RTEMS 6.3
component_gpbr.h
6/* */
7/* All rights reserved. */
8/* */
11/* */
14/* */
17/* */
29
30#ifndef _SAME70_GPBR_COMPONENT_
31#define _SAME70_GPBR_COMPONENT_
32
33/* ============================================================================= */
35/* ============================================================================= */
38
39#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41typedef struct {
42 __IO uint32_t SYS_GPBR[8];
43} Gpbr;
44#endif /* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
45/* -------- SYS_GPBR[8] : (GPBR Offset: 0x0) General Purpose Backup Register -------- */
46#define SYS_GPBR_GPBR_VALUE_Pos 0
47#define SYS_GPBR_GPBR_VALUE_Msk (0xffffffffu << SYS_GPBR_GPBR_VALUE_Pos)
48#define SYS_GPBR_GPBR_VALUE(value) ((SYS_GPBR_GPBR_VALUE_Msk & ((value) << SYS_GPBR_GPBR_VALUE_Pos)))
49
51
52
53#endif /* _SAME70_GPBR_COMPONENT_ */
#define __IO
Definition core_cm4.h:239
Gpbr hardware registers.
Definition component_gpbr.h:41
(Gpbr Offset: 0x0) General Purpose Backup Register
Definition component_gpbr.h:42
