uint32_t AFEC_MR;
44
__IO
uint32_t AFEC_EMR;
45
__IO
uint32_t AFEC_SEQ1R;
46
__IO
uint32_t AFEC_SEQ2R;
47
__O
uint32_t AFEC_CHER;
48
__O
uint32_t AFEC_CHDR;
49
__I
uint32_t AFEC_CHSR;
50
__I
uint32_t AFEC_LCDR;
51
__O
uint32_t AFEC_IER;
52
__O
uint32_t AFEC_IDR;
53
__I
uint32_t AFEC_IMR;
54
__I
uint32_t AFEC_ISR;
55
__I
uint32_t Reserved1[6];
56
__I
uint32_t AFEC_OVER;
57
__IO
uint32_t AFEC_CWR;
58
__IO
uint32_t AFEC_CGR;
59
__I
uint32_t Reserved2[2];
60
__IO
uint32_t AFEC_DIFFR;
61
__IO
uint32_t AFEC_CSELR;
62
__I
uint32_t AFEC_CDR;
63
__IO
uint32_t AFEC_COCR;
64
__IO
uint32_t AFEC_TEMPMR;
65
__IO
uint32_t AFEC_TEMPCWR;
66
__I
uint32_t Reserved3[7];
67
__IO
uint32_t AFEC_ACR;
68
__I
uint32_t Reserved4[2];
69
__IO
uint32_t AFEC_SHMR;
70
__I
uint32_t Reserved5[11];
71
__IO
uint32_t AFEC_COSR;
72
__IO
uint32_t AFEC_CVR;
73
__IO
uint32_t AFEC_CECR;
74
__I
uint32_t Reserved6[2];
75
__IO
uint32_t AFEC_WPMR;
76
__I
uint32_t AFEC_WPSR;
77
__I
uint32_t Reserved7[4];
78
__I
uint32_t
AFEC_VERSION
79
Afec
80
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
81
/* -------- AFEC_CR : (AFEC Offset: 0x00) AFEC Control Register -------- */
82
#define AFEC_CR_SWRST (0x1u << 0)
83
#define AFEC_CR_START (0x1u << 1)
84
/* -------- AFEC_MR : (AFEC Offset: 0x04) AFEC Mode Register -------- */
85
#define AFEC_MR_TRGEN (0x1u << 0)
86
#define AFEC_MR_TRGEN_DIS (0x0u << 0)
87
#define AFEC_MR_TRGEN_EN (0x1u << 0)
88
#define AFEC_MR_TRGSEL_Pos 1
89
#define AFEC_MR_TRGSEL_Msk (0x7u << AFEC_MR_TRGSEL_Pos)
90
#define AFEC_MR_TRGSEL(value) ((AFEC_MR_TRGSEL_Msk & ((value) << AFEC_MR_TRGSEL_Pos)))
91
#define AFEC_MR_TRGSEL_AFEC_TRIG0 (0x0u << 1)
92
#define AFEC_MR_TRGSEL_AFEC_TRIG1 (0x1u << 1)
93
#define AFEC_MR_TRGSEL_AFEC_TRIG2 (0x2u << 1)
94
#define AFEC_MR_TRGSEL_AFEC_TRIG3 (0x3u << 1)
95
#define AFEC_MR_TRGSEL_AFEC_TRIG4 (0x4u << 1)
96
#define AFEC_MR_TRGSEL_AFEC_TRIG5 (0x5u << 1)
97
#define AFEC_MR_TRGSEL_AFEC_TRIG6 (0x6u << 1)
98
#define AFEC_MR_SLEEP (0x1u << 5)
99
#define AFEC_MR_SLEEP_NORMAL (0x0u << 5)
100
#define AFEC_MR_SLEEP_SLEEP (0x1u << 5)
101
#define AFEC_MR_FWUP (0x1u << 6)
102
#define AFEC_MR_FWUP_OFF (0x0u << 6)
103
#define AFEC_MR_FWUP_ON (0x1u << 6)
104
#define AFEC_MR_FREERUN (0x1u << 7)
105
#define AFEC_MR_FREERUN_OFF (0x0u << 7)
106
#define AFEC_MR_FREERUN_ON (0x1u << 7)
107
#define AFEC_MR_PRESCAL_Pos 8
108
#define AFEC_MR_PRESCAL_Msk (0xffu << AFEC_MR_PRESCAL_Pos)
109
#define AFEC_MR_PRESCAL(value) ((AFEC_MR_PRESCAL_Msk & ((value) << AFEC_MR_PRESCAL_Pos)))
110
#define AFEC_MR_STARTUP_Pos 16
111
#define AFEC_MR_STARTUP_Msk (0xfu << AFEC_MR_STARTUP_Pos)
112
#define AFEC_MR_STARTUP(value) ((AFEC_MR_STARTUP_Msk & ((value) << AFEC_MR_STARTUP_Pos)))
113
#define AFEC_MR_STARTUP_SUT0 (0x0u << 16)
114
#define AFEC_MR_STARTUP_SUT8 (0x1u << 16)
115
#define AFEC_MR_STARTUP_SUT16 (0x2u << 16)
116
#define AFEC_MR_STARTUP_SUT24 (0x3u << 16)
117
#define AFEC_MR_STARTUP_SUT64 (0x4u << 16)
118
#define AFEC_MR_STARTUP_SUT80 (0x5u << 16)
119
#define AFEC_MR_STARTUP_SUT96 (0x6u << 16)
120
#define AFEC_MR_STARTUP_SUT112 (0x7u << 16)
121
#define AFEC_MR_STARTUP_SUT512 (0x8u << 16)
122
#define AFEC_MR_STARTUP_SUT576 (0x9u << 16)
123
#define AFEC_MR_STARTUP_SUT640 (0xAu << 16)
124
#define AFEC_MR_STARTUP_SUT704 (0xBu << 16)
125
#define AFEC_MR_STARTUP_SUT768 (0xCu << 16)
126
#define AFEC_MR_STARTUP_SUT832 (0xDu << 16)
127
#define AFEC_MR_STARTUP_SUT896 (0xEu << 16)
128
#define AFEC_MR_STARTUP_SUT960 (0xFu << 16)
129
#define AFEC_MR_ONE (0x1u << 23)
130
#define AFEC_MR_TRACKTIM_Pos 24
131
#define AFEC_MR_TRACKTIM_Msk (0xfu << AFEC_MR_TRACKTIM_Pos)
132
#define AFEC_MR_TRACKTIM(value) ((AFEC_MR_TRACKTIM_Msk & ((value) << AFEC_MR_TRACKTIM_Pos)))
133
#define AFEC_MR_TRANSFER_Pos 28
134
#define AFEC_MR_TRANSFER_Msk (0x3u << AFEC_MR_TRANSFER_Pos)
135
#define AFEC_MR_TRANSFER(value) ((AFEC_MR_TRANSFER_Msk & ((value) << AFEC_MR_TRANSFER_Pos)))
136
#define AFEC_MR_USEQ (0x1u << 31)
137
#define AFEC_MR_USEQ_NUM_ORDER (0x0u << 31)
138
#define AFEC_MR_USEQ_REG_ORDER (0x1u << 31)
139
/* -------- AFEC_EMR : (AFEC Offset: 0x08) AFEC Extended Mode Register -------- */
140
#define AFEC_EMR_CMPMODE_Pos 0
141
#define AFEC_EMR_CMPMODE_Msk (0x3u << AFEC_EMR_CMPMODE_Pos)
142
#define AFEC_EMR_CMPMODE(value) ((AFEC_EMR_CMPMODE_Msk & ((value) << AFEC_EMR_CMPMODE_Pos)))
143
#define AFEC_EMR_CMPMODE_LOW (0x0u << 0)
144
#define AFEC_EMR_CMPMODE_HIGH (0x1u << 0)
145
#define AFEC_EMR_CMPMODE_IN (0x2u << 0)
146
#define AFEC_EMR_CMPMODE_OUT (0x3u << 0)
147
#define AFEC_EMR_CMPSEL_Pos 3
148
#define AFEC_EMR_CMPSEL_Msk (0x1fu << AFEC_EMR_CMPSEL_Pos)
149
#define AFEC_EMR_CMPSEL(value) ((AFEC_EMR_CMPSEL_Msk & ((value) << AFEC_EMR_CMPSEL_Pos)))
150
#define AFEC_EMR_CMPALL (0x1u << 9)
151
#define AFEC_EMR_CMPFILTER_Pos 12
152
#define AFEC_EMR_CMPFILTER_Msk (0x3u << AFEC_EMR_CMPFILTER_Pos)
153
#define AFEC_EMR_CMPFILTER(value) ((AFEC_EMR_CMPFILTER_Msk & ((value) << AFEC_EMR_CMPFILTER_Pos)))
154
#define AFEC_EMR_RES_Pos 16
155
#define AFEC_EMR_RES_Msk (0x7u << AFEC_EMR_RES_Pos)
156
#define AFEC_EMR_RES(value) ((AFEC_EMR_RES_Msk & ((value) << AFEC_EMR_RES_Pos)))
157
#define AFEC_EMR_RES_NO_AVERAGE (0x0u << 16)
158
#define AFEC_EMR_RES_OSR4 (0x2u << 16)
159
#define AFEC_EMR_RES_OSR16 (0x3u << 16)
160
#define AFEC_EMR_RES_OSR64 (0x4u << 16)
161
#define AFEC_EMR_RES_OSR256 (0x5u << 16)
162
#define AFEC_EMR_TAG (0x1u << 24)
163
#define AFEC_EMR_STM (0x1u << 25)
164
#define AFEC_EMR_SIGNMODE_Pos 28
165
#define AFEC_EMR_SIGNMODE_Msk (0x3u << AFEC_EMR_SIGNMODE_Pos)
166
#define AFEC_EMR_SIGNMODE(value) ((AFEC_EMR_SIGNMODE_Msk & ((value) << AFEC_EMR_SIGNMODE_Pos)))
167
#define AFEC_EMR_SIGNMODE_SE_UNSG_DF_SIGN (0x0u << 28)
168
#define AFEC_EMR_SIGNMODE_SE_SIGN_DF_UNSG (0x1u << 28)
169
#define AFEC_EMR_SIGNMODE_ALL_UNSIGNED (0x2u << 28)
170
#define AFEC_EMR_SIGNMODE_ALL_SIGNED (0x3u << 28)
171
/* -------- AFEC_SEQ1R : (AFEC Offset: 0x0C) AFEC Channel Sequence 1 Register -------- */
172
#define AFEC_SEQ1R_USCH0_Pos 0
173
#define AFEC_SEQ1R_USCH0_Msk (0xfu << AFEC_SEQ1R_USCH0_Pos)
174
#define AFEC_SEQ1R_USCH0(value) ((AFEC_SEQ1R_USCH0_Msk & ((value) << AFEC_SEQ1R_USCH0_Pos)))
175
#define AFEC_SEQ1R_USCH1_Pos 4
176
#define AFEC_SEQ1R_USCH1_Msk (0xfu << AFEC_SEQ1R_USCH1_Pos)
177
#define AFEC_SEQ1R_USCH1(value) ((AFEC_SEQ1R_USCH1_Msk & ((value) << AFEC_SEQ1R_USCH1_Pos)))
178
#define AFEC_SEQ1R_USCH2_Pos 8
179
#define AFEC_SEQ1R_USCH2_Msk (0xfu << AFEC_SEQ1R_USCH2_Pos)
180
#define AFEC_SEQ1R_USCH2(value) ((AFEC_SEQ1R_USCH2_Msk & ((value) << AFEC_SEQ1R_USCH2_Pos)))
181
#define AFEC_SEQ1R_USCH3_Pos 12
182
#define AFEC_SEQ1R_USCH3_Msk (0xfu << AFEC_SEQ1R_USCH3_Pos)
183
#define AFEC_SEQ1R_USCH3(value) ((AFEC_SEQ1R_USCH3_Msk & ((value) << AFEC_SEQ1R_USCH3_Pos)))
184
#define AFEC_SEQ1R_USCH4_Pos 16
185
#define AFEC_SEQ1R_USCH4_Msk (0xfu << AFEC_SEQ1R_USCH4_Pos)
186
#define AFEC_SEQ1R_USCH4(value) ((AFEC_SEQ1R_USCH4_Msk & ((value) << AFEC_SEQ1R_USCH4_Pos)))
187
#define AFEC_SEQ1R_USCH5_Pos 20
188
#define AFEC_SEQ1R_USCH5_Msk (0xfu << AFEC_SEQ1R_USCH5_Pos)
189
#define AFEC_SEQ1R_USCH5(value) ((AFEC_SEQ1R_USCH5_Msk & ((value) << AFEC_SEQ1R_USCH5_Pos)))
190
#define AFEC_SEQ1R_USCH6_Pos 24
191
#define AFEC_SEQ1R_USCH6_Msk (0xfu << AFEC_SEQ1R_USCH6_Pos)
192
#define AFEC_SEQ1R_USCH6(value) ((AFEC_SEQ1R_USCH6_Msk & ((value) << AFEC_SEQ1R_USCH6_Pos)))
193
#define AFEC_SEQ1R_USCH7_Pos 28
194
#define AFEC_SEQ1R_USCH7_Msk (0xfu << AFEC_SEQ1R_USCH7_Pos)
195
#define AFEC_SEQ1R_USCH7(value) ((AFEC_SEQ1R_USCH7_Msk & ((value) << AFEC_SEQ1R_USCH7_Pos)))
196
/* -------- AFEC_SEQ2R : (AFEC Offset: 0x10) AFEC Channel Sequence 2 Register -------- */
197
#define AFEC_SEQ2R_USCH8_Pos 0
198
#define AFEC_SEQ2R_USCH8_Msk (0xfu << AFEC_SEQ2R_USCH8_Pos)
199
#define AFEC_SEQ2R_USCH8(value) ((AFEC_SEQ2R_USCH8_Msk & ((value) << AFEC_SEQ2R_USCH8_Pos)))
200
#define AFEC_SEQ2R_USCH9_Pos 4
201
#define AFEC_SEQ2R_USCH9_Msk (0xfu << AFEC_SEQ2R_USCH9_Pos)
202
#define AFEC_SEQ2R_USCH9(value) ((AFEC_SEQ2R_USCH9_Msk & ((value) << AFEC_SEQ2R_USCH9_Pos)))
203
#define AFEC_SEQ2R_USCH10_Pos 8
204
#define AFEC_SEQ2R_USCH10_Msk (0xfu << AFEC_SEQ2R_USCH10_Pos)
205
#define AFEC_SEQ2R_USCH10(value) ((AFEC_SEQ2R_USCH10_Msk & ((value) << AFEC_SEQ2R_USCH10_Pos)))
206
#define AFEC_SEQ2R_USCH11_Pos 12
207
#define AFEC_SEQ2R_USCH11_Msk (0xfu << AFEC_SEQ2R_USCH11_Pos)
208
#define AFEC_SEQ2R_USCH11(value) ((AFEC_SEQ2R_USCH11_Msk & ((value) << AFEC_SEQ2R_USCH11_Pos)))
209
#define AFEC_SEQ2R_USCH12_Pos 16
210
#define AFEC_SEQ2R_USCH12_Msk (0xfu << AFEC_SEQ2R_USCH12_Pos)
211
#define AFEC_SEQ2R_USCH12(value) ((AFEC_SEQ2R_USCH12_Msk & ((value) << AFEC_SEQ2R_USCH12_Pos)))
212
#define AFEC_SEQ2R_USCH13_Pos 20
213
#define AFEC_SEQ2R_USCH13_Msk (0xfu << AFEC_SEQ2R_USCH13_Pos)
214
#define AFEC_SEQ2R_USCH13(value) ((AFEC_SEQ2R_USCH13_Msk & ((value) << AFEC_SEQ2R_USCH13_Pos)))
215
#define AFEC_SEQ2R_USCH14_Pos 24
216
#define AFEC_SEQ2R_USCH14_Msk (0xfu << AFEC_SEQ2R_USCH14_Pos)
217
#define AFEC_SEQ2R_USCH14(value) ((AFEC_SEQ2R_USCH14_Msk & ((value) << AFEC_SEQ2R_USCH14_Pos)))
218
#define AFEC_SEQ2R_USCH15_Pos 28
219
#define AFEC_SEQ2R_USCH15_Msk (0xfu << AFEC_SEQ2R_USCH15_Pos)
220
#define AFEC_SEQ2R_USCH15(value) ((AFEC_SEQ2R_USCH15_Msk & ((value) << AFEC_SEQ2R_USCH15_Pos)))
221
/* -------- AFEC_CHER : (AFEC Offset: 0x14) AFEC Channel Enable Register -------- */
222
#define AFEC_CHER_CH0 (0x1u << 0)
223
#define AFEC_CHER_CH1 (0x1u << 1)
224
#define AFEC_CHER_CH2 (0x1u << 2)
225
#define AFEC_CHER_CH3 (0x1u << 3)
226
#define AFEC_CHER_CH4 (0x1u << 4)
227
#define AFEC_CHER_CH5 (0x1u << 5)
228
#define AFEC_CHER_CH6 (0x1u << 6)
229
#define AFEC_CHER_CH7 (0x1u << 7)
230
#define AFEC_CHER_CH8 (0x1u << 8)
231
#define AFEC_CHER_CH9 (0x1u << 9)
232
#define AFEC_CHER_CH10 (0x1u << 10)
233
#define AFEC_CHER_CH11 (0x1u << 11)
234
/* -------- AFEC_CHDR : (AFEC Offset: 0x18) AFEC Channel Disable Register -------- */
235
#define AFEC_CHDR_CH0 (0x1u << 0)
236
#define AFEC_CHDR_CH1 (0x1u << 1)
237
#define AFEC_CHDR_CH2 (0x1u << 2)
238
#define AFEC_CHDR_CH3 (0x1u << 3)
239
#define AFEC_CHDR_CH4 (0x1u << 4)
240
#define AFEC_CHDR_CH5 (0x1u << 5)
241
#define AFEC_CHDR_CH6 (0x1u << 6)
242
#define AFEC_CHDR_CH7 (0x1u << 7)
243
#define AFEC_CHDR_CH8 (0x1u << 8)
244
#define AFEC_CHDR_CH9 (0x1u << 9)
245
#define AFEC_CHDR_CH10 (0x1u << 10)
246
#define AFEC_CHDR_CH11 (0x1u << 11)
247
/* -------- AFEC_CHSR : (AFEC Offset: 0x1C) AFEC Channel Status Register -------- */
248
#define AFEC_CHSR_CH0 (0x1u << 0)
249
#define AFEC_CHSR_CH1 (0x1u << 1)
250
#define AFEC_CHSR_CH2 (0x1u << 2)
251
#define AFEC_CHSR_CH3 (0x1u << 3)
252
#define AFEC_CHSR_CH4 (0x1u << 4)
253
#define AFEC_CHSR_CH5 (0x1u << 5)
254
#define AFEC_CHSR_CH6 (0x1u << 6)
255
#define AFEC_CHSR_CH7 (0x1u << 7)
256
#define AFEC_CHSR_CH8 (0x1u << 8)
257
#define AFEC_CHSR_CH9 (0x1u << 9)
258
#define AFEC_CHSR_CH10 (0x1u << 10)
259
#define AFEC_CHSR_CH11 (0x1u << 11)
260
/* -------- AFEC_LCDR : (AFEC Offset: 0x20) AFEC Last Converted Data Register -------- */
261
#define AFEC_LCDR_LDATA_Pos 0
262
#define AFEC_LCDR_LDATA_Msk (0xffffu << AFEC_LCDR_LDATA_Pos)
263
#define AFEC_LCDR_CHNB_Pos 24
264
#define AFEC_LCDR_CHNB_Msk (0xfu << AFEC_LCDR_CHNB_Pos)
265
/* -------- AFEC_IER : (AFEC Offset: 0x24) AFEC Interrupt Enable Register -------- */
266
#define AFEC_IER_EOC0 (0x1u << 0)
267
#define AFEC_IER_EOC1 (0x1u << 1)
268
#define AFEC_IER_EOC2 (0x1u << 2)
269
#define AFEC_IER_EOC3 (0x1u << 3)
270
#define AFEC_IER_EOC4 (0x1u << 4)
271
#define AFEC_IER_EOC5 (0x1u << 5)
272
#define AFEC_IER_EOC6 (0x1u << 6)
273
#define AFEC_IER_EOC7 (0x1u << 7)
274
#define AFEC_IER_EOC8 (0x1u << 8)
275
#define AFEC_IER_EOC9 (0x1u << 9)
276
#define AFEC_IER_EOC10 (0x1u << 10)
277
#define AFEC_IER_EOC11 (0x1u << 11)
278
#define AFEC_IER_DRDY (0x1u << 24)
279
#define AFEC_IER_GOVRE (0x1u << 25)
280
#define AFEC_IER_COMPE (0x1u << 26)
281
#define AFEC_IER_TEMPCHG (0x1u << 30)
282
/* -------- AFEC_IDR : (AFEC Offset: 0x28) AFEC Interrupt Disable Register -------- */
283
#define AFEC_IDR_EOC0 (0x1u << 0)
284
#define AFEC_IDR_EOC1 (0x1u << 1)
285
#define AFEC_IDR_EOC2 (0x1u << 2)
286
#define AFEC_IDR_EOC3 (0x1u << 3)
287
#define AFEC_IDR_EOC4 (0x1u << 4)
288
#define AFEC_IDR_EOC5 (0x1u << 5)
289
#define AFEC_IDR_EOC6 (0x1u << 6)
290
#define AFEC_IDR_EOC7 (0x1u << 7)
291
#define AFEC_IDR_EOC8 (0x1u << 8)
292
#define AFEC_IDR_EOC9 (0x1u << 9)
293
#define AFEC_IDR_EOC10 (0x1u << 10)
294
#define AFEC_IDR_EOC11 (0x1u << 11)
295
#define AFEC_IDR_DRDY (0x1u << 24)
296
#define AFEC_IDR_GOVRE (0x1u << 25)
297
#define AFEC_IDR_COMPE (0x1u << 26)
298
#define AFEC_IDR_TEMPCHG (0x1u << 30)
299
/* -------- AFEC_IMR : (AFEC Offset: 0x2C) AFEC Interrupt Mask Register -------- */
300
#define AFEC_IMR_EOC0 (0x1u << 0)
301
#define AFEC_IMR_EOC1 (0x1u << 1)
302
#define AFEC_IMR_EOC2 (0x1u << 2)
303
#define AFEC_IMR_EOC3 (0x1u << 3)
304
#define AFEC_IMR_EOC4 (0x1u << 4)
305
#define AFEC_IMR_EOC5 (0x1u << 5)
306
#define AFEC_IMR_EOC6 (0x1u << 6)
307
#define AFEC_IMR_EOC7 (0x1u << 7)
308
#define AFEC_IMR_EOC8 (0x1u << 8)
309
#define AFEC_IMR_EOC9 (0x1u << 9)
310
#define AFEC_IMR_EOC10 (0x1u << 10)
311
#define AFEC_IMR_EOC11 (0x1u << 11)
312
#define AFEC_IMR_DRDY (0x1u << 24)
313
#define AFEC_IMR_GOVRE (0x1u << 25)
314
#define AFEC_IMR_COMPE (0x1u << 26)
315
#define AFEC_IMR_TEMPCHG (0x1u << 30)
316
/* -------- AFEC_ISR : (AFEC Offset: 0x30) AFEC Interrupt Status Register -------- */
317
#define AFEC_ISR_EOC0 (0x1u << 0)
318
#define AFEC_ISR_EOC1 (0x1u << 1)
319
#define AFEC_ISR_EOC2 (0x1u << 2)
320
#define AFEC_ISR_EOC3 (0x1u << 3)
321
#define AFEC_ISR_EOC4 (0x1u << 4)
322
#define AFEC_ISR_EOC5 (0x1u << 5)
323
#define AFEC_ISR_EOC6 (0x1u << 6)
324
#define AFEC_ISR_EOC7 (0x1u << 7)
325
#define AFEC_ISR_EOC8 (0x1u << 8)
326
#define AFEC_ISR_EOC9 (0x1u << 9)
327
#define AFEC_ISR_EOC10 (0x1u << 10)
328
#define AFEC_ISR_EOC11 (0x1u << 11)
329
#define AFEC_ISR_DRDY (0x1u << 24)
330
#define AFEC_ISR_GOVRE (0x1u << 25)
331
#define AFEC_ISR_COMPE (0x1u << 26)
332
#define AFEC_ISR_TEMPCHG (0x1u << 30)
333
/* -------- AFEC_OVER : (AFEC Offset: 0x4C) AFEC Overrun Status Register -------- */
334
#define AFEC_OVER_OVRE0 (0x1u << 0)
335
#define AFEC_OVER_OVRE1 (0x1u << 1)
336
#define AFEC_OVER_OVRE2 (0x1u << 2)
337
#define AFEC_OVER_OVRE3 (0x1u << 3)
338
#define AFEC_OVER_OVRE4 (0x1u << 4)
339
#define AFEC_OVER_OVRE5 (0x1u << 5)
340
#define AFEC_OVER_OVRE6 (0x1u << 6)
341
#define AFEC_OVER_OVRE7 (0x1u << 7)
342
#define AFEC_OVER_OVRE8 (0x1u << 8)
343
#define AFEC_OVER_OVRE9 (0x1u << 9)
344
#define AFEC_OVER_OVRE10 (0x1u << 10)
345
#define AFEC_OVER_OVRE11 (0x1u << 11)
346
/* -------- AFEC_CWR : (AFEC Offset: 0x50) AFEC Compare Window Register -------- */
347
#define AFEC_CWR_LOWTHRES_Pos 0
348
#define AFEC_CWR_LOWTHRES_Msk (0xffffu << AFEC_CWR_LOWTHRES_Pos)
349
#define AFEC_CWR_LOWTHRES(value) ((AFEC_CWR_LOWTHRES_Msk & ((value) << AFEC_CWR_LOWTHRES_Pos)))
350
#define AFEC_CWR_HIGHTHRES_Pos 16
351
#define AFEC_CWR_HIGHTHRES_Msk (0xffffu << AFEC_CWR_HIGHTHRES_Pos)
352
#define AFEC_CWR_HIGHTHRES(value) ((AFEC_CWR_HIGHTHRES_Msk & ((value) << AFEC_CWR_HIGHTHRES_Pos)))
353
/* -------- AFEC_CGR : (AFEC Offset: 0x54) AFEC Channel Gain Register -------- */
354
#define AFEC_CGR_GAIN0_Pos 0
355
#define AFEC_CGR_GAIN0_Msk (0x3u << AFEC_CGR_GAIN0_Pos)
356
#define AFEC_CGR_GAIN0(value) ((AFEC_CGR_GAIN0_Msk & ((value) << AFEC_CGR_GAIN0_Pos)))
357
#define AFEC_CGR_GAIN1_Pos 2
358
#define AFEC_CGR_GAIN1_Msk (0x3u << AFEC_CGR_GAIN1_Pos)
359
#define AFEC_CGR_GAIN1(value) ((AFEC_CGR_GAIN1_Msk & ((value) << AFEC_CGR_GAIN1_Pos)))
360
#define AFEC_CGR_GAIN2_Pos 4
361
#define AFEC_CGR_GAIN2_Msk (0x3u << AFEC_CGR_GAIN2_Pos)
362
#define AFEC_CGR_GAIN2(value) ((AFEC_CGR_GAIN2_Msk & ((value) << AFEC_CGR_GAIN2_Pos)))
363
#define AFEC_CGR_GAIN3_Pos 6
364
#define AFEC_CGR_GAIN3_Msk (0x3u << AFEC_CGR_GAIN3_Pos)
365
#define AFEC_CGR_GAIN3(value) ((AFEC_CGR_GAIN3_Msk & ((value) << AFEC_CGR_GAIN3_Pos)))
366
#define AFEC_CGR_GAIN4_Pos 8
367
#define AFEC_CGR_GAIN4_Msk (0x3u << AFEC_CGR_GAIN4_Pos)
368
#define AFEC_CGR_GAIN4(value) ((AFEC_CGR_GAIN4_Msk & ((value) << AFEC_CGR_GAIN4_Pos)))
369
#define AFEC_CGR_GAIN5_Pos 10
370
#define AFEC_CGR_GAIN5_Msk (0x3u << AFEC_CGR_GAIN5_Pos)
371
#define AFEC_CGR_GAIN5(value) ((AFEC_CGR_GAIN5_Msk & ((value) << AFEC_CGR_GAIN5_Pos)))
372
#define AFEC_CGR_GAIN6_Pos 12
373
#define AFEC_CGR_GAIN6_Msk (0x3u << AFEC_CGR_GAIN6_Pos)
374
#define AFEC_CGR_GAIN6(value) ((AFEC_CGR_GAIN6_Msk & ((value) << AFEC_CGR_GAIN6_Pos)))
375
#define AFEC_CGR_GAIN7_Pos 14
376
#define AFEC_CGR_GAIN7_Msk (0x3u << AFEC_CGR_GAIN7_Pos)
377
#define AFEC_CGR_GAIN7(value) ((AFEC_CGR_GAIN7_Msk & ((value) << AFEC_CGR_GAIN7_Pos)))
378
#define AFEC_CGR_GAIN8_Pos 16
379
#define AFEC_CGR_GAIN8_Msk (0x3u << AFEC_CGR_GAIN8_Pos)
380
#define AFEC_CGR_GAIN8(value) ((AFEC_CGR_GAIN8_Msk & ((value) << AFEC_CGR_GAIN8_Pos)))
381
#define AFEC_CGR_GAIN9_Pos 18
382
#define AFEC_CGR_GAIN9_Msk (0x3u << AFEC_CGR_GAIN9_Pos)
383
#define AFEC_CGR_GAIN9(value) ((AFEC_CGR_GAIN9_Msk & ((value) << AFEC_CGR_GAIN9_Pos)))
384
#define AFEC_CGR_GAIN10_Pos 20
385
#define AFEC_CGR_GAIN10_Msk (0x3u << AFEC_CGR_GAIN10_Pos)
386
#define AFEC_CGR_GAIN10(value) ((AFEC_CGR_GAIN10_Msk & ((value) << AFEC_CGR_GAIN10_Pos)))
387
#define AFEC_CGR_GAIN11_Pos 22
388
#define AFEC_CGR_GAIN11_Msk (0x3u << AFEC_CGR_GAIN11_Pos)
389
#define AFEC_CGR_GAIN11(value) ((AFEC_CGR_GAIN11_Msk & ((value) << AFEC_CGR_GAIN11_Pos)))
390
/* -------- AFEC_DIFFR : (AFEC Offset: 0x60) AFEC Channel Differential Register -------- */
391
#define AFEC_DIFFR_DIFF0 (0x1u << 0)
392
#define AFEC_DIFFR_DIFF1 (0x1u << 1)
393
#define AFEC_DIFFR_DIFF2 (0x1u << 2)
394
#define AFEC_DIFFR_DIFF3 (0x1u << 3)
395
#define AFEC_DIFFR_DIFF4 (0x1u << 4)
396
#define AFEC_DIFFR_DIFF5 (0x1u << 5)
397
#define AFEC_DIFFR_DIFF6 (0x1u << 6)
398
#define AFEC_DIFFR_DIFF7 (0x1u << 7)
399
#define AFEC_DIFFR_DIFF8 (0x1u << 8)
400
#define AFEC_DIFFR_DIFF9 (0x1u << 9)
401
#define AFEC_DIFFR_DIFF10 (0x1u << 10)
402
#define AFEC_DIFFR_DIFF11 (0x1u << 11)
403
/* -------- AFEC_CSELR : (AFEC Offset: 0x64) AFEC Channel Selection Register -------- */
404
#define AFEC_CSELR_CSEL_Pos 0
405
#define AFEC_CSELR_CSEL_Msk (0xfu << AFEC_CSELR_CSEL_Pos)
406
#define AFEC_CSELR_CSEL(value) ((AFEC_CSELR_CSEL_Msk & ((value) << AFEC_CSELR_CSEL_Pos)))
407
/* -------- AFEC_CDR : (AFEC Offset: 0x68) AFEC Channel Data Register -------- */
408
#define AFEC_CDR_DATA_Pos 0
409
#define AFEC_CDR_DATA_Msk (0xffffu << AFEC_CDR_DATA_Pos)
410
/* -------- AFEC_COCR : (AFEC Offset: 0x6C) AFEC Channel Offset Compensation Register -------- */
411
#define AFEC_COCR_AOFF_Pos 0
412
#define AFEC_COCR_AOFF_Msk (0x3ffu << AFEC_COCR_AOFF_Pos)
413
#define AFEC_COCR_AOFF(value) ((AFEC_COCR_AOFF_Msk & ((value) << AFEC_COCR_AOFF_Pos)))
414
/* -------- AFEC_TEMPMR : (AFEC Offset: 0x70) AFEC Temperature Sensor Mode Register -------- */
415
#define AFEC_TEMPMR_RTCT (0x1u << 0)
416
#define AFEC_TEMPMR_TEMPCMPMOD_Pos 4
417
#define AFEC_TEMPMR_TEMPCMPMOD_Msk (0x3u << AFEC_TEMPMR_TEMPCMPMOD_Pos)
418
#define AFEC_TEMPMR_TEMPCMPMOD(value) ((AFEC_TEMPMR_TEMPCMPMOD_Msk & ((value) << AFEC_TEMPMR_TEMPCMPMOD_Pos)))
419
#define AFEC_TEMPMR_TEMPCMPMOD_LOW (0x0u << 4)
420
#define AFEC_TEMPMR_TEMPCMPMOD_HIGH (0x1u << 4)
421
#define AFEC_TEMPMR_TEMPCMPMOD_IN (0x2u << 4)
422
#define AFEC_TEMPMR_TEMPCMPMOD_OUT (0x3u << 4)
423
/* -------- AFEC_TEMPCWR : (AFEC Offset: 0x74) AFEC Temperature Compare Window Register -------- */
424
#define AFEC_TEMPCWR_TLOWTHRES_Pos 0
425
#define AFEC_TEMPCWR_TLOWTHRES_Msk (0xffffu << AFEC_TEMPCWR_TLOWTHRES_Pos)
426
#define AFEC_TEMPCWR_TLOWTHRES(value) ((AFEC_TEMPCWR_TLOWTHRES_Msk & ((value) << AFEC_TEMPCWR_TLOWTHRES_Pos)))
427
#define AFEC_TEMPCWR_THIGHTHRES_Pos 16
428
#define AFEC_TEMPCWR_THIGHTHRES_Msk (0xffffu << AFEC_TEMPCWR_THIGHTHRES_Pos)
429
#define AFEC_TEMPCWR_THIGHTHRES(value) ((AFEC_TEMPCWR_THIGHTHRES_Msk & ((value) << AFEC_TEMPCWR_THIGHTHRES_Pos)))
430
/* -------- AFEC_ACR : (AFEC Offset: 0x94) AFEC Analog Control Register -------- */
431
#define AFEC_ACR_PGA0EN (0x1u << 2)
432
#define AFEC_ACR_PGA1EN (0x1u << 3)
433
#define AFEC_ACR_IBCTL_Pos 8
434
#define AFEC_ACR_IBCTL_Msk (0x3u << AFEC_ACR_IBCTL_Pos)
435
#define AFEC_ACR_IBCTL(value) ((AFEC_ACR_IBCTL_Msk & ((value) << AFEC_ACR_IBCTL_Pos)))
436
/* -------- AFEC_SHMR : (AFEC Offset: 0xA0) AFEC Sample & Hold Mode Register -------- */
437
#define AFEC_SHMR_DUAL0 (0x1u << 0)
438
#define AFEC_SHMR_DUAL1 (0x1u << 1)
439
#define AFEC_SHMR_DUAL2 (0x1u << 2)
440
#define AFEC_SHMR_DUAL3 (0x1u << 3)
441
#define AFEC_SHMR_DUAL4 (0x1u << 4)
442
#define AFEC_SHMR_DUAL5 (0x1u << 5)
443
#define AFEC_SHMR_DUAL6 (0x1u << 6)
444
#define AFEC_SHMR_DUAL7 (0x1u << 7)
445
#define AFEC_SHMR_DUAL8 (0x1u << 8)
446
#define AFEC_SHMR_DUAL9 (0x1u << 9)
447
#define AFEC_SHMR_DUAL10 (0x1u << 10)
448
#define AFEC_SHMR_DUAL11 (0x1u << 11)
449
/* -------- AFEC_COSR : (AFEC Offset: 0xD0) AFEC Correction Select Register -------- */
450
#define AFEC_COSR_CSEL (0x1u << 0)
451
/* -------- AFEC_CVR : (AFEC Offset: 0xD4) AFEC Correction Values Register -------- */
452
#define AFEC_CVR_OFFSETCORR_Pos 0
453
#define AFEC_CVR_OFFSETCORR_Msk (0xffffu << AFEC_CVR_OFFSETCORR_Pos)
454
#define AFEC_CVR_OFFSETCORR(value) ((AFEC_CVR_OFFSETCORR_Msk & ((value) << AFEC_CVR_OFFSETCORR_Pos)))
455
#define AFEC_CVR_GAINCORR_Pos 16
456
#define AFEC_CVR_GAINCORR_Msk (0xffffu << AFEC_CVR_GAINCORR_Pos)
457
#define AFEC_CVR_GAINCORR(value) ((AFEC_CVR_GAINCORR_Msk & ((value) << AFEC_CVR_GAINCORR_Pos)))
458
/* -------- AFEC_CECR : (AFEC Offset: 0xD8) AFEC Channel Error Correction Register -------- */
459
#define AFEC_CECR_ECORR0 (0x1u << 0)
460
#define AFEC_CECR_ECORR1 (0x1u << 1)
461
#define AFEC_CECR_ECORR2 (0x1u << 2)
462
#define AFEC_CECR_ECORR3 (0x1u << 3)
463
#define AFEC_CECR_ECORR4 (0x1u << 4)
464
#define AFEC_CECR_ECORR5 (0x1u << 5)
465
#define AFEC_CECR_ECORR6 (0x1u << 6)
466
#define AFEC_CECR_ECORR7 (0x1u << 7)
467
#define AFEC_CECR_ECORR8 (0x1u << 8)
468
#define AFEC_CECR_ECORR9 (0x1u << 9)
469
#define AFEC_CECR_ECORR10 (0x1u << 10)
470
#define AFEC_CECR_ECORR11 (0x1u << 11)
471
/* -------- AFEC_WPMR : (AFEC Offset: 0xE4) AFEC Write Protection Mode Register -------- */
472
#define AFEC_WPMR_WPEN (0x1u << 0)
473
#define AFEC_WPMR_WPKEY_Pos 8
474
#define AFEC_WPMR_WPKEY_Msk (0xffffffu << AFEC_WPMR_WPKEY_Pos)
475
#define AFEC_WPMR_WPKEY(value) ((AFEC_WPMR_WPKEY_Msk & ((value) << AFEC_WPMR_WPKEY_Pos)))
476
#define AFEC_WPMR_WPKEY_PASSWD (0x414443u << 8)
477
/* -------- AFEC_WPSR : (AFEC Offset: 0xE8) AFEC Write Protection Status Register -------- */
478
#define AFEC_WPSR_WPVS (0x1u << 0)
479
#define AFEC_WPSR_WPVSRC_Pos 8
480
#define AFEC_WPSR_WPVSRC_Msk (0xffffu << AFEC_WPSR_WPVSRC_Pos)
481
/* -------- AFEC_VERSION : (AFEC Offset: 0xFC) AFEC Version Register -------- */
482
#define AFEC_VERSION_VERSION_Pos 0
483
#define AFEC_VERSION_VERSION_Msk (0xfffu << AFEC_VERSION_VERSION_Pos)
484
#define AFEC_VERSION_MFN_Pos 16
485
#define AFEC_VERSION_MFN_Msk (0x7u << AFEC_VERSION_MFN_Pos)
486
488
489
490
#endif
/* _SAMV71_AFEC_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Afec
Afec hardware registers.
Definition
component_afec.h:41
Afec::AFEC_VERSION
__I uint32_t AFEC_VERSION
(Afec Offset: 0xFC) AFEC Version Register
Definition
component_afec.h:78
