RTEMS 6.3
rtl-shell.h File Reference
RTEMS Run-Time Linker ELF Shell Support. More...
#include <rtems/print.h>
int rtems_rtl_shell_command (int argc, char *argv[])
int rtems_rtl_shell_list (const rtems_printer *printer, int argc, char *argv[])
int rtems_rtl_shell_sym (const rtems_printer *printer, int argc, char *argv[])
int rtems_rtl_shell_object (const rtems_printer *printer, int argc, char *argv[])
int rtems_rtl_shell_archive (const rtems_printer *printer, int argc, char *argv[])
int rtems_rtl_shell_call (const rtems_printer *printer, int argc, char *argv[])
◆ rtems_rtl_shell_archive()
int rtems_rtl_shell_archive ( const rtems_printer * printer,
int argc,
char * argv[] )
Archive files.
◆ rtems_rtl_shell_call()
int rtems_rtl_shell_call ( const rtems_printer * printer,
int argc,
char * argv[] )
Call text symbol.
◆ rtems_rtl_shell_command()
int rtems_rtl_shell_command ( int argc,
char * argv[] )
The RTL single shell command contains sub-commands.
Parameters
argcThe argument count.
argvArray of argument strings.
Return values
0No error.
Returns
int The exit code.
◆ rtems_rtl_shell_list()
int rtems_rtl_shell_list ( const rtems_printer * printer,
int argc,
char * argv[] )
List object files.
◆ rtems_rtl_shell_object()
int rtems_rtl_shell_object ( const rtems_printer * printer,
int argc,
char * argv[] )
Object files.
◆ rtems_rtl_shell_sym()
int rtems_rtl_shell_sym ( const rtems_printer * printer,
int argc,
char * argv[] )
Symbols.
