RTEMS 6.3
component_pmc.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAMS70_PMC_COMPONENT_
31#define _SAMS70_PMC_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __O uint32_t PMC_SCER;
43 __O uint32_t PMC_SCDR;
44 __I uint32_t PMC_SCSR;
45 __I uint32_t Reserved1[1];
46 __O uint32_t PMC_PCER0;
47 __O uint32_t PMC_PCDR0;
48 __I uint32_t PMC_PCSR0;
49 __IO uint32_t CKGR_UCKR;
50 __IO uint32_t CKGR_MOR;
51 __IO uint32_t CKGR_MCFR;
52 __IO uint32_t CKGR_PLLAR;
53 __I uint32_t Reserved2[1];
54 __IO uint32_t PMC_MCKR;
55 __I uint32_t Reserved3[1];
56 __IO uint32_t PMC_USB;
57 __I uint32_t Reserved4[1];
58 __IO uint32_t PMC_PCK0;
59 __IO uint32_t PMC_PCK1;
60 __IO uint32_t PMC_PCK2;
61 __IO uint32_t PMC_PCK3;
62 __IO uint32_t PMC_PCK4;
63 __I uint32_t Reserved5[1];
64 __IO uint32_t PMC_PCK6;
65 __I uint32_t Reserved6[1];
66 __O uint32_t PMC_IER;
67 __O uint32_t PMC_IDR;
68 __I uint32_t PMC_SR;
69 __I uint32_t PMC_IMR;
70 __IO uint32_t PMC_FSMR;
71 __IO uint32_t PMC_FSPR;
72 __O uint32_t PMC_FOCR;
73 __I uint32_t Reserved7[26];
74 __IO uint32_t PMC_WPMR;
75 __I uint32_t PMC_WPSR;
76 __I uint32_t Reserved8[5];
77 __O uint32_t PMC_PCER1;
78 __O uint32_t PMC_PCDR1;
79 __I uint32_t PMC_PCSR1;
80 __IO uint32_t PMC_PCR;
81 __IO uint32_t PMC_OCR;
82 __O uint32_t PMC_SLPWK_ER0;
83 __O uint32_t PMC_SLPWK_DR0;
84 __I uint32_t PMC_SLPWK_SR0;
85 __I uint32_t PMC_SLPWK_ASR0;
86 __I uint32_t Reserved9[3];
87 __IO uint32_t PMC_PMMR;
88 __O uint32_t PMC_SLPWK_ER1;
89 __O uint32_t PMC_SLPWK_DR1;
90 __I uint32_t PMC_SLPWK_SR1;
91 __I uint32_t PMC_SLPWK_ASR1;
92 __I uint32_t PMC_SLPWK_AIPR;
93} Pmc;
94#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
95/* -------- PMC_SCER : (PMC Offset: 0x0000) System Clock Enable Register -------- */
96#define PMC_SCER_USBCLK (0x1u << 5)
97#define PMC_SCER_PCK0 (0x1u << 8)
98#define PMC_SCER_PCK1 (0x1u << 9)
99#define PMC_SCER_PCK2 (0x1u << 10)
100#define PMC_SCER_PCK3 (0x1u << 11)
101#define PMC_SCER_PCK4 (0x1u << 12)
102#define PMC_SCER_PCK6 (0x1u << 14)
103/* -------- PMC_SCDR : (PMC Offset: 0x0004) System Clock Disable Register -------- */
104#define PMC_SCDR_USBCLK (0x1u << 5)
105#define PMC_SCDR_PCK0 (0x1u << 8)
106#define PMC_SCDR_PCK1 (0x1u << 9)
107#define PMC_SCDR_PCK2 (0x1u << 10)
108#define PMC_SCDR_PCK3 (0x1u << 11)
109#define PMC_SCDR_PCK4 (0x1u << 12)
110#define PMC_SCDR_PCK6 (0x1u << 14)
111/* -------- PMC_SCSR : (PMC Offset: 0x0008) System Clock Status Register -------- */
112#define PMC_SCSR_USBCLK (0x1u << 5)
113#define PMC_SCSR_PCK0 (0x1u << 8)
114#define PMC_SCSR_PCK1 (0x1u << 9)
115#define PMC_SCSR_PCK2 (0x1u << 10)
116#define PMC_SCSR_PCK3 (0x1u << 11)
117#define PMC_SCSR_PCK4 (0x1u << 12)
118#define PMC_SCSR_PCK6 (0x1u << 14)
119/* -------- PMC_PCER0 : (PMC Offset: 0x0010) Peripheral Clock Enable Register 0 -------- */
120#define PMC_PCER0_PID7 (0x1u << 7)
121#define PMC_PCER0_PID8 (0x1u << 8)
122#define PMC_PCER0_PID9 (0x1u << 9)
123#define PMC_PCER0_PID10 (0x1u << 10)
124#define PMC_PCER0_PID11 (0x1u << 11)
125#define PMC_PCER0_PID12 (0x1u << 12)
126#define PMC_PCER0_PID13 (0x1u << 13)
127#define PMC_PCER0_PID14 (0x1u << 14)
128#define PMC_PCER0_PID15 (0x1u << 15)
129#define PMC_PCER0_PID16 (0x1u << 16)
130#define PMC_PCER0_PID17 (0x1u << 17)
131#define PMC_PCER0_PID18 (0x1u << 18)
132#define PMC_PCER0_PID19 (0x1u << 19)
133#define PMC_PCER0_PID20 (0x1u << 20)
134#define PMC_PCER0_PID21 (0x1u << 21)
135#define PMC_PCER0_PID22 (0x1u << 22)
136#define PMC_PCER0_PID23 (0x1u << 23)
137#define PMC_PCER0_PID24 (0x1u << 24)
138#define PMC_PCER0_PID25 (0x1u << 25)
139#define PMC_PCER0_PID26 (0x1u << 26)
140#define PMC_PCER0_PID27 (0x1u << 27)
141#define PMC_PCER0_PID28 (0x1u << 28)
142#define PMC_PCER0_PID29 (0x1u << 29)
143#define PMC_PCER0_PID30 (0x1u << 30)
144#define PMC_PCER0_PID31 (0x1u << 31)
145/* -------- PMC_PCDR0 : (PMC Offset: 0x0014) Peripheral Clock Disable Register 0 -------- */
146#define PMC_PCDR0_PID7 (0x1u << 7)
147#define PMC_PCDR0_PID8 (0x1u << 8)
148#define PMC_PCDR0_PID9 (0x1u << 9)
149#define PMC_PCDR0_PID10 (0x1u << 10)
150#define PMC_PCDR0_PID11 (0x1u << 11)
151#define PMC_PCDR0_PID12 (0x1u << 12)
152#define PMC_PCDR0_PID13 (0x1u << 13)
153#define PMC_PCDR0_PID14 (0x1u << 14)
154#define PMC_PCDR0_PID15 (0x1u << 15)
155#define PMC_PCDR0_PID16 (0x1u << 16)
156#define PMC_PCDR0_PID17 (0x1u << 17)
157#define PMC_PCDR0_PID18 (0x1u << 18)
158#define PMC_PCDR0_PID19 (0x1u << 19)
159#define PMC_PCDR0_PID20 (0x1u << 20)
160#define PMC_PCDR0_PID21 (0x1u << 21)
161#define PMC_PCDR0_PID22 (0x1u << 22)
162#define PMC_PCDR0_PID23 (0x1u << 23)
163#define PMC_PCDR0_PID24 (0x1u << 24)
164#define PMC_PCDR0_PID25 (0x1u << 25)
165#define PMC_PCDR0_PID26 (0x1u << 26)
166#define PMC_PCDR0_PID27 (0x1u << 27)
167#define PMC_PCDR0_PID28 (0x1u << 28)
168#define PMC_PCDR0_PID29 (0x1u << 29)
169#define PMC_PCDR0_PID30 (0x1u << 30)
170#define PMC_PCDR0_PID31 (0x1u << 31)
171/* -------- PMC_PCSR0 : (PMC Offset: 0x0018) Peripheral Clock Status Register 0 -------- */
172#define PMC_PCSR0_PID7 (0x1u << 7)
173#define PMC_PCSR0_PID8 (0x1u << 8)
174#define PMC_PCSR0_PID9 (0x1u << 9)
175#define PMC_PCSR0_PID10 (0x1u << 10)
176#define PMC_PCSR0_PID11 (0x1u << 11)
177#define PMC_PCSR0_PID12 (0x1u << 12)
178#define PMC_PCSR0_PID13 (0x1u << 13)
179#define PMC_PCSR0_PID14 (0x1u << 14)
180#define PMC_PCSR0_PID15 (0x1u << 15)
181#define PMC_PCSR0_PID16 (0x1u << 16)
182#define PMC_PCSR0_PID17 (0x1u << 17)
183#define PMC_PCSR0_PID18 (0x1u << 18)
184#define PMC_PCSR0_PID19 (0x1u << 19)
185#define PMC_PCSR0_PID20 (0x1u << 20)
186#define PMC_PCSR0_PID21 (0x1u << 21)
187#define PMC_PCSR0_PID22 (0x1u << 22)
188#define PMC_PCSR0_PID23 (0x1u << 23)
189#define PMC_PCSR0_PID24 (0x1u << 24)
190#define PMC_PCSR0_PID25 (0x1u << 25)
191#define PMC_PCSR0_PID26 (0x1u << 26)
192#define PMC_PCSR0_PID27 (0x1u << 27)
193#define PMC_PCSR0_PID28 (0x1u << 28)
194#define PMC_PCSR0_PID29 (0x1u << 29)
195#define PMC_PCSR0_PID30 (0x1u << 30)
196#define PMC_PCSR0_PID31 (0x1u << 31)
197/* -------- CKGR_UCKR : (PMC Offset: 0x001C) UTMI Clock Register -------- */
198#define CKGR_UCKR_UPLLEN (0x1u << 16)
199#define CKGR_UCKR_UPLLCOUNT_Pos 20
200#define CKGR_UCKR_UPLLCOUNT_Msk (0xfu << CKGR_UCKR_UPLLCOUNT_Pos)
201#define CKGR_UCKR_UPLLCOUNT(value) ((CKGR_UCKR_UPLLCOUNT_Msk & ((value) << CKGR_UCKR_UPLLCOUNT_Pos)))
202/* -------- CKGR_MOR : (PMC Offset: 0x0020) Main Oscillator Register -------- */
203#define CKGR_MOR_MOSCXTEN (0x1u << 0)
204#define CKGR_MOR_MOSCXTBY (0x1u << 1)
205#define CKGR_MOR_WAITMODE (0x1u << 2)
206#define CKGR_MOR_MOSCRCEN (0x1u << 3)
207#define CKGR_MOR_MOSCRCF_Pos 4
208#define CKGR_MOR_MOSCRCF_Msk (0x7u << CKGR_MOR_MOSCRCF_Pos)
209#define CKGR_MOR_MOSCRCF(value) ((CKGR_MOR_MOSCRCF_Msk & ((value) << CKGR_MOR_MOSCRCF_Pos)))
210#define CKGR_MOR_MOSCRCF_4_MHz (0x0u << 4)
211#define CKGR_MOR_MOSCRCF_8_MHz (0x1u << 4)
212#define CKGR_MOR_MOSCRCF_12_MHz (0x2u << 4)
213#define CKGR_MOR_MOSCXTST_Pos 8
214#define CKGR_MOR_MOSCXTST_Msk (0xffu << CKGR_MOR_MOSCXTST_Pos)
215#define CKGR_MOR_MOSCXTST(value) ((CKGR_MOR_MOSCXTST_Msk & ((value) << CKGR_MOR_MOSCXTST_Pos)))
216#define CKGR_MOR_KEY_Pos 16
217#define CKGR_MOR_KEY_Msk (0xffu << CKGR_MOR_KEY_Pos)
218#define CKGR_MOR_KEY(value) ((CKGR_MOR_KEY_Msk & ((value) << CKGR_MOR_KEY_Pos)))
219#define CKGR_MOR_KEY_PASSWD (0x37u << 16)
220#define CKGR_MOR_MOSCSEL (0x1u << 24)
221#define CKGR_MOR_CFDEN (0x1u << 25)
222#define CKGR_MOR_XT32KFME (0x1u << 26)
223/* -------- CKGR_MCFR : (PMC Offset: 0x0024) Main Clock Frequency Register -------- */
224#define CKGR_MCFR_MAINF_Pos 0
225#define CKGR_MCFR_MAINF_Msk (0xffffu << CKGR_MCFR_MAINF_Pos)
226#define CKGR_MCFR_MAINF(value) ((CKGR_MCFR_MAINF_Msk & ((value) << CKGR_MCFR_MAINF_Pos)))
227#define CKGR_MCFR_MAINFRDY (0x1u << 16)
228#define CKGR_MCFR_RCMEAS (0x1u << 20)
229#define CKGR_MCFR_CCSS (0x1u << 24)
230/* -------- CKGR_PLLAR : (PMC Offset: 0x0028) PLLA Register -------- */
231#define CKGR_PLLAR_DIVA_Pos 0
232#define CKGR_PLLAR_DIVA_Msk (0xffu << CKGR_PLLAR_DIVA_Pos)
233#define CKGR_PLLAR_DIVA(value) ((CKGR_PLLAR_DIVA_Msk & ((value) << CKGR_PLLAR_DIVA_Pos)))
234#define CKGR_PLLAR_DIVA_0 (0x0u << 0)
235#define CKGR_PLLAR_DIVA_BYPASS (0x1u << 0)
236#define CKGR_PLLAR_PLLACOUNT_Pos 8
237#define CKGR_PLLAR_PLLACOUNT_Msk (0x3fu << CKGR_PLLAR_PLLACOUNT_Pos)
238#define CKGR_PLLAR_PLLACOUNT(value) ((CKGR_PLLAR_PLLACOUNT_Msk & ((value) << CKGR_PLLAR_PLLACOUNT_Pos)))
239#define CKGR_PLLAR_MULA_Pos 16
240#define CKGR_PLLAR_MULA_Msk (0x7ffu << CKGR_PLLAR_MULA_Pos)
241#define CKGR_PLLAR_MULA(value) ((CKGR_PLLAR_MULA_Msk & ((value) << CKGR_PLLAR_MULA_Pos)))
242#define CKGR_PLLAR_ONE (0x1u << 29)
243/* -------- PMC_MCKR : (PMC Offset: 0x0030) Master Clock Register -------- */
244#define PMC_MCKR_CSS_Pos 0
245#define PMC_MCKR_CSS_Msk (0x3u << PMC_MCKR_CSS_Pos)
246#define PMC_MCKR_CSS(value) ((PMC_MCKR_CSS_Msk & ((value) << PMC_MCKR_CSS_Pos)))
247#define PMC_MCKR_CSS_SLOW_CLK (0x0u << 0)
248#define PMC_MCKR_CSS_MAIN_CLK (0x1u << 0)
249#define PMC_MCKR_CSS_PLLA_CLK (0x2u << 0)
250#define PMC_MCKR_CSS_UPLL_CLK (0x3u << 0)
251#define PMC_MCKR_PRES_Pos 4
252#define PMC_MCKR_PRES_Msk (0x7u << PMC_MCKR_PRES_Pos)
253#define PMC_MCKR_PRES(value) ((PMC_MCKR_PRES_Msk & ((value) << PMC_MCKR_PRES_Pos)))
254#define PMC_MCKR_PRES_CLK_1 (0x0u << 4)
255#define PMC_MCKR_PRES_CLK_2 (0x1u << 4)
256#define PMC_MCKR_PRES_CLK_4 (0x2u << 4)
257#define PMC_MCKR_PRES_CLK_8 (0x3u << 4)
258#define PMC_MCKR_PRES_CLK_16 (0x4u << 4)
259#define PMC_MCKR_PRES_CLK_32 (0x5u << 4)
260#define PMC_MCKR_PRES_CLK_64 (0x6u << 4)
261#define PMC_MCKR_PRES_CLK_3 (0x7u << 4)
262#define PMC_MCKR_MDIV_Pos 8
263#define PMC_MCKR_MDIV_Msk (0x3u << PMC_MCKR_MDIV_Pos)
264#define PMC_MCKR_MDIV(value) ((PMC_MCKR_MDIV_Msk & ((value) << PMC_MCKR_MDIV_Pos)))
265#define PMC_MCKR_MDIV_EQ_PCK (0x0u << 8)
266#define PMC_MCKR_MDIV_PCK_DIV2 (0x1u << 8)
267#define PMC_MCKR_MDIV_PCK_DIV4 (0x2u << 8)
268#define PMC_MCKR_MDIV_PCK_DIV3 (0x3u << 8)
269#define PMC_MCKR_UPLLDIV2 (0x1u << 13)
270/* -------- PMC_USB : (PMC Offset: 0x0038) USB Clock Register -------- */
271#define PMC_USB_USBS (0x1u << 0)
272#define PMC_USB_USBDIV_Pos 8
273#define PMC_USB_USBDIV_Msk (0xfu << PMC_USB_USBDIV_Pos)
274#define PMC_USB_USBDIV(value) ((PMC_USB_USBDIV_Msk & ((value) << PMC_USB_USBDIV_Pos)))
275/* -------- PMC_PCK0 : (PMC Offset: 0x0040) Programmable Clock 0 Register -------- */
276#define PMC_PCK0_CSS_Pos 0
277#define PMC_PCK0_CSS_Msk (0x7u << PMC_PCK0_CSS_Pos)
278#define PMC_PCK0_CSS(value) ((PMC_PCK0_CSS_Msk & ((value) << PMC_PCK0_CSS_Pos)))
279#define PMC_PCK0_CSS_SLOW_CLK (0x0u << 0)
280#define PMC_PCK0_CSS_MAIN_CLK (0x1u << 0)
281#define PMC_PCK0_CSS_PLLA_CLK (0x2u << 0)
282#define PMC_PCK0_CSS_UPLL_CLK (0x3u << 0)
283#define PMC_PCK0_CSS_MCK (0x4u << 0)
284#define PMC_PCK0_PRES_Pos 4
285#define PMC_PCK0_PRES_Msk (0xffu << PMC_PCK0_PRES_Pos)
286#define PMC_PCK0_PRES(value) ((PMC_PCK0_PRES_Msk & ((value) << PMC_PCK0_PRES_Pos)))
287/* -------- PMC_PCK1 : (PMC Offset: 0x0044) Programmable Clock 1 Register -------- */
288#define PMC_PCK1_CSS_Pos 0
289#define PMC_PCK1_CSS_Msk (0x7u << PMC_PCK1_CSS_Pos)
290#define PMC_PCK1_CSS(value) ((PMC_PCK1_CSS_Msk & ((value) << PMC_PCK1_CSS_Pos)))
291#define PMC_PCK1_CSS_SLOW_CLK (0x0u << 0)
292#define PMC_PCK1_CSS_MAIN_CLK (0x1u << 0)
293#define PMC_PCK1_CSS_PLLA_CLK (0x2u << 0)
294#define PMC_PCK1_CSS_UPLL_CLK (0x3u << 0)
295#define PMC_PCK1_CSS_MCK (0x4u << 0)
296#define PMC_PCK1_PRES_Pos 4
297#define PMC_PCK1_PRES_Msk (0xffu << PMC_PCK1_PRES_Pos)
298#define PMC_PCK1_PRES(value) ((PMC_PCK1_PRES_Msk & ((value) << PMC_PCK1_PRES_Pos)))
299/* -------- PMC_PCK2 : (PMC Offset: 0x0048) Programmable Clock 2 Register -------- */
300#define PMC_PCK2_CSS_Pos 0
301#define PMC_PCK2_CSS_Msk (0x7u << PMC_PCK2_CSS_Pos)
302#define PMC_PCK2_CSS(value) ((PMC_PCK2_CSS_Msk & ((value) << PMC_PCK2_CSS_Pos)))
303#define PMC_PCK2_CSS_SLOW_CLK (0x0u << 0)
304#define PMC_PCK2_CSS_MAIN_CLK (0x1u << 0)
305#define PMC_PCK2_CSS_PLLA_CLK (0x2u << 0)
306#define PMC_PCK2_CSS_UPLL_CLK (0x3u << 0)
307#define PMC_PCK2_CSS_MCK (0x4u << 0)
308#define PMC_PCK2_PRES_Pos 4
309#define PMC_PCK2_PRES_Msk (0xffu << PMC_PCK2_PRES_Pos)
310#define PMC_PCK2_PRES(value) ((PMC_PCK2_PRES_Msk & ((value) << PMC_PCK2_PRES_Pos)))
311/* -------- PMC_PCK3 : (PMC Offset: 0x004C) Programmable Clock 3 Register -------- */
312#define PMC_PCK3_CSS_Pos 0
313#define PMC_PCK3_CSS_Msk (0x7u << PMC_PCK3_CSS_Pos)
314#define PMC_PCK3_CSS(value) ((PMC_PCK3_CSS_Msk & ((value) << PMC_PCK3_CSS_Pos)))
315#define PMC_PCK3_CSS_SLOW_CLK (0x0u << 0)
316#define PMC_PCK3_CSS_MAIN_CLK (0x1u << 0)
317#define PMC_PCK3_CSS_PLLA_CLK (0x2u << 0)
318#define PMC_PCK3_CSS_UPLL_CLK (0x3u << 0)
319#define PMC_PCK3_CSS_MCK (0x4u << 0)
320#define PMC_PCK3_PRES_Pos 4
321#define PMC_PCK3_PRES_Msk (0xffu << PMC_PCK3_PRES_Pos)
322#define PMC_PCK3_PRES(value) ((PMC_PCK3_PRES_Msk & ((value) << PMC_PCK3_PRES_Pos)))
323/* -------- PMC_PCK4 : (PMC Offset: 0x0050) Programmable Clock 4 Register -------- */
324#define PMC_PCK4_CSS_Pos 0
325#define PMC_PCK4_CSS_Msk (0x7u << PMC_PCK4_CSS_Pos)
326#define PMC_PCK4_CSS(value) ((PMC_PCK4_CSS_Msk & ((value) << PMC_PCK4_CSS_Pos)))
327#define PMC_PCK4_CSS_SLOW_CLK (0x0u << 0)
328#define PMC_PCK4_CSS_MAIN_CLK (0x1u << 0)
329#define PMC_PCK4_CSS_PLLA_CLK (0x2u << 0)
330#define PMC_PCK4_CSS_UPLL_CLK (0x3u << 0)
331#define PMC_PCK4_CSS_MCK (0x4u << 0)
332#define PMC_PCK4_PRES_Pos 4
333#define PMC_PCK4_PRES_Msk (0xffu << PMC_PCK4_PRES_Pos)
334#define PMC_PCK4_PRES(value) ((PMC_PCK4_PRES_Msk & ((value) << PMC_PCK4_PRES_Pos)))
335/* -------- PMC_PCK6 : (PMC Offset: 0x0058) Programmable Clock 6 Register -------- */
336#define PMC_PCK6_CSS_Pos 0
337#define PMC_PCK6_CSS_Msk (0x7u << PMC_PCK6_CSS_Pos)
338#define PMC_PCK6_CSS(value) ((PMC_PCK6_CSS_Msk & ((value) << PMC_PCK6_CSS_Pos)))
339#define PMC_PCK6_CSS_SLOW_CLK (0x0u << 0)
340#define PMC_PCK6_CSS_MAIN_CLK (0x1u << 0)
341#define PMC_PCK6_CSS_PLLA_CLK (0x2u << 0)
342#define PMC_PCK6_CSS_UPLL_CLK (0x3u << 0)
343#define PMC_PCK6_CSS_MCK (0x4u << 0)
344#define PMC_PCK6_PRES_Pos 4
345#define PMC_PCK6_PRES_Msk (0xffu << PMC_PCK6_PRES_Pos)
346#define PMC_PCK6_PRES(value) ((PMC_PCK6_PRES_Msk & ((value) << PMC_PCK6_PRES_Pos)))
347/* -------- PMC_IER : (PMC Offset: 0x0060) Interrupt Enable Register -------- */
348#define PMC_IER_MOSCXTS (0x1u << 0)
349#define PMC_IER_LOCKA (0x1u << 1)
350#define PMC_IER_MCKRDY (0x1u << 3)
351#define PMC_IER_LOCKU (0x1u << 6)
352#define PMC_IER_PCKRDY0 (0x1u << 8)
353#define PMC_IER_PCKRDY1 (0x1u << 9)
354#define PMC_IER_PCKRDY2 (0x1u << 10)
355#define PMC_IER_PCKRDY3 (0x1u << 11)
356#define PMC_IER_PCKRDY4 (0x1u << 12)
357#define PMC_IER_PCKRDY5 (0x1u << 13)
358#define PMC_IER_PCKRDY6 (0x1u << 14)
359#define PMC_IER_MOSCSELS (0x1u << 16)
360#define PMC_IER_MOSCRCS (0x1u << 17)
361#define PMC_IER_CFDEV (0x1u << 18)
362#define PMC_IER_XT32KERR (0x1u << 21)
363/* -------- PMC_IDR : (PMC Offset: 0x0064) Interrupt Disable Register -------- */
364#define PMC_IDR_MOSCXTS (0x1u << 0)
365#define PMC_IDR_LOCKA (0x1u << 1)
366#define PMC_IDR_MCKRDY (0x1u << 3)
367#define PMC_IDR_LOCKU (0x1u << 6)
368#define PMC_IDR_PCKRDY0 (0x1u << 8)
369#define PMC_IDR_PCKRDY1 (0x1u << 9)
370#define PMC_IDR_PCKRDY2 (0x1u << 10)
371#define PMC_IDR_PCKRDY3 (0x1u << 11)
372#define PMC_IDR_PCKRDY4 (0x1u << 12)
373#define PMC_IDR_PCKRDY5 (0x1u << 13)
374#define PMC_IDR_PCKRDY6 (0x1u << 14)
375#define PMC_IDR_MOSCSELS (0x1u << 16)
376#define PMC_IDR_MOSCRCS (0x1u << 17)
377#define PMC_IDR_CFDEV (0x1u << 18)
378#define PMC_IDR_XT32KERR (0x1u << 21)
379/* -------- PMC_SR : (PMC Offset: 0x0068) Status Register -------- */
380#define PMC_SR_MOSCXTS (0x1u << 0)
381#define PMC_SR_LOCKA (0x1u << 1)
382#define PMC_SR_MCKRDY (0x1u << 3)
383#define PMC_SR_LOCKU (0x1u << 6)
384#define PMC_SR_OSCSELS (0x1u << 7)
385#define PMC_SR_PCKRDY0 (0x1u << 8)
386#define PMC_SR_PCKRDY1 (0x1u << 9)
387#define PMC_SR_PCKRDY2 (0x1u << 10)
388#define PMC_SR_PCKRDY3 (0x1u << 11)
389#define PMC_SR_PCKRDY4 (0x1u << 12)
390#define PMC_SR_PCKRDY5 (0x1u << 13)
391#define PMC_SR_PCKRDY6 (0x1u << 14)
392#define PMC_SR_MOSCSELS (0x1u << 16)
393#define PMC_SR_MOSCRCS (0x1u << 17)
394#define PMC_SR_CFDEV (0x1u << 18)
395#define PMC_SR_CFDS (0x1u << 19)
396#define PMC_SR_FOS (0x1u << 20)
397#define PMC_SR_XT32KERR (0x1u << 21)
398/* -------- PMC_IMR : (PMC Offset: 0x006C) Interrupt Mask Register -------- */
399#define PMC_IMR_MOSCXTS (0x1u << 0)
400#define PMC_IMR_LOCKA (0x1u << 1)
401#define PMC_IMR_MCKRDY (0x1u << 3)
402#define PMC_IMR_LOCKU (0x1u << 6)
403#define PMC_IMR_PCKRDY0 (0x1u << 8)
404#define PMC_IMR_PCKRDY1 (0x1u << 9)
405#define PMC_IMR_PCKRDY2 (0x1u << 10)
406#define PMC_IMR_PCKRDY3 (0x1u << 11)
407#define PMC_IMR_PCKRDY4 (0x1u << 12)
408#define PMC_IMR_PCKRDY5 (0x1u << 13)
409#define PMC_IMR_PCKRDY6 (0x1u << 14)
410#define PMC_IMR_MOSCSELS (0x1u << 16)
411#define PMC_IMR_MOSCRCS (0x1u << 17)
412#define PMC_IMR_CFDEV (0x1u << 18)
413#define PMC_IMR_XT32KERR (0x1u << 21)
414/* -------- PMC_FSMR : (PMC Offset: 0x0070) Fast Startup Mode Register -------- */
415#define PMC_FSMR_FSTT0 (0x1u << 0)
416#define PMC_FSMR_FSTT1 (0x1u << 1)
417#define PMC_FSMR_FSTT2 (0x1u << 2)
418#define PMC_FSMR_FSTT3 (0x1u << 3)
419#define PMC_FSMR_FSTT4 (0x1u << 4)
420#define PMC_FSMR_FSTT5 (0x1u << 5)
421#define PMC_FSMR_FSTT6 (0x1u << 6)
422#define PMC_FSMR_FSTT7 (0x1u << 7)
423#define PMC_FSMR_FSTT8 (0x1u << 8)
424#define PMC_FSMR_FSTT9 (0x1u << 9)
425#define PMC_FSMR_FSTT10 (0x1u << 10)
426#define PMC_FSMR_FSTT11 (0x1u << 11)
427#define PMC_FSMR_FSTT12 (0x1u << 12)
428#define PMC_FSMR_FSTT13 (0x1u << 13)
429#define PMC_FSMR_FSTT14 (0x1u << 14)
430#define PMC_FSMR_FSTT15 (0x1u << 15)
431#define PMC_FSMR_RTTAL (0x1u << 16)
432#define PMC_FSMR_RTCAL (0x1u << 17)
433#define PMC_FSMR_USBAL (0x1u << 18)
434#define PMC_FSMR_LPM (0x1u << 20)
435#define PMC_FSMR_FLPM_Pos 21
436#define PMC_FSMR_FLPM_Msk (0x3u << PMC_FSMR_FLPM_Pos)
437#define PMC_FSMR_FLPM(value) ((PMC_FSMR_FLPM_Msk & ((value) << PMC_FSMR_FLPM_Pos)))
438#define PMC_FSMR_FLPM_FLASH_STANDBY (0x0u << 21)
439#define PMC_FSMR_FLPM_FLASH_DEEP_POWERDOWN (0x1u << 21)
440#define PMC_FSMR_FLPM_FLASH_IDLE (0x2u << 21)
441#define PMC_FSMR_FFLPM (0x1u << 23)
442/* -------- PMC_FSPR : (PMC Offset: 0x0074) Fast Startup Polarity Register -------- */
443#define PMC_FSPR_FSTP0 (0x1u << 0)
444#define PMC_FSPR_FSTP1 (0x1u << 1)
445#define PMC_FSPR_FSTP2 (0x1u << 2)
446#define PMC_FSPR_FSTP3 (0x1u << 3)
447#define PMC_FSPR_FSTP4 (0x1u << 4)
448#define PMC_FSPR_FSTP5 (0x1u << 5)
449#define PMC_FSPR_FSTP6 (0x1u << 6)
450#define PMC_FSPR_FSTP7 (0x1u << 7)
451#define PMC_FSPR_FSTP8 (0x1u << 8)
452#define PMC_FSPR_FSTP9 (0x1u << 9)
453#define PMC_FSPR_FSTP10 (0x1u << 10)
454#define PMC_FSPR_FSTP11 (0x1u << 11)
455#define PMC_FSPR_FSTP12 (0x1u << 12)
456#define PMC_FSPR_FSTP13 (0x1u << 13)
457#define PMC_FSPR_FSTP14 (0x1u << 14)
458#define PMC_FSPR_FSTP15 (0x1u << 15)
459/* -------- PMC_FOCR : (PMC Offset: 0x0078) Fault Output Clear Register -------- */
460#define PMC_FOCR_FOCLR (0x1u << 0)
461/* -------- PMC_WPMR : (PMC Offset: 0x00E4) Write Protection Mode Register -------- */
462#define PMC_WPMR_WPEN (0x1u << 0)
463#define PMC_WPMR_WPKEY_Pos 8
464#define PMC_WPMR_WPKEY_Msk (0xffffffu << PMC_WPMR_WPKEY_Pos)
465#define PMC_WPMR_WPKEY(value) ((PMC_WPMR_WPKEY_Msk & ((value) << PMC_WPMR_WPKEY_Pos)))
466#define PMC_WPMR_WPKEY_PASSWD (0x504D43u << 8)
467/* -------- PMC_WPSR : (PMC Offset: 0x00E8) Write Protection Status Register -------- */
468#define PMC_WPSR_WPVS (0x1u << 0)
469#define PMC_WPSR_WPVSRC_Pos 8
470#define PMC_WPSR_WPVSRC_Msk (0xffffu << PMC_WPSR_WPVSRC_Pos)
471/* -------- PMC_PCER1 : (PMC Offset: 0x0100) Peripheral Clock Enable Register 1 -------- */
472#define PMC_PCER1_PID32 (0x1u << 0)
473#define PMC_PCER1_PID33 (0x1u << 1)
474#define PMC_PCER1_PID34 (0x1u << 2)
475#define PMC_PCER1_PID35 (0x1u << 3)
476#define PMC_PCER1_PID37 (0x1u << 5)
477#define PMC_PCER1_PID39 (0x1u << 7)
478#define PMC_PCER1_PID40 (0x1u << 8)
479#define PMC_PCER1_PID41 (0x1u << 9)
480#define PMC_PCER1_PID42 (0x1u << 10)
481#define PMC_PCER1_PID43 (0x1u << 11)
482#define PMC_PCER1_PID44 (0x1u << 12)
483#define PMC_PCER1_PID45 (0x1u << 13)
484#define PMC_PCER1_PID46 (0x1u << 14)
485#define PMC_PCER1_PID47 (0x1u << 15)
486#define PMC_PCER1_PID48 (0x1u << 16)
487#define PMC_PCER1_PID49 (0x1u << 17)
488#define PMC_PCER1_PID50 (0x1u << 18)
489#define PMC_PCER1_PID51 (0x1u << 19)
490#define PMC_PCER1_PID52 (0x1u << 20)
491#define PMC_PCER1_PID53 (0x1u << 21)
492#define PMC_PCER1_PID56 (0x1u << 24)
493#define PMC_PCER1_PID57 (0x1u << 25)
494#define PMC_PCER1_PID58 (0x1u << 26)
495#define PMC_PCER1_PID59 (0x1u << 27)
496#define PMC_PCER1_PID60 (0x1u << 28)
497/* -------- PMC_PCDR1 : (PMC Offset: 0x0104) Peripheral Clock Disable Register 1 -------- */
498#define PMC_PCDR1_PID32 (0x1u << 0)
499#define PMC_PCDR1_PID33 (0x1u << 1)
500#define PMC_PCDR1_PID34 (0x1u << 2)
501#define PMC_PCDR1_PID35 (0x1u << 3)
502#define PMC_PCDR1_PID37 (0x1u << 5)
503#define PMC_PCDR1_PID39 (0x1u << 7)
504#define PMC_PCDR1_PID40 (0x1u << 8)
505#define PMC_PCDR1_PID41 (0x1u << 9)
506#define PMC_PCDR1_PID42 (0x1u << 10)
507#define PMC_PCDR1_PID43 (0x1u << 11)
508#define PMC_PCDR1_PID44 (0x1u << 12)
509#define PMC_PCDR1_PID45 (0x1u << 13)
510#define PMC_PCDR1_PID46 (0x1u << 14)
511#define PMC_PCDR1_PID47 (0x1u << 15)
512#define PMC_PCDR1_PID48 (0x1u << 16)
513#define PMC_PCDR1_PID49 (0x1u << 17)
514#define PMC_PCDR1_PID50 (0x1u << 18)
515#define PMC_PCDR1_PID51 (0x1u << 19)
516#define PMC_PCDR1_PID52 (0x1u << 20)
517#define PMC_PCDR1_PID53 (0x1u << 21)
518#define PMC_PCDR1_PID56 (0x1u << 24)
519#define PMC_PCDR1_PID57 (0x1u << 25)
520#define PMC_PCDR1_PID58 (0x1u << 26)
521#define PMC_PCDR1_PID59 (0x1u << 27)
522#define PMC_PCDR1_PID60 (0x1u << 28)
523/* -------- PMC_PCSR1 : (PMC Offset: 0x0108) Peripheral Clock Status Register 1 -------- */
524#define PMC_PCSR1_PID32 (0x1u << 0)
525#define PMC_PCSR1_PID33 (0x1u << 1)
526#define PMC_PCSR1_PID34 (0x1u << 2)
527#define PMC_PCSR1_PID35 (0x1u << 3)
528#define PMC_PCSR1_PID37 (0x1u << 5)
529#define PMC_PCSR1_PID39 (0x1u << 7)
530#define PMC_PCSR1_PID40 (0x1u << 8)
531#define PMC_PCSR1_PID41 (0x1u << 9)
532#define PMC_PCSR1_PID42 (0x1u << 10)
533#define PMC_PCSR1_PID43 (0x1u << 11)
534#define PMC_PCSR1_PID44 (0x1u << 12)
535#define PMC_PCSR1_PID45 (0x1u << 13)
536#define PMC_PCSR1_PID46 (0x1u << 14)
537#define PMC_PCSR1_PID47 (0x1u << 15)
538#define PMC_PCSR1_PID48 (0x1u << 16)
539#define PMC_PCSR1_PID49 (0x1u << 17)
540#define PMC_PCSR1_PID50 (0x1u << 18)
541#define PMC_PCSR1_PID51 (0x1u << 19)
542#define PMC_PCSR1_PID52 (0x1u << 20)
543#define PMC_PCSR1_PID53 (0x1u << 21)
544#define PMC_PCSR1_PID56 (0x1u << 24)
545#define PMC_PCSR1_PID57 (0x1u << 25)
546#define PMC_PCSR1_PID58 (0x1u << 26)
547#define PMC_PCSR1_PID59 (0x1u << 27)
548#define PMC_PCSR1_PID60 (0x1u << 28)
549/* -------- PMC_PCR : (PMC Offset: 0x010C) Peripheral Control Register -------- */
550#define PMC_PCR_PID_Pos 0
551#define PMC_PCR_PID_Msk (0x3fu << PMC_PCR_PID_Pos)
552#define PMC_PCR_PID(value) ((PMC_PCR_PID_Msk & ((value) << PMC_PCR_PID_Pos)))
553#define PMC_PCR_CMD (0x1u << 12)
554#define PMC_PCR_EN (0x1u << 28)
555/* -------- PMC_OCR : (PMC Offset: 0x0110) Oscillator Calibration Register -------- */
556#define PMC_OCR_CAL4_Pos 0
557#define PMC_OCR_CAL4_Msk (0x7fu << PMC_OCR_CAL4_Pos)
558#define PMC_OCR_CAL4(value) ((PMC_OCR_CAL4_Msk & ((value) << PMC_OCR_CAL4_Pos)))
559#define PMC_OCR_SEL4 (0x1u << 7)
560#define PMC_OCR_CAL8_Pos 8
561#define PMC_OCR_CAL8_Msk (0x7fu << PMC_OCR_CAL8_Pos)
562#define PMC_OCR_CAL8(value) ((PMC_OCR_CAL8_Msk & ((value) << PMC_OCR_CAL8_Pos)))
563#define PMC_OCR_SEL8 (0x1u << 15)
564#define PMC_OCR_CAL12_Pos 16
565#define PMC_OCR_CAL12_Msk (0x7fu << PMC_OCR_CAL12_Pos)
566#define PMC_OCR_CAL12(value) ((PMC_OCR_CAL12_Msk & ((value) << PMC_OCR_CAL12_Pos)))
567#define PMC_OCR_SEL12 (0x1u << 23)
568/* -------- PMC_SLPWK_ER0 : (PMC Offset: 0x0114) SleepWalking Enable Register 0 -------- */
569#define PMC_SLPWK_ER0_PID7 (0x1u << 7)
570#define PMC_SLPWK_ER0_PID8 (0x1u << 8)
571#define PMC_SLPWK_ER0_PID9 (0x1u << 9)
572#define PMC_SLPWK_ER0_PID10 (0x1u << 10)
573#define PMC_SLPWK_ER0_PID11 (0x1u << 11)
574#define PMC_SLPWK_ER0_PID12 (0x1u << 12)
575#define PMC_SLPWK_ER0_PID13 (0x1u << 13)
576#define PMC_SLPWK_ER0_PID14 (0x1u << 14)
577#define PMC_SLPWK_ER0_PID15 (0x1u << 15)
578#define PMC_SLPWK_ER0_PID16 (0x1u << 16)
579#define PMC_SLPWK_ER0_PID17 (0x1u << 17)
580#define PMC_SLPWK_ER0_PID18 (0x1u << 18)
581#define PMC_SLPWK_ER0_PID19 (0x1u << 19)
582#define PMC_SLPWK_ER0_PID20 (0x1u << 20)
583#define PMC_SLPWK_ER0_PID21 (0x1u << 21)
584#define PMC_SLPWK_ER0_PID22 (0x1u << 22)
585#define PMC_SLPWK_ER0_PID23 (0x1u << 23)
586#define PMC_SLPWK_ER0_PID24 (0x1u << 24)
587#define PMC_SLPWK_ER0_PID25 (0x1u << 25)
588#define PMC_SLPWK_ER0_PID26 (0x1u << 26)
589#define PMC_SLPWK_ER0_PID27 (0x1u << 27)
590#define PMC_SLPWK_ER0_PID28 (0x1u << 28)
591#define PMC_SLPWK_ER0_PID29 (0x1u << 29)
592#define PMC_SLPWK_ER0_PID30 (0x1u << 30)
593#define PMC_SLPWK_ER0_PID31 (0x1u << 31)
594/* -------- PMC_SLPWK_DR0 : (PMC Offset: 0x0118) SleepWalking Disable Register 0 -------- */
595#define PMC_SLPWK_DR0_PID7 (0x1u << 7)
596#define PMC_SLPWK_DR0_PID8 (0x1u << 8)
597#define PMC_SLPWK_DR0_PID9 (0x1u << 9)
598#define PMC_SLPWK_DR0_PID10 (0x1u << 10)
599#define PMC_SLPWK_DR0_PID11 (0x1u << 11)
600#define PMC_SLPWK_DR0_PID12 (0x1u << 12)
601#define PMC_SLPWK_DR0_PID13 (0x1u << 13)
602#define PMC_SLPWK_DR0_PID14 (0x1u << 14)
603#define PMC_SLPWK_DR0_PID15 (0x1u << 15)
604#define PMC_SLPWK_DR0_PID16 (0x1u << 16)
605#define PMC_SLPWK_DR0_PID17 (0x1u << 17)
606#define PMC_SLPWK_DR0_PID18 (0x1u << 18)
607#define PMC_SLPWK_DR0_PID19 (0x1u << 19)
608#define PMC_SLPWK_DR0_PID20 (0x1u << 20)
609#define PMC_SLPWK_DR0_PID21 (0x1u << 21)
610#define PMC_SLPWK_DR0_PID22 (0x1u << 22)
611#define PMC_SLPWK_DR0_PID23 (0x1u << 23)
612#define PMC_SLPWK_DR0_PID24 (0x1u << 24)
613#define PMC_SLPWK_DR0_PID25 (0x1u << 25)
614#define PMC_SLPWK_DR0_PID26 (0x1u << 26)
615#define PMC_SLPWK_DR0_PID27 (0x1u << 27)
616#define PMC_SLPWK_DR0_PID28 (0x1u << 28)
617#define PMC_SLPWK_DR0_PID29 (0x1u << 29)
618#define PMC_SLPWK_DR0_PID30 (0x1u << 30)
619#define PMC_SLPWK_DR0_PID31 (0x1u << 31)
620/* -------- PMC_SLPWK_SR0 : (PMC Offset: 0x011C) SleepWalking Status Register 0 -------- */
621#define PMC_SLPWK_SR0_PID7 (0x1u << 7)
622#define PMC_SLPWK_SR0_PID8 (0x1u << 8)
623#define PMC_SLPWK_SR0_PID9 (0x1u << 9)
624#define PMC_SLPWK_SR0_PID10 (0x1u << 10)
625#define PMC_SLPWK_SR0_PID11 (0x1u << 11)
626#define PMC_SLPWK_SR0_PID12 (0x1u << 12)
627#define PMC_SLPWK_SR0_PID13 (0x1u << 13)
628#define PMC_SLPWK_SR0_PID14 (0x1u << 14)
629#define PMC_SLPWK_SR0_PID15 (0x1u << 15)
630#define PMC_SLPWK_SR0_PID16 (0x1u << 16)
631#define PMC_SLPWK_SR0_PID17 (0x1u << 17)
632#define PMC_SLPWK_SR0_PID18 (0x1u << 18)
633#define PMC_SLPWK_SR0_PID19 (0x1u << 19)
634#define PMC_SLPWK_SR0_PID20 (0x1u << 20)
635#define PMC_SLPWK_SR0_PID21 (0x1u << 21)
636#define PMC_SLPWK_SR0_PID22 (0x1u << 22)
637#define PMC_SLPWK_SR0_PID23 (0x1u << 23)
638#define PMC_SLPWK_SR0_PID24 (0x1u << 24)
639#define PMC_SLPWK_SR0_PID25 (0x1u << 25)
640#define PMC_SLPWK_SR0_PID26 (0x1u << 26)
641#define PMC_SLPWK_SR0_PID27 (0x1u << 27)
642#define PMC_SLPWK_SR0_PID28 (0x1u << 28)
643#define PMC_SLPWK_SR0_PID29 (0x1u << 29)
644#define PMC_SLPWK_SR0_PID30 (0x1u << 30)
645#define PMC_SLPWK_SR0_PID31 (0x1u << 31)
646/* -------- PMC_SLPWK_ASR0 : (PMC Offset: 0x0120) SleepWalking Activity Status Register 0 -------- */
647#define PMC_SLPWK_ASR0_PID7 (0x1u << 7)
648#define PMC_SLPWK_ASR0_PID8 (0x1u << 8)
649#define PMC_SLPWK_ASR0_PID9 (0x1u << 9)
650#define PMC_SLPWK_ASR0_PID10 (0x1u << 10)
651#define PMC_SLPWK_ASR0_PID11 (0x1u << 11)
652#define PMC_SLPWK_ASR0_PID12 (0x1u << 12)
653#define PMC_SLPWK_ASR0_PID13 (0x1u << 13)
654#define PMC_SLPWK_ASR0_PID14 (0x1u << 14)
655#define PMC_SLPWK_ASR0_PID15 (0x1u << 15)
656#define PMC_SLPWK_ASR0_PID16 (0x1u << 16)
657#define PMC_SLPWK_ASR0_PID17 (0x1u << 17)
658#define PMC_SLPWK_ASR0_PID18 (0x1u << 18)
659#define PMC_SLPWK_ASR0_PID19 (0x1u << 19)
660#define PMC_SLPWK_ASR0_PID20 (0x1u << 20)
661#define PMC_SLPWK_ASR0_PID21 (0x1u << 21)
662#define PMC_SLPWK_ASR0_PID22 (0x1u << 22)
663#define PMC_SLPWK_ASR0_PID23 (0x1u << 23)
664#define PMC_SLPWK_ASR0_PID24 (0x1u << 24)
665#define PMC_SLPWK_ASR0_PID25 (0x1u << 25)
666#define PMC_SLPWK_ASR0_PID26 (0x1u << 26)
667#define PMC_SLPWK_ASR0_PID27 (0x1u << 27)
668#define PMC_SLPWK_ASR0_PID28 (0x1u << 28)
669#define PMC_SLPWK_ASR0_PID29 (0x1u << 29)
670#define PMC_SLPWK_ASR0_PID30 (0x1u << 30)
671#define PMC_SLPWK_ASR0_PID31 (0x1u << 31)
672/* -------- PMC_PMMR : (PMC Offset: 0x0130) PLL Maximum Multiplier Value Register -------- */
673#define PMC_PMMR_PLLA_MMAX_Pos 0
674#define PMC_PMMR_PLLA_MMAX_Msk (0x7ffu << PMC_PMMR_PLLA_MMAX_Pos)
675#define PMC_PMMR_PLLA_MMAX(value) ((PMC_PMMR_PLLA_MMAX_Msk & ((value) << PMC_PMMR_PLLA_MMAX_Pos)))
676/* -------- PMC_SLPWK_ER1 : (PMC Offset: 0x0134) SleepWalking Enable Register 1 -------- */
677#define PMC_SLPWK_ER1_PID32 (0x1u << 0)
678#define PMC_SLPWK_ER1_PID33 (0x1u << 1)
679#define PMC_SLPWK_ER1_PID34 (0x1u << 2)
680#define PMC_SLPWK_ER1_PID35 (0x1u << 3)
681#define PMC_SLPWK_ER1_PID37 (0x1u << 5)
682#define PMC_SLPWK_ER1_PID39 (0x1u << 7)
683#define PMC_SLPWK_ER1_PID40 (0x1u << 8)
684#define PMC_SLPWK_ER1_PID41 (0x1u << 9)
685#define PMC_SLPWK_ER1_PID42 (0x1u << 10)
686#define PMC_SLPWK_ER1_PID43 (0x1u << 11)
687#define PMC_SLPWK_ER1_PID44 (0x1u << 12)
688#define PMC_SLPWK_ER1_PID45 (0x1u << 13)
689#define PMC_SLPWK_ER1_PID46 (0x1u << 14)
690#define PMC_SLPWK_ER1_PID47 (0x1u << 15)
691#define PMC_SLPWK_ER1_PID48 (0x1u << 16)
692#define PMC_SLPWK_ER1_PID49 (0x1u << 17)
693#define PMC_SLPWK_ER1_PID50 (0x1u << 18)
694#define PMC_SLPWK_ER1_PID51 (0x1u << 19)
695#define PMC_SLPWK_ER1_PID52 (0x1u << 20)
696#define PMC_SLPWK_ER1_PID53 (0x1u << 21)
697#define PMC_SLPWK_ER1_PID56 (0x1u << 24)
698#define PMC_SLPWK_ER1_PID57 (0x1u << 25)
699#define PMC_SLPWK_ER1_PID58 (0x1u << 26)
700#define PMC_SLPWK_ER1_PID59 (0x1u << 27)
701#define PMC_SLPWK_ER1_PID60 (0x1u << 28)
702/* -------- PMC_SLPWK_DR1 : (PMC Offset: 0x0138) SleepWalking Disable Register 1 -------- */
703#define PMC_SLPWK_DR1_PID32 (0x1u << 0)
704#define PMC_SLPWK_DR1_PID33 (0x1u << 1)
705#define PMC_SLPWK_DR1_PID34 (0x1u << 2)
706#define PMC_SLPWK_DR1_PID35 (0x1u << 3)
707#define PMC_SLPWK_DR1_PID37 (0x1u << 5)
708#define PMC_SLPWK_DR1_PID39 (0x1u << 7)
709#define PMC_SLPWK_DR1_PID40 (0x1u << 8)
710#define PMC_SLPWK_DR1_PID41 (0x1u << 9)
711#define PMC_SLPWK_DR1_PID42 (0x1u << 10)
712#define PMC_SLPWK_DR1_PID43 (0x1u << 11)
713#define PMC_SLPWK_DR1_PID44 (0x1u << 12)
714#define PMC_SLPWK_DR1_PID45 (0x1u << 13)
715#define PMC_SLPWK_DR1_PID46 (0x1u << 14)
716#define PMC_SLPWK_DR1_PID47 (0x1u << 15)
717#define PMC_SLPWK_DR1_PID48 (0x1u << 16)
718#define PMC_SLPWK_DR1_PID49 (0x1u << 17)
719#define PMC_SLPWK_DR1_PID50 (0x1u << 18)
720#define PMC_SLPWK_DR1_PID51 (0x1u << 19)
721#define PMC_SLPWK_DR1_PID52 (0x1u << 20)
722#define PMC_SLPWK_DR1_PID53 (0x1u << 21)
723#define PMC_SLPWK_DR1_PID56 (0x1u << 24)
724#define PMC_SLPWK_DR1_PID57 (0x1u << 25)
725#define PMC_SLPWK_DR1_PID58 (0x1u << 26)
726#define PMC_SLPWK_DR1_PID59 (0x1u << 27)
727#define PMC_SLPWK_DR1_PID60 (0x1u << 28)
728/* -------- PMC_SLPWK_SR1 : (PMC Offset: 0x013C) SleepWalking Status Register 1 -------- */
729#define PMC_SLPWK_SR1_PID32 (0x1u << 0)
730#define PMC_SLPWK_SR1_PID33 (0x1u << 1)
731#define PMC_SLPWK_SR1_PID34 (0x1u << 2)
732#define PMC_SLPWK_SR1_PID35 (0x1u << 3)
733#define PMC_SLPWK_SR1_PID37 (0x1u << 5)
734#define PMC_SLPWK_SR1_PID39 (0x1u << 7)
735#define PMC_SLPWK_SR1_PID40 (0x1u << 8)
736#define PMC_SLPWK_SR1_PID41 (0x1u << 9)
737#define PMC_SLPWK_SR1_PID42 (0x1u << 10)
738#define PMC_SLPWK_SR1_PID43 (0x1u << 11)
739#define PMC_SLPWK_SR1_PID44 (0x1u << 12)
740#define PMC_SLPWK_SR1_PID45 (0x1u << 13)
741#define PMC_SLPWK_SR1_PID46 (0x1u << 14)
742#define PMC_SLPWK_SR1_PID47 (0x1u << 15)
743#define PMC_SLPWK_SR1_PID48 (0x1u << 16)
744#define PMC_SLPWK_SR1_PID49 (0x1u << 17)
745#define PMC_SLPWK_SR1_PID50 (0x1u << 18)
746#define PMC_SLPWK_SR1_PID51 (0x1u << 19)
747#define PMC_SLPWK_SR1_PID52 (0x1u << 20)
748#define PMC_SLPWK_SR1_PID53 (0x1u << 21)
749#define PMC_SLPWK_SR1_PID56 (0x1u << 24)
750#define PMC_SLPWK_SR1_PID57 (0x1u << 25)
751#define PMC_SLPWK_SR1_PID58 (0x1u << 26)
752#define PMC_SLPWK_SR1_PID59 (0x1u << 27)
753#define PMC_SLPWK_SR1_PID60 (0x1u << 28)
754/* -------- PMC_SLPWK_ASR1 : (PMC Offset: 0x0140) SleepWalking Activity Status Register 1 -------- */
755#define PMC_SLPWK_ASR1_PID32 (0x1u << 0)
756#define PMC_SLPWK_ASR1_PID33 (0x1u << 1)
757#define PMC_SLPWK_ASR1_PID34 (0x1u << 2)
758#define PMC_SLPWK_ASR1_PID35 (0x1u << 3)
759#define PMC_SLPWK_ASR1_PID37 (0x1u << 5)
760#define PMC_SLPWK_ASR1_PID39 (0x1u << 7)
761#define PMC_SLPWK_ASR1_PID40 (0x1u << 8)
762#define PMC_SLPWK_ASR1_PID41 (0x1u << 9)
763#define PMC_SLPWK_ASR1_PID42 (0x1u << 10)
764#define PMC_SLPWK_ASR1_PID43 (0x1u << 11)
765#define PMC_SLPWK_ASR1_PID44 (0x1u << 12)
766#define PMC_SLPWK_ASR1_PID45 (0x1u << 13)
767#define PMC_SLPWK_ASR1_PID46 (0x1u << 14)
768#define PMC_SLPWK_ASR1_PID47 (0x1u << 15)
769#define PMC_SLPWK_ASR1_PID48 (0x1u << 16)
770#define PMC_SLPWK_ASR1_PID49 (0x1u << 17)
771#define PMC_SLPWK_ASR1_PID50 (0x1u << 18)
772#define PMC_SLPWK_ASR1_PID51 (0x1u << 19)
773#define PMC_SLPWK_ASR1_PID52 (0x1u << 20)
774#define PMC_SLPWK_ASR1_PID53 (0x1u << 21)
775#define PMC_SLPWK_ASR1_PID56 (0x1u << 24)
776#define PMC_SLPWK_ASR1_PID57 (0x1u << 25)
777#define PMC_SLPWK_ASR1_PID58 (0x1u << 26)
778#define PMC_SLPWK_ASR1_PID59 (0x1u << 27)
779#define PMC_SLPWK_ASR1_PID60 (0x1u << 28)
780/* -------- PMC_SLPWK_AIPR : (PMC Offset: 0x0144) SleepWalking Activity In Progress Register -------- */
781#define PMC_SLPWK_AIPR_AIP (0x1u << 0)
782
784
785
786#endif /* _SAMS70_PMC_COMPONENT_ */
#define __O
Definition core_cm4.h:238
#define __IO
Definition core_cm4.h:239
#define __I
Definition core_cm4.h:236
Pmc hardware registers.
Definition component_pmc.h:41
(Pmc Offset: 0x0048) Programmable Clock 2 Register
Definition component_pmc.h:60
(Pmc Offset: 0x0060) Interrupt Enable Register
(Pmc Offset: 0x0130) PLL Maximum Multiplier Value Register
Definition component_pmc.h:81
(Pmc Offset: 0x0070) Fast Startup Mode Register
Definition component_pmc.h:64
__I uint32_t PMC_SR
(Pmc Offset: 0x0068) Status Register
Definition component_pmc.h:62
(Pmc Offset: 0x011C) SleepWalking Status Register 0
Definition component_pmc.h:78
(Pmc Offset: 0x0134) SleepWalking Enable Register 1
Definition component_pmc.h:82
(Pmc Offset: 0x0114) SleepWalking Enable Register 0
Definition component_pmc.h:76
(Pmc Offset: 0x006C) Interrupt Mask Register
Definition component_pmc.h:63
(Pmc Offset: 0x00E8) Write Protection Status Register
Definition component_pmc.h:69
(Pmc Offset: 0x0040) Programmable Clock 0 Register
Definition component_pmc.h:58
(Pmc Offset: 0x013C) SleepWalking Status Register 1
Definition component_pmc.h:84
(Pmc Offset: 0x0108) Peripheral Clock Status Register 1
Definition component_pmc.h:73
(Pmc Offset: 0x0100) Peripheral Clock Enable Register 1
Definition component_pmc.h:71
(Pmc Offset: 0x0064) Interrupt Disable Register
Definition component_pmc.h:61
(Pmc Offset: 0x0044) Programmable Clock 1 Register
Definition component_pmc.h:59
(Pmc Offset: 0x0074) Fast Startup Polarity Register
Definition component_pmc.h:65
(Pmc Offset: 0x0138) SleepWalking Disable Register 1
Definition component_pmc.h:83
(Pmc Offset: 0x0110) Oscillator Calibration Register
Definition component_pmc.h:75
(Pmc Offset: 0x0118) SleepWalking Disable Register 0
Definition component_pmc.h:77
(Pmc Offset: 0x00E4) Write Protection Mode Register
Definition component_pmc.h:68
(Pmc Offset: 0x0120) SleepWalking Activity Status Register 0
Definition component_pmc.h:79
(Pmc Offset: 0x0050) Programmable Clock 4 Register
(Pmc Offset: 0x0104) Peripheral Clock Disable Register 1
Definition component_pmc.h:72
(Pmc Offset: 0x004C) Programmable Clock 3 Register
(Pmc Offset: 0x0144) SleepWalking Activity In Progress Register
Definition component_pmc.h:86
(Pmc Offset: 0x0058) Programmable Clock 6 Register
(Pmc Offset: 0x0140) SleepWalking Activity Status Register 1
Definition component_pmc.h:85
(Pmc Offset: 0x0078) Fault Output Clear Register
Definition component_pmc.h:66
(Pmc Offset: 0x010C) Peripheral Control Register
Definition component_pmc.h:74
