RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
samv71
component
component_aes.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMV71_AES_COMPONENT_
31
#define _SAMV71_AES_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t AES_CR;
43
__IO
uint32_t AES_MR;
44
__I
uint32_t Reserved1[2];
45
__O
uint32_t AES_IER;
46
__O
uint32_t AES_IDR;
47
__I
uint32_t AES_IMR;
48
__I
uint32_t AES_ISR;
49
__O
uint32_t AES_KEYWR[8];
50
__O
uint32_t AES_IDATAR[4];
51
__I
uint32_t AES_ODATAR[4];
52
__O
uint32_t AES_IVR[4];
53
__IO
uint32_t AES_AADLENR;
54
__IO
uint32_t AES_CLENR;
55
__IO
uint32_t AES_GHASHR[4];
56
__I
uint32_t AES_TAGR[4];
57
__I
uint32_t AES_CTRR;
58
__IO
uint32_t AES_GCMHR[4];
59
__I
uint32_t Reserved2[20];
60
__I
uint32_t
AES_VERSION
61
Aes
62
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
63
/* -------- AES_CR : (AES Offset: 0x00) Control Register -------- */
64
#define AES_CR_START (0x1u << 0)
65
#define AES_CR_SWRST (0x1u << 8)
66
#define AES_CR_LOADSEED (0x1u << 16)
67
/* -------- AES_MR : (AES Offset: 0x04) Mode Register -------- */
68
#define AES_MR_CIPHER (0x1u << 0)
69
#define AES_MR_GTAGEN (0x1u << 1)
70
#define AES_MR_DUALBUFF (0x1u << 3)
71
#define AES_MR_DUALBUFF_INACTIVE (0x0u << 3)
72
#define AES_MR_DUALBUFF_ACTIVE (0x1u << 3)
73
#define AES_MR_PROCDLY_Pos 4
74
#define AES_MR_PROCDLY_Msk (0xfu << AES_MR_PROCDLY_Pos)
75
#define AES_MR_PROCDLY(value) ((AES_MR_PROCDLY_Msk & ((value) << AES_MR_PROCDLY_Pos)))
76
#define AES_MR_SMOD_Pos 8
77
#define AES_MR_SMOD_Msk (0x3u << AES_MR_SMOD_Pos)
78
#define AES_MR_SMOD(value) ((AES_MR_SMOD_Msk & ((value) << AES_MR_SMOD_Pos)))
79
#define AES_MR_SMOD_MANUAL_START (0x0u << 8)
80
#define AES_MR_SMOD_AUTO_START (0x1u << 8)
81
#define AES_MR_SMOD_IDATAR0_START (0x2u << 8)
82
#define AES_MR_KEYSIZE_Pos 10
83
#define AES_MR_KEYSIZE_Msk (0x3u << AES_MR_KEYSIZE_Pos)
84
#define AES_MR_KEYSIZE(value) ((AES_MR_KEYSIZE_Msk & ((value) << AES_MR_KEYSIZE_Pos)))
85
#define AES_MR_KEYSIZE_AES128 (0x0u << 10)
86
#define AES_MR_KEYSIZE_AES192 (0x1u << 10)
87
#define AES_MR_KEYSIZE_AES256 (0x2u << 10)
88
#define AES_MR_OPMOD_Pos 12
89
#define AES_MR_OPMOD_Msk (0x7u << AES_MR_OPMOD_Pos)
90
#define AES_MR_OPMOD(value) ((AES_MR_OPMOD_Msk & ((value) << AES_MR_OPMOD_Pos)))
91
#define AES_MR_OPMOD_ECB (0x0u << 12)
92
#define AES_MR_OPMOD_CBC (0x1u << 12)
93
#define AES_MR_OPMOD_OFB (0x2u << 12)
94
#define AES_MR_OPMOD_CFB (0x3u << 12)
95
#define AES_MR_OPMOD_CTR (0x4u << 12)
96
#define AES_MR_OPMOD_GCM (0x5u << 12)
97
#define AES_MR_LOD (0x1u << 15)
98
#define AES_MR_CFBS_Pos 16
99
#define AES_MR_CFBS_Msk (0x7u << AES_MR_CFBS_Pos)
100
#define AES_MR_CFBS(value) ((AES_MR_CFBS_Msk & ((value) << AES_MR_CFBS_Pos)))
101
#define AES_MR_CFBS_SIZE_128BIT (0x0u << 16)
102
#define AES_MR_CFBS_SIZE_64BIT (0x1u << 16)
103
#define AES_MR_CFBS_SIZE_32BIT (0x2u << 16)
104
#define AES_MR_CFBS_SIZE_16BIT (0x3u << 16)
105
#define AES_MR_CFBS_SIZE_8BIT (0x4u << 16)
106
#define AES_MR_CKEY_Pos 20
107
#define AES_MR_CKEY_Msk (0xfu << AES_MR_CKEY_Pos)
108
#define AES_MR_CKEY(value) ((AES_MR_CKEY_Msk & ((value) << AES_MR_CKEY_Pos)))
109
#define AES_MR_CKEY_PASSWD (0xEu << 20)
110
#define AES_MR_CMTYP1 (0x1u << 24)
111
#define AES_MR_CMTYP1_NOPROT_EXTKEY (0x0u << 24)
112
#define AES_MR_CMTYP1_PROT_EXTKEY (0x1u << 24)
113
#define AES_MR_CMTYP2 (0x1u << 25)
114
#define AES_MR_CMTYP2_NO_PAUSE (0x0u << 25)
115
#define AES_MR_CMTYP2_PAUSE (0x1u << 25)
116
#define AES_MR_CMTYP3 (0x1u << 26)
117
#define AES_MR_CMTYP3_NO_DUMMY (0x0u << 26)
118
#define AES_MR_CMTYP3_DUMMY (0x1u << 26)
119
#define AES_MR_CMTYP4 (0x1u << 27)
120
#define AES_MR_CMTYP4_NO_RESTART (0x0u << 27)
121
#define AES_MR_CMTYP4_RESTART (0x1u << 27)
122
#define AES_MR_CMTYP5 (0x1u << 28)
123
#define AES_MR_CMTYP5_NO_ADDACCESS (0x0u << 28)
124
#define AES_MR_CMTYP5_ADDACCESS (0x1u << 28)
125
#define AES_MR_CMTYP6 (0x1u << 29)
126
#define AES_MR_CMTYP6_NO_IDLECURRENT (0x0u << 29)
127
#define AES_MR_CMTYP6_IDLECURRENT (0x1u << 29)
128
/* -------- AES_IER : (AES Offset: 0x10) Interrupt Enable Register -------- */
129
#define AES_IER_DATRDY (0x1u << 0)
130
#define AES_IER_URAD (0x1u << 8)
131
#define AES_IER_TAGRDY (0x1u << 16)
132
/* -------- AES_IDR : (AES Offset: 0x14) Interrupt Disable Register -------- */
133
#define AES_IDR_DATRDY (0x1u << 0)
134
#define AES_IDR_URAD (0x1u << 8)
135
#define AES_IDR_TAGRDY (0x1u << 16)
136
/* -------- AES_IMR : (AES Offset: 0x18) Interrupt Mask Register -------- */
137
#define AES_IMR_DATRDY (0x1u << 0)
138
#define AES_IMR_URAD (0x1u << 8)
139
#define AES_IMR_TAGRDY (0x1u << 16)
140
/* -------- AES_ISR : (AES Offset: 0x1C) Interrupt Status Register -------- */
141
#define AES_ISR_DATRDY (0x1u << 0)
142
#define AES_ISR_URAD (0x1u << 8)
143
#define AES_ISR_URAT_Pos 12
144
#define AES_ISR_URAT_Msk (0xfu << AES_ISR_URAT_Pos)
145
#define AES_ISR_URAT_IDR_WR_PROCESSING (0x0u << 12)
146
#define AES_ISR_URAT_ODR_RD_PROCESSING (0x1u << 12)
147
#define AES_ISR_URAT_MR_WR_PROCESSING (0x2u << 12)
148
#define AES_ISR_URAT_ODR_RD_SUBKGEN (0x3u << 12)
149
#define AES_ISR_URAT_MR_WR_SUBKGEN (0x4u << 12)
150
#define AES_ISR_URAT_WOR_RD_ACCESS (0x5u << 12)
151
#define AES_ISR_TAGRDY (0x1u << 16)
152
/* -------- AES_KEYWR[8] : (AES Offset: 0x20) Key Word Register -------- */
153
#define AES_KEYWR_KEYW_Pos 0
154
#define AES_KEYWR_KEYW_Msk (0xffffffffu << AES_KEYWR_KEYW_Pos)
155
#define AES_KEYWR_KEYW(value) ((AES_KEYWR_KEYW_Msk & ((value) << AES_KEYWR_KEYW_Pos)))
156
/* -------- AES_IDATAR[4] : (AES Offset: 0x40) Input Data Register -------- */
157
#define AES_IDATAR_IDATA_Pos 0
158
#define AES_IDATAR_IDATA_Msk (0xffffffffu << AES_IDATAR_IDATA_Pos)
159
#define AES_IDATAR_IDATA(value) ((AES_IDATAR_IDATA_Msk & ((value) << AES_IDATAR_IDATA_Pos)))
160
/* -------- AES_ODATAR[4] : (AES Offset: 0x50) Output Data Register -------- */
161
#define AES_ODATAR_ODATA_Pos 0
162
#define AES_ODATAR_ODATA_Msk (0xffffffffu << AES_ODATAR_ODATA_Pos)
163
/* -------- AES_IVR[4] : (AES Offset: 0x60) Initialization Vector Register -------- */
164
#define AES_IVR_IV_Pos 0
165
#define AES_IVR_IV_Msk (0xffffffffu << AES_IVR_IV_Pos)
166
#define AES_IVR_IV(value) ((AES_IVR_IV_Msk & ((value) << AES_IVR_IV_Pos)))
167
/* -------- AES_AADLENR : (AES Offset: 0x70) Additional Authenticated Data Length Register -------- */
168
#define AES_AADLENR_AADLEN_Pos 0
169
#define AES_AADLENR_AADLEN_Msk (0xffffffffu << AES_AADLENR_AADLEN_Pos)
170
#define AES_AADLENR_AADLEN(value) ((AES_AADLENR_AADLEN_Msk & ((value) << AES_AADLENR_AADLEN_Pos)))
171
/* -------- AES_CLENR : (AES Offset: 0x74) Plaintext/Ciphertext Length Register -------- */
172
#define AES_CLENR_CLEN_Pos 0
173
#define AES_CLENR_CLEN_Msk (0xffffffffu << AES_CLENR_CLEN_Pos)
174
#define AES_CLENR_CLEN(value) ((AES_CLENR_CLEN_Msk & ((value) << AES_CLENR_CLEN_Pos)))
175
/* -------- AES_GHASHR[4] : (AES Offset: 0x78) GCM Intermediate Hash Word Register -------- */
176
#define AES_GHASHR_GHASH_Pos 0
177
#define AES_GHASHR_GHASH_Msk (0xffffffffu << AES_GHASHR_GHASH_Pos)
178
#define AES_GHASHR_GHASH(value) ((AES_GHASHR_GHASH_Msk & ((value) << AES_GHASHR_GHASH_Pos)))
179
/* -------- AES_TAGR[4] : (AES Offset: 0x88) GCM Authentication Tag Word Register -------- */
180
#define AES_TAGR_TAG_Pos 0
181
#define AES_TAGR_TAG_Msk (0xffffffffu << AES_TAGR_TAG_Pos)
182
/* -------- AES_CTRR : (AES Offset: 0x98) GCM Encryption Counter Value Register -------- */
183
#define AES_CTRR_CTR_Pos 0
184
#define AES_CTRR_CTR_Msk (0xffffffffu << AES_CTRR_CTR_Pos)
185
/* -------- AES_GCMHR[4] : (AES Offset: 0x9C) GCM H Word Register -------- */
186
#define AES_GCMHR_H_Pos 0
187
#define AES_GCMHR_H_Msk (0xffffffffu << AES_GCMHR_H_Pos)
188
#define AES_GCMHR_H(value) ((AES_GCMHR_H_Msk & ((value) << AES_GCMHR_H_Pos)))
189
/* -------- AES_VERSION : (AES Offset: 0xFC) Version Register -------- */
190
#define AES_VERSION_VERSION_Pos 0
191
#define AES_VERSION_VERSION_Msk (0xfffu << AES_VERSION_VERSION_Pos)
192
#define AES_VERSION_MFN_Pos 16
193
#define AES_VERSION_MFN_Msk (0x7u << AES_VERSION_MFN_Pos)
194
196
197
198
#endif
/* _SAMV71_AES_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Aes
Aes hardware registers.
Definition
component_aes.h:41
Aes::AES_VERSION
__I uint32_t AES_VERSION
(Aes Offset: 0xFC) Version Register
Definition
component_aes.h:60
