RTEMS 6.3
rtl-alloc-heap.h
2
10
11/*
12 * COPYRIGHT (c) 2012, 2018 Chris Johns <chrisj@rtems.org>
13 *
16 * are met:
22 *
34 */
35
36#if !defined (_RTEMS_RTL_ALLOC_HEAP_H_)
37#define _RTEMS_RTL_ALLOC_HEAP_H_
38
40
41#ifdef __cplusplus
42extern "C" {
43#endif /* __cplusplus */
44
60 void** address,
61 size_t size);
62
63#ifdef __cplusplus
64}
65#endif /* __cplusplus */
66
67#endif
void rtems_rtl_alloc_heap(rtems_rtl_alloc_cmd cmd, rtems_rtl_alloc_tag tag, void **address, size_t size)
Definition rtl-alloc-heap.c:43
RTEMS Run-Time Linker Allocator.
enum rtems_rtl_alloc_tags rtems_rtl_alloc_tag
Definition rtl-allocator.h:64
rtems_rtl_alloc_cmd
Definition rtl-allocator.h:69
