RTEMS 6.3
RTEMS Run-Time Linker. More...
#include <link.h>#include <rtems/chain.h>#include <rtems/thread.h>#include <rtems/rtl/rtl-allocator.h>#include <rtems/rtl/rtl-archive.h>#include <rtems/rtl/rtl-fwd.h>#include <rtems/rtl/rtl-obj.h>#include <rtems/rtl/rtl-obj-cache.h>#include <rtems/rtl/rtl-obj-comp.h>#include <rtems/rtl/rtl-sym.h>#include <rtems/rtl/rtl-unresolved.h>Go to the source code of this file.
| struct | rtems_rtl_data |
| #define | RTL_XGLUE(a, b) |
| #define | RTL_GLUE(a, b) |
| #define | RTEMS_RTL_SYMS_GLOBAL_BUCKETS (32) |
| #define | RTEMS_RTL_UNRESOLVED_BLOCK_SIZE (256) |
| #define | RTEMS_RTL_DEPENDENCY_BLOCK_SIZE (16) |
Typedefs | |
| typedef void(*) | rtems_rtl_cdtor(void) |
| struct r_debug | _rtld_debug |
This is the POSIX interface to run-time loading of code into RTEMS.
| #define RTEMS_RTL_DEPENDENCY_BLOCK_SIZE (16) |
The number of dependency record per block in the dependency table.
| #define RTEMS_RTL_SYMS_GLOBAL_BUCKETS (32) |
The number of buckets in the global symbol table.
| #define RTEMS_RTL_UNRESOLVED_BLOCK_SIZE (256) |
The number of relocation record per block in the unresolved table.
| #define RTL_XGLUE | ( | a, | |
| b ) |
Macros to glue two tokens.
| typedef void(*) rtems_rtl_cdtor(void) |
The type of constructor/destructor function.
| void _rtld_debug_state | ( | void | ) |
Debugger break function. Call when debugging to have it read the _rtld_debug variable.
| rtems_rtl_archives * rtems_rtl_archives_unprotected | ( | void | ) |
Get the RTL archives with out locking. This call assumes the RTL is locked.
| NULL | The RTL data is not initialised. |
| void rtems_rtl_base_sym_global_add | ( | const unsigned char * | esyms, |
| unsigned int | count, | ||
| const rtems_rtl_tls_offset * | tls_offsets, | ||
| unsigned int | tls_size ) |
Add an exported symbol table to the global symbol table. This call is normally used by an object file when loaded that contains a global symbol table.
| esyms | The exported symbol table. |
| count | The size of the exported symbol table. |
| tls_offsets | The TLS offsets table. If NULL none provided. |
| tls_size | The number TLS offset entries in the table. |
| rtems_rtl_obj * rtems_rtl_baseimage | ( | void | ) |
Return the object file descriptor for the base image. The object file descriptor returned is created when the run time linker is initialised.
Assumes the RTL has been locked.
| rtems_rtl_obj * rtems_rtl_check_handle | ( | void * | handle | ) |
Check a pointer is a valid object file descriptor returning the pointer as that type.
| handle | Pointer to the object file to be validated. |
| rtems_rtl_data * rtems_rtl_data_unprotected | ( | void | ) |
Get the RTL data with out locking. This call assumes the RTL is locked.
| rtems_rtl_obj * rtems_rtl_find_obj | ( | const char * | name | ) |
Find the object given a file name.
| name | The name of the object file. |
| NULL | No object file with that name found. |
| rtems_rtl_obj * rtems_rtl_find_obj_with_symbol | ( | const rtems_rtl_obj_sym * | sym | ) |
Find the object file a symbol is exported from.
| sym | The symbol to search with. |
| NULL | No object file found. |
| int rtems_rtl_get_error | ( | char * | message, |
| size_t | max_message ) |
Get the last error message clearing it. This operation locks the run time linker and therefore keeps the RTL thread safe but this call is not thread safe is multiple threads are loading object files at the same time. This call is provided to map to the dlopen family of calls.
| message | Pointer to a buffer to copy the message into. |
| max_message | The maximum message that can be copied. |
| rtems_rtl_symbols * rtems_rtl_global_symbols | ( | void | ) |
Get the RTL global symbol table with out locking. This call assumes the RTL is locked.
| const char * rtems_rtl_last_error_unprotected | ( | void | ) |
Get the RTL last error string with out locking. This call assumes the RTL is locked.
| rtems_rtl_obj * rtems_rtl_load | ( | const char * | name, |
| int | mode ) |
Load an object file. This is the user accessable interface to unloading an object file. See @rtems_rtl_load_object.
| mode | The mode of the load as defined by the dlopen call. |
| rtems_rtl_obj * rtems_rtl_load_object | ( | const char * | name, |
| int | mode ) |
Load an object file into memory relocating it. It will not be resolved against other symbols in other object files or the base image.
The name can be a file name for an object file or it can be encoded to reference an archive of object modules (static library). This encoding is specific to RTEMS and allows dependences to specify an archive without the searching overhead normally incurred by linkers locating object files in an archive. The file name format rules are:
| rtems_rtl_data * rtems_rtl_lock | ( | void | ) |
Lock the Run-time Linker.
| NULL | The RTL data could not be initialised or locked. Typically this means the lock could not be created. |
| void rtems_rtl_obj_caches | ( | rtems_rtl_obj_cache ** | symbols, |
| rtems_rtl_obj_cache ** | strings, | ||
| rtems_rtl_obj_cache ** | relocs ) |
Get the RTL symbols, strings, or relocations object file caches. This call assmes the RTL is locked.
| symbols | Pointer to the location to set the cache into. Returns NULL is rtl is not initialised. If NULL is passed in no value set. |
| strings | Pointer to the location to set the cache into. Returns NULL is rtl is not initialised. If NULL is passed in no value set. |
| relocs | Pointer to the location to set the cache into. Returns NULL is rtl is not initialised. If NULL is passed in no value set. |
| void rtems_rtl_obj_caches_flush | ( | void | ) |
Flush all the object file caches.
| void rtems_rtl_obj_decompress | ( | rtems_rtl_obj_comp ** | decomp, |
| rtems_rtl_obj_cache * | cache, | ||
| int | fd, | ||
| int | compression, | ||
| off_t | offset ) |
Get the RTL decompressor setting for the cache and the offset in the file the compressed stream starts. This call assumes the RTL is locked.
| decomp | Pointer to the location to set the compressor into. Returns NULL is rtl is not initialised. |
| cache | The cache to read the file with. Saves needing an extrs buffer. |
| offset | The offset in the file the compressed stream starts. |
| void rtems_rtl_obj_update_flags | ( | uint32_t | clear, |
| uint32_t | set ) |
Update the mask in the object files. You can clear flags and then set flags. A zero (0) does not clear or set the flags. This is global to all object files that are laoded.
| clear | The flag's clear mask, a 0 does not clear any flags. |
| set | The flag's set mask, a 0 does not set any flags. |
| rtems_chain_control * rtems_rtl_objects_unprotected | ( | void | ) |
Get the RTL objects table with out locking. This call assumes the RTL is locked.
| bool rtems_rtl_path_append | ( | const char * | path | ) |
Append the path to the search path.
| path | The path to append. |
| false | The path could not be appended. |
| true | The path was appended. |
| bool rtems_rtl_path_prepend | ( | const char * | path | ) |
Prepend the path to the search path.
| path | The path to prepend. |
| false | The path could not be prepended. |
| true | The path was prepended. |
| rtems_chain_control * rtems_rtl_pending_unprotected | ( | void | ) |
Get the RTL pending with out locking. This call assumes the RTL is locked.
| bool rtems_rtl_unload | ( | rtems_rtl_obj * | obj | ) |
Unload an object file. This is the user accessable interface to unloading an object file. See @rtems_rtl_unload_object.
| obj | The object file descriptor. |
| true | The object file has been unloaded. |
| false | The object file could not be unloaded. |
| bool rtems_rtl_unload_object | ( | rtems_rtl_obj * | obj | ) |
Unload an object file. This only happens when the user count is 0.
| void rtems_rtl_unlock | ( | void | ) |
Unlock the Run-time Linker.
| rtems_rtl_unresolved * rtems_rtl_unresolved_unprotected | ( | void | ) |
Get the RTL unresolved table with out locking. This call assumes the RTL is locked.
extern |
The global debugger interface variable.
