RTEMS 6.3
RTEMS File System Data. More...
#include <stdint.h>
#define rtems_rfs_data_ptr(_d)
#define rtems_rfs_data_get(_d, _t, _o, _s)
#define rtems_rfs_read_u8(_d)
#define rtems_rfs_read_u16(_d)
#define rtems_rfs_read_u32(_d)
#define rtems_rfs_write_u8(_d, _v)
#define rtems_rfs_write_u16(_d, _v)
#define rtems_rfs_write_u32(_d, _v)
Access data in the correct byte order for the specific target we are running on.
Todo
Make direct access on matching byte ordered targets.
◆ rtems_rfs_data_get
#define rtems_rfs_data_get ( _d,
_t,
_o,
_s )
Value:
(((_t)(rtems_rfs_data_ptr (_d)[_o])) << (_s))
Definition rtems-rfs-data.h:52
Helper function to get the data shifted in the correctly sized type.
◆ rtems_rfs_data_ptr
#define rtems_rfs_data_ptr ( _d)
Value:
((uint8_t*)(_d))
Helper function to make sure we have a byte pointer.
◆ rtems_rfs_read_u16
#define rtems_rfs_read_u16 ( _d)
Value:
(rtems_rfs_data_get (_d, uint16_t, 0, 8) | \
rtems_rfs_data_get (_d, uint16_t, 1, 0))
Definition rtems-rfs-data.h:57
RFS Read Unsigned 16bit Integer
◆ rtems_rfs_read_u32
#define rtems_rfs_read_u32 ( _d)
Value:
(rtems_rfs_data_get (_d, uint32_t, 0, 24) | \
rtems_rfs_data_get (_d, uint32_t, 1, 16) | \
rtems_rfs_data_get (_d, uint32_t, 2, 8) | \
rtems_rfs_data_get (_d, uint32_t, 3, 0))
RFS Read Unsigned 32bit Integer
◆ rtems_rfs_read_u8
#define rtems_rfs_read_u8 ( _d)
Value:
RFS Read Unsigned 8bit Integer
◆ rtems_rfs_write_u16
#define rtems_rfs_write_u16 ( _d,
_v )
Value:
do { \
rtems_rfs_data_ptr (_d)[0] = (uint8_t)(((uint16_t)(_v)) >> 8); \
rtems_rfs_data_ptr (_d)[1] = (uint8_t)((_v)); \
} while (0)
RFS Write Unsigned 16bit Integer
◆ rtems_rfs_write_u32
#define rtems_rfs_write_u32 ( _d,
_v )
Value:
do { \
rtems_rfs_data_ptr (_d)[0] = (uint8_t)(((uint32_t)(_v)) >> 24); \
rtems_rfs_data_ptr (_d)[1] = (uint8_t)(((uint32_t)(_v)) >> 16); \
rtems_rfs_data_ptr (_d)[2] = (uint8_t)(((uint32_t)(_v)) >> 8); \
rtems_rfs_data_ptr (_d)[3] = (uint8_t)((uint32_t)(_v)); \
} while (0)
RFS Write Unsigned 32bit Integer
◆ rtems_rfs_write_u8
#define rtems_rfs_write_u8 ( _d,
_v )
Value:
(*rtems_rfs_data_ptr (_d) = (uint8_t)(_v))
RFS Write Unsigned 8bit Integer
