RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
same70
same70q19.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAME70Q19_
31
#define _SAME70Q19_
32
41
42
#ifdef __cplusplus
43
extern
"C"
44
#endif
45
46
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
47
#include <stdint.h>
48
#endif
49
50
51
/* CMSIS DEFINITIONS FOR SAME70Q19 */
52
55
57
typedef
enum
IRQn
58
59
/****** Cortex-M7 Processor Exceptions Numbers ******************************/
60
NonMaskableInt_IRQn = -14,
61
HardFault_IRQn = -13,
62
MemoryManagement_IRQn = -12,
63
BusFault_IRQn = -11,
64
UsageFault_IRQn = -10,
65
SVCall_IRQn = -5,
66
DebugMonitor_IRQn = -4,
67
PendSV_IRQn = -2,
68
SysTick_IRQn = -1,
69
/****** SAME70Q19 specific Interrupt Numbers *********************************/
70
71
SUPC_IRQn = 0,
72
RSTC_IRQn = 1,
73
RTC_IRQn = 2,
74
RTT_IRQn = 3,
75
WDT_IRQn = 4,
76
PMC_IRQn = 5,
77
EFC_IRQn = 6,
78
UART0_IRQn = 7,
79
UART1_IRQn = 8,
80
PIOA_IRQn = 10,
81
PIOB_IRQn = 11,
82
PIOC_IRQn = 12,
83
USART0_IRQn = 13,
84
USART1_IRQn = 14,
85
USART2_IRQn = 15,
86
PIOD_IRQn = 16,
87
PIOE_IRQn = 17,
88
HSMCI_IRQn = 18,
89
TWIHS0_IRQn = 19,
90
TWIHS1_IRQn = 20,
91
SPI0_IRQn = 21,
92
SSC_IRQn = 22,
93
TC0_IRQn = 23,
94
TC1_IRQn = 24,
95
TC2_IRQn = 25,
96
TC3_IRQn = 26,
97
TC4_IRQn = 27,
98
TC5_IRQn = 28,
99
AFEC0_IRQn = 29,
100
DACC_IRQn = 30,
101
PWM0_IRQn = 31,
102
ICM_IRQn = 32,
103
ACC_IRQn = 33,
104
USBHS_IRQn = 34,
105
MCAN0_IRQn = 35,
106
MCAN1_IRQn = 37,
107
GMAC_IRQn = 39,
108
AFEC1_IRQn = 40,
109
TWIHS2_IRQn = 41,
110
SPI1_IRQn = 42,
111
QSPI_IRQn = 43,
112
UART2_IRQn = 44,
113
UART3_IRQn = 45,
114
UART4_IRQn = 46,
115
TC6_IRQn = 47,
116
TC7_IRQn = 48,
117
TC8_IRQn = 49,
118
TC9_IRQn = 50,
119
TC10_IRQn = 51,
120
TC11_IRQn = 52,
121
AES_IRQn = 56,
122
TRNG_IRQn = 57,
123
XDMAC_IRQn = 58,
124
ISI_IRQn = 59,
125
PWM1_IRQn = 60,
126
SDRAMC_IRQn = 62,
127
RSWDT_IRQn = 63,
128
129
PERIPH_COUNT_IRQn = 64
130
IRQn_Type
131
132
typedef
struct
_DeviceVectors
133
134
/* Stack pointer */
135
void
* pvStack;
136
137
/* Cortex-M handlers */
138
void
* pfnReset_Handler;
139
void
* pfnNMI_Handler;
140
void
* pfnHardFault_Handler;
141
void
* pfnMemManage_Handler;
142
void
* pfnBusFault_Handler;
143
void
* pfnUsageFault_Handler;
144
void
* pfnReserved1_Handler;
145
void
* pfnReserved2_Handler;
146
void
* pfnReserved3_Handler;
147
void
* pfnReserved4_Handler;
148
void
* pfnSVC_Handler;
149
void
* pfnDebugMon_Handler;
150
void
* pfnReserved5_Handler;
151
void
* pfnPendSV_Handler;
152
void
* pfnSysTick_Handler;
153
154
/* Peripheral handlers */
155
void
* pfnSUPC_Handler;
/* 0 Supply Controller */
156
void
* pfnRSTC_Handler;
/* 1 Reset Controller */
157
void
* pfnRTC_Handler;
/* 2 Real Time Clock */
158
void
* pfnRTT_Handler;
/* 3 Real Time Timer */
159
void
* pfnWDT_Handler;
/* 4 Watchdog Timer */
160
void
* pfnPMC_Handler;
/* 5 Power Management Controller */
161
void
* pfnEFC_Handler;
/* 6 Enhanced Embedded Flash Controller */
162
void
* pfnUART0_Handler;
/* 7 UART 0 */
163
void
* pfnUART1_Handler;
/* 8 UART 1 */
164
void
* pvReserved9;
165
void
* pfnPIOA_Handler;
/* 10 Parallel I/O Controller A */
166
void
* pfnPIOB_Handler;
/* 11 Parallel I/O Controller B */
167
void
* pfnPIOC_Handler;
/* 12 Parallel I/O Controller C */
168
void
* pfnUSART0_Handler;
/* 13 USART 0 */
169
void
* pfnUSART1_Handler;
/* 14 USART 1 */
170
void
* pfnUSART2_Handler;
/* 15 USART 2 */
171
void
* pfnPIOD_Handler;
/* 16 Parallel I/O Controller D */
172
void
* pfnPIOE_Handler;
/* 17 Parallel I/O Controller E */
173
void
* pfnHSMCI_Handler;
/* 18 Multimedia Card Interface */
174
void
* pfnTWIHS0_Handler;
/* 19 Two Wire Interface 0 HS */
175
void
* pfnTWIHS1_Handler;
/* 20 Two Wire Interface 1 HS */
176
void
* pfnSPI0_Handler;
/* 21 Serial Peripheral Interface 0 */
177
void
* pfnSSC_Handler;
/* 22 Synchronous Serial Controller */
178
void
* pfnTC0_Handler;
/* 23 Timer/Counter 0 */
179
void
* pfnTC1_Handler;
/* 24 Timer/Counter 1 */
180
void
* pfnTC2_Handler;
/* 25 Timer/Counter 2 */
181
void
* pfnTC3_Handler;
/* 26 Timer/Counter 3 */
182
void
* pfnTC4_Handler;
/* 27 Timer/Counter 4 */
183
void
* pfnTC5_Handler;
/* 28 Timer/Counter 5 */
184
void
* pfnAFEC0_Handler;
/* 29 Analog Front End 0 */
185
void
* pfnDACC_Handler;
/* 30 Digital To Analog Converter */
186
void
* pfnPWM0_Handler;
/* 31 Pulse Width Modulation 0 */
187
void
* pfnICM_Handler;
/* 32 Integrity Check Monitor */
188
void
* pfnACC_Handler;
/* 33 Analog Comparator */
189
void
* pfnUSBHS_Handler;
/* 34 USB Host / Device Controller */
190
void
* pfnMCAN0_Handler;
/* 35 MCAN Controller 0 */
191
void
* pvReserved36;
192
void
* pfnMCAN1_Handler;
/* 37 MCAN Controller 1 */
193
void
* pvReserved38;
194
void
* pfnGMAC_Handler;
/* 39 Ethernet MAC */
195
void
* pfnAFEC1_Handler;
/* 40 Analog Front End 1 */
196
void
* pfnTWIHS2_Handler;
/* 41 Two Wire Interface 2 HS */
197
void
* pfnSPI1_Handler;
/* 42 Serial Peripheral Interface 1 */
198
void
* pfnQSPI_Handler;
/* 43 Quad I/O Serial Peripheral Interface */
199
void
* pfnUART2_Handler;
/* 44 UART 2 */
200
void
* pfnUART3_Handler;
/* 45 UART 3 */
201
void
* pfnUART4_Handler;
/* 46 UART 4 */
202
void
* pfnTC6_Handler;
/* 47 Timer/Counter 6 */
203
void
* pfnTC7_Handler;
/* 48 Timer/Counter 7 */
204
void
* pfnTC8_Handler;
/* 49 Timer/Counter 8 */
205
void
* pfnTC9_Handler;
/* 50 Timer/Counter 9 */
206
void
* pfnTC10_Handler;
/* 51 Timer/Counter 10 */
207
void
* pfnTC11_Handler;
/* 52 Timer/Counter 11 */
208
void
* pvReserved53;
209
void
* pvReserved54;
210
void
* pvReserved55;
211
void
* pfnAES_Handler;
/* 56 AES */
212
void
* pfnTRNG_Handler;
/* 57 True Random Generator */
213
void
* pfnXDMAC_Handler;
/* 58 DMA */
214
void
* pfnISI_Handler;
/* 59 Camera Interface */
215
void
* pfnPWM1_Handler;
/* 60 Pulse Width Modulation 1 */
216
void
* pvReserved61;
217
void
* pfnSDRAMC_Handler;
/* 62 SDRAM Controller */
218
void
* pfnRSWDT_Handler;
/* 63 Reinforced Secure Watchdog Timer */
219
} DeviceVectors;
220
221
/* Cortex-M7 core handlers */
222
void
Reset_Handler (
void
223
void
NMI_Handler
void
224
void
HardFault_Handler
void
225
void
MemManage_Handler
void
226
void
BusFault_Handler
void
227
void
UsageFault_Handler
void
228
void
SVC_Handler (
void
229
void
DebugMon_Handler (
void
230
void
PendSV_Handler (
void
231
void
SysTick_Handler (
void
232
233
/* Peripherals handlers */
234
void
ACC_Handler (
void
235
void
AES_Handler (
void
236
void
AFEC0_Handler (
void
237
void
AFEC1_Handler (
void
238
void
DACC_Handler (
void
239
void
EFC_Handler (
void
240
void
GMAC_Handler (
void
241
void
HSMCI_Handler (
void
242
void
ICM_Handler (
void
243
void
ISI_Handler (
void
244
void
MCAN0_Handler (
void
245
void
MCAN1_Handler (
void
246
void
PIOA_Handler (
void
247
void
PIOB_Handler (
void
248
void
PIOC_Handler (
void
249
void
PIOD_Handler (
void
250
void
PIOE_Handler (
void
251
void
PMC_Handler (
void
252
void
PWM0_Handler (
void
253
void
PWM1_Handler (
void
254
void
QSPI_Handler (
void
255
void
RSTC_Handler (
void
256
void
RSWDT_Handler (
void
257
void
RTC_Handler (
void
258
void
RTT_Handler (
void
259
void
SDRAMC_Handler (
void
260
void
SPI0_Handler (
void
261
void
SPI1_Handler (
void
262
void
SSC_Handler (
void
263
void
SUPC_Handler (
void
264
void
TC0_Handler (
void
265
void
TC1_Handler (
void
266
void
TC2_Handler (
void
267
void
TC3_Handler (
void
268
void
TC4_Handler (
void
269
void
TC5_Handler (
void
270
void
TC6_Handler (
void
271
void
TC7_Handler (
void
272
void
TC8_Handler (
void
273
void
TC9_Handler (
void
274
void
TC10_Handler (
void
275
void
TC11_Handler (
void
276
void
TRNG_Handler (
void
277
void
TWIHS0_Handler (
void
278
void
TWIHS1_Handler (
void
279
void
TWIHS2_Handler (
void
280
void
UART0_Handler (
void
281
void
UART1_Handler (
void
282
void
UART2_Handler (
void
283
void
UART3_Handler (
void
284
void
UART4_Handler (
void
285
void
USART0_Handler (
void
286
void
USART1_Handler (
void
287
void
USART2_Handler (
void
288
void
USBHS_Handler (
void
289
void
WDT_Handler (
void
290
void
XDMAC_Handler (
void
291
295
296
#define __CM7_REV 0x0000
297
#define __MPU_PRESENT 1
298
#define __NVIC_PRIO_BITS 3
299
#define __FPU_PRESENT 1
300
#define __FPU_DP 1
301
#define __ICACHE_PRESENT 1
302
#define __DCACHE_PRESENT 1
303
#define __DTCM_PRESENT 1
304
#define __ITCM_PRESENT 1
305
#define __Vendor_SysTickConfig 0
306
307
308
* \brief CMSIS includes
309
310
311
core_cm7.h
312
#if !defined DONT_USE_CMSIS_INIT
313
#include "system_same70.h"
314
#endif
/* DONT_USE_CMSIS_INIT */
315
317
318
320
323
324
#include "component/component_acc.h"
325
#include "component/component_aes.h"
326
#include "component/component_afec.h"
327
#include "component/component_chipid.h"
328
#include "component/component_dacc.h"
329
#include "component/component_efc.h"
330
#include "component/component_gmac.h"
331
#include "component/component_gpbr.h"
332
#include "component/component_hsmci.h"
333
#include "component/component_icm.h"
334
#include "component/component_isi.h"
335
#include "component/component_matrix.h"
336
#include "component/component_mcan.h"
337
#include "component/component_pio.h"
338
#include "component/component_pmc.h"
339
#include "component/component_pwm.h"
340
#include "component/component_qspi.h"
341
#include "component/component_rstc.h"
342
#include "component/component_rswdt.h"
343
#include "component/component_rtc.h"
344
#include "component/component_rtt.h"
345
#include "component/component_sdramc.h"
346
#include "component/component_smc.h"
347
#include "component/component_spi.h"
348
#include "component/component_ssc.h"
349
#include "component/component_supc.h"
350
#include "component/component_tc.h"
351
#include "component/component_trng.h"
352
#include "component/component_twihs.h"
353
#include "component/component_uart.h"
354
#include "component/component_usart.h"
355
#include "component/component_usbhs.h"
356
#include "component/component_utmi.h"
357
#include "component/component_wdt.h"
358
#include "component/component_xdmac.h"
360
361
#ifndef __rtems__
362
363
/* REGISTER ACCESS DEFINITIONS FOR SAME70Q19 */
364
367
368
#include "instance/instance_hsmci.h"
369
#include "instance/instance_ssc.h"
370
#include "instance/instance_spi0.h"
371
#include "instance/instance_tc0.h"
372
#include "instance/instance_tc1.h"
373
#include "instance/instance_tc2.h"
374
#include "instance/instance_twihs0.h"
375
#include "instance/instance_twihs1.h"
376
#include "instance/instance_pwm0.h"
377
#include "instance/instance_usart0.h"
378
#include "instance/instance_usart1.h"
379
#include "instance/instance_usart2.h"
380
#include "instance/instance_mcan0.h"
381
#include "instance/instance_mcan1.h"
382
#include "instance/instance_usbhs.h"
383
#include "instance/instance_afec0.h"
384
#include "instance/instance_dacc.h"
385
#include "instance/instance_acc.h"
386
#include "instance/instance_icm.h"
387
#include "instance/instance_isi.h"
388
#include "instance/instance_gmac.h"
389
#include "instance/instance_tc3.h"
390
#include "instance/instance_spi1.h"
391
#include "instance/instance_pwm1.h"
392
#include "instance/instance_twihs2.h"
393
#include "instance/instance_afec1.h"
394
#include "instance/instance_aes.h"
395
#include "instance/instance_trng.h"
396
#include "instance/instance_xdmac.h"
397
#include "instance/instance_qspi.h"
398
#include "instance/instance_smc.h"
399
#include "instance/instance_sdramc.h"
400
#include "instance/instance_matrix.h"
401
#include "instance/instance_utmi.h"
402
#include "instance/instance_pmc.h"
403
#include "instance/instance_uart0.h"
404
#include "instance/instance_chipid.h"
405
#include "instance/instance_uart1.h"
406
#include "instance/instance_efc.h"
407
#include "instance/instance_pioa.h"
408
#include "instance/instance_piob.h"
409
#include "instance/instance_pioc.h"
410
#include "instance/instance_piod.h"
411
#include "instance/instance_pioe.h"
412
#include "instance/instance_rstc.h"
413
#include "instance/instance_supc.h"
414
#include "instance/instance_rtt.h"
415
#include "instance/instance_wdt.h"
416
#include "instance/instance_rtc.h"
417
#include "instance/instance_gpbr.h"
418
#include "instance/instance_rswdt.h"
419
#include "instance/instance_uart2.h"
420
#include "instance/instance_uart3.h"
421
#include "instance/instance_uart4.h"
423
#endif
/* __rtems__ */
424
425
426
/* PERIPHERAL ID DEFINITIONS FOR SAME70Q19 */
427
430
431
#define ID_SUPC ( 0)
432
#define ID_RSTC ( 1)
433
#define ID_RTC ( 2)
434
#define ID_RTT ( 3)
435
#define ID_WDT ( 4)
436
#define ID_PMC ( 5)
437
#define ID_EFC ( 6)
438
#define ID_UART0 ( 7)
439
#define ID_UART1 ( 8)
440
#define ID_SMC ( 9)
441
#define ID_PIOA (10)
442
#define ID_PIOB (11)
443
#define ID_PIOC (12)
444
#define ID_USART0 (13)
445
#define ID_USART1 (14)
446
#define ID_USART2 (15)
447
#define ID_PIOD (16)
448
#define ID_PIOE (17)
449
#define ID_HSMCI (18)
450
#define ID_TWIHS0 (19)
451
#define ID_TWIHS1 (20)
452
#define ID_SPI0 (21)
453
#define ID_SSC (22)
454
#define ID_TC0 (23)
455
#define ID_TC1 (24)
456
#define ID_TC2 (25)
457
#define ID_TC3 (26)
458
#define ID_TC4 (27)
459
#define ID_TC5 (28)
460
#define ID_AFEC0 (29)
461
#define ID_DACC (30)
462
#define ID_PWM0 (31)
463
#define ID_ICM (32)
464
#define ID_ACC (33)
465
#define ID_USBHS (34)
466
#define ID_MCAN0 (35)
467
#define ID_MCAN1 (37)
468
#define ID_GMAC (39)
469
#define ID_AFEC1 (40)
470
#define ID_TWIHS2 (41)
471
#define ID_SPI1 (42)
472
#define ID_QSPI (43)
473
#define ID_UART2 (44)
474
#define ID_UART3 (45)
475
#define ID_UART4 (46)
476
#define ID_TC6 (47)
477
#define ID_TC7 (48)
478
#define ID_TC8 (49)
479
#define ID_TC9 (50)
480
#define ID_TC10 (51)
481
#define ID_TC11 (52)
482
#define ID_AES (56)
483
#define ID_TRNG (57)
484
#define ID_XDMAC (58)
485
#define ID_ISI (59)
486
#define ID_PWM1 (60)
487
#define ID_SDRAMC (62)
488
#define ID_RSWDT (63)
489
490
#define ID_PERIPH_COUNT (64)
492
493
494
/* BASE ADDRESS DEFINITIONS FOR SAME70Q19 */
495
498
499
#if (defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
500
#define HSMCI (0x40000000U)
501
#define SSC (0x40004000U)
502
#define SPI0 (0x40008000U)
503
#define TC0 (0x4000C000U)
504
#define TC1 (0x40010000U)
505
#define TC2 (0x40014000U)
506
#define TWIHS0 (0x40018000U)
507
#define TWIHS1 (0x4001C000U)
508
#define PWM0 (0x40020000U)
509
#define USART0 (0x40024000U)
510
#define USART1 (0x40028000U)
511
#define USART2 (0x4002C000U)
512
#define MCAN0 (0x40030000U)
513
#define MCAN1 (0x40034000U)
514
#define USBHS (0x40038000U)
515
#define AFEC0 (0x4003C000U)
516
#define DACC (0x40040000U)
517
#define ACC (0x40044000U)
518
#define ICM (0x40048000U)
519
#define ISI (0x4004C000U)
520
#define GMAC (0x40050000U)
521
#define TC3 (0x40054000U)
522
#define SPI1 (0x40058000U)
523
#define PWM1 (0x4005C000U)
524
#define TWIHS2 (0x40060000U)
525
#define AFEC1 (0x40064000U)
526
#define AES (0x4006C000U)
527
#define TRNG (0x40070000U)
528
#define XDMAC (0x40078000U)
529
#define QSPI (0x4007C000U)
530
#define SMC (0x40080000U)
531
#define SDRAMC (0x40084000U)
532
#define MATRIX (0x40088000U)
533
#define UTMI (0x400E0400U)
534
#define PMC (0x400E0600U)
535
#define UART0 (0x400E0800U)
536
#define CHIPID (0x400E0940U)
537
#define UART1 (0x400E0A00U)
538
#define EFC (0x400E0C00U)
539
#define PIOA (0x400E0E00U)
540
#define PIOB (0x400E1000U)
541
#define PIOC (0x400E1200U)
542
#define PIOD (0x400E1400U)
543
#define PIOE (0x400E1600U)
544
#define RSTC (0x400E1800U)
545
#define SUPC (0x400E1810U)
546
#define RTT (0x400E1830U)
547
#define WDT (0x400E1850U)
548
#define RTC (0x400E1860U)
549
#define GPBR (0x400E1890U)
550
#define RSWDT (0x400E1900U)
551
#define UART2 (0x400E1A00U)
552
#define UART3 (0x400E1C00U)
553
#define UART4 (0x400E1E00U)
554
#else
555
#define HSMCI ((Hsmci *)0x40000000U)
556
#define SSC ((Ssc *)0x40004000U)
557
#define SPI0 ((Spi *)0x40008000U)
558
#define TC0 ((Tc *)0x4000C000U)
559
#define TC1 ((Tc *)0x40010000U)
560
#define TC2 ((Tc *)0x40014000U)
561
#define TWIHS0 ((Twihs *)0x40018000U)
562
#define TWIHS1 ((Twihs *)0x4001C000U)
563
#define PWM0 ((Pwm *)0x40020000U)
564
#define USART0 ((Usart *)0x40024000U)
565
#define USART1 ((Usart *)0x40028000U)
566
#define USART2 ((Usart *)0x4002C000U)
567
#define MCAN0 ((Mcan *)0x40030000U)
568
#define MCAN1 ((Mcan *)0x40034000U)
569
#define USBHS ((Usbhs *)0x40038000U)
570
#define AFEC0 ((Afec *)0x4003C000U)
571
#define DACC ((Dacc *)0x40040000U)
572
#define ACC ((Acc *)0x40044000U)
573
#define ICM ((Icm *)0x40048000U)
574
#define ISI ((Isi *)0x4004C000U)
575
#define GMAC ((Gmac *)0x40050000U)
576
#define TC3 ((Tc *)0x40054000U)
577
#define SPI1 ((Spi *)0x40058000U)
578
#define PWM1 ((Pwm *)0x4005C000U)
579
#define TWIHS2 ((Twihs *)0x40060000U)
580
#define AFEC1 ((Afec *)0x40064000U)
581
#define AES ((Aes *)0x4006C000U)
582
#define TRNG ((Trng *)0x40070000U)
583
#define XDMAC ((Xdmac *)0x40078000U)
584
#define QSPI ((Qspi *)0x4007C000U)
585
#define SMC ((Smc *)0x40080000U)
586
#define SDRAMC ((Sdramc *)0x40084000U)
587
#define MATRIX ((Matrix *)0x40088000U)
588
#define UTMI ((Utmi *)0x400E0400U)
589
#define PMC ((Pmc *)0x400E0600U)
590
#define UART0 ((Uart *)0x400E0800U)
591
#define CHIPID ((Chipid *)0x400E0940U)
592
#define UART1 ((Uart *)0x400E0A00U)
593
#define EFC ((Efc *)0x400E0C00U)
594
#define PIOA ((Pio *)0x400E0E00U)
595
#define PIOB ((Pio *)0x400E1000U)
596
#define PIOC ((Pio *)0x400E1200U)
597
#define PIOD ((Pio *)0x400E1400U)
598
#define PIOE ((Pio *)0x400E1600U)
599
#define RSTC ((Rstc *)0x400E1800U)
600
#define SUPC ((Supc *)0x400E1810U)
601
#define RTT ((Rtt *)0x400E1830U)
602
#define WDT ((Wdt *)0x400E1850U)
603
#define RTC ((Rtc *)0x400E1860U)
604
#define GPBR ((Gpbr *)0x400E1890U)
605
#define RSWDT ((Rswdt *)0x400E1900U)
606
#define UART2 ((Uart *)0x400E1A00U)
607
#define UART3 ((Uart *)0x400E1C00U)
608
#define UART4 ((Uart *)0x400E1E00U)
609
#endif
/* (defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
611
612
613
/* PIO DEFINITIONS FOR SAME70Q19 */
614
617
618
#include "pio/pio_same70q19.h"
620
621
622
/* MEMORY MAPPING DEFINITIONS FOR SAME70Q19 */
623
624
625
#define IFLASH_SIZE (0x80000u)
626
#define IFLASH_PAGE_SIZE (512u)
627
#define IFLASH_LOCK_REGION_SIZE (8192u)
628
#define IFLASH_NB_OF_PAGES (1024u)
629
#define IFLASH_NB_OF_LOCK_BITS (32u)
630
#define IRAM_SIZE (0x40000u)
631
632
#define QSPIMEM_ADDR (0x80000000u)
633
#define AXIMX_ADDR (0xA0000000u)
634
#define ITCM_ADDR (0x00000000u)
635
#define IFLASH_ADDR (0x00400000u)
636
#define IROM_ADDR (0x00800000u)
637
#define DTCM_ADDR (0x20000000u)
638
#define IRAM_ADDR (0x20400000u)
639
#define EBI_CS0_ADDR (0x60000000u)
640
#define EBI_CS1_ADDR (0x61000000u)
641
#define EBI_CS2_ADDR (0x62000000u)
642
#define EBI_CS3_ADDR (0x63000000u)
643
#define SDRAM_CS_ADDR (0x70000000u)
644
645
646
/* MISCELLANEOUS DEFINITIONS FOR SAME70Q19 */
647
648
649
#define CHIP_JTAGID (0x05B3D03FUL)
650
#define CHIP_CIDR (0xA10D0A00UL)
651
#define CHIP_EXID (0x00000002UL)
652
653
654
/* ELECTRICAL DEFINITIONS FOR SAME70Q19 */
655
656
657
/* %ATMEL_ELECTRICAL% */
658
659
/* Device characteristics */
660
#define CHIP_FREQ_SLCK_RC_MIN (20000UL)
661
#define CHIP_FREQ_SLCK_RC (32000UL)
662
#define CHIP_FREQ_SLCK_RC_MAX (44000UL)
663
#define CHIP_FREQ_MAINCK_RC_4MHZ (4000000UL)
664
#define CHIP_FREQ_MAINCK_RC_8MHZ (8000000UL)
665
#define CHIP_FREQ_MAINCK_RC_12MHZ (12000000UL)
666
#define CHIP_FREQ_CPU_MAX (120000000UL)
667
#define CHIP_FREQ_XTAL_32K (32768UL)
668
#define CHIP_FREQ_XTAL_12M (12000000UL)
669
670
/* Embedded Flash Read Wait State (VDDCORE set at 1.20V) */
671
#define CHIP_FREQ_FWS_0 (20000000UL)
672
#define CHIP_FREQ_FWS_1 (40000000UL)
673
#define CHIP_FREQ_FWS_2 (60000000UL)
674
#define CHIP_FREQ_FWS_3 (80000000UL)
675
#define CHIP_FREQ_FWS_4 (100000000UL)
676
#define CHIP_FREQ_FWS_5 (123000000UL)
677
678
#ifdef __cplusplus
679
680
#endif
681
683
684
#endif
/* _SAME70Q19_ */
core_cm7.h
CMSIS Cortex-M7 Core Peripheral Access Layer Header File.
UsageFault_Handler
void UsageFault_Handler(void)
Default UsageFault interrupt handler.
Definition
exceptions.c:207
HardFault_Handler
void HardFault_Handler(void)
Default HardFault interrupt handler.
Definition
exceptions.c:168
MemManage_Handler
void MemManage_Handler(void)
Default MemManage interrupt handler.
Definition
exceptions.c:180
NMI_Handler
void NMI_Handler(void)
Default NMI interrupt handler.
Definition
exceptions.c:53
BusFault_Handler
void BusFault_Handler(void)
Default BusFault interrupt handler.
Definition
exceptions.c:193
IRQn_Type
IRQn_Type
STM32H7XX Interrupt Number Definition, according to the selected device in Library_configuration_sect...
Definition
stm32h723xx.h:49
_DeviceVectors
Definition
same70j19.h:122
