RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
sams70
component
component_rstc.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMS70_RSTC_COMPONENT_
31
#define _SAMS70_RSTC_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t RSTC_CR;
43
__I
uint32_t RSTC_SR;
44
__IO
uint32_t RSTC_MR;
45
Rstc
46
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
47
/* -------- RSTC_CR : (RSTC Offset: 0x00) Control Register -------- */
48
#define RSTC_CR_PROCRST (0x1u << 0)
49
#define RSTC_CR_EXTRST (0x1u << 3)
50
#define RSTC_CR_KEY_Pos 24
51
#define RSTC_CR_KEY_Msk (0xffu << RSTC_CR_KEY_Pos)
52
#define RSTC_CR_KEY(value) ((RSTC_CR_KEY_Msk & ((value) << RSTC_CR_KEY_Pos)))
53
#define RSTC_CR_KEY_PASSWD (0xA5u << 24)
54
/* -------- RSTC_SR : (RSTC Offset: 0x04) Status Register -------- */
55
#define RSTC_SR_URSTS (0x1u << 0)
56
#define RSTC_SR_RSTTYP_Pos 8
57
#define RSTC_SR_RSTTYP_Msk (0x7u << RSTC_SR_RSTTYP_Pos)
58
#define RSTC_SR_RSTTYP_GENERAL_RST (0x0u << 8)
59
#define RSTC_SR_RSTTYP_BACKUP_RST (0x1u << 8)
60
#define RSTC_SR_RSTTYP_WDT_RST (0x2u << 8)
61
#define RSTC_SR_RSTTYP_SOFT_RST (0x3u << 8)
62
#define RSTC_SR_RSTTYP_USER_RST (0x4u << 8)
63
#define RSTC_SR_NRSTL (0x1u << 16)
64
#define RSTC_SR_SRCMP (0x1u << 17)
65
/* -------- RSTC_MR : (RSTC Offset: 0x08) Mode Register -------- */
66
#define RSTC_MR_URSTEN (0x1u << 0)
67
#define RSTC_MR_URSTIEN (0x1u << 4)
68
#define RSTC_MR_ERSTL_Pos 8
69
#define RSTC_MR_ERSTL_Msk (0xfu << RSTC_MR_ERSTL_Pos)
70
#define RSTC_MR_ERSTL(value) ((RSTC_MR_ERSTL_Msk & ((value) << RSTC_MR_ERSTL_Pos)))
71
#define RSTC_MR_KEY_Pos 24
72
#define RSTC_MR_KEY_Msk (0xffu << RSTC_MR_KEY_Pos)
73
#define RSTC_MR_KEY(value) ((RSTC_MR_KEY_Msk & ((value) << RSTC_MR_KEY_Pos)))
74
#define RSTC_MR_KEY_PASSWD (0xA5u << 24)
75
77
78
79
#endif
/* _SAMS70_RSTC_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Rstc
Rstc hardware registers.
Definition
component_rstc.h:41
