RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
sams70
component
component_afec.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAMS70_AFEC_COMPONENT_
31
#define _SAMS70_AFEC_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t AFEC_CR;
43
__IO
uint32_t AFEC_MR;
44
__IO
uint32_t AFEC_EMR;
45
__IO
uint32_t AFEC_SEQ1R;
46
__IO
uint32_t AFEC_SEQ2R;
47
__O
uint32_t AFEC_CHER;
48
__O
uint32_t AFEC_CHDR;
49
__I
uint32_t AFEC_CHSR;
50
__I
uint32_t AFEC_LCDR;
51
__O
uint32_t AFEC_IER;
52
__O
uint32_t AFEC_IDR;
53
__I
uint32_t AFEC_IMR;
54
__I
uint32_t AFEC_ISR;
55
__I
uint32_t Reserved1[6];
56
__I
uint32_t AFEC_OVER;
57
__IO
uint32_t AFEC_CWR;
58
__IO
uint32_t AFEC_CGR;
59
__I
uint32_t Reserved2[2];
60
__IO
uint32_t AFEC_DIFFR;
61
__IO
uint32_t AFEC_CSELR;
62
__I
uint32_t AFEC_CDR;
63
__IO
uint32_t AFEC_COCR;
64
__IO
uint32_t AFEC_TEMPMR;
65
__IO
uint32_t AFEC_TEMPCWR;
66
__I
uint32_t Reserved3[7];
67
__IO
uint32_t AFEC_ACR;
68
__I
uint32_t Reserved4[2];
69
__IO
uint32_t AFEC_SHMR;
70
__I
uint32_t Reserved5[11];
71
__IO
uint32_t AFEC_COSR;
72
__IO
uint32_t AFEC_CVR;
73
__IO
uint32_t AFEC_CECR;
74
__I
uint32_t Reserved6[2];
75
__IO
uint32_t AFEC_WPMR;
76
__I
uint32_t AFEC_WPSR;
77
Afec
78
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
79
/* -------- AFEC_CR : (AFEC Offset: 0x00) AFEC Control Register -------- */
80
#define AFEC_CR_SWRST (0x1u << 0)
81
#define AFEC_CR_START (0x1u << 1)
82
/* -------- AFEC_MR : (AFEC Offset: 0x04) AFEC Mode Register -------- */
83
#define AFEC_MR_TRGEN (0x1u << 0)
84
#define AFEC_MR_TRGEN_DIS (0x0u << 0)
85
#define AFEC_MR_TRGEN_EN (0x1u << 0)
86
#define AFEC_MR_TRGSEL_Pos 1
87
#define AFEC_MR_TRGSEL_Msk (0x7u << AFEC_MR_TRGSEL_Pos)
88
#define AFEC_MR_TRGSEL(value) ((AFEC_MR_TRGSEL_Msk & ((value) << AFEC_MR_TRGSEL_Pos)))
89
#define AFEC_MR_TRGSEL_AFEC_TRIG0 (0x0u << 1)
90
#define AFEC_MR_TRGSEL_AFEC_TRIG1 (0x1u << 1)
91
#define AFEC_MR_TRGSEL_AFEC_TRIG2 (0x2u << 1)
92
#define AFEC_MR_TRGSEL_AFEC_TRIG3 (0x3u << 1)
93
#define AFEC_MR_TRGSEL_AFEC_TRIG4 (0x4u << 1)
94
#define AFEC_MR_TRGSEL_AFEC_TRIG5 (0x5u << 1)
95
#define AFEC_MR_TRGSEL_AFEC_TRIG6 (0x6u << 1)
96
#define AFEC_MR_SLEEP (0x1u << 5)
97
#define AFEC_MR_SLEEP_NORMAL (0x0u << 5)
98
#define AFEC_MR_SLEEP_SLEEP (0x1u << 5)
99
#define AFEC_MR_FWUP (0x1u << 6)
100
#define AFEC_MR_FWUP_OFF (0x0u << 6)
101
#define AFEC_MR_FWUP_ON (0x1u << 6)
102
#define AFEC_MR_FREERUN (0x1u << 7)
103
#define AFEC_MR_FREERUN_OFF (0x0u << 7)
104
#define AFEC_MR_FREERUN_ON (0x1u << 7)
105
#define AFEC_MR_PRESCAL_Pos 8
106
#define AFEC_MR_PRESCAL_Msk (0xffu << AFEC_MR_PRESCAL_Pos)
107
#define AFEC_MR_PRESCAL(value) ((AFEC_MR_PRESCAL_Msk & ((value) << AFEC_MR_PRESCAL_Pos)))
108
#define AFEC_MR_STARTUP_Pos 16
109
#define AFEC_MR_STARTUP_Msk (0xfu << AFEC_MR_STARTUP_Pos)
110
#define AFEC_MR_STARTUP(value) ((AFEC_MR_STARTUP_Msk & ((value) << AFEC_MR_STARTUP_Pos)))
111
#define AFEC_MR_STARTUP_SUT0 (0x0u << 16)
112
#define AFEC_MR_STARTUP_SUT8 (0x1u << 16)
113
#define AFEC_MR_STARTUP_SUT16 (0x2u << 16)
114
#define AFEC_MR_STARTUP_SUT24 (0x3u << 16)
115
#define AFEC_MR_STARTUP_SUT64 (0x4u << 16)
116
#define AFEC_MR_STARTUP_SUT80 (0x5u << 16)
117
#define AFEC_MR_STARTUP_SUT96 (0x6u << 16)
118
#define AFEC_MR_STARTUP_SUT112 (0x7u << 16)
119
#define AFEC_MR_STARTUP_SUT512 (0x8u << 16)
120
#define AFEC_MR_STARTUP_SUT576 (0x9u << 16)
121
#define AFEC_MR_STARTUP_SUT640 (0xAu << 16)
122
#define AFEC_MR_STARTUP_SUT704 (0xBu << 16)
123
#define AFEC_MR_STARTUP_SUT768 (0xCu << 16)
124
#define AFEC_MR_STARTUP_SUT832 (0xDu << 16)
125
#define AFEC_MR_STARTUP_SUT896 (0xEu << 16)
126
#define AFEC_MR_STARTUP_SUT960 (0xFu << 16)
127
#define AFEC_MR_ONE (0x1u << 23)
128
#define AFEC_MR_TRACKTIM_Pos 24
129
#define AFEC_MR_TRACKTIM_Msk (0xfu << AFEC_MR_TRACKTIM_Pos)
130
#define AFEC_MR_TRACKTIM(value) ((AFEC_MR_TRACKTIM_Msk & ((value) << AFEC_MR_TRACKTIM_Pos)))
131
#define AFEC_MR_TRANSFER_Pos 28
132
#define AFEC_MR_TRANSFER_Msk (0x3u << AFEC_MR_TRANSFER_Pos)
133
#define AFEC_MR_TRANSFER(value) ((AFEC_MR_TRANSFER_Msk & ((value) << AFEC_MR_TRANSFER_Pos)))
134
#define AFEC_MR_USEQ (0x1u << 31)
135
#define AFEC_MR_USEQ_NUM_ORDER (0x0u << 31)
136
#define AFEC_MR_USEQ_REG_ORDER (0x1u << 31)
137
/* -------- AFEC_EMR : (AFEC Offset: 0x08) AFEC Extended Mode Register -------- */
138
#define AFEC_EMR_CMPMODE_Pos 0
139
#define AFEC_EMR_CMPMODE_Msk (0x3u << AFEC_EMR_CMPMODE_Pos)
140
#define AFEC_EMR_CMPMODE(value) ((AFEC_EMR_CMPMODE_Msk & ((value) << AFEC_EMR_CMPMODE_Pos)))
141
#define AFEC_EMR_CMPMODE_LOW (0x0u << 0)
142
#define AFEC_EMR_CMPMODE_HIGH (0x1u << 0)
143
#define AFEC_EMR_CMPMODE_IN (0x2u << 0)
144
#define AFEC_EMR_CMPMODE_OUT (0x3u << 0)
145
#define AFEC_EMR_CMPSEL_Pos 3
146
#define AFEC_EMR_CMPSEL_Msk (0x1fu << AFEC_EMR_CMPSEL_Pos)
147
#define AFEC_EMR_CMPSEL(value) ((AFEC_EMR_CMPSEL_Msk & ((value) << AFEC_EMR_CMPSEL_Pos)))
148
#define AFEC_EMR_CMPALL (0x1u << 9)
149
#define AFEC_EMR_CMPFILTER_Pos 12
150
#define AFEC_EMR_CMPFILTER_Msk (0x3u << AFEC_EMR_CMPFILTER_Pos)
151
#define AFEC_EMR_CMPFILTER(value) ((AFEC_EMR_CMPFILTER_Msk & ((value) << AFEC_EMR_CMPFILTER_Pos)))
152
#define AFEC_EMR_RES_Pos 16
153
#define AFEC_EMR_RES_Msk (0x7u << AFEC_EMR_RES_Pos)
154
#define AFEC_EMR_RES(value) ((AFEC_EMR_RES_Msk & ((value) << AFEC_EMR_RES_Pos)))
155
#define AFEC_EMR_RES_NO_AVERAGE (0x0u << 16)
156
#define AFEC_EMR_RES_OSR4 (0x2u << 16)
157
#define AFEC_EMR_RES_OSR16 (0x3u << 16)
158
#define AFEC_EMR_RES_OSR64 (0x4u << 16)
159
#define AFEC_EMR_RES_OSR256 (0x5u << 16)
160
#define AFEC_EMR_TAG (0x1u << 24)
161
#define AFEC_EMR_STM (0x1u << 25)
162
#define AFEC_EMR_SIGNMODE_Pos 28
163
#define AFEC_EMR_SIGNMODE_Msk (0x3u << AFEC_EMR_SIGNMODE_Pos)
164
#define AFEC_EMR_SIGNMODE(value) ((AFEC_EMR_SIGNMODE_Msk & ((value) << AFEC_EMR_SIGNMODE_Pos)))
165
#define AFEC_EMR_SIGNMODE_SE_UNSG_DF_SIGN (0x0u << 28)
166
#define AFEC_EMR_SIGNMODE_SE_SIGN_DF_UNSG (0x1u << 28)
167
#define AFEC_EMR_SIGNMODE_ALL_UNSIGNED (0x2u << 28)
168
#define AFEC_EMR_SIGNMODE_ALL_SIGNED (0x3u << 28)
169
/* -------- AFEC_SEQ1R : (AFEC Offset: 0x0C) AFEC Channel Sequence 1 Register -------- */
170
#define AFEC_SEQ1R_USCH0_Pos 0
171
#define AFEC_SEQ1R_USCH0_Msk (0xfu << AFEC_SEQ1R_USCH0_Pos)
172
#define AFEC_SEQ1R_USCH0(value) ((AFEC_SEQ1R_USCH0_Msk & ((value) << AFEC_SEQ1R_USCH0_Pos)))
173
#define AFEC_SEQ1R_USCH1_Pos 4
174
#define AFEC_SEQ1R_USCH1_Msk (0xfu << AFEC_SEQ1R_USCH1_Pos)
175
#define AFEC_SEQ1R_USCH1(value) ((AFEC_SEQ1R_USCH1_Msk & ((value) << AFEC_SEQ1R_USCH1_Pos)))
176
#define AFEC_SEQ1R_USCH2_Pos 8
177
#define AFEC_SEQ1R_USCH2_Msk (0xfu << AFEC_SEQ1R_USCH2_Pos)
178
#define AFEC_SEQ1R_USCH2(value) ((AFEC_SEQ1R_USCH2_Msk & ((value) << AFEC_SEQ1R_USCH2_Pos)))
179
#define AFEC_SEQ1R_USCH3_Pos 12
180
#define AFEC_SEQ1R_USCH3_Msk (0xfu << AFEC_SEQ1R_USCH3_Pos)
181
#define AFEC_SEQ1R_USCH3(value) ((AFEC_SEQ1R_USCH3_Msk & ((value) << AFEC_SEQ1R_USCH3_Pos)))
182
#define AFEC_SEQ1R_USCH4_Pos 16
183
#define AFEC_SEQ1R_USCH4_Msk (0xfu << AFEC_SEQ1R_USCH4_Pos)
184
#define AFEC_SEQ1R_USCH4(value) ((AFEC_SEQ1R_USCH4_Msk & ((value) << AFEC_SEQ1R_USCH4_Pos)))
185
#define AFEC_SEQ1R_USCH5_Pos 20
186
#define AFEC_SEQ1R_USCH5_Msk (0xfu << AFEC_SEQ1R_USCH5_Pos)
187
#define AFEC_SEQ1R_USCH5(value) ((AFEC_SEQ1R_USCH5_Msk & ((value) << AFEC_SEQ1R_USCH5_Pos)))
188
#define AFEC_SEQ1R_USCH6_Pos 24
189
#define AFEC_SEQ1R_USCH6_Msk (0xfu << AFEC_SEQ1R_USCH6_Pos)
190
#define AFEC_SEQ1R_USCH6(value) ((AFEC_SEQ1R_USCH6_Msk & ((value) << AFEC_SEQ1R_USCH6_Pos)))
191
#define AFEC_SEQ1R_USCH7_Pos 28
192
#define AFEC_SEQ1R_USCH7_Msk (0xfu << AFEC_SEQ1R_USCH7_Pos)
193
#define AFEC_SEQ1R_USCH7(value) ((AFEC_SEQ1R_USCH7_Msk & ((value) << AFEC_SEQ1R_USCH7_Pos)))
194
/* -------- AFEC_SEQ2R : (AFEC Offset: 0x10) AFEC Channel Sequence 2 Register -------- */
195
#define AFEC_SEQ2R_USCH8_Pos 0
196
#define AFEC_SEQ2R_USCH8_Msk (0xfu << AFEC_SEQ2R_USCH8_Pos)
197
#define AFEC_SEQ2R_USCH8(value) ((AFEC_SEQ2R_USCH8_Msk & ((value) << AFEC_SEQ2R_USCH8_Pos)))
198
#define AFEC_SEQ2R_USCH9_Pos 4
199
#define AFEC_SEQ2R_USCH9_Msk (0xfu << AFEC_SEQ2R_USCH9_Pos)
200
#define AFEC_SEQ2R_USCH9(value) ((AFEC_SEQ2R_USCH9_Msk & ((value) << AFEC_SEQ2R_USCH9_Pos)))
201
#define AFEC_SEQ2R_USCH10_Pos 8
202
#define AFEC_SEQ2R_USCH10_Msk (0xfu << AFEC_SEQ2R_USCH10_Pos)
203
#define AFEC_SEQ2R_USCH10(value) ((AFEC_SEQ2R_USCH10_Msk & ((value) << AFEC_SEQ2R_USCH10_Pos)))
204
#define AFEC_SEQ2R_USCH11_Pos 12
205
#define AFEC_SEQ2R_USCH11_Msk (0xfu << AFEC_SEQ2R_USCH11_Pos)
206
#define AFEC_SEQ2R_USCH11(value) ((AFEC_SEQ2R_USCH11_Msk & ((value) << AFEC_SEQ2R_USCH11_Pos)))
207
#define AFEC_SEQ2R_USCH12_Pos 16
208
#define AFEC_SEQ2R_USCH12_Msk (0xfu << AFEC_SEQ2R_USCH12_Pos)
209
#define AFEC_SEQ2R_USCH12(value) ((AFEC_SEQ2R_USCH12_Msk & ((value) << AFEC_SEQ2R_USCH12_Pos)))
210
#define AFEC_SEQ2R_USCH13_Pos 20
211
#define AFEC_SEQ2R_USCH13_Msk (0xfu << AFEC_SEQ2R_USCH13_Pos)
212
#define AFEC_SEQ2R_USCH13(value) ((AFEC_SEQ2R_USCH13_Msk & ((value) << AFEC_SEQ2R_USCH13_Pos)))
213
#define AFEC_SEQ2R_USCH14_Pos 24
214
#define AFEC_SEQ2R_USCH14_Msk (0xfu << AFEC_SEQ2R_USCH14_Pos)
215
#define AFEC_SEQ2R_USCH14(value) ((AFEC_SEQ2R_USCH14_Msk & ((value) << AFEC_SEQ2R_USCH14_Pos)))
216
#define AFEC_SEQ2R_USCH15_Pos 28
217
#define AFEC_SEQ2R_USCH15_Msk (0xfu << AFEC_SEQ2R_USCH15_Pos)
218
#define AFEC_SEQ2R_USCH15(value) ((AFEC_SEQ2R_USCH15_Msk & ((value) << AFEC_SEQ2R_USCH15_Pos)))
219
/* -------- AFEC_CHER : (AFEC Offset: 0x14) AFEC Channel Enable Register -------- */
220
#define AFEC_CHER_CH0 (0x1u << 0)
221
#define AFEC_CHER_CH1 (0x1u << 1)
222
#define AFEC_CHER_CH2 (0x1u << 2)
223
#define AFEC_CHER_CH3 (0x1u << 3)
224
#define AFEC_CHER_CH4 (0x1u << 4)
225
#define AFEC_CHER_CH5 (0x1u << 5)
226
#define AFEC_CHER_CH6 (0x1u << 6)
227
#define AFEC_CHER_CH7 (0x1u << 7)
228
#define AFEC_CHER_CH8 (0x1u << 8)
229
#define AFEC_CHER_CH9 (0x1u << 9)
230
#define AFEC_CHER_CH10 (0x1u << 10)
231
#define AFEC_CHER_CH11 (0x1u << 11)
232
/* -------- AFEC_CHDR : (AFEC Offset: 0x18) AFEC Channel Disable Register -------- */
233
#define AFEC_CHDR_CH0 (0x1u << 0)
234
#define AFEC_CHDR_CH1 (0x1u << 1)
235
#define AFEC_CHDR_CH2 (0x1u << 2)
236
#define AFEC_CHDR_CH3 (0x1u << 3)
237
#define AFEC_CHDR_CH4 (0x1u << 4)
238
#define AFEC_CHDR_CH5 (0x1u << 5)
239
#define AFEC_CHDR_CH6 (0x1u << 6)
240
#define AFEC_CHDR_CH7 (0x1u << 7)
241
#define AFEC_CHDR_CH8 (0x1u << 8)
242
#define AFEC_CHDR_CH9 (0x1u << 9)
243
#define AFEC_CHDR_CH10 (0x1u << 10)
244
#define AFEC_CHDR_CH11 (0x1u << 11)
245
/* -------- AFEC_CHSR : (AFEC Offset: 0x1C) AFEC Channel Status Register -------- */
246
#define AFEC_CHSR_CH0 (0x1u << 0)
247
#define AFEC_CHSR_CH1 (0x1u << 1)
248
#define AFEC_CHSR_CH2 (0x1u << 2)
249
#define AFEC_CHSR_CH3 (0x1u << 3)
250
#define AFEC_CHSR_CH4 (0x1u << 4)
251
#define AFEC_CHSR_CH5 (0x1u << 5)
252
#define AFEC_CHSR_CH6 (0x1u << 6)
253
#define AFEC_CHSR_CH7 (0x1u << 7)
254
#define AFEC_CHSR_CH8 (0x1u << 8)
255
#define AFEC_CHSR_CH9 (0x1u << 9)
256
#define AFEC_CHSR_CH10 (0x1u << 10)
257
#define AFEC_CHSR_CH11 (0x1u << 11)
258
/* -------- AFEC_LCDR : (AFEC Offset: 0x20) AFEC Last Converted Data Register -------- */
259
#define AFEC_LCDR_LDATA_Pos 0
260
#define AFEC_LCDR_LDATA_Msk (0xffffu << AFEC_LCDR_LDATA_Pos)
261
#define AFEC_LCDR_CHNB_Pos 24
262
#define AFEC_LCDR_CHNB_Msk (0xfu << AFEC_LCDR_CHNB_Pos)
263
/* -------- AFEC_IER : (AFEC Offset: 0x24) AFEC Interrupt Enable Register -------- */
264
#define AFEC_IER_EOC0 (0x1u << 0)
265
#define AFEC_IER_EOC1 (0x1u << 1)
266
#define AFEC_IER_EOC2 (0x1u << 2)
267
#define AFEC_IER_EOC3 (0x1u << 3)
268
#define AFEC_IER_EOC4 (0x1u << 4)
269
#define AFEC_IER_EOC5 (0x1u << 5)
270
#define AFEC_IER_EOC6 (0x1u << 6)
271
#define AFEC_IER_EOC7 (0x1u << 7)
272
#define AFEC_IER_EOC8 (0x1u << 8)
273
#define AFEC_IER_EOC9 (0x1u << 9)
274
#define AFEC_IER_EOC10 (0x1u << 10)
275
#define AFEC_IER_EOC11 (0x1u << 11)
276
#define AFEC_IER_DRDY (0x1u << 24)
277
#define AFEC_IER_GOVRE (0x1u << 25)
278
#define AFEC_IER_COMPE (0x1u << 26)
279
#define AFEC_IER_TEMPCHG (0x1u << 30)
280
/* -------- AFEC_IDR : (AFEC Offset: 0x28) AFEC Interrupt Disable Register -------- */
281
#define AFEC_IDR_EOC0 (0x1u << 0)
282
#define AFEC_IDR_EOC1 (0x1u << 1)
283
#define AFEC_IDR_EOC2 (0x1u << 2)
284
#define AFEC_IDR_EOC3 (0x1u << 3)
285
#define AFEC_IDR_EOC4 (0x1u << 4)
286
#define AFEC_IDR_EOC5 (0x1u << 5)
287
#define AFEC_IDR_EOC6 (0x1u << 6)
288
#define AFEC_IDR_EOC7 (0x1u << 7)
289
#define AFEC_IDR_EOC8 (0x1u << 8)
290
#define AFEC_IDR_EOC9 (0x1u << 9)
291
#define AFEC_IDR_EOC10 (0x1u << 10)
292
#define AFEC_IDR_EOC11 (0x1u << 11)
293
#define AFEC_IDR_DRDY (0x1u << 24)
294
#define AFEC_IDR_GOVRE (0x1u << 25)
295
#define AFEC_IDR_COMPE (0x1u << 26)
296
#define AFEC_IDR_TEMPCHG (0x1u << 30)
297
/* -------- AFEC_IMR : (AFEC Offset: 0x2C) AFEC Interrupt Mask Register -------- */
298
#define AFEC_IMR_EOC0 (0x1u << 0)
299
#define AFEC_IMR_EOC1 (0x1u << 1)
300
#define AFEC_IMR_EOC2 (0x1u << 2)
301
#define AFEC_IMR_EOC3 (0x1u << 3)
302
#define AFEC_IMR_EOC4 (0x1u << 4)
303
#define AFEC_IMR_EOC5 (0x1u << 5)
304
#define AFEC_IMR_EOC6 (0x1u << 6)
305
#define AFEC_IMR_EOC7 (0x1u << 7)
306
#define AFEC_IMR_EOC8 (0x1u << 8)
307
#define AFEC_IMR_EOC9 (0x1u << 9)
308
#define AFEC_IMR_EOC10 (0x1u << 10)
309
#define AFEC_IMR_EOC11 (0x1u << 11)
310
#define AFEC_IMR_DRDY (0x1u << 24)
311
#define AFEC_IMR_GOVRE (0x1u << 25)
312
#define AFEC_IMR_COMPE (0x1u << 26)
313
#define AFEC_IMR_TEMPCHG (0x1u << 30)
314
/* -------- AFEC_ISR : (AFEC Offset: 0x30) AFEC Interrupt Status Register -------- */
315
#define AFEC_ISR_EOC0 (0x1u << 0)
316
#define AFEC_ISR_EOC1 (0x1u << 1)
317
#define AFEC_ISR_EOC2 (0x1u << 2)
318
#define AFEC_ISR_EOC3 (0x1u << 3)
319
#define AFEC_ISR_EOC4 (0x1u << 4)
320
#define AFEC_ISR_EOC5 (0x1u << 5)
321
#define AFEC_ISR_EOC6 (0x1u << 6)
322
#define AFEC_ISR_EOC7 (0x1u << 7)
323
#define AFEC_ISR_EOC8 (0x1u << 8)
324
#define AFEC_ISR_EOC9 (0x1u << 9)
325
#define AFEC_ISR_EOC10 (0x1u << 10)
326
#define AFEC_ISR_EOC11 (0x1u << 11)
327
#define AFEC_ISR_DRDY (0x1u << 24)
328
#define AFEC_ISR_GOVRE (0x1u << 25)
329
#define AFEC_ISR_COMPE (0x1u << 26)
330
#define AFEC_ISR_TEMPCHG (0x1u << 30)
331
/* -------- AFEC_OVER : (AFEC Offset: 0x4C) AFEC Overrun Status Register -------- */
332
#define AFEC_OVER_OVRE0 (0x1u << 0)
333
#define AFEC_OVER_OVRE1 (0x1u << 1)
334
#define AFEC_OVER_OVRE2 (0x1u << 2)
335
#define AFEC_OVER_OVRE3 (0x1u << 3)
336
#define AFEC_OVER_OVRE4 (0x1u << 4)
337
#define AFEC_OVER_OVRE5 (0x1u << 5)
338
#define AFEC_OVER_OVRE6 (0x1u << 6)
339
#define AFEC_OVER_OVRE7 (0x1u << 7)
340
#define AFEC_OVER_OVRE8 (0x1u << 8)
341
#define AFEC_OVER_OVRE9 (0x1u << 9)
342
#define AFEC_OVER_OVRE10 (0x1u << 10)
343
#define AFEC_OVER_OVRE11 (0x1u << 11)
344
/* -------- AFEC_CWR : (AFEC Offset: 0x50) AFEC Compare Window Register -------- */
345
#define AFEC_CWR_LOWTHRES_Pos 0
346
#define AFEC_CWR_LOWTHRES_Msk (0xffffu << AFEC_CWR_LOWTHRES_Pos)
347
#define AFEC_CWR_LOWTHRES(value) ((AFEC_CWR_LOWTHRES_Msk & ((value) << AFEC_CWR_LOWTHRES_Pos)))
348
#define AFEC_CWR_HIGHTHRES_Pos 16
349
#define AFEC_CWR_HIGHTHRES_Msk (0xffffu << AFEC_CWR_HIGHTHRES_Pos)
350
#define AFEC_CWR_HIGHTHRES(value) ((AFEC_CWR_HIGHTHRES_Msk & ((value) << AFEC_CWR_HIGHTHRES_Pos)))
351
/* -------- AFEC_CGR : (AFEC Offset: 0x54) AFEC Channel Gain Register -------- */
352
#define AFEC_CGR_GAIN0_Pos 0
353
#define AFEC_CGR_GAIN0_Msk (0x3u << AFEC_CGR_GAIN0_Pos)
354
#define AFEC_CGR_GAIN0(value) ((AFEC_CGR_GAIN0_Msk & ((value) << AFEC_CGR_GAIN0_Pos)))
355
#define AFEC_CGR_GAIN1_Pos 2
356
#define AFEC_CGR_GAIN1_Msk (0x3u << AFEC_CGR_GAIN1_Pos)
357
#define AFEC_CGR_GAIN1(value) ((AFEC_CGR_GAIN1_Msk & ((value) << AFEC_CGR_GAIN1_Pos)))
358
#define AFEC_CGR_GAIN2_Pos 4
359
#define AFEC_CGR_GAIN2_Msk (0x3u << AFEC_CGR_GAIN2_Pos)
360
#define AFEC_CGR_GAIN2(value) ((AFEC_CGR_GAIN2_Msk & ((value) << AFEC_CGR_GAIN2_Pos)))
361
#define AFEC_CGR_GAIN3_Pos 6
362
#define AFEC_CGR_GAIN3_Msk (0x3u << AFEC_CGR_GAIN3_Pos)
363
#define AFEC_CGR_GAIN3(value) ((AFEC_CGR_GAIN3_Msk & ((value) << AFEC_CGR_GAIN3_Pos)))
364
#define AFEC_CGR_GAIN4_Pos 8
365
#define AFEC_CGR_GAIN4_Msk (0x3u << AFEC_CGR_GAIN4_Pos)
366
#define AFEC_CGR_GAIN4(value) ((AFEC_CGR_GAIN4_Msk & ((value) << AFEC_CGR_GAIN4_Pos)))
367
#define AFEC_CGR_GAIN5_Pos 10
368
#define AFEC_CGR_GAIN5_Msk (0x3u << AFEC_CGR_GAIN5_Pos)
369
#define AFEC_CGR_GAIN5(value) ((AFEC_CGR_GAIN5_Msk & ((value) << AFEC_CGR_GAIN5_Pos)))
370
#define AFEC_CGR_GAIN6_Pos 12
371
#define AFEC_CGR_GAIN6_Msk (0x3u << AFEC_CGR_GAIN6_Pos)
372
#define AFEC_CGR_GAIN6(value) ((AFEC_CGR_GAIN6_Msk & ((value) << AFEC_CGR_GAIN6_Pos)))
373
#define AFEC_CGR_GAIN7_Pos 14
374
#define AFEC_CGR_GAIN7_Msk (0x3u << AFEC_CGR_GAIN7_Pos)
375
#define AFEC_CGR_GAIN7(value) ((AFEC_CGR_GAIN7_Msk & ((value) << AFEC_CGR_GAIN7_Pos)))
376
#define AFEC_CGR_GAIN8_Pos 16
377
#define AFEC_CGR_GAIN8_Msk (0x3u << AFEC_CGR_GAIN8_Pos)
378
#define AFEC_CGR_GAIN8(value) ((AFEC_CGR_GAIN8_Msk & ((value) << AFEC_CGR_GAIN8_Pos)))
379
#define AFEC_CGR_GAIN9_Pos 18
380
#define AFEC_CGR_GAIN9_Msk (0x3u << AFEC_CGR_GAIN9_Pos)
381
#define AFEC_CGR_GAIN9(value) ((AFEC_CGR_GAIN9_Msk & ((value) << AFEC_CGR_GAIN9_Pos)))
382
#define AFEC_CGR_GAIN10_Pos 20
383
#define AFEC_CGR_GAIN10_Msk (0x3u << AFEC_CGR_GAIN10_Pos)
384
#define AFEC_CGR_GAIN10(value) ((AFEC_CGR_GAIN10_Msk & ((value) << AFEC_CGR_GAIN10_Pos)))
385
#define AFEC_CGR_GAIN11_Pos 22
386
#define AFEC_CGR_GAIN11_Msk (0x3u << AFEC_CGR_GAIN11_Pos)
387
#define AFEC_CGR_GAIN11(value) ((AFEC_CGR_GAIN11_Msk & ((value) << AFEC_CGR_GAIN11_Pos)))
388
/* -------- AFEC_DIFFR : (AFEC Offset: 0x60) AFEC Channel Differential Register -------- */
389
#define AFEC_DIFFR_DIFF0 (0x1u << 0)
390
#define AFEC_DIFFR_DIFF1 (0x1u << 1)
391
#define AFEC_DIFFR_DIFF2 (0x1u << 2)
392
#define AFEC_DIFFR_DIFF3 (0x1u << 3)
393
#define AFEC_DIFFR_DIFF4 (0x1u << 4)
394
#define AFEC_DIFFR_DIFF5 (0x1u << 5)
395
#define AFEC_DIFFR_DIFF6 (0x1u << 6)
396
#define AFEC_DIFFR_DIFF7 (0x1u << 7)
397
#define AFEC_DIFFR_DIFF8 (0x1u << 8)
398
#define AFEC_DIFFR_DIFF9 (0x1u << 9)
399
#define AFEC_DIFFR_DIFF10 (0x1u << 10)
400
#define AFEC_DIFFR_DIFF11 (0x1u << 11)
401
/* -------- AFEC_CSELR : (AFEC Offset: 0x64) AFEC Channel Selection Register -------- */
402
#define AFEC_CSELR_CSEL_Pos 0
403
#define AFEC_CSELR_CSEL_Msk (0xfu << AFEC_CSELR_CSEL_Pos)
404
#define AFEC_CSELR_CSEL(value) ((AFEC_CSELR_CSEL_Msk & ((value) << AFEC_CSELR_CSEL_Pos)))
405
/* -------- AFEC_CDR : (AFEC Offset: 0x68) AFEC Channel Data Register -------- */
406
#define AFEC_CDR_DATA_Pos 0
407
#define AFEC_CDR_DATA_Msk (0xffffu << AFEC_CDR_DATA_Pos)
408
/* -------- AFEC_COCR : (AFEC Offset: 0x6C) AFEC Channel Offset Compensation Register -------- */
409
#define AFEC_COCR_AOFF_Pos 0
410
#define AFEC_COCR_AOFF_Msk (0x3ffu << AFEC_COCR_AOFF_Pos)
411
#define AFEC_COCR_AOFF(value) ((AFEC_COCR_AOFF_Msk & ((value) << AFEC_COCR_AOFF_Pos)))
412
/* -------- AFEC_TEMPMR : (AFEC Offset: 0x70) AFEC Temperature Sensor Mode Register -------- */
413
#define AFEC_TEMPMR_RTCT (0x1u << 0)
414
#define AFEC_TEMPMR_TEMPCMPMOD_Pos 4
415
#define AFEC_TEMPMR_TEMPCMPMOD_Msk (0x3u << AFEC_TEMPMR_TEMPCMPMOD_Pos)
416
#define AFEC_TEMPMR_TEMPCMPMOD(value) ((AFEC_TEMPMR_TEMPCMPMOD_Msk & ((value) << AFEC_TEMPMR_TEMPCMPMOD_Pos)))
417
#define AFEC_TEMPMR_TEMPCMPMOD_LOW (0x0u << 4)
418
#define AFEC_TEMPMR_TEMPCMPMOD_HIGH (0x1u << 4)
419
#define AFEC_TEMPMR_TEMPCMPMOD_IN (0x2u << 4)
420
#define AFEC_TEMPMR_TEMPCMPMOD_OUT (0x3u << 4)
421
/* -------- AFEC_TEMPCWR : (AFEC Offset: 0x74) AFEC Temperature Compare Window Register -------- */
422
#define AFEC_TEMPCWR_TLOWTHRES_Pos 0
423
#define AFEC_TEMPCWR_TLOWTHRES_Msk (0xffffu << AFEC_TEMPCWR_TLOWTHRES_Pos)
424
#define AFEC_TEMPCWR_TLOWTHRES(value) ((AFEC_TEMPCWR_TLOWTHRES_Msk & ((value) << AFEC_TEMPCWR_TLOWTHRES_Pos)))
425
#define AFEC_TEMPCWR_THIGHTHRES_Pos 16
426
#define AFEC_TEMPCWR_THIGHTHRES_Msk (0xffffu << AFEC_TEMPCWR_THIGHTHRES_Pos)
427
#define AFEC_TEMPCWR_THIGHTHRES(value) ((AFEC_TEMPCWR_THIGHTHRES_Msk & ((value) << AFEC_TEMPCWR_THIGHTHRES_Pos)))
428
/* -------- AFEC_ACR : (AFEC Offset: 0x94) AFEC Analog Control Register -------- */
429
#define AFEC_ACR_PGA0EN (0x1u << 2)
430
#define AFEC_ACR_PGA1EN (0x1u << 3)
431
#define AFEC_ACR_IBCTL_Pos 8
432
#define AFEC_ACR_IBCTL_Msk (0x3u << AFEC_ACR_IBCTL_Pos)
433
#define AFEC_ACR_IBCTL(value) ((AFEC_ACR_IBCTL_Msk & ((value) << AFEC_ACR_IBCTL_Pos)))
434
/* -------- AFEC_SHMR : (AFEC Offset: 0xA0) AFEC Sample & Hold Mode Register -------- */
435
#define AFEC_SHMR_DUAL0 (0x1u << 0)
436
#define AFEC_SHMR_DUAL1 (0x1u << 1)
437
#define AFEC_SHMR_DUAL2 (0x1u << 2)
438
#define AFEC_SHMR_DUAL3 (0x1u << 3)
439
#define AFEC_SHMR_DUAL4 (0x1u << 4)
440
#define AFEC_SHMR_DUAL5 (0x1u << 5)
441
#define AFEC_SHMR_DUAL6 (0x1u << 6)
442
#define AFEC_SHMR_DUAL7 (0x1u << 7)
443
#define AFEC_SHMR_DUAL8 (0x1u << 8)
444
#define AFEC_SHMR_DUAL9 (0x1u << 9)
445
#define AFEC_SHMR_DUAL10 (0x1u << 10)
446
#define AFEC_SHMR_DUAL11 (0x1u << 11)
447
/* -------- AFEC_COSR : (AFEC Offset: 0xD0) AFEC Correction Select Register -------- */
448
#define AFEC_COSR_CSEL (0x1u << 0)
449
/* -------- AFEC_CVR : (AFEC Offset: 0xD4) AFEC Correction Values Register -------- */
450
#define AFEC_CVR_OFFSETCORR_Pos 0
451
#define AFEC_CVR_OFFSETCORR_Msk (0xffffu << AFEC_CVR_OFFSETCORR_Pos)
452
#define AFEC_CVR_OFFSETCORR(value) ((AFEC_CVR_OFFSETCORR_Msk & ((value) << AFEC_CVR_OFFSETCORR_Pos)))
453
#define AFEC_CVR_GAINCORR_Pos 16
454
#define AFEC_CVR_GAINCORR_Msk (0xffffu << AFEC_CVR_GAINCORR_Pos)
455
#define AFEC_CVR_GAINCORR(value) ((AFEC_CVR_GAINCORR_Msk & ((value) << AFEC_CVR_GAINCORR_Pos)))
456
/* -------- AFEC_CECR : (AFEC Offset: 0xD8) AFEC Channel Error Correction Register -------- */
457
#define AFEC_CECR_ECORR0 (0x1u << 0)
458
#define AFEC_CECR_ECORR1 (0x1u << 1)
459
#define AFEC_CECR_ECORR2 (0x1u << 2)
460
#define AFEC_CECR_ECORR3 (0x1u << 3)
461
#define AFEC_CECR_ECORR4 (0x1u << 4)
462
#define AFEC_CECR_ECORR5 (0x1u << 5)
463
#define AFEC_CECR_ECORR6 (0x1u << 6)
464
#define AFEC_CECR_ECORR7 (0x1u << 7)
465
#define AFEC_CECR_ECORR8 (0x1u << 8)
466
#define AFEC_CECR_ECORR9 (0x1u << 9)
467
#define AFEC_CECR_ECORR10 (0x1u << 10)
468
#define AFEC_CECR_ECORR11 (0x1u << 11)
469
/* -------- AFEC_WPMR : (AFEC Offset: 0xE4) AFEC Write Protection Mode Register -------- */
470
#define AFEC_WPMR_WPEN (0x1u << 0)
471
#define AFEC_WPMR_WPKEY_Pos 8
472
#define AFEC_WPMR_WPKEY_Msk (0xffffffu << AFEC_WPMR_WPKEY_Pos)
473
#define AFEC_WPMR_WPKEY(value) ((AFEC_WPMR_WPKEY_Msk & ((value) << AFEC_WPMR_WPKEY_Pos)))
474
#define AFEC_WPMR_WPKEY_PASSWD (0x414443u << 8)
475
/* -------- AFEC_WPSR : (AFEC Offset: 0xE8) AFEC Write Protection Status Register -------- */
476
#define AFEC_WPSR_WPVS (0x1u << 0)
477
#define AFEC_WPSR_WPVSRC_Pos 8
478
#define AFEC_WPSR_WPVSRC_Msk (0xffffu << AFEC_WPSR_WPVSRC_Pos)
479
481
482
483
#endif
/* _SAMS70_AFEC_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Afec
Afec hardware registers.
Definition
component_afec.h:41
