RTEMS
6.3
Toggle main menu visibility
libdl
rtl-tls.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
14
* COPYRIGHT (c) 2023 Chris Johns <chrisj@rtems.org>
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#if !defined (_RTEMS_RTL_TLS_H_)
39
#define _RTEMS_RTL_TLS_H_
40
41
#ifdef __cplusplus
42
extern
"C"
43
#endif
/* __cplusplus */
44
45
void
* rtems_rtl_tls_get_base (
void
46
47
#ifdef __cplusplus
48
49
#endif
/* __cplusplus */
50
51
#endif
