RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
sams70
component
component_rswdt.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMS70_RSWDT_COMPONENT_
31
#define _SAMS70_RSWDT_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t RSWDT_CR;
43
__IO
uint32_t RSWDT_MR;
44
__I
uint32_t RSWDT_SR;
45
Rswdt
46
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
47
/* -------- RSWDT_CR : (RSWDT Offset: 0x00) Control Register -------- */
48
#define RSWDT_CR_WDRSTT (0x1u << 0)
49
#define RSWDT_CR_KEY_Pos 24
50
#define RSWDT_CR_KEY_Msk (0xffu << RSWDT_CR_KEY_Pos)
51
#define RSWDT_CR_KEY(value) ((RSWDT_CR_KEY_Msk & ((value) << RSWDT_CR_KEY_Pos)))
52
#define RSWDT_CR_KEY_PASSWD (0xC4u << 24)
53
/* -------- RSWDT_MR : (RSWDT Offset: 0x04) Mode Register -------- */
54
#define RSWDT_MR_WDV_Pos 0
55
#define RSWDT_MR_WDV_Msk (0xfffu << RSWDT_MR_WDV_Pos)
56
#define RSWDT_MR_WDV(value) ((RSWDT_MR_WDV_Msk & ((value) << RSWDT_MR_WDV_Pos)))
57
#define RSWDT_MR_WDFIEN (0x1u << 12)
58
#define RSWDT_MR_WDRSTEN (0x1u << 13)
59
#define RSWDT_MR_WDRPROC (0x1u << 14)
60
#define RSWDT_MR_WDDIS (0x1u << 15)
61
#define RSWDT_MR_ALLONES_Pos 16
62
#define RSWDT_MR_ALLONES_Msk (0xfffu << RSWDT_MR_ALLONES_Pos)
63
#define RSWDT_MR_ALLONES(value) ((RSWDT_MR_ALLONES_Msk & ((value) << RSWDT_MR_ALLONES_Pos)))
64
#define RSWDT_MR_WDDBGHLT (0x1u << 28)
65
#define RSWDT_MR_WDIDLEHLT (0x1u << 29)
66
/* -------- RSWDT_SR : (RSWDT Offset: 0x08) Status Register -------- */
67
#define RSWDT_SR_WDUNF (0x1u << 0)
68
70
71
72
#endif
/* _SAMS70_RSWDT_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Rswdt
Rswdt hardware registers.
Definition
component_rswdt.h:41
