RTEMS 6.3
RTEMS File Systems Block Position and Size Management. More...
| struct | rtems_rfs_block_pos_s |
| struct | rtems_rfs_block_size_s |
| #define | rtems_rfs_block_copy_bpos(_lhs, _rhs) |
| #define | rtems_rfs_block_copy_size(_lhs, _rhs) |
| #define | rtems_rfs_block_pos_last_block(_p, _s) |
| #define | rtems_rfs_block_pos_past_end(_p, _s) |
| #define | rtems_rfs_block_pos_block_past_end(_p, _s) |
| #define | rtems_rfs_block_size_get_bpos(_s, _b) |
| #define | rtems_rfs_block_size_equal(_lhs, _rhs) |
Typedefs | |
| typedef rtems_rfs_inode_block | rtems_rfs_block_no |
| typedef uint32_t | rtems_rfs_block_off |
| typedef struct rtems_rfs_block_pos_s | rtems_rfs_block_pos |
| typedef struct rtems_rfs_block_size_s | rtems_rfs_block_size |
| void | rtems_rfs_block_get_bpos (rtems_rfs_file_system *fs, rtems_rfs_pos pos, rtems_rfs_block_pos *bpos) |
| rtems_rfs_pos | rtems_rfs_block_get_pos (rtems_rfs_file_system *fs, rtems_rfs_block_pos *bpos) |
| void | rtems_rfs_block_get_block_size (rtems_rfs_file_system *fs, rtems_rfs_pos pos, rtems_rfs_block_size *size) |
| rtems_rfs_pos | rtems_rfs_block_get_size (rtems_rfs_file_system *fs, rtems_rfs_block_size *size) |
These functions manage the position in a block map as well as a size of data held in a block map. The position is the block count plus the offset into the last block where a block position of 0 and an offset of 0 is the start of a map. The size has a block count plus an offset, but the offset into the last block gives the actual size of the data in the map. This means a size will always have a block count greater than 0 when the file is not empty. A size offset of 0 and a non-zero block count means the length if aligned to the end of the block. For this reason there are 2 similar types so we know which set of rules are in use and the reason for this file.
| #define rtems_rfs_block_copy_bpos | ( | _lhs, | |
| _rhs ) |
Copy a block position.
| [in] | _lhs | is the left hand side. |
| [in] | _rhs | is the right hand side. |
| #define rtems_rfs_block_copy_size | ( | _lhs, | |
| _rhs ) |
Copy a block size.
| #define rtems_rfs_block_pos_block_past_end | ( | _p, | |
| _s ) |
Is the block position past the end.
| #define rtems_rfs_block_pos_last_block | ( | _p, | |
| _s ) |
Last block ?
| #define rtems_rfs_block_pos_past_end | ( | _p, | |
| _s ) |
Last block ?
| #define rtems_rfs_block_size_equal | ( | _lhs, | |
| _rhs ) |
Do the sizes match ?
| #define rtems_rfs_block_size_get_bpos | ( | _s, | |
| _b ) |
Copy the size to the block position. Note the block position and the size have different block counts.
The block number is the same type as the inode block number. This makes sure the sizes of the types match.
| typedef uint32_t rtems_rfs_block_off |
The offset into a block.
| typedef struct rtems_rfs_block_pos_s rtems_rfs_block_pos |
A block position is a block number times the block size plus the offset. The block field can be used hold a block number for the position as a look up cache.
| typedef struct rtems_rfs_block_size_s rtems_rfs_block_size |
A block size is the number of blocks less one plus the offset where the offset must be less than the block size.
| void rtems_rfs_block_get_block_size | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_pos | pos, | ||
| rtems_rfs_block_size * | size ) |
Set the size given a position.
| [in] | fs | is the file system data. |
| [in] | pos | is the position as an absolute offset from the start. |
| [out] | size | is a pointer to the block size to fill in. |
| void rtems_rfs_block_get_bpos | ( | rtems_rfs_file_system * | fs, |
| rtems_rfs_block_pos * | bpos ) |
Given a position compute the block number and block offset.
| [out] | bpos | is a pointer to the block position to fill in. |
| rtems_rfs_pos rtems_rfs_block_get_pos | ( | rtems_rfs_file_system * | fs, |
Given a block position compute the absolute offset.
| offset | The absolute offset. |
| rtems_rfs_pos rtems_rfs_block_get_size | ( | rtems_rfs_file_system * | fs, |
Calculate the position given the number of blocks and the offset. If the block count is 0 the size is 0. If the block is greater than 0 and the offset is 0 the size is number of blocks multipled by the block size and if the offset is not 0 it is the offset into the last block. For example if blocks is 1 and offset is 0 the size is the block size. If the block count is 1 and size is 100 the size is 100.
| [in] | size | The size in blocks and offset. |
| size | The size in bytes. |
