RTEMS
6.3
Toggle main menu visibility
include
debugger
rtems-debugger-bsp.h
1
2
* Copyright (c) 2019 Chris Johns <chrisj@rtems.org>.
3
* All rights reserved.
4
5
6
* modification, are permitted provided that the following conditions
7
* are met:
8
* 1. Redistributions of source code must retain the above copyright
9
* notice, this list of conditions and the following disclaimer.
10
* 2. Redistributions in binary form must reproduce the above copyright
11
* notice, this list of conditions and the following disclaimer in the
12
* documentation and/or other materials provided with the distribution.
13
14
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
15
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
16
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
17
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
18
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
19
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
20
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
21
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
22
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
23
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
24
* SUCH DAMAGE.
25
26
27
28
* Debugger BSP support.
29
30
31
#ifndef _RTEMS_DEBUGGER_BSP_h
32
#define _RTEMS_DEBUGGER_BSP_h
33
34
#include <rtems/rtems-debugger.h>
35
36
#ifdef __cplusplus
37
extern
"C"
38
#endif
/* __cplusplus */
39
43
51
void
* rtems_debugger_arm_debug_registers(
void
52
60
bool
rtems_debugger_arm_debug_configure(
void
61
62
#ifdef __cplusplus
63
64
#endif
/* __cplusplus */
65
66
#endif
