RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
same70
component
component_chipid.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _SAME70_CHIPID_COMPONENT_
31
#define _SAME70_CHIPID_COMPONENT_
32
33
35
38
39
#if !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__))
41
typedef
struct
42
__I
uint32_t
CHIPID_CIDR
43
__I
uint32_t
CHIPID_EXID
44
Chipid
45
#endif
/* !(defined(__ASSEMBLY__) || defined(__IAR_SYSTEMS_ASM__)) */
46
/* -------- CHIPID_CIDR : (CHIPID Offset: 0x0) Chip ID Register -------- */
47
#define CHIPID_CIDR_VERSION_Pos 0
48
#define CHIPID_CIDR_VERSION_Msk (0x1fu << CHIPID_CIDR_VERSION_Pos)
49
#define CHIPID_CIDR_EPROC_Pos 5
50
#define CHIPID_CIDR_EPROC_Msk (0x7u << CHIPID_CIDR_EPROC_Pos)
51
#define CHIPID_CIDR_EPROC_SAMx7 (0x0u << 5)
52
#define CHIPID_CIDR_EPROC_ARM946ES (0x1u << 5)
53
#define CHIPID_CIDR_EPROC_ARM7TDMI (0x2u << 5)
54
#define CHIPID_CIDR_EPROC_CM3 (0x3u << 5)
55
#define CHIPID_CIDR_EPROC_ARM920T (0x4u << 5)
56
#define CHIPID_CIDR_EPROC_ARM926EJS (0x5u << 5)
57
#define CHIPID_CIDR_EPROC_CA5 (0x6u << 5)
58
#define CHIPID_CIDR_EPROC_CM4 (0x7u << 5)
59
#define CHIPID_CIDR_NVPSIZ_Pos 8
60
#define CHIPID_CIDR_NVPSIZ_Msk (0xfu << CHIPID_CIDR_NVPSIZ_Pos)
61
#define CHIPID_CIDR_NVPSIZ_NONE (0x0u << 8)
62
#define CHIPID_CIDR_NVPSIZ_8K (0x1u << 8)
63
#define CHIPID_CIDR_NVPSIZ_16K (0x2u << 8)
64
#define CHIPID_CIDR_NVPSIZ_32K (0x3u << 8)
65
#define CHIPID_CIDR_NVPSIZ_64K (0x5u << 8)
66
#define CHIPID_CIDR_NVPSIZ_128K (0x7u << 8)
67
#define CHIPID_CIDR_NVPSIZ_160K (0x8u << 8)
68
#define CHIPID_CIDR_NVPSIZ_256K (0x9u << 8)
69
#define CHIPID_CIDR_NVPSIZ_512K (0xAu << 8)
70
#define CHIPID_CIDR_NVPSIZ_1024K (0xCu << 8)
71
#define CHIPID_CIDR_NVPSIZ_2048K (0xEu << 8)
72
#define CHIPID_CIDR_NVPSIZ2_Pos 12
73
#define CHIPID_CIDR_NVPSIZ2_Msk (0xfu << CHIPID_CIDR_NVPSIZ2_Pos)
74
#define CHIPID_CIDR_NVPSIZ2_NONE (0x0u << 12)
75
#define CHIPID_CIDR_NVPSIZ2_8K (0x1u << 12)
76
#define CHIPID_CIDR_NVPSIZ2_16K (0x2u << 12)
77
#define CHIPID_CIDR_NVPSIZ2_32K (0x3u << 12)
78
#define CHIPID_CIDR_NVPSIZ2_64K (0x5u << 12)
79
#define CHIPID_CIDR_NVPSIZ2_128K (0x7u << 12)
80
#define CHIPID_CIDR_NVPSIZ2_256K (0x9u << 12)
81
#define CHIPID_CIDR_NVPSIZ2_512K (0xAu << 12)
82
#define CHIPID_CIDR_NVPSIZ2_1024K (0xCu << 12)
83
#define CHIPID_CIDR_NVPSIZ2_2048K (0xEu << 12)
84
#define CHIPID_CIDR_SRAMSIZ_Pos 16
85
#define CHIPID_CIDR_SRAMSIZ_Msk (0xfu << CHIPID_CIDR_SRAMSIZ_Pos)
86
#define CHIPID_CIDR_SRAMSIZ_48K (0x0u << 16)
87
#define CHIPID_CIDR_SRAMSIZ_192K (0x1u << 16)
88
#define CHIPID_CIDR_SRAMSIZ_384K (0x2u << 16)
89
#define CHIPID_CIDR_SRAMSIZ_6K (0x3u << 16)
90
#define CHIPID_CIDR_SRAMSIZ_24K (0x4u << 16)
91
#define CHIPID_CIDR_SRAMSIZ_4K (0x5u << 16)
92
#define CHIPID_CIDR_SRAMSIZ_80K (0x6u << 16)
93
#define CHIPID_CIDR_SRAMSIZ_160K (0x7u << 16)
94
#define CHIPID_CIDR_SRAMSIZ_8K (0x8u << 16)
95
#define CHIPID_CIDR_SRAMSIZ_16K (0x9u << 16)
96
#define CHIPID_CIDR_SRAMSIZ_32K (0xAu << 16)
97
#define CHIPID_CIDR_SRAMSIZ_64K (0xBu << 16)
98
#define CHIPID_CIDR_SRAMSIZ_128K (0xCu << 16)
99
#define CHIPID_CIDR_SRAMSIZ_256K (0xDu << 16)
100
#define CHIPID_CIDR_SRAMSIZ_96K (0xEu << 16)
101
#define CHIPID_CIDR_SRAMSIZ_512K (0xFu << 16)
102
#define CHIPID_CIDR_ARCH_Pos 20
103
#define CHIPID_CIDR_ARCH_Msk (0xffu << CHIPID_CIDR_ARCH_Pos)
104
#define CHIPID_CIDR_ARCH_SAME70 (0x10u << 20)
105
#define CHIPID_CIDR_ARCH_SAMS70 (0x11u << 20)
106
#define CHIPID_CIDR_ARCH_SAMV71 (0x12u << 20)
107
#define CHIPID_CIDR_ARCH_SAMV70 (0x13u << 20)
108
#define CHIPID_CIDR_NVPTYP_Pos 28
109
#define CHIPID_CIDR_NVPTYP_Msk (0x7u << CHIPID_CIDR_NVPTYP_Pos)
110
#define CHIPID_CIDR_NVPTYP_ROM (0x0u << 28)
111
#define CHIPID_CIDR_NVPTYP_ROMLESS (0x1u << 28)
112
#define CHIPID_CIDR_NVPTYP_FLASH (0x2u << 28)
113
#define CHIPID_CIDR_NVPTYP_ROM_FLASH (0x3u << 28)
114
#define CHIPID_CIDR_NVPTYP_SRAM (0x4u << 28)
115
#define CHIPID_CIDR_EXT (0x1u << 31)
116
/* -------- CHIPID_EXID : (CHIPID Offset: 0x4) Chip ID Extension Register -------- */
117
#define CHIPID_EXID_EXID_Pos 0
118
#define CHIPID_EXID_EXID_Msk (0xffffffffu << CHIPID_EXID_EXID_Pos)
119
121
122
123
#endif
/* _SAME70_CHIPID_COMPONENT_ */
__I
#define __I
Definition
core_cm4.h:236
Chipid
Chipid hardware registers.
Definition
component_chipid.h:41
Chipid::CHIPID_EXID
__I uint32_t CHIPID_EXID
(Chipid Offset: 0x4) Chip ID Extension Register
Definition
component_chipid.h:43
Chipid::CHIPID_CIDR
__I uint32_t CHIPID_CIDR
(Chipid Offset: 0x0) Chip ID Register
Definition
component_chipid.h:42
