RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
sams70
sams70n21.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMS70N21_
31
#define _SAMS70N21_
32
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
46
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
47
#include <stdint.h>
48
#endif
49
50
51
/* CMSIS DEFINITIONS FOR SAMS70N21 */
52
55
57
typedef
enum
IRQn
58
59
/****** Cortex-M7 Processor Exceptions Numbers ******************************/
60
NonMaskableInt_IRQn = -14,
61
HardFault_IRQn = -13,
62
MemoryManagement_IRQn = -12,
63
BusFault_IRQn = -11,
64
UsageFault_IRQn = -10,
65
SVCall_IRQn = -5,
66
DebugMonitor_IRQn = -4,
67
PendSV_IRQn = -2,
68
SysTick_IRQn = -1,
69
/****** SAMS70N21 specific Interrupt Numbers *********************************/
70
71
SUPC_IRQn = 0,
72
RSTC_IRQn = 1,
73
RTC_IRQn = 2,
74
RTT_IRQn = 3,
75
WDT_IRQn = 4,
76
PMC_IRQn = 5,
77
EFC_IRQn = 6,
78
UART0_IRQn = 7,
79
UART1_IRQn = 8,
80
PIOA_IRQn = 10,
81
PIOB_IRQn = 11,
82
USART0_IRQn = 13,
83
USART1_IRQn = 14,
84
USART2_IRQn = 15,
85
PIOD_IRQn = 16,
86
HSMCI_IRQn = 18,
87
TWIHS0_IRQn = 19,
88
TWIHS1_IRQn = 20,
89
SPI0_IRQn = 21,
90
SSC_IRQn = 22,
91
TC0_IRQn = 23,
92
TC1_IRQn = 24,
93
TC2_IRQn = 25,
94
AFEC0_IRQn = 29,
95
DACC_IRQn = 30,
96
PWM0_IRQn = 31,
97
ICM_IRQn = 32,
98
ACC_IRQn = 33,
99
USBHS_IRQn = 34,
100
AFEC1_IRQn = 40,
101
TWIHS2_IRQn = 41,
102
SPI1_IRQn = 42,
103
QSPI_IRQn = 43,
104
UART2_IRQn = 44,
105
UART3_IRQn = 45,
106
UART4_IRQn = 46,
107
TC9_IRQn = 50,
108
TC10_IRQn = 51,
109
TC11_IRQn = 52,
110
AES_IRQn = 56,
111
TRNG_IRQn = 57,
112
XDMAC_IRQn = 58,
113
ISI_IRQn = 59,
114
PWM1_IRQn = 60,
115
RSWDT_IRQn = 63,
116
117
PERIPH_COUNT_IRQn = 64
118
IRQn_Type
119
120
typedef
struct
_DeviceVectors
121
122
/* Stack pointer */
123
void
* pvStack;
124
125
/* Cortex-M handlers */
126
void
* pfnReset_Handler;
127
void
* pfnNMI_Handler;
128
void
* pfnHardFault_Handler;
129
void
* pfnMemManage_Handler;
130
void
* pfnBusFault_Handler;
131
void
* pfnUsageFault_Handler;
132
void
* pfnReserved1_Handler;
133
void
* pfnReserved2_Handler;
134
void
* pfnReserved3_Handler;
135
void
* pfnReserved4_Handler;
136
void
* pfnSVC_Handler;
137
void
* pfnDebugMon_Handler;
138
void
* pfnReserved5_Handler;
139
void
* pfnPendSV_Handler;
140
void
* pfnSysTick_Handler;
141
142
/* Peripheral handlers */
143
void
* pfnSUPC_Handler;
/* 0 Supply Controller */
144
void
* pfnRSTC_Handler;
/* 1 Reset Controller */
145
void
* pfnRTC_Handler;
/* 2 Real Time Clock */
146
void
* pfnRTT_Handler;
/* 3 Real Time Timer */
147
void
* pfnWDT_Handler;
/* 4 Watchdog Timer */
148
void
* pfnPMC_Handler;
/* 5 Power Management Controller */
149
void
* pfnEFC_Handler;
/* 6 Enhanced Embedded Flash Controller */
150
void
* pfnUART0_Handler;
/* 7 UART 0 */
151
void
* pfnUART1_Handler;
/* 8 UART 1 */
152
void
* pvReserved9;
153
void
* pfnPIOA_Handler;
/* 10 Parallel I/O Controller A */
154
void
* pfnPIOB_Handler;
/* 11 Parallel I/O Controller B */
155
void
* pvReserved12;
156
void
* pfnUSART0_Handler;
/* 13 USART 0 */
157
void
* pfnUSART1_Handler;
/* 14 USART 1 */
158
void
* pfnUSART2_Handler;
/* 15 USART 2 */
159
void
* pfnPIOD_Handler;
/* 16 Parallel I/O Controller D */
160
void
* pvReserved17;
161
void
* pfnHSMCI_Handler;
/* 18 Multimedia Card Interface */
162
void
* pfnTWIHS0_Handler;
/* 19 Two Wire Interface 0 HS */
163
void
* pfnTWIHS1_Handler;
/* 20 Two Wire Interface 1 HS */
164
void
* pfnSPI0_Handler;
/* 21 Serial Peripheral Interface 0 */
165
void
* pfnSSC_Handler;
/* 22 Synchronous Serial Controller */
166
void
* pfnTC0_Handler;
/* 23 Timer/Counter 0 */
167
void
* pfnTC1_Handler;
/* 24 Timer/Counter 1 */
168
void
* pfnTC2_Handler;
/* 25 Timer/Counter 2 */
169
void
* pvReserved26;
170
void
* pvReserved27;
171
void
* pvReserved28;
172
void
* pfnAFEC0_Handler;
/* 29 Analog Front End 0 */
173
void
* pfnDACC_Handler;
/* 30 Digital To Analog Converter */
174
void
* pfnPWM0_Handler;
/* 31 Pulse Width Modulation 0 */
175
void
* pfnICM_Handler;
/* 32 Integrity Check Monitor */
176
void
* pfnACC_Handler;
/* 33 Analog Comparator */
177
void
* pfnUSBHS_Handler;
/* 34 USB Host / Device Controller */
178
void
* pvReserved35;
179
void
* pvReserved36;
180
void
* pvReserved37;
181
void
* pvReserved38;
182
void
* pvReserved39;
183
void
* pfnAFEC1_Handler;
/* 40 Analog Front End 1 */
184
void
* pfnTWIHS2_Handler;
/* 41 Two Wire Interface 2 HS */
185
void
* pfnSPI1_Handler;
/* 42 Serial Peripheral Interface 1 */
186
void
* pfnQSPI_Handler;
/* 43 Quad I/O Serial Peripheral Interface */
187
void
* pfnUART2_Handler;
/* 44 UART 2 */
188
void
* pfnUART3_Handler;
/* 45 UART 3 */
189
void
* pfnUART4_Handler;
/* 46 UART 4 */
190
void
* pvReserved47;
191
void
* pvReserved48;
192
void
* pvReserved49;
193
void
* pfnTC9_Handler;
/* 50 Timer/Counter 9 */
194
void
* pfnTC10_Handler;
/* 51 Timer/Counter 10 */
195
void
* pfnTC11_Handler;
/* 52 Timer/Counter 11 */
196
void
* pvReserved53;
197
void
* pvReserved54;
198
void
* pvReserved55;
199
void
* pfnAES_Handler;
/* 56 AES */
200
void
* pfnTRNG_Handler;
/* 57 True Random Generator */
201
void
* pfnXDMAC_Handler;
/* 58 DMA */
202
void
* pfnISI_Handler;
/* 59 Camera Interface */
203
void
* pfnPWM1_Handler;
/* 60 Pulse Width Modulation 1 */
204
void
* pvReserved61;
205
void
* pvReserved62;
206
void
* pfnRSWDT_Handler;
/* 63 Reinforced Secure Watchdog Timer */
207
} DeviceVectors;
208
209
/* Cortex-M7 core handlers */
210
void
Reset_Handler (
void
211
void
NMI_Handler
void
212
void
HardFault_Handler
void
213
void
MemManage_Handler
void
214
void
BusFault_Handler
void
215
void
UsageFault_Handler
void
216
void
SVC_Handler (
void
217
void
DebugMon_Handler (
void
218
void
PendSV_Handler (
void
219
void
SysTick_Handler (
void
220
221
/* Peripherals handlers */
222
void
ACC_Handler (
void
223
void
AES_Handler (
void
224
void
AFEC0_Handler (
void
225
void
AFEC1_Handler (
void
226
void
DACC_Handler (
void
227
void
EFC_Handler (
void
228
void
HSMCI_Handler (
void
229
void
ICM_Handler (
void
230
void
ISI_Handler (
void
231
void
PIOA_Handler (
void
232
void
PIOB_Handler (
void
233
void
PIOD_Handler (
void
234
void
PMC_Handler (
void
235
void
PWM0_Handler (
void
236
void
PWM1_Handler (
void
237
void
QSPI_Handler (
void
238
void
RSTC_Handler (
void
239
void
RSWDT_Handler (
void
240
void
RTC_Handler (
void
241
void
RTT_Handler (
void
242
void
SPI0_Handler (
void
243
void
SPI1_Handler (
void
244
void
SSC_Handler (
void
245
void
SUPC_Handler (
void
246
void
TC0_Handler (
void
247
void
TC1_Handler (
void
248
void
TC2_Handler (
void
249
void
TC9_Handler (
void
250
void
TC10_Handler (
void
251
void
TC11_Handler (
void
252
void
TRNG_Handler (
void
253
void
TWIHS0_Handler (
void
254
void
TWIHS1_Handler (
void
255
void
TWIHS2_Handler (
void
256
void
UART0_Handler (
void
257
void
UART1_Handler (
void
258
void
UART2_Handler (
void
259
void
UART3_Handler (
void
260
void
UART4_Handler (
void
261
void
USART0_Handler (
void
262
void
USART1_Handler (
void
263
void
USART2_Handler (
void
264
void
USBHS_Handler (
void
265
void
WDT_Handler (
void
266
void
XDMAC_Handler (
void
267
271
272
#define __CM7_REV 0x0000
273
#define __MPU_PRESENT 1
274
#define __NVIC_PRIO_BITS 3
275
#define __FPU_PRESENT 1
276
#define __FPU_DP 1
277
#define __ICACHE_PRESENT 1
278
#define __DCACHE_PRESENT 1
279
#define __DTCM_PRESENT 1
280
#define __ITCM_PRESENT 1
281
#define __Vendor_SysTickConfig 0
282
283
284
* \brief CMSIS includes
285
286
287
core_cm7.h
288
#if !defined DONT_USE_CMSIS_INIT
289
#include "system_sams70.h"
290
#endif
/* DONT_USE_CMSIS_INIT */
291
293
294
296
299
300
#include "component/component_acc.h"
301
#include "component/component_aes.h"
302
#include "component/component_afec.h"
303
#include "component/component_chipid.h"
304
#include "component/component_dacc.h"
305
#include "component/component_efc.h"
306
#include "component/component_gpbr.h"
307
#include "component/component_hsmci.h"
308
#include "component/component_icm.h"
309
#include "component/component_isi.h"
310
#include "component/component_matrix.h"
311
#include "component/component_pio.h"
312
#include "component/component_pmc.h"
313
#include "component/component_pwm.h"
314
#include "component/component_qspi.h"
315
#include "component/component_rstc.h"
316
#include "component/component_rswdt.h"
317
#include "component/component_rtc.h"
318
#include "component/component_rtt.h"
319
#include "component/component_spi.h"
320
#include "component/component_ssc.h"
321
#include "component/component_supc.h"
322
#include "component/component_tc.h"
323
#include "component/component_trng.h"
324
#include "component/component_twihs.h"
325
#include "component/component_uart.h"
326
#include "component/component_usart.h"
327
#include "component/component_usbhs.h"
328
#include "component/component_utmi.h"
329
#include "component/component_wdt.h"
330
#include "component/component_xdmac.h"
332
333
#ifndef __rtems__
334
335
/* REGISTER ACCESS DEFINITIONS FOR SAMS70N21 */
336
339
340
#include "instance/instance_hsmci.h"
341
#include "instance/instance_ssc.h"
342
#include "instance/instance_spi0.h"
343
#include "instance/instance_tc0.h"
344
#include "instance/instance_twihs0.h"
345
#include "instance/instance_twihs1.h"
346
#include "instance/instance_pwm0.h"
347
#include "instance/instance_usart0.h"
348
#include "instance/instance_usart1.h"
349
#include "instance/instance_usart2.h"
350
#include "instance/instance_usbhs.h"
351
#include "instance/instance_afec0.h"
352
#include "instance/instance_dacc.h"
353
#include "instance/instance_acc.h"
354
#include "instance/instance_icm.h"
355
#include "instance/instance_isi.h"
356
#include "instance/instance_tc3.h"
357
#include "instance/instance_spi1.h"
358
#include "instance/instance_pwm1.h"
359
#include "instance/instance_twihs2.h"
360
#include "instance/instance_afec1.h"
361
#include "instance/instance_aes.h"
362
#include "instance/instance_trng.h"
363
#include "instance/instance_xdmac.h"
364
#include "instance/instance_qspi.h"
365
#include "instance/instance_matrix.h"
366
#include "instance/instance_utmi.h"
367
#include "instance/instance_pmc.h"
368
#include "instance/instance_uart0.h"
369
#include "instance/instance_chipid.h"
370
#include "instance/instance_uart1.h"
371
#include "instance/instance_efc.h"
372
#include "instance/instance_pioa.h"
373
#include "instance/instance_piob.h"
374
#include "instance/instance_piod.h"
375
#include "instance/instance_rstc.h"
376
#include "instance/instance_supc.h"
377
#include "instance/instance_rtt.h"
378
#include "instance/instance_wdt.h"
379
#include "instance/instance_rtc.h"
380
#include "instance/instance_gpbr.h"
381
#include "instance/instance_rswdt.h"
382
#include "instance/instance_uart2.h"
383
#include "instance/instance_uart3.h"
384
#include "instance/instance_uart4.h"
386
#endif
/* __rtems__ */
387
388
389
/* PERIPHERAL ID DEFINITIONS FOR SAMS70N21 */
390
393
394
#define ID_SUPC ( 0)
395
#define ID_RSTC ( 1)
396
#define ID_RTC ( 2)
397
#define ID_RTT ( 3)
398
#define ID_WDT ( 4)
399
#define ID_PMC ( 5)
400
#define ID_EFC ( 6)
401
#define ID_UART0 ( 7)
402
#define ID_UART1 ( 8)
403
#define ID_PIOA (10)
404
#define ID_PIOB (11)
405
#define ID_USART0 (13)
406
#define ID_USART1 (14)
407
#define ID_USART2 (15)
408
#define ID_PIOD (16)
409
#define ID_HSMCI (18)
410
#define ID_TWIHS0 (19)
411
#define ID_TWIHS1 (20)
412
#define ID_SPI0 (21)
413
#define ID_SSC (22)
414
#define ID_TC0 (23)
415
#define ID_TC1 (24)
416
#define ID_TC2 (25)
417
#define ID_AFEC0 (29)
418
#define ID_DACC (30)
419
#define ID_PWM0 (31)
420
#define ID_ICM (32)
421
#define ID_ACC (33)
422
#define ID_USBHS (34)
423
#define ID_AFEC1 (40)
424
#define ID_TWIHS2 (41)
425
#define ID_SPI1 (42)
426
#define ID_QSPI (43)
427
#define ID_UART2 (44)
428
#define ID_UART3 (45)
429
#define ID_UART4 (46)
430
#define ID_TC9 (50)
431
#define ID_TC10 (51)
432
#define ID_TC11 (52)
433
#define ID_AES (56)
434
#define ID_TRNG (57)
435
#define ID_XDMAC (58)
436
#define ID_ISI (59)
437
#define ID_PWM1 (60)
438
#define ID_RSWDT (63)
439
440
#define ID_PERIPH_COUNT (64)
442
443
444
/* BASE ADDRESS DEFINITIONS FOR SAMS70N21 */
445
448
449
#if (defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
450
#define HSMCI (0x40000000U)
451
#define SSC (0x40004000U)
452
#define SPI0 (0x40008000U)
453
#define TC0 (0x4000C000U)
454
#define TWIHS0 (0x40018000U)
455
#define TWIHS1 (0x4001C000U)
456
#define PWM0 (0x40020000U)
457
#define USART0 (0x40024000U)
458
#define USART1 (0x40028000U)
459
#define USART2 (0x4002C000U)
460
#define USBHS (0x40038000U)
461
#define AFEC0 (0x4003C000U)
462
#define DACC (0x40040000U)
463
#define ACC (0x40044000U)
464
#define ICM (0x40048000U)
465
#define ISI (0x4004C000U)
466
#define TC3 (0x40054000U)
467
#define SPI1 (0x40058000U)
468
#define PWM1 (0x4005C000U)
469
#define TWIHS2 (0x40060000U)
470
#define AFEC1 (0x40064000U)
471
#define AES (0x4006C000U)
472
#define TRNG (0x40070000U)
473
#define XDMAC (0x40078000U)
474
#define QSPI (0x4007C000U)
475
#define MATRIX (0x40088000U)
476
#define UTMI (0x400E0400U)
477
#define PMC (0x400E0600U)
478
#define UART0 (0x400E0800U)
479
#define CHIPID (0x400E0940U)
480
#define UART1 (0x400E0A00U)
481
#define EFC (0x400E0C00U)
482
#define PIOA (0x400E0E00U)
483
#define PIOB (0x400E1000U)
484
#define PIOD (0x400E1400U)
485
#define RSTC (0x400E1800U)
486
#define SUPC (0x400E1810U)
487
#define RTT (0x400E1830U)
488
#define WDT (0x400E1850U)
489
#define RTC (0x400E1860U)
490
#define GPBR (0x400E1890U)
491
#define RSWDT (0x400E1900U)
492
#define UART2 (0x400E1A00U)
493
#define UART3 (0x400E1C00U)
494
#define UART4 (0x400E1E00U)
495
#else
496
#define HSMCI ((Hsmci *)0x40000000U)
497
#define SSC ((Ssc *)0x40004000U)
498
#define SPI0 ((Spi *)0x40008000U)
499
#define TC0 ((Tc *)0x4000C000U)
500
#define TWIHS0 ((Twihs *)0x40018000U)
501
#define TWIHS1 ((Twihs *)0x4001C000U)
502
#define PWM0 ((Pwm *)0x40020000U)
503
#define USART0 ((Usart *)0x40024000U)
504
#define USART1 ((Usart *)0x40028000U)
505
#define USART2 ((Usart *)0x4002C000U)
506
#define USBHS ((Usbhs *)0x40038000U)
507
#define AFEC0 ((Afec *)0x4003C000U)
508
#define DACC ((Dacc *)0x40040000U)
509
#define ACC ((Acc *)0x40044000U)
510
#define ICM ((Icm *)0x40048000U)
511
#define ISI ((Isi *)0x4004C000U)
512
#define TC3 ((Tc *)0x40054000U)
513
#define SPI1 ((Spi *)0x40058000U)
514
#define PWM1 ((Pwm *)0x4005C000U)
515
#define TWIHS2 ((Twihs *)0x40060000U)
516
#define AFEC1 ((Afec *)0x40064000U)
517
#define AES ((Aes *)0x4006C000U)
518
#define TRNG ((Trng *)0x40070000U)
519
#define XDMAC ((Xdmac *)0x40078000U)
520
#define QSPI ((Qspi *)0x4007C000U)
521
#define MATRIX ((Matrix *)0x40088000U)
522
#define UTMI ((Utmi *)0x400E0400U)
523
#define PMC ((Pmc *)0x400E0600U)
524
#define UART0 ((Uart *)0x400E0800U)
525
#define CHIPID ((Chipid *)0x400E0940U)
526
#define UART1 ((Uart *)0x400E0A00U)
527
#define EFC ((Efc *)0x400E0C00U)
528
#define PIOA ((Pio *)0x400E0E00U)
529
#define PIOB ((Pio *)0x400E1000U)
530
#define PIOD ((Pio *)0x400E1400U)
531
#define RSTC ((Rstc *)0x400E1800U)
532
#define SUPC ((Supc *)0x400E1810U)
533
#define RTT ((Rtt *)0x400E1830U)
534
#define WDT ((Wdt *)0x400E1850U)
535
#define RTC ((Rtc *)0x400E1860U)
536
#define GPBR ((Gpbr *)0x400E1890U)
537
#define RSWDT ((Rswdt *)0x400E1900U)
538
#define UART2 ((Uart *)0x400E1A00U)
539
#define UART3 ((Uart *)0x400E1C00U)
540
#define UART4 ((Uart *)0x400E1E00U)
541
#endif
/* (defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
543
544
545
/* PIO DEFINITIONS FOR SAMS70N21 */
546
549
550
#include "pio/pio_sams70n21.h"
552
553
554
/* MEMORY MAPPING DEFINITIONS FOR SAMS70N21 */
555
556
557
#define IFLASH_SIZE (0x200000u)
558
#define IFLASH_PAGE_SIZE (512u)
559
#define IFLASH_LOCK_REGION_SIZE (8192u)
560
#define IFLASH_NB_OF_PAGES (4096u)
561
#define IFLASH_NB_OF_LOCK_BITS (128u)
562
#define IRAM_SIZE (0x60000u)
563
564
#define QSPIMEM_ADDR (0x80000000u)
565
#define AXIMX_ADDR (0xA0000000u)
566
#define ITCM_ADDR (0x00000000u)
567
#define IFLASH_ADDR (0x00400000u)
568
#define IROM_ADDR (0x00800000u)
569
#define DTCM_ADDR (0x20000000u)
570
#define IRAM_ADDR (0x20400000u)
571
#define EBI_CS0_ADDR (0x60000000u)
572
#define EBI_CS1_ADDR (0x61000000u)
573
#define EBI_CS2_ADDR (0x62000000u)
574
#define EBI_CS3_ADDR (0x63000000u)
575
#define SDRAM_CS_ADDR (0x70000000u)
576
577
578
/* MISCELLANEOUS DEFINITIONS FOR SAMS70N21 */
579
580
581
#define CHIP_JTAGID (0x05B3D03FUL)
582
#define CHIP_CIDR (0xA1120E00UL)
583
#define CHIP_EXID (0x00000001UL)
584
585
586
/* ELECTRICAL DEFINITIONS FOR SAMS70N21 */
587
588
589
/* %ATMEL_ELECTRICAL% */
590
591
/* Device characteristics */
592
#define CHIP_FREQ_SLCK_RC_MIN (20000UL)
593
#define CHIP_FREQ_SLCK_RC (32000UL)
594
#define CHIP_FREQ_SLCK_RC_MAX (44000UL)
595
#define CHIP_FREQ_MAINCK_RC_4MHZ (4000000UL)
596
#define CHIP_FREQ_MAINCK_RC_8MHZ (8000000UL)
597
#define CHIP_FREQ_MAINCK_RC_12MHZ (12000000UL)
598
#define CHIP_FREQ_CPU_MAX (120000000UL)
599
#define CHIP_FREQ_XTAL_32K (32768UL)
600
#define CHIP_FREQ_XTAL_12M (12000000UL)
601
602
/* Embedded Flash Read Wait State (VDDCORE set at 1.20V) */
603
#define CHIP_FREQ_FWS_0 (20000000UL)
604
#define CHIP_FREQ_FWS_1 (40000000UL)
605
#define CHIP_FREQ_FWS_2 (60000000UL)
606
#define CHIP_FREQ_FWS_3 (80000000UL)
607
#define CHIP_FREQ_FWS_4 (100000000UL)
608
#define CHIP_FREQ_FWS_5 (123000000UL)
609
610
#ifdef __cplusplus
611
612
#endif
613
615
616
#endif
/* _SAMS70N21_ */
core_cm7.h
CMSIS Cortex-M7 Core Peripheral Access Layer Header File.
UsageFault_Handler
void UsageFault_Handler(void)
Default UsageFault interrupt handler.
Definition
exceptions.c:207
HardFault_Handler
void HardFault_Handler(void)
Default HardFault interrupt handler.
Definition
exceptions.c:168
MemManage_Handler
void MemManage_Handler(void)
Default MemManage interrupt handler.
Definition
exceptions.c:180
NMI_Handler
void NMI_Handler(void)
Default NMI interrupt handler.
Definition
exceptions.c:53
BusFault_Handler
void BusFault_Handler(void)
Default BusFault interrupt handler.
Definition
exceptions.c:193
IRQn_Type
IRQn_Type
STM32H7XX Interrupt Number Definition, according to the selected device in Library_configuration_sect...
Definition
stm32h723xx.h:49
_DeviceVectors
Definition
same70j19.h:122
