RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
sams70
component
component_rtc.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMS70_RTC_COMPONENT_
31
#define _SAMS70_RTC_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__IO
uint32_t RTC_CR;
43
__IO
uint32_t RTC_MR;
44
__IO
uint32_t RTC_TIMR;
45
__IO
uint32_t RTC_CALR;
46
__IO
uint32_t RTC_TIMALR;
47
__IO
uint32_t RTC_CALALR;
48
__I
uint32_t RTC_SR;
49
__O
uint32_t RTC_SCCR;
50
__O
uint32_t RTC_IER;
51
__O
uint32_t RTC_IDR;
52
__I
uint32_t RTC_IMR;
53
__I
uint32_t RTC_VER;
54
__I
uint32_t Reserved1[45];
55
__IO
uint32_t RTC_WPMR;
56
Rtc
57
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
58
/* -------- RTC_CR : (RTC Offset: 0x00) Control Register -------- */
59
#define RTC_CR_UPDTIM (0x1u << 0)
60
#define RTC_CR_UPDCAL (0x1u << 1)
61
#define RTC_CR_TIMEVSEL_Pos 8
62
#define RTC_CR_TIMEVSEL_Msk (0x3u << RTC_CR_TIMEVSEL_Pos)
63
#define RTC_CR_TIMEVSEL(value) ((RTC_CR_TIMEVSEL_Msk & ((value) << RTC_CR_TIMEVSEL_Pos)))
64
#define RTC_CR_TIMEVSEL_MINUTE (0x0u << 8)
65
#define RTC_CR_TIMEVSEL_HOUR (0x1u << 8)
66
#define RTC_CR_TIMEVSEL_MIDNIGHT (0x2u << 8)
67
#define RTC_CR_TIMEVSEL_NOON (0x3u << 8)
68
#define RTC_CR_CALEVSEL_Pos 16
69
#define RTC_CR_CALEVSEL_Msk (0x3u << RTC_CR_CALEVSEL_Pos)
70
#define RTC_CR_CALEVSEL(value) ((RTC_CR_CALEVSEL_Msk & ((value) << RTC_CR_CALEVSEL_Pos)))
71
#define RTC_CR_CALEVSEL_WEEK (0x0u << 16)
72
#define RTC_CR_CALEVSEL_MONTH (0x1u << 16)
73
#define RTC_CR_CALEVSEL_YEAR (0x2u << 16)
74
/* -------- RTC_MR : (RTC Offset: 0x04) Mode Register -------- */
75
#define RTC_MR_HRMOD (0x1u << 0)
76
#define RTC_MR_PERSIAN (0x1u << 1)
77
#define RTC_MR_NEGPPM (0x1u << 4)
78
#define RTC_MR_CORRECTION_Pos 8
79
#define RTC_MR_CORRECTION_Msk (0x7fu << RTC_MR_CORRECTION_Pos)
80
#define RTC_MR_CORRECTION(value) ((RTC_MR_CORRECTION_Msk & ((value) << RTC_MR_CORRECTION_Pos)))
81
#define RTC_MR_HIGHPPM (0x1u << 15)
82
#define RTC_MR_OUT0_Pos 16
83
#define RTC_MR_OUT0_Msk (0x7u << RTC_MR_OUT0_Pos)
84
#define RTC_MR_OUT0(value) ((RTC_MR_OUT0_Msk & ((value) << RTC_MR_OUT0_Pos)))
85
#define RTC_MR_OUT0_NO_WAVE (0x0u << 16)
86
#define RTC_MR_OUT0_FREQ1HZ (0x1u << 16)
87
#define RTC_MR_OUT0_FREQ32HZ (0x2u << 16)
88
#define RTC_MR_OUT0_FREQ64HZ (0x3u << 16)
89
#define RTC_MR_OUT0_FREQ512HZ (0x4u << 16)
90
#define RTC_MR_OUT0_ALARM_TOGGLE (0x5u << 16)
91
#define RTC_MR_OUT0_ALARM_FLAG (0x6u << 16)
92
#define RTC_MR_OUT0_PROG_PULSE (0x7u << 16)
93
#define RTC_MR_OUT1_Pos 20
94
#define RTC_MR_OUT1_Msk (0x7u << RTC_MR_OUT1_Pos)
95
#define RTC_MR_OUT1(value) ((RTC_MR_OUT1_Msk & ((value) << RTC_MR_OUT1_Pos)))
96
#define RTC_MR_OUT1_NO_WAVE (0x0u << 20)
97
#define RTC_MR_OUT1_FREQ1HZ (0x1u << 20)
98
#define RTC_MR_OUT1_FREQ32HZ (0x2u << 20)
99
#define RTC_MR_OUT1_FREQ64HZ (0x3u << 20)
100
#define RTC_MR_OUT1_FREQ512HZ (0x4u << 20)
101
#define RTC_MR_OUT1_ALARM_TOGGLE (0x5u << 20)
102
#define RTC_MR_OUT1_ALARM_FLAG (0x6u << 20)
103
#define RTC_MR_OUT1_PROG_PULSE (0x7u << 20)
104
#define RTC_MR_THIGH_Pos 24
105
#define RTC_MR_THIGH_Msk (0x7u << RTC_MR_THIGH_Pos)
106
#define RTC_MR_THIGH(value) ((RTC_MR_THIGH_Msk & ((value) << RTC_MR_THIGH_Pos)))
107
#define RTC_MR_THIGH_H_31MS (0x0u << 24)
108
#define RTC_MR_THIGH_H_16MS (0x1u << 24)
109
#define RTC_MR_THIGH_H_4MS (0x2u << 24)
110
#define RTC_MR_THIGH_H_976US (0x3u << 24)
111
#define RTC_MR_THIGH_H_488US (0x4u << 24)
112
#define RTC_MR_THIGH_H_122US (0x5u << 24)
113
#define RTC_MR_THIGH_H_30US (0x6u << 24)
114
#define RTC_MR_THIGH_H_15US (0x7u << 24)
115
#define RTC_MR_TPERIOD_Pos 28
116
#define RTC_MR_TPERIOD_Msk (0x3u << RTC_MR_TPERIOD_Pos)
117
#define RTC_MR_TPERIOD(value) ((RTC_MR_TPERIOD_Msk & ((value) << RTC_MR_TPERIOD_Pos)))
118
#define RTC_MR_TPERIOD_P_1S (0x0u << 28)
119
#define RTC_MR_TPERIOD_P_500MS (0x1u << 28)
120
#define RTC_MR_TPERIOD_P_250MS (0x2u << 28)
121
#define RTC_MR_TPERIOD_P_125MS (0x3u << 28)
122
/* -------- RTC_TIMR : (RTC Offset: 0x08) Time Register -------- */
123
#define RTC_TIMR_SEC_Pos 0
124
#define RTC_TIMR_SEC_Msk (0x7fu << RTC_TIMR_SEC_Pos)
125
#define RTC_TIMR_SEC(value) ((RTC_TIMR_SEC_Msk & ((value) << RTC_TIMR_SEC_Pos)))
126
#define RTC_TIMR_MIN_Pos 8
127
#define RTC_TIMR_MIN_Msk (0x7fu << RTC_TIMR_MIN_Pos)
128
#define RTC_TIMR_MIN(value) ((RTC_TIMR_MIN_Msk & ((value) << RTC_TIMR_MIN_Pos)))
129
#define RTC_TIMR_HOUR_Pos 16
130
#define RTC_TIMR_HOUR_Msk (0x3fu << RTC_TIMR_HOUR_Pos)
131
#define RTC_TIMR_HOUR(value) ((RTC_TIMR_HOUR_Msk & ((value) << RTC_TIMR_HOUR_Pos)))
132
#define RTC_TIMR_AMPM (0x1u << 22)
133
/* -------- RTC_CALR : (RTC Offset: 0x0C) Calendar Register -------- */
134
#define RTC_CALR_CENT_Pos 0
135
#define RTC_CALR_CENT_Msk (0x7fu << RTC_CALR_CENT_Pos)
136
#define RTC_CALR_CENT(value) ((RTC_CALR_CENT_Msk & ((value) << RTC_CALR_CENT_Pos)))
137
#define RTC_CALR_YEAR_Pos 8
138
#define RTC_CALR_YEAR_Msk (0xffu << RTC_CALR_YEAR_Pos)
139
#define RTC_CALR_YEAR(value) ((RTC_CALR_YEAR_Msk & ((value) << RTC_CALR_YEAR_Pos)))
140
#define RTC_CALR_MONTH_Pos 16
141
#define RTC_CALR_MONTH_Msk (0x1fu << RTC_CALR_MONTH_Pos)
142
#define RTC_CALR_MONTH(value) ((RTC_CALR_MONTH_Msk & ((value) << RTC_CALR_MONTH_Pos)))
143
#define RTC_CALR_DAY_Pos 21
144
#define RTC_CALR_DAY_Msk (0x7u << RTC_CALR_DAY_Pos)
145
#define RTC_CALR_DAY(value) ((RTC_CALR_DAY_Msk & ((value) << RTC_CALR_DAY_Pos)))
146
#define RTC_CALR_DATE_Pos 24
147
#define RTC_CALR_DATE_Msk (0x3fu << RTC_CALR_DATE_Pos)
148
#define RTC_CALR_DATE(value) ((RTC_CALR_DATE_Msk & ((value) << RTC_CALR_DATE_Pos)))
149
/* -------- RTC_TIMALR : (RTC Offset: 0x10) Time Alarm Register -------- */
150
#define RTC_TIMALR_SEC_Pos 0
151
#define RTC_TIMALR_SEC_Msk (0x7fu << RTC_TIMALR_SEC_Pos)
152
#define RTC_TIMALR_SEC(value) ((RTC_TIMALR_SEC_Msk & ((value) << RTC_TIMALR_SEC_Pos)))
153
#define RTC_TIMALR_SECEN (0x1u << 7)
154
#define RTC_TIMALR_MIN_Pos 8
155
#define RTC_TIMALR_MIN_Msk (0x7fu << RTC_TIMALR_MIN_Pos)
156
#define RTC_TIMALR_MIN(value) ((RTC_TIMALR_MIN_Msk & ((value) << RTC_TIMALR_MIN_Pos)))
157
#define RTC_TIMALR_MINEN (0x1u << 15)
158
#define RTC_TIMALR_HOUR_Pos 16
159
#define RTC_TIMALR_HOUR_Msk (0x3fu << RTC_TIMALR_HOUR_Pos)
160
#define RTC_TIMALR_HOUR(value) ((RTC_TIMALR_HOUR_Msk & ((value) << RTC_TIMALR_HOUR_Pos)))
161
#define RTC_TIMALR_AMPM (0x1u << 22)
162
#define RTC_TIMALR_HOUREN (0x1u << 23)
163
/* -------- RTC_CALALR : (RTC Offset: 0x14) Calendar Alarm Register -------- */
164
#define RTC_CALALR_MONTH_Pos 16
165
#define RTC_CALALR_MONTH_Msk (0x1fu << RTC_CALALR_MONTH_Pos)
166
#define RTC_CALALR_MONTH(value) ((RTC_CALALR_MONTH_Msk & ((value) << RTC_CALALR_MONTH_Pos)))
167
#define RTC_CALALR_MTHEN (0x1u << 23)
168
#define RTC_CALALR_DATE_Pos 24
169
#define RTC_CALALR_DATE_Msk (0x3fu << RTC_CALALR_DATE_Pos)
170
#define RTC_CALALR_DATE(value) ((RTC_CALALR_DATE_Msk & ((value) << RTC_CALALR_DATE_Pos)))
171
#define RTC_CALALR_DATEEN (0x1u << 31)
172
/* -------- RTC_SR : (RTC Offset: 0x18) Status Register -------- */
173
#define RTC_SR_ACKUPD (0x1u << 0)
174
#define RTC_SR_ACKUPD_FREERUN (0x0u << 0)
175
#define RTC_SR_ACKUPD_UPDATE (0x1u << 0)
176
#define RTC_SR_ALARM (0x1u << 1)
177
#define RTC_SR_ALARM_NO_ALARMEVENT (0x0u << 1)
178
#define RTC_SR_ALARM_ALARMEVENT (0x1u << 1)
179
#define RTC_SR_SEC (0x1u << 2)
180
#define RTC_SR_SEC_NO_SECEVENT (0x0u << 2)
181
#define RTC_SR_SEC_SECEVENT (0x1u << 2)
182
#define RTC_SR_TIMEV (0x1u << 3)
183
#define RTC_SR_TIMEV_NO_TIMEVENT (0x0u << 3)
184
#define RTC_SR_TIMEV_TIMEVENT (0x1u << 3)
185
#define RTC_SR_CALEV (0x1u << 4)
186
#define RTC_SR_CALEV_NO_CALEVENT (0x0u << 4)
187
#define RTC_SR_CALEV_CALEVENT (0x1u << 4)
188
#define RTC_SR_TDERR (0x1u << 5)
189
#define RTC_SR_TDERR_CORRECT (0x0u << 5)
190
#define RTC_SR_TDERR_ERR_TIMEDATE (0x1u << 5)
191
/* -------- RTC_SCCR : (RTC Offset: 0x1C) Status Clear Command Register -------- */
192
#define RTC_SCCR_ACKCLR (0x1u << 0)
193
#define RTC_SCCR_ALRCLR (0x1u << 1)
194
#define RTC_SCCR_SECCLR (0x1u << 2)
195
#define RTC_SCCR_TIMCLR (0x1u << 3)
196
#define RTC_SCCR_CALCLR (0x1u << 4)
197
#define RTC_SCCR_TDERRCLR (0x1u << 5)
198
/* -------- RTC_IER : (RTC Offset: 0x20) Interrupt Enable Register -------- */
199
#define RTC_IER_ACKEN (0x1u << 0)
200
#define RTC_IER_ALREN (0x1u << 1)
201
#define RTC_IER_SECEN (0x1u << 2)
202
#define RTC_IER_TIMEN (0x1u << 3)
203
#define RTC_IER_CALEN (0x1u << 4)
204
#define RTC_IER_TDERREN (0x1u << 5)
205
/* -------- RTC_IDR : (RTC Offset: 0x24) Interrupt Disable Register -------- */
206
#define RTC_IDR_ACKDIS (0x1u << 0)
207
#define RTC_IDR_ALRDIS (0x1u << 1)
208
#define RTC_IDR_SECDIS (0x1u << 2)
209
#define RTC_IDR_TIMDIS (0x1u << 3)
210
#define RTC_IDR_CALDIS (0x1u << 4)
211
#define RTC_IDR_TDERRDIS (0x1u << 5)
212
/* -------- RTC_IMR : (RTC Offset: 0x28) Interrupt Mask Register -------- */
213
#define RTC_IMR_ACK (0x1u << 0)
214
#define RTC_IMR_ALR (0x1u << 1)
215
#define RTC_IMR_SEC (0x1u << 2)
216
#define RTC_IMR_TIM (0x1u << 3)
217
#define RTC_IMR_CAL (0x1u << 4)
218
#define RTC_IMR_TDERR (0x1u << 5)
219
/* -------- RTC_VER : (RTC Offset: 0x2C) Valid Entry Register -------- */
220
#define RTC_VER_NVTIM (0x1u << 0)
221
#define RTC_VER_NVCAL (0x1u << 1)
222
#define RTC_VER_NVTIMALR (0x1u << 2)
223
#define RTC_VER_NVCALALR (0x1u << 3)
224
/* -------- RTC_WPMR : (RTC Offset: 0xE4) Write Protection Mode Register -------- */
225
#define RTC_WPMR_WPEN (0x1u << 0)
226
#define RTC_WPMR_WPKEY_Pos 8
227
#define RTC_WPMR_WPKEY_Msk (0xffffffu << RTC_WPMR_WPKEY_Pos)
228
#define RTC_WPMR_WPKEY(value) ((RTC_WPMR_WPKEY_Msk & ((value) << RTC_WPMR_WPKEY_Pos)))
229
#define RTC_WPMR_WPKEY_PASSWD (0x525443u << 8)
230
232
233
234
#endif
/* _SAMS70_RTC_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Rtc
Rtc hardware registers.
Definition
component_rtc.h:41
