RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
sams70
component
component_twihs.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMS70_TWIHS_COMPONENT_
31
#define _SAMS70_TWIHS_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t TWIHS_CR;
43
__IO
uint32_t TWIHS_MMR;
44
__IO
uint32_t TWIHS_SMR;
45
__IO
uint32_t TWIHS_IADR;
46
__IO
uint32_t TWIHS_CWGR;
47
__I
uint32_t Reserved1[3];
48
__I
uint32_t TWIHS_SR;
49
__O
uint32_t TWIHS_IER;
50
__O
uint32_t TWIHS_IDR;
51
__I
uint32_t TWIHS_IMR;
52
__I
uint32_t TWIHS_RHR;
53
__O
uint32_t TWIHS_THR;
54
__IO
uint32_t TWIHS_SMBTR;
55
__I
uint32_t Reserved2[2];
56
__IO
uint32_t TWIHS_FILTR;
57
__I
uint32_t Reserved3[1];
58
__IO
uint32_t TWIHS_SWMR;
59
__I
uint32_t Reserved4[37];
60
__IO
uint32_t TWIHS_WPMR;
61
__I
uint32_t TWIHS_WPSR;
62
Twihs
63
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
64
/* -------- TWIHS_CR : (TWIHS Offset: 0x00) Control Register -------- */
65
#define TWIHS_CR_START (0x1u << 0)
66
#define TWIHS_CR_STOP (0x1u << 1)
67
#define TWIHS_CR_MSEN (0x1u << 2)
68
#define TWIHS_CR_MSDIS (0x1u << 3)
69
#define TWIHS_CR_SVEN (0x1u << 4)
70
#define TWIHS_CR_SVDIS (0x1u << 5)
71
#define TWIHS_CR_QUICK (0x1u << 6)
72
#define TWIHS_CR_SWRST (0x1u << 7)
73
#define TWIHS_CR_HSEN (0x1u << 8)
74
#define TWIHS_CR_HSDIS (0x1u << 9)
75
#define TWIHS_CR_SMBEN (0x1u << 10)
76
#define TWIHS_CR_SMBDIS (0x1u << 11)
77
#define TWIHS_CR_PECEN (0x1u << 12)
78
#define TWIHS_CR_PECDIS (0x1u << 13)
79
#define TWIHS_CR_PECRQ (0x1u << 14)
80
#define TWIHS_CR_CLEAR (0x1u << 15)
81
/* -------- TWIHS_MMR : (TWIHS Offset: 0x04) Master Mode Register -------- */
82
#define TWIHS_MMR_IADRSZ_Pos 8
83
#define TWIHS_MMR_IADRSZ_Msk (0x3u << TWIHS_MMR_IADRSZ_Pos)
84
#define TWIHS_MMR_IADRSZ(value) ((TWIHS_MMR_IADRSZ_Msk & ((value) << TWIHS_MMR_IADRSZ_Pos)))
85
#define TWIHS_MMR_IADRSZ_NONE (0x0u << 8)
86
#define TWIHS_MMR_IADRSZ_1_BYTE (0x1u << 8)
87
#define TWIHS_MMR_IADRSZ_2_BYTE (0x2u << 8)
88
#define TWIHS_MMR_IADRSZ_3_BYTE (0x3u << 8)
89
#define TWIHS_MMR_MREAD (0x1u << 12)
90
#define TWIHS_MMR_DADR_Pos 16
91
#define TWIHS_MMR_DADR_Msk (0x7fu << TWIHS_MMR_DADR_Pos)
92
#define TWIHS_MMR_DADR(value) ((TWIHS_MMR_DADR_Msk & ((value) << TWIHS_MMR_DADR_Pos)))
93
/* -------- TWIHS_SMR : (TWIHS Offset: 0x08) Slave Mode Register -------- */
94
#define TWIHS_SMR_NACKEN (0x1u << 0)
95
#define TWIHS_SMR_SMDA (0x1u << 2)
96
#define TWIHS_SMR_SMHH (0x1u << 3)
97
#define TWIHS_SMR_SCLWSDIS (0x1u << 6)
98
#define TWIHS_SMR_MASK_Pos 8
99
#define TWIHS_SMR_MASK_Msk (0x7fu << TWIHS_SMR_MASK_Pos)
100
#define TWIHS_SMR_MASK(value) ((TWIHS_SMR_MASK_Msk & ((value) << TWIHS_SMR_MASK_Pos)))
101
#define TWIHS_SMR_SADR_Pos 16
102
#define TWIHS_SMR_SADR_Msk (0x7fu << TWIHS_SMR_SADR_Pos)
103
#define TWIHS_SMR_SADR(value) ((TWIHS_SMR_SADR_Msk & ((value) << TWIHS_SMR_SADR_Pos)))
104
#define TWIHS_SMR_SADR1EN (0x1u << 28)
105
#define TWIHS_SMR_SADR2EN (0x1u << 29)
106
#define TWIHS_SMR_SADR3EN (0x1u << 30)
107
#define TWIHS_SMR_DATAMEN (0x1u << 31)
108
/* -------- TWIHS_IADR : (TWIHS Offset: 0x0C) Internal Address Register -------- */
109
#define TWIHS_IADR_IADR_Pos 0
110
#define TWIHS_IADR_IADR_Msk (0xffffffu << TWIHS_IADR_IADR_Pos)
111
#define TWIHS_IADR_IADR(value) ((TWIHS_IADR_IADR_Msk & ((value) << TWIHS_IADR_IADR_Pos)))
112
/* -------- TWIHS_CWGR : (TWIHS Offset: 0x10) Clock Waveform Generator Register -------- */
113
#define TWIHS_CWGR_CLDIV_Pos 0
114
#define TWIHS_CWGR_CLDIV_Msk (0xffu << TWIHS_CWGR_CLDIV_Pos)
115
#define TWIHS_CWGR_CLDIV(value) ((TWIHS_CWGR_CLDIV_Msk & ((value) << TWIHS_CWGR_CLDIV_Pos)))
116
#define TWIHS_CWGR_CHDIV_Pos 8
117
#define TWIHS_CWGR_CHDIV_Msk (0xffu << TWIHS_CWGR_CHDIV_Pos)
118
#define TWIHS_CWGR_CHDIV(value) ((TWIHS_CWGR_CHDIV_Msk & ((value) << TWIHS_CWGR_CHDIV_Pos)))
119
#define TWIHS_CWGR_CKDIV_Pos 16
120
#define TWIHS_CWGR_CKDIV_Msk (0x7u << TWIHS_CWGR_CKDIV_Pos)
121
#define TWIHS_CWGR_CKDIV(value) ((TWIHS_CWGR_CKDIV_Msk & ((value) << TWIHS_CWGR_CKDIV_Pos)))
122
#define TWIHS_CWGR_HOLD_Pos 24
123
#define TWIHS_CWGR_HOLD_Msk (0x1fu << TWIHS_CWGR_HOLD_Pos)
124
#define TWIHS_CWGR_HOLD(value) ((TWIHS_CWGR_HOLD_Msk & ((value) << TWIHS_CWGR_HOLD_Pos)))
125
/* -------- TWIHS_SR : (TWIHS Offset: 0x20) Status Register -------- */
126
#define TWIHS_SR_TXCOMP (0x1u << 0)
127
#define TWIHS_SR_RXRDY (0x1u << 1)
128
#define TWIHS_SR_TXRDY (0x1u << 2)
129
#define TWIHS_SR_SVREAD (0x1u << 3)
130
#define TWIHS_SR_SVACC (0x1u << 4)
131
#define TWIHS_SR_GACC (0x1u << 5)
132
#define TWIHS_SR_OVRE (0x1u << 6)
133
#define TWIHS_SR_UNRE (0x1u << 7)
134
#define TWIHS_SR_NACK (0x1u << 8)
135
#define TWIHS_SR_ARBLST (0x1u << 9)
136
#define TWIHS_SR_SCLWS (0x1u << 10)
137
#define TWIHS_SR_EOSACC (0x1u << 11)
138
#define TWIHS_SR_MCACK (0x1u << 16)
139
#define TWIHS_SR_TOUT (0x1u << 18)
140
#define TWIHS_SR_PECERR (0x1u << 19)
141
#define TWIHS_SR_SMBDAM (0x1u << 20)
142
#define TWIHS_SR_SMBHHM (0x1u << 21)
143
#define TWIHS_SR_SCL (0x1u << 24)
144
#define TWIHS_SR_SDA (0x1u << 25)
145
/* -------- TWIHS_IER : (TWIHS Offset: 0x24) Interrupt Enable Register -------- */
146
#define TWIHS_IER_TXCOMP (0x1u << 0)
147
#define TWIHS_IER_RXRDY (0x1u << 1)
148
#define TWIHS_IER_TXRDY (0x1u << 2)
149
#define TWIHS_IER_SVACC (0x1u << 4)
150
#define TWIHS_IER_GACC (0x1u << 5)
151
#define TWIHS_IER_OVRE (0x1u << 6)
152
#define TWIHS_IER_UNRE (0x1u << 7)
153
#define TWIHS_IER_NACK (0x1u << 8)
154
#define TWIHS_IER_ARBLST (0x1u << 9)
155
#define TWIHS_IER_SCL_WS (0x1u << 10)
156
#define TWIHS_IER_EOSACC (0x1u << 11)
157
#define TWIHS_IER_MCACK (0x1u << 16)
158
#define TWIHS_IER_TOUT (0x1u << 18)
159
#define TWIHS_IER_PECERR (0x1u << 19)
160
#define TWIHS_IER_SMBDAM (0x1u << 20)
161
#define TWIHS_IER_SMBHHM (0x1u << 21)
162
/* -------- TWIHS_IDR : (TWIHS Offset: 0x28) Interrupt Disable Register -------- */
163
#define TWIHS_IDR_TXCOMP (0x1u << 0)
164
#define TWIHS_IDR_RXRDY (0x1u << 1)
165
#define TWIHS_IDR_TXRDY (0x1u << 2)
166
#define TWIHS_IDR_SVACC (0x1u << 4)
167
#define TWIHS_IDR_GACC (0x1u << 5)
168
#define TWIHS_IDR_OVRE (0x1u << 6)
169
#define TWIHS_IDR_UNRE (0x1u << 7)
170
#define TWIHS_IDR_NACK (0x1u << 8)
171
#define TWIHS_IDR_ARBLST (0x1u << 9)
172
#define TWIHS_IDR_SCL_WS (0x1u << 10)
173
#define TWIHS_IDR_EOSACC (0x1u << 11)
174
#define TWIHS_IDR_MCACK (0x1u << 16)
175
#define TWIHS_IDR_TOUT (0x1u << 18)
176
#define TWIHS_IDR_PECERR (0x1u << 19)
177
#define TWIHS_IDR_SMBDAM (0x1u << 20)
178
#define TWIHS_IDR_SMBHHM (0x1u << 21)
179
/* -------- TWIHS_IMR : (TWIHS Offset: 0x2C) Interrupt Mask Register -------- */
180
#define TWIHS_IMR_TXCOMP (0x1u << 0)
181
#define TWIHS_IMR_RXRDY (0x1u << 1)
182
#define TWIHS_IMR_TXRDY (0x1u << 2)
183
#define TWIHS_IMR_SVACC (0x1u << 4)
184
#define TWIHS_IMR_GACC (0x1u << 5)
185
#define TWIHS_IMR_OVRE (0x1u << 6)
186
#define TWIHS_IMR_UNRE (0x1u << 7)
187
#define TWIHS_IMR_NACK (0x1u << 8)
188
#define TWIHS_IMR_ARBLST (0x1u << 9)
189
#define TWIHS_IMR_SCL_WS (0x1u << 10)
190
#define TWIHS_IMR_EOSACC (0x1u << 11)
191
#define TWIHS_IMR_MCACK (0x1u << 16)
192
#define TWIHS_IMR_TOUT (0x1u << 18)
193
#define TWIHS_IMR_PECERR (0x1u << 19)
194
#define TWIHS_IMR_SMBDAM (0x1u << 20)
195
#define TWIHS_IMR_SMBHHM (0x1u << 21)
196
/* -------- TWIHS_RHR : (TWIHS Offset: 0x30) Receive Holding Register -------- */
197
#define TWIHS_RHR_RXDATA_Pos 0
198
#define TWIHS_RHR_RXDATA_Msk (0xffu << TWIHS_RHR_RXDATA_Pos)
199
/* -------- TWIHS_THR : (TWIHS Offset: 0x34) Transmit Holding Register -------- */
200
#define TWIHS_THR_TXDATA_Pos 0
201
#define TWIHS_THR_TXDATA_Msk (0xffu << TWIHS_THR_TXDATA_Pos)
202
#define TWIHS_THR_TXDATA(value) ((TWIHS_THR_TXDATA_Msk & ((value) << TWIHS_THR_TXDATA_Pos)))
203
/* -------- TWIHS_SMBTR : (TWIHS Offset: 0x38) SMBus Timing Register -------- */
204
#define TWIHS_SMBTR_PRESC_Pos 0
205
#define TWIHS_SMBTR_PRESC_Msk (0xfu << TWIHS_SMBTR_PRESC_Pos)
206
#define TWIHS_SMBTR_PRESC(value) ((TWIHS_SMBTR_PRESC_Msk & ((value) << TWIHS_SMBTR_PRESC_Pos)))
207
#define TWIHS_SMBTR_TLOWS_Pos 8
208
#define TWIHS_SMBTR_TLOWS_Msk (0xffu << TWIHS_SMBTR_TLOWS_Pos)
209
#define TWIHS_SMBTR_TLOWS(value) ((TWIHS_SMBTR_TLOWS_Msk & ((value) << TWIHS_SMBTR_TLOWS_Pos)))
210
#define TWIHS_SMBTR_TLOWM_Pos 16
211
#define TWIHS_SMBTR_TLOWM_Msk (0xffu << TWIHS_SMBTR_TLOWM_Pos)
212
#define TWIHS_SMBTR_TLOWM(value) ((TWIHS_SMBTR_TLOWM_Msk & ((value) << TWIHS_SMBTR_TLOWM_Pos)))
213
#define TWIHS_SMBTR_THMAX_Pos 24
214
#define TWIHS_SMBTR_THMAX_Msk (0xffu << TWIHS_SMBTR_THMAX_Pos)
215
#define TWIHS_SMBTR_THMAX(value) ((TWIHS_SMBTR_THMAX_Msk & ((value) << TWIHS_SMBTR_THMAX_Pos)))
216
/* -------- TWIHS_FILTR : (TWIHS Offset: 0x44) Filter Register -------- */
217
#define TWIHS_FILTR_FILT (0x1u << 0)
218
#define TWIHS_FILTR_PADFEN (0x1u << 1)
219
#define TWIHS_FILTR_PADFCFG (0x1u << 2)
220
#define TWIHS_FILTR_THRES_Pos 8
221
#define TWIHS_FILTR_THRES_Msk (0x7u << TWIHS_FILTR_THRES_Pos)
222
#define TWIHS_FILTR_THRES(value) ((TWIHS_FILTR_THRES_Msk & ((value) << TWIHS_FILTR_THRES_Pos)))
223
/* -------- TWIHS_SWMR : (TWIHS Offset: 0x4C) SleepWalking Matching Register -------- */
224
#define TWIHS_SWMR_SADR1_Pos 0
225
#define TWIHS_SWMR_SADR1_Msk (0x7fu << TWIHS_SWMR_SADR1_Pos)
226
#define TWIHS_SWMR_SADR1(value) ((TWIHS_SWMR_SADR1_Msk & ((value) << TWIHS_SWMR_SADR1_Pos)))
227
#define TWIHS_SWMR_SADR2_Pos 8
228
#define TWIHS_SWMR_SADR2_Msk (0x7fu << TWIHS_SWMR_SADR2_Pos)
229
#define TWIHS_SWMR_SADR2(value) ((TWIHS_SWMR_SADR2_Msk & ((value) << TWIHS_SWMR_SADR2_Pos)))
230
#define TWIHS_SWMR_SADR3_Pos 16
231
#define TWIHS_SWMR_SADR3_Msk (0x7fu << TWIHS_SWMR_SADR3_Pos)
232
#define TWIHS_SWMR_SADR3(value) ((TWIHS_SWMR_SADR3_Msk & ((value) << TWIHS_SWMR_SADR3_Pos)))
233
#define TWIHS_SWMR_DATAM_Pos 24
234
#define TWIHS_SWMR_DATAM_Msk (0xffu << TWIHS_SWMR_DATAM_Pos)
235
#define TWIHS_SWMR_DATAM(value) ((TWIHS_SWMR_DATAM_Msk & ((value) << TWIHS_SWMR_DATAM_Pos)))
236
/* -------- TWIHS_WPMR : (TWIHS Offset: 0xE4) Write Protection Mode Register -------- */
237
#define TWIHS_WPMR_WPEN (0x1u << 0)
238
#define TWIHS_WPMR_WPKEY_Pos 8
239
#define TWIHS_WPMR_WPKEY_Msk (0xffffffu << TWIHS_WPMR_WPKEY_Pos)
240
#define TWIHS_WPMR_WPKEY(value) ((TWIHS_WPMR_WPKEY_Msk & ((value) << TWIHS_WPMR_WPKEY_Pos)))
241
#define TWIHS_WPMR_WPKEY_PASSWD (0x545749u << 8)
242
/* -------- TWIHS_WPSR : (TWIHS Offset: 0xE8) Write Protection Status Register -------- */
243
#define TWIHS_WPSR_WPVS (0x1u << 0)
244
#define TWIHS_WPSR_WPVSRC_Pos 8
245
#define TWIHS_WPSR_WPVSRC_Msk (0xffffffu << TWIHS_WPSR_WPVSRC_Pos)
246
248
249
250
#endif
/* _SAMS70_TWIHS_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Twihs
Twihs hardware registers.
Definition
component_twihs.h:41
