RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
same70
component
component_rtt.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAME70_RTT_COMPONENT_
31
#define _SAME70_RTT_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__IO
uint32_t
RTT_MR
43
__IO
uint32_t
RTT_AR
44
__I
uint32_t
RTT_VR
45
__I
uint32_t
RTT_SR
46
Rtt
47
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
48
/* -------- RTT_MR : (RTT Offset: 0x00) Mode Register -------- */
49
#define RTT_MR_RTPRES_Pos 0
50
#define RTT_MR_RTPRES_Msk (0xffffu << RTT_MR_RTPRES_Pos)
51
#define RTT_MR_RTPRES(value) ((RTT_MR_RTPRES_Msk & ((value) << RTT_MR_RTPRES_Pos)))
52
#define RTT_MR_ALMIEN (0x1u << 16)
53
#define RTT_MR_RTTINCIEN (0x1u << 17)
54
#define RTT_MR_RTTRST (0x1u << 18)
55
#define RTT_MR_RTTDIS (0x1u << 20)
56
#define RTT_MR_RTC1HZ (0x1u << 24)
57
/* -------- RTT_AR : (RTT Offset: 0x04) Alarm Register -------- */
58
#define RTT_AR_ALMV_Pos 0
59
#define RTT_AR_ALMV_Msk (0xffffffffu << RTT_AR_ALMV_Pos)
60
#define RTT_AR_ALMV(value) ((RTT_AR_ALMV_Msk & ((value) << RTT_AR_ALMV_Pos)))
61
/* -------- RTT_VR : (RTT Offset: 0x08) Value Register -------- */
62
#define RTT_VR_CRTV_Pos 0
63
#define RTT_VR_CRTV_Msk (0xffffffffu << RTT_VR_CRTV_Pos)
64
/* -------- RTT_SR : (RTT Offset: 0x0C) Status Register -------- */
65
#define RTT_SR_ALMS (0x1u << 0)
66
#define RTT_SR_RTTINC (0x1u << 1)
67
69
70
71
#endif
/* _SAME70_RTT_COMPONENT_ */
__IO
#define __IO
Definition
core_cm4.h:239
__I
#define __I
Definition
core_cm4.h:236
Rtt
Rtt hardware registers.
Definition
component_rtt.h:41
Rtt::RTT_MR
__IO uint32_t RTT_MR
(Rtt Offset: 0x00) Mode Register
Definition
component_rtt.h:42
Rtt::RTT_SR
__I uint32_t RTT_SR
(Rtt Offset: 0x0C) Status Register
Definition
component_rtt.h:45
Rtt::RTT_VR
__I uint32_t RTT_VR
(Rtt Offset: 0x08) Value Register
Definition
component_rtt.h:44
Rtt::RTT_AR
__IO uint32_t RTT_AR
(Rtt Offset: 0x04) Alarm Register
Definition
component_rtt.h:43
