RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
same70
component
component_supc.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAME70_SUPC_COMPONENT_
31
#define _SAME70_SUPC_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__O
uint32_t
SUPC_CR
43
__IO
uint32_t
SUPC_SMMR
44
__IO
uint32_t
SUPC_MR
45
__IO
uint32_t
SUPC_WUMR
46
__IO
uint32_t
SUPC_WUIR
47
__I
uint32_t
SUPC_SR
48
Supc
49
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
50
/* -------- SUPC_CR : (SUPC Offset: 0x00) Supply Controller Control Register -------- */
51
#define SUPC_CR_VROFF (0x1u << 2)
52
#define SUPC_CR_VROFF_NO_EFFECT (0x0u << 2)
53
#define SUPC_CR_VROFF_STOP_VREG (0x1u << 2)
54
#define SUPC_CR_XTALSEL (0x1u << 3)
55
#define SUPC_CR_XTALSEL_NO_EFFECT (0x0u << 3)
56
#define SUPC_CR_XTALSEL_CRYSTAL_SEL (0x1u << 3)
57
#define SUPC_CR_KEY_Pos 24
58
#define SUPC_CR_KEY_Msk (0xffu << SUPC_CR_KEY_Pos)
59
#define SUPC_CR_KEY(value) ((SUPC_CR_KEY_Msk & ((value) << SUPC_CR_KEY_Pos)))
60
#define SUPC_CR_KEY_PASSWD (0xA5u << 24)
61
/* -------- SUPC_SMMR : (SUPC Offset: 0x04) Supply Controller Supply Monitor Mode Register -------- */
62
#define SUPC_SMMR_SMTH_Pos 0
63
#define SUPC_SMMR_SMTH_Msk (0xfu << SUPC_SMMR_SMTH_Pos)
64
#define SUPC_SMMR_SMTH(value) ((SUPC_SMMR_SMTH_Msk & ((value) << SUPC_SMMR_SMTH_Pos)))
65
#define SUPC_SMMR_SMSMPL_Pos 8
66
#define SUPC_SMMR_SMSMPL_Msk (0x7u << SUPC_SMMR_SMSMPL_Pos)
67
#define SUPC_SMMR_SMSMPL(value) ((SUPC_SMMR_SMSMPL_Msk & ((value) << SUPC_SMMR_SMSMPL_Pos)))
68
#define SUPC_SMMR_SMSMPL_SMD (0x0u << 8)
69
#define SUPC_SMMR_SMSMPL_CSM (0x1u << 8)
70
#define SUPC_SMMR_SMSMPL_32SLCK (0x2u << 8)
71
#define SUPC_SMMR_SMSMPL_256SLCK (0x3u << 8)
72
#define SUPC_SMMR_SMSMPL_2048SLCK (0x4u << 8)
73
#define SUPC_SMMR_SMRSTEN (0x1u << 12)
74
#define SUPC_SMMR_SMRSTEN_NOT_ENABLE (0x0u << 12)
75
#define SUPC_SMMR_SMRSTEN_ENABLE (0x1u << 12)
76
#define SUPC_SMMR_SMIEN (0x1u << 13)
77
#define SUPC_SMMR_SMIEN_NOT_ENABLE (0x0u << 13)
78
#define SUPC_SMMR_SMIEN_ENABLE (0x1u << 13)
79
/* -------- SUPC_MR : (SUPC Offset: 0x08) Supply Controller Mode Register -------- */
80
#define SUPC_MR_BODRSTEN (0x1u << 12)
81
#define SUPC_MR_BODRSTEN_NOT_ENABLE (0x0u << 12)
82
#define SUPC_MR_BODRSTEN_ENABLE (0x1u << 12)
83
#define SUPC_MR_BODDIS (0x1u << 13)
84
#define SUPC_MR_BODDIS_ENABLE (0x0u << 13)
85
#define SUPC_MR_BODDIS_DISABLE (0x1u << 13)
86
#define SUPC_MR_ONREG (0x1u << 14)
87
#define SUPC_MR_ONREG_ONREG_UNUSED (0x0u << 14)
88
#define SUPC_MR_ONREG_ONREG_USED (0x1u << 14)
89
#define SUPC_MR_BKUPRETON (0x1u << 17)
90
#define SUPC_MR_OSCBYPASS (0x1u << 20)
91
#define SUPC_MR_OSCBYPASS_NO_EFFECT (0x0u << 20)
92
#define SUPC_MR_OSCBYPASS_BYPASS (0x1u << 20)
93
#define SUPC_MR_KEY_Pos 24
94
#define SUPC_MR_KEY_Msk (0xffu << SUPC_MR_KEY_Pos)
95
#define SUPC_MR_KEY(value) ((SUPC_MR_KEY_Msk & ((value) << SUPC_MR_KEY_Pos)))
96
#define SUPC_MR_KEY_PASSWD (0xA5u << 24)
97
/* -------- SUPC_WUMR : (SUPC Offset: 0x0C) Supply Controller Wake-up Mode Register -------- */
98
#define SUPC_WUMR_SMEN (0x1u << 1)
99
#define SUPC_WUMR_SMEN_NOT_ENABLE (0x0u << 1)
100
#define SUPC_WUMR_SMEN_ENABLE (0x1u << 1)
101
#define SUPC_WUMR_RTTEN (0x1u << 2)
102
#define SUPC_WUMR_RTTEN_NOT_ENABLE (0x0u << 2)
103
#define SUPC_WUMR_RTTEN_ENABLE (0x1u << 2)
104
#define SUPC_WUMR_RTCEN (0x1u << 3)
105
#define SUPC_WUMR_RTCEN_NOT_ENABLE (0x0u << 3)
106
#define SUPC_WUMR_RTCEN_ENABLE (0x1u << 3)
107
#define SUPC_WUMR_LPDBCEN0 (0x1u << 5)
108
#define SUPC_WUMR_LPDBCEN0_NOT_ENABLE (0x0u << 5)
109
#define SUPC_WUMR_LPDBCEN0_ENABLE (0x1u << 5)
110
#define SUPC_WUMR_LPDBCEN1 (0x1u << 6)
111
#define SUPC_WUMR_LPDBCEN1_NOT_ENABLE (0x0u << 6)
112
#define SUPC_WUMR_LPDBCEN1_ENABLE (0x1u << 6)
113
#define SUPC_WUMR_LPDBCCLR (0x1u << 7)
114
#define SUPC_WUMR_LPDBCCLR_NOT_ENABLE (0x0u << 7)
115
#define SUPC_WUMR_LPDBCCLR_ENABLE (0x1u << 7)
116
#define SUPC_WUMR_WKUPDBC_Pos 12
117
#define SUPC_WUMR_WKUPDBC_Msk (0x7u << SUPC_WUMR_WKUPDBC_Pos)
118
#define SUPC_WUMR_WKUPDBC(value) ((SUPC_WUMR_WKUPDBC_Msk & ((value) << SUPC_WUMR_WKUPDBC_Pos)))
119
#define SUPC_WUMR_WKUPDBC_IMMEDIATE (0x0u << 12)
120
#define SUPC_WUMR_WKUPDBC_3_SLCK (0x1u << 12)
121
#define SUPC_WUMR_WKUPDBC_32_SLCK (0x2u << 12)
122
#define SUPC_WUMR_WKUPDBC_512_SLCK (0x3u << 12)
123
#define SUPC_WUMR_WKUPDBC_4096_SLCK (0x4u << 12)
124
#define SUPC_WUMR_WKUPDBC_32768_SLCK (0x5u << 12)
125
#define SUPC_WUMR_LPDBC_Pos 16
126
#define SUPC_WUMR_LPDBC_Msk (0x7u << SUPC_WUMR_LPDBC_Pos)
127
#define SUPC_WUMR_LPDBC(value) ((SUPC_WUMR_LPDBC_Msk & ((value) << SUPC_WUMR_LPDBC_Pos)))
128
#define SUPC_WUMR_LPDBC_DISABLE (0x0u << 16)
129
#define SUPC_WUMR_LPDBC_2_RTCOUT (0x1u << 16)
130
#define SUPC_WUMR_LPDBC_3_RTCOUT (0x2u << 16)
131
#define SUPC_WUMR_LPDBC_4_RTCOUT (0x3u << 16)
132
#define SUPC_WUMR_LPDBC_5_RTCOUT (0x4u << 16)
133
#define SUPC_WUMR_LPDBC_6_RTCOUT (0x5u << 16)
134
#define SUPC_WUMR_LPDBC_7_RTCOUT (0x6u << 16)
135
#define SUPC_WUMR_LPDBC_8_RTCOUT (0x7u << 16)
136
/* -------- SUPC_WUIR : (SUPC Offset: 0x10) Supply Controller Wake-up Inputs Register -------- */
137
#define SUPC_WUIR_WKUPEN0 (0x1u << 0)
138
#define SUPC_WUIR_WKUPEN0_DISABLE (0x0u << 0)
139
#define SUPC_WUIR_WKUPEN0_ENABLE (0x1u << 0)
140
#define SUPC_WUIR_WKUPEN1 (0x1u << 1)
141
#define SUPC_WUIR_WKUPEN1_DISABLE (0x0u << 1)
142
#define SUPC_WUIR_WKUPEN1_ENABLE (0x1u << 1)
143
#define SUPC_WUIR_WKUPEN2 (0x1u << 2)
144
#define SUPC_WUIR_WKUPEN2_DISABLE (0x0u << 2)
145
#define SUPC_WUIR_WKUPEN2_ENABLE (0x1u << 2)
146
#define SUPC_WUIR_WKUPEN3 (0x1u << 3)
147
#define SUPC_WUIR_WKUPEN3_DISABLE (0x0u << 3)
148
#define SUPC_WUIR_WKUPEN3_ENABLE (0x1u << 3)
149
#define SUPC_WUIR_WKUPEN4 (0x1u << 4)
150
#define SUPC_WUIR_WKUPEN4_DISABLE (0x0u << 4)
151
#define SUPC_WUIR_WKUPEN4_ENABLE (0x1u << 4)
152
#define SUPC_WUIR_WKUPEN5 (0x1u << 5)
153
#define SUPC_WUIR_WKUPEN5_DISABLE (0x0u << 5)
154
#define SUPC_WUIR_WKUPEN5_ENABLE (0x1u << 5)
155
#define SUPC_WUIR_WKUPEN6 (0x1u << 6)
156
#define SUPC_WUIR_WKUPEN6_DISABLE (0x0u << 6)
157
#define SUPC_WUIR_WKUPEN6_ENABLE (0x1u << 6)
158
#define SUPC_WUIR_WKUPEN7 (0x1u << 7)
159
#define SUPC_WUIR_WKUPEN7_DISABLE (0x0u << 7)
160
#define SUPC_WUIR_WKUPEN7_ENABLE (0x1u << 7)
161
#define SUPC_WUIR_WKUPEN8 (0x1u << 8)
162
#define SUPC_WUIR_WKUPEN8_DISABLE (0x0u << 8)
163
#define SUPC_WUIR_WKUPEN8_ENABLE (0x1u << 8)
164
#define SUPC_WUIR_WKUPEN9 (0x1u << 9)
165
#define SUPC_WUIR_WKUPEN9_DISABLE (0x0u << 9)
166
#define SUPC_WUIR_WKUPEN9_ENABLE (0x1u << 9)
167
#define SUPC_WUIR_WKUPEN10 (0x1u << 10)
168
#define SUPC_WUIR_WKUPEN10_DISABLE (0x0u << 10)
169
#define SUPC_WUIR_WKUPEN10_ENABLE (0x1u << 10)
170
#define SUPC_WUIR_WKUPEN11 (0x1u << 11)
171
#define SUPC_WUIR_WKUPEN11_DISABLE (0x0u << 11)
172
#define SUPC_WUIR_WKUPEN11_ENABLE (0x1u << 11)
173
#define SUPC_WUIR_WKUPEN12 (0x1u << 12)
174
#define SUPC_WUIR_WKUPEN12_DISABLE (0x0u << 12)
175
#define SUPC_WUIR_WKUPEN12_ENABLE (0x1u << 12)
176
#define SUPC_WUIR_WKUPEN13 (0x1u << 13)
177
#define SUPC_WUIR_WKUPEN13_DISABLE (0x0u << 13)
178
#define SUPC_WUIR_WKUPEN13_ENABLE (0x1u << 13)
179
#define SUPC_WUIR_WKUPT0 (0x1u << 16)
180
#define SUPC_WUIR_WKUPT0_LOW (0x0u << 16)
181
#define SUPC_WUIR_WKUPT0_HIGH (0x1u << 16)
182
#define SUPC_WUIR_WKUPT1 (0x1u << 17)
183
#define SUPC_WUIR_WKUPT1_LOW (0x0u << 17)
184
#define SUPC_WUIR_WKUPT1_HIGH (0x1u << 17)
185
#define SUPC_WUIR_WKUPT2 (0x1u << 18)
186
#define SUPC_WUIR_WKUPT2_LOW (0x0u << 18)
187
#define SUPC_WUIR_WKUPT2_HIGH (0x1u << 18)
188
#define SUPC_WUIR_WKUPT3 (0x1u << 19)
189
#define SUPC_WUIR_WKUPT3_LOW (0x0u << 19)
190
#define SUPC_WUIR_WKUPT3_HIGH (0x1u << 19)
191
#define SUPC_WUIR_WKUPT4 (0x1u << 20)
192
#define SUPC_WUIR_WKUPT4_LOW (0x0u << 20)
193
#define SUPC_WUIR_WKUPT4_HIGH (0x1u << 20)
194
#define SUPC_WUIR_WKUPT5 (0x1u << 21)
195
#define SUPC_WUIR_WKUPT5_LOW (0x0u << 21)
196
#define SUPC_WUIR_WKUPT5_HIGH (0x1u << 21)
197
#define SUPC_WUIR_WKUPT6 (0x1u << 22)
198
#define SUPC_WUIR_WKUPT6_LOW (0x0u << 22)
199
#define SUPC_WUIR_WKUPT6_HIGH (0x1u << 22)
200
#define SUPC_WUIR_WKUPT7 (0x1u << 23)
201
#define SUPC_WUIR_WKUPT7_LOW (0x0u << 23)
202
#define SUPC_WUIR_WKUPT7_HIGH (0x1u << 23)
203
#define SUPC_WUIR_WKUPT8 (0x1u << 24)
204
#define SUPC_WUIR_WKUPT8_LOW (0x0u << 24)
205
#define SUPC_WUIR_WKUPT8_HIGH (0x1u << 24)
206
#define SUPC_WUIR_WKUPT9 (0x1u << 25)
207
#define SUPC_WUIR_WKUPT9_LOW (0x0u << 25)
208
#define SUPC_WUIR_WKUPT9_HIGH (0x1u << 25)
209
#define SUPC_WUIR_WKUPT10 (0x1u << 26)
210
#define SUPC_WUIR_WKUPT10_LOW (0x0u << 26)
211
#define SUPC_WUIR_WKUPT10_HIGH (0x1u << 26)
212
#define SUPC_WUIR_WKUPT11 (0x1u << 27)
213
#define SUPC_WUIR_WKUPT11_LOW (0x0u << 27)
214
#define SUPC_WUIR_WKUPT11_HIGH (0x1u << 27)
215
#define SUPC_WUIR_WKUPT12 (0x1u << 28)
216
#define SUPC_WUIR_WKUPT12_LOW (0x0u << 28)
217
#define SUPC_WUIR_WKUPT12_HIGH (0x1u << 28)
218
#define SUPC_WUIR_WKUPT13 (0x1u << 29)
219
#define SUPC_WUIR_WKUPT13_LOW (0x0u << 29)
220
#define SUPC_WUIR_WKUPT13_HIGH (0x1u << 29)
221
/* -------- SUPC_SR : (SUPC Offset: 0x14) Supply Controller Status Register -------- */
222
#define SUPC_SR_WKUPS (0x1u << 1)
223
#define SUPC_SR_WKUPS_NO (0x0u << 1)
224
#define SUPC_SR_WKUPS_PRESENT (0x1u << 1)
225
#define SUPC_SR_SMWS (0x1u << 2)
226
#define SUPC_SR_SMWS_NO (0x0u << 2)
227
#define SUPC_SR_SMWS_PRESENT (0x1u << 2)
228
#define SUPC_SR_BODRSTS (0x1u << 3)
229
#define SUPC_SR_BODRSTS_NO (0x0u << 3)
230
#define SUPC_SR_BODRSTS_PRESENT (0x1u << 3)
231
#define SUPC_SR_SMRSTS (0x1u << 4)
232
#define SUPC_SR_SMRSTS_NO (0x0u << 4)
233
#define SUPC_SR_SMRSTS_PRESENT (0x1u << 4)
234
#define SUPC_SR_SMS (0x1u << 5)
235
#define SUPC_SR_SMS_NO (0x0u << 5)
236
#define SUPC_SR_SMS_PRESENT (0x1u << 5)
237
#define SUPC_SR_SMOS (0x1u << 6)
238
#define SUPC_SR_SMOS_HIGH (0x0u << 6)
239
#define SUPC_SR_SMOS_LOW (0x1u << 6)
240
#define SUPC_SR_OSCSEL (0x1u << 7)
241
#define SUPC_SR_OSCSEL_RC (0x0u << 7)
242
#define SUPC_SR_OSCSEL_CRYST (0x1u << 7)
243
#define SUPC_SR_LPDBCS0 (0x1u << 13)
244
#define SUPC_SR_LPDBCS0_NO (0x0u << 13)
245
#define SUPC_SR_LPDBCS0_PRESENT (0x1u << 13)
246
#define SUPC_SR_LPDBCS1 (0x1u << 14)
247
#define SUPC_SR_LPDBCS1_NO (0x0u << 14)
248
#define SUPC_SR_LPDBCS1_PRESENT (0x1u << 14)
249
#define SUPC_SR_WKUPIS0 (0x1u << 16)
250
#define SUPC_SR_WKUPIS0_DIS (0x0u << 16)
251
#define SUPC_SR_WKUPIS0_EN (0x1u << 16)
252
#define SUPC_SR_WKUPIS1 (0x1u << 17)
253
#define SUPC_SR_WKUPIS1_DIS (0x0u << 17)
254
#define SUPC_SR_WKUPIS1_EN (0x1u << 17)
255
#define SUPC_SR_WKUPIS2 (0x1u << 18)
256
#define SUPC_SR_WKUPIS2_DIS (0x0u << 18)
257
#define SUPC_SR_WKUPIS2_EN (0x1u << 18)
258
#define SUPC_SR_WKUPIS3 (0x1u << 19)
259
#define SUPC_SR_WKUPIS3_DIS (0x0u << 19)
260
#define SUPC_SR_WKUPIS3_EN (0x1u << 19)
261
#define SUPC_SR_WKUPIS4 (0x1u << 20)
262
#define SUPC_SR_WKUPIS4_DIS (0x0u << 20)
263
#define SUPC_SR_WKUPIS4_EN (0x1u << 20)
264
#define SUPC_SR_WKUPIS5 (0x1u << 21)
265
#define SUPC_SR_WKUPIS5_DIS (0x0u << 21)
266
#define SUPC_SR_WKUPIS5_EN (0x1u << 21)
267
#define SUPC_SR_WKUPIS6 (0x1u << 22)
268
#define SUPC_SR_WKUPIS6_DIS (0x0u << 22)
269
#define SUPC_SR_WKUPIS6_EN (0x1u << 22)
270
#define SUPC_SR_WKUPIS7 (0x1u << 23)
271
#define SUPC_SR_WKUPIS7_DIS (0x0u << 23)
272
#define SUPC_SR_WKUPIS7_EN (0x1u << 23)
273
#define SUPC_SR_WKUPIS8 (0x1u << 24)
274
#define SUPC_SR_WKUPIS8_DIS (0x0u << 24)
275
#define SUPC_SR_WKUPIS8_EN (0x1u << 24)
276
#define SUPC_SR_WKUPIS9 (0x1u << 25)
277
#define SUPC_SR_WKUPIS9_DIS (0x0u << 25)
278
#define SUPC_SR_WKUPIS9_EN (0x1u << 25)
279
#define SUPC_SR_WKUPIS10 (0x1u << 26)
280
#define SUPC_SR_WKUPIS10_DIS (0x0u << 26)
281
#define SUPC_SR_WKUPIS10_EN (0x1u << 26)
282
#define SUPC_SR_WKUPIS11 (0x1u << 27)
283
#define SUPC_SR_WKUPIS11_DIS (0x0u << 27)
284
#define SUPC_SR_WKUPIS11_EN (0x1u << 27)
285
#define SUPC_SR_WKUPIS12 (0x1u << 28)
286
#define SUPC_SR_WKUPIS12_DIS (0x0u << 28)
287
#define SUPC_SR_WKUPIS12_EN (0x1u << 28)
288
#define SUPC_SR_WKUPIS13 (0x1u << 29)
289
#define SUPC_SR_WKUPIS13_DIS (0x0u << 29)
290
#define SUPC_SR_WKUPIS13_EN (0x1u << 29)
291
293
294
295
#endif
/* _SAME70_SUPC_COMPONENT_ */
__O
#define __O
Definition
core_cm4.h:238
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Supc
Supc hardware registers.
Definition
component_supc.h:41
Supc::SUPC_CR
__O uint32_t SUPC_CR
(Supc Offset: 0x00) Supply Controller Control Register
Definition
component_supc.h:42
Supc::SUPC_SMMR
__IO uint32_t SUPC_SMMR
(Supc Offset: 0x04) Supply Controller Supply Monitor Mode Register
Definition
component_supc.h:43
Supc::SUPC_MR
__IO uint32_t SUPC_MR
(Supc Offset: 0x08) Supply Controller Mode Register
Definition
component_supc.h:44
Supc::SUPC_WUIR
__IO uint32_t SUPC_WUIR
(Supc Offset: 0x10) Supply Controller Wake-up Inputs Register
Definition
component_supc.h:46
Supc::SUPC_SR
__I uint32_t SUPC_SR
(Supc Offset: 0x14) Supply Controller Status Register
Definition
component_supc.h:47
Supc::SUPC_WUMR
__IO uint32_t SUPC_WUMR
(Supc Offset: 0x0C) Supply Controller Wake-up Mode Register
Definition
component_supc.h:45
