RTEMS 6.3
component_trng.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMS70_TRNG_COMPONENT_
31#define _SAMS70_TRNG_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __O uint32_t TRNG_CR;
43 __I uint32_t Reserved1[3];
44 __O uint32_t TRNG_IER;
45 __O uint32_t TRNG_IDR;
46 __I uint32_t TRNG_IMR;
47 __I uint32_t TRNG_ISR;
48 __I uint32_t Reserved2[12];
49 __I uint32_t TRNG_ODATA;
50} Trng;
51#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
52/* -------- TRNG_CR : (TRNG Offset: 0x00) Control Register -------- */
53#define TRNG_CR_ENABLE (0x1u << 0)
54#define TRNG_CR_KEY_Pos 8
55#define TRNG_CR_KEY_Msk (0xffffffu << TRNG_CR_KEY_Pos)
56#define TRNG_CR_KEY(value) ((TRNG_CR_KEY_Msk & ((value) << TRNG_CR_KEY_Pos)))
57#define TRNG_CR_KEY_PASSWD (0x524E47u << 8)
58/* -------- TRNG_IER : (TRNG Offset: 0x10) Interrupt Enable Register -------- */
59#define TRNG_IER_DATRDY (0x1u << 0)
60/* -------- TRNG_IDR : (TRNG Offset: 0x14) Interrupt Disable Register -------- */
61#define TRNG_IDR_DATRDY (0x1u << 0)
62/* -------- TRNG_IMR : (TRNG Offset: 0x18) Interrupt Mask Register -------- */
63#define TRNG_IMR_DATRDY (0x1u << 0)
64/* -------- TRNG_ISR : (TRNG Offset: 0x1C) Interrupt Status Register -------- */
65#define TRNG_ISR_DATRDY (0x1u << 0)
66/* -------- TRNG_ODATA : (TRNG Offset: 0x50) Output Data Register -------- */
67#define TRNG_ODATA_ODATA_Pos 0
68#define TRNG_ODATA_ODATA_Msk (0xffffffffu << TRNG_ODATA_ODATA_Pos)
69
71
72
73#endif /* _SAMS70_TRNG_COMPONENT_ */
#define __O
Definition core_cm4.h:238
#define __I
Definition core_cm4.h:236
Trng hardware registers.
Definition component_trng.h:41
