RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
same70
component
component_trng.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAME70_TRNG_COMPONENT_
31
#define _SAME70_TRNG_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t
TRNG_CR
43
__I
uint32_t Reserved1[3];
44
__O
uint32_t
TRNG_IER
45
__O
uint32_t
TRNG_IDR
46
__I
uint32_t
TRNG_IMR
47
__I
uint32_t
TRNG_ISR
48
__I
uint32_t Reserved2[12];
49
__I
uint32_t
TRNG_ODATA
50
Trng
51
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
52
/* -------- TRNG_CR : (TRNG Offset: 0x00) Control Register -------- */
53
#define TRNG_CR_ENABLE (0x1u << 0)
54
#define TRNG_CR_KEY_Pos 8
55
#define TRNG_CR_KEY_Msk (0xffffffu << TRNG_CR_KEY_Pos)
56
#define TRNG_CR_KEY(value) ((TRNG_CR_KEY_Msk & ((value) << TRNG_CR_KEY_Pos)))
57
#define TRNG_CR_KEY_PASSWD (0x524E47u << 8)
58
/* -------- TRNG_IER : (TRNG Offset: 0x10) Interrupt Enable Register -------- */
59
#define TRNG_IER_DATRDY (0x1u << 0)
60
/* -------- TRNG_IDR : (TRNG Offset: 0x14) Interrupt Disable Register -------- */
61
#define TRNG_IDR_DATRDY (0x1u << 0)
62
/* -------- TRNG_IMR : (TRNG Offset: 0x18) Interrupt Mask Register -------- */
63
#define TRNG_IMR_DATRDY (0x1u << 0)
64
/* -------- TRNG_ISR : (TRNG Offset: 0x1C) Interrupt Status Register -------- */
65
#define TRNG_ISR_DATRDY (0x1u << 0)
66
/* -------- TRNG_ODATA : (TRNG Offset: 0x50) Output Data Register -------- */
67
#define TRNG_ODATA_ODATA_Pos 0
68
#define TRNG_ODATA_ODATA_Msk (0xffffffffu << TRNG_ODATA_ODATA_Pos)
69
71
72
73
#endif
/* _SAME70_TRNG_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__I
#define __I
Definition
core_cm4.h:236
Trng
Trng hardware registers.
Definition
component_trng.h:41
Trng::TRNG_CR
__O uint32_t TRNG_CR
(Trng Offset: 0x00) Control Register
Definition
component_trng.h:42
Trng::TRNG_IDR
__O uint32_t TRNG_IDR
(Trng Offset: 0x14) Interrupt Disable Register
Definition
component_trng.h:45
Trng::TRNG_IER
__O uint32_t TRNG_IER
(Trng Offset: 0x10) Interrupt Enable Register
Definition
component_trng.h:44
Trng::TRNG_IMR
__I uint32_t TRNG_IMR
(Trng Offset: 0x18) Interrupt Mask Register
Definition
component_trng.h:46
Trng::TRNG_ODATA
__I uint32_t TRNG_ODATA
(Trng Offset: 0x50) Output Data Register
Definition
component_trng.h:49
Trng::TRNG_ISR
__I uint32_t TRNG_ISR
(Trng Offset: 0x1C) Interrupt Status Register
Definition
component_trng.h:47
