RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
include
bsp
residual.h
1
/* 7/18/95 */
2
3
/* Residual Data header definitions and prototypes */
4
5
6
/* Structure map for RESIDUAL on PowerPC Reference Platform */
7
/* residual.h - Residual data structure passed in r3. */
8
/* Load point passed in r4 to boot image. */
9
/* For enum's: if given in hex then they are bit significant, */
10
/* i.e. only one bit is on for each enum */
11
/* Reserved fields must be filled with zeros. */
12
13
14
#ifndef _RESIDUAL_
15
#define _RESIDUAL_
16
17
#ifndef ASM
18
19
#include <stdint.h>
20
21
#define MAX_CPUS 32
/* These should be set to the maximum */
22
#define MAX_MEMS 64
/* number possible for this system. */
23
#define MAX_DEVICES 256
/* Changing these will change the */
24
#define AVE_PNP_SIZE 32
/* structure, hence the version of */
25
#define MAX_MEM_SEGS 64
/* this header file. */
26
27
28
/* Public structures... */
29
30
31
#include <bsp/pnp.h>
32
33
typedef
enum
_L1CACHE_TYPE {
34
NoneCAC = 0,
35
SplitCAC = 1,
36
CombinedCAC = 2
37
} L1CACHE_TYPE;
38
39
typedef
enum
_TLB_TYPE {
40
NoneTLB = 0,
41
SplitTLB = 1,
42
CombinedTLB = 2
43
} TLB_TYPE;
44
45
typedef
enum
_FIRMWARE_SUPPORT {
46
Conventional = 0x01,
47
OpenFirmware = 0x02,
48
Diagnostics = 0x04,
49
LowDebug = 0x08,
50
Multiboot = 0x10,
51
LowClient = 0x20,
52
Hex41 = 0x40,
53
FAT = 0x80,
54
ISO9660 = 0x0100,
55
SCSI_InitiatorID_Override = 0x0200,
56
Tape_Boot = 0x0400,
57
FW_Boot_Path = 0x0800
58
} FIRMWARE_SUPPORT;
59
60
typedef
enum
_FIRMWARE_SUPPLIERS {
61
IBMFirmware = 0x00,
62
MotoFirmware = 0x01,
/* 7/18/95 */
63
FirmWorks = 0x02,
/* 10/5/95 */
64
Bull = 0x03,
/* 04/03/96 */
65
QEMU = (
'q'
<<24) | (
'e'
<<16) | (
'm'
<<8) | (
'u'
<<0),
66
} FIRMWARE_SUPPLIERS;
67
68
typedef
enum
_ENDIAN_SWITCH_METHODS {
69
UsePort92 = 0x01,
70
UsePCIConfigA8 = 0x02,
71
UseFF001030 = 0x03,
72
} ENDIAN_SWITCH_METHODS;
73
74
typedef
enum
_SPREAD_IO_METHODS {
75
UsePort850 = 0x00,
76
/*UsePCIConfigA8 = 0x02,*/
77
} SPREAD_IO_METHODS;
78
79
typedef
struct
_VPD
80
81
/* Box dependent stuff */
82
unsigned
char
PrintableModel[32];
/* Null terminated string.
83
Must be of the form:
84
vvv,<20h>,<model designation>,<0x0>
85
where vvv is the vendor ID
86
e.g. IBM PPS MODEL 6015<0x0> */
87
unsigned
char
Serial[16];
/* 12/94:
88
Serial Number; must be of the form:
89
vvv<serial number> where vvv is the
90
vendor ID.
91
e.g. IBM60151234567<20h><20h> */
92
unsigned
char
Reserved[48];
93
unsigned
long
FirmwareSupplier;
/* See FirmwareSuppliers enum */
94
unsigned
long
FirmwareSupports;
/* See FirmwareSupport enum */
95
unsigned
long
NvramSize;
/* Size of nvram in bytes */
96
unsigned
long
NumSIMMSlots;
97
unsigned
short
EndianSwitchMethod;
/* See EndianSwitchMethods enum */
98
unsigned
short
SpreadIOMethod;
/* See SpreadIOMethods enum */
99
unsigned
long
SmpIar;
100
unsigned
long
RAMErrLogOffset;
/* Heap offset to error log */
101
unsigned
long
Reserved5;
102
unsigned
long
Reserved6;
103
unsigned
long
ProcessorHz;
/* Processor clock frequency in Hertz */
104
unsigned
long
ProcessorBusHz;
/* Processor bus clock frequency */
105
unsigned
long
Reserved7;
106
unsigned
long
TimeBaseDivisor;
/* (Bus clocks per timebase tic)*1000 */
107
unsigned
long
WordWidth;
/* Word width in bits */
108
unsigned
long
PageSize;
/* Page size in bytes */
109
unsigned
long
CoherenceBlockSize;
/* Unit of transfer in/out of cache
110
for which coherency is maintained;
111
normally <= CacheLineSize. */
112
unsigned
long
GranuleSize;
/* Unit of lock allocation to avoid */
113
/* false sharing of locks. */
114
115
/* L1 Cache variables */
116
unsigned
long
CacheSize;
/* L1 Cache size in KB. This is the */
117
/* total size of the L1, whether */
118
/* combined or split */
119
unsigned
long
CacheAttrib;
/* L1CACHE_TYPE */
120
unsigned
long
CacheAssoc;
/* L1 Cache associativity. Use this
121
for combined cache. If split, put
122
zeros here. */
123
unsigned
long
CacheLineSize;
/* L1 Cache line size in bytes. Use
124
125
zeros here. */
126
/* For split L1 Cache: (= combined if combined cache) */
127
unsigned
long
I_CacheSize;
128
unsigned
long
I_CacheAssoc;
129
unsigned
long
I_CacheLineSize;
130
unsigned
long
D_CacheSize;
131
unsigned
long
D_CacheAssoc;
132
unsigned
long
D_CacheLineSize;
133
134
/* Translation Lookaside Buffer variables */
135
unsigned
long
TLBSize;
/* Total number of TLBs on the system */
136
unsigned
long
TLBAttrib;
/* Combined I+D or split TLB */
137
unsigned
long
TLBAssoc;
/* TLB Associativity. Use this for
138
combined TLB. If split, put zeros
139
here. */
140
/* For split TLB: (= combined if combined TLB) */
141
unsigned
long
I_TLBSize;
142
unsigned
long
I_TLBAssoc;
143
unsigned
long
D_TLBSize;
144
unsigned
long
D_TLBAssoc;
145
146
unsigned
long
ExtendedVPD;
/* Offset to extended VPD area;
147
null if unused */
148
} VPD;
149
150
typedef
enum
_DEVICE_FLAGS {
151
Enabled = 0x4000,
/* 1 - PCI device is enabled */
152
Integrated = 0x2000,
153
Failed = 0x1000,
/* 1 - device failed POST code tests */
154
Static = 0x0800,
/* 0 - dynamically configurable
155
1 - static */
156
Dock = 0x0400,
/* 0 - not a docking station device
157
1 - is a docking station device */
158
Boot = 0x0200,
/* 0 - device cannot be used for BOOT
159
1 - can be a BOOT device */
160
Configurable = 0x0100,
/* 1 - device is configurable */
161
Disableable = 0x80,
/* 1 - device can be disabled */
162
PowerManaged = 0x40,
/* 0 - not managed; 1 - managed */
163
ReadOnly = 0x20,
/* 1 - device is read only */
164
Removable = 0x10,
/* 1 - device is removable */
165
ConsoleIn = 0x08,
166
ConsoleOut = 0x04,
167
Input = 0x02,
168
Output = 0x01
169
} DEVICE_FLAGS;
170
171
typedef
enum
_BUS_ID {
172
ISADEVICE = 0x01,
173
EISADEVICE = 0x02,
174
PCIDEVICE = 0x04,
175
PCMCIADEVICE = 0x08,
176
PNPISADEVICE = 0x10,
177
MCADEVICE = 0x20,
178
MXDEVICE = 0x40,
/* Devices on mezzanine bus */
179
PROCESSORDEVICE = 0x80,
/* Devices on processor bus */
180
VMEDEVICE = 0x100,
181
} BUS_ID;
182
183
typedef
struct
_DEVICE_ID
184
unsigned
long
BusId;
/* See BUS_ID enum above */
185
unsigned
long
DevId;
/* Big Endian format */
186
unsigned
long
SerialNum;
/* For multiple usage of a single
187
DevId */
188
unsigned
long
Flags;
/* See DEVICE_FLAGS enum above */
189
unsigned
char
BaseType;
/* See pnp.h for bit definitions */
190
unsigned
char
SubType;
191
unsigned
char
Interface;
192
unsigned
char
Spare;
193
} DEVICE_ID;
194
195
typedef
union
_BUS_ACCESS
196
struct
_PnPAccess
197
unsigned
char
CSN;
198
unsigned
char
LogicalDevNumber;
199
unsigned
short
ReadDataPort;
200
} PnPAccess;
201
struct
_ISAAccess
202
unsigned
char
SlotNumber;
/* ISA Slot Number generally not
203
available; 0 if unknown */
204
unsigned
char
LogicalDevNumber;
205
unsigned
short
ISAReserved;
206
} ISAAccess;
207
struct
_MCAAccess
208
unsigned
char
SlotNumber;
209
unsigned
char
LogicalDevNumber;
210
unsigned
short
MCAReserved;
211
} MCAAccess;
212
struct
_PCMCIAAccess
213
unsigned
char
SlotNumber;
214
unsigned
char
LogicalDevNumber;
215
unsigned
short
PCMCIAReserved;
216
} PCMCIAAccess;
217
struct
_EISAAccess
218
unsigned
char
SlotNumber;
219
unsigned
char
FunctionNumber;
220
unsigned
short
EISAReserved;
221
} EISAAccess;
222
struct
_PCIAccess
223
unsigned
char
BusNumber;
224
unsigned
char
DevFuncNumber;
225
unsigned
short
PCIReserved;
226
} PCIAccess;
227
struct
_ProcBusAccess
228
unsigned
char
BusNumber;
229
unsigned
char
BUID;
230
unsigned
short
ProcBusReserved;
231
} ProcBusAccess;
232
} BUS_ACCESS;
233
234
/* Per logical device information */
235
typedef
struct
_PPC_DEVICE
236
DEVICE_ID DeviceId;
237
BUS_ACCESS BusAccess;
238
239
/* The following three are offsets into the DevicePnPHeap */
240
/* All are in PnP compressed format */
241
unsigned
long
AllocatedOffset;
/* Allocated resource description */
242
unsigned
long
PossibleOffset;
/* Possible resource description */
243
unsigned
long
CompatibleOffset;
/* Compatible device identifiers */
244
} PPC_DEVICE;
245
246
typedef
enum
_CPU_STATE {
247
CPU_GOOD = 0,
/* CPU is present, and active */
248
CPU_GOOD_FW = 1,
/* CPU is present, and in firmware */
249
CPU_OFF = 2,
/* CPU is present, but inactive */
250
CPU_FAILED = 3,
/* CPU is present, but failed POST */
251
CPU_NOT_PRESENT = 255
/* CPU not present */
252
} CPU_STATE;
253
254
typedef
struct
_PPC_CPU
255
unsigned
long
CpuType;
/* Result of mfspr from Processor
256
Version Register (PVR).
257
PVR(0-15) = Version (e.g. 601)
258
PVR(16-31 = EC Level */
259
unsigned
char
CpuNumber;
/* CPU Number for this processor */
260
unsigned
char
CpuState;
/* CPU State, see CPU_STATE enum */
261
unsigned
short
Reserved;
262
} PPC_CPU;
263
264
typedef
struct
_PPC_MEM
265
unsigned
long
SIMMSize;
/* 0 - absent or bad
266
8M, 32M (in MB) */
267
} PPC_MEM;
268
269
typedef
enum
_MEM_USAGE {
270
Other = 0x8000,
271
ResumeBlock = 0x4000,
/* for use by power management */
272
SystemROM = 0x2000,
/* Flash memory (populated) */
273
UnPopSystemROM = 0x1000,
/* Unpopulated part of SystemROM area */
274
IOMemory = 0x0800,
275
SystemIO = 0x0400,
276
SystemRegs = 0x0200,
277
PCIAddr = 0x0100,
278
PCIConfig = 0x80,
279
ISAAddr = 0x40,
280
Unpopulated = 0x20,
/* Unpopulated part of System Memory */
281
Free = 0x10,
/* Free part of System Memory */
282
BootImage = 0x08,
/* BootImage part of System Memory */
283
FirmwareCode = 0x04,
/* FirmwareCode part of System Memory */
284
FirmwareHeap = 0x02,
/* FirmwareHeap part of System Memory */
285
FirmwareStack = 0x01
/* FirmwareStack part of System Memory*/
286
} MEM_USAGE;
287
288
typedef
struct
_MEM_MAP
289
unsigned
long
Usage;
/* See MEM_USAGE above */
290
unsigned
long
BasePage;
/* Page number measured in 4KB pages */
291
unsigned
long
PageCount;
/* Page count measured in 4KB pages */
292
} MEM_MAP;
293
294
typedef
struct
_RESIDUAL
295
unsigned
long
ResidualLength;
/* Length of Residual */
296
unsigned
char
Version;
/* of this data structure */
297
unsigned
char
Revision;
298
unsigned
short
EC;
299
/* VPD */
300
VPD VitalProductData;
301
/* CPU */
302
unsigned
short
MaxNumCpus;
/* Max CPUs in this system */
303
unsigned
short
ActualNumCpus;
/* ActualNumCpus < MaxNumCpus means */
304
/* that there are unpopulated or */
305
/* otherwise unusable cpu locations */
306
PPC_CPU Cpus[MAX_CPUS];
307
/* Memory */
308
unsigned
long
TotalMemory;
/* Total amount of memory installed */
309
unsigned
long
GoodMemory;
/* Total amount of good memory */
310
unsigned
long
ActualNumMemSegs;
311
MEM_MAP Segs[MAX_MEM_SEGS];
312
unsigned
long
ActualNumMemories;
313
PPC_MEM Memories[MAX_MEMS];
314
/* Devices */
315
unsigned
long
ActualNumDevices;
316
PPC_DEVICE Devices[MAX_DEVICES];
317
unsigned
char
DevicePnPHeap[2*MAX_DEVICES*AVE_PNP_SIZE];
318
} RESIDUAL;
319
320
#ifndef NULL
321
#define NULL 0
322
#endif
323
324
static
inline
int
325
residual_fw_is_qemu(RESIDUAL *r)
326
327
return
QEMU == r->VitalProductData.FirmwareSupplier;
328
329
330
extern
RESIDUAL residualCopy;
331
332
extern
void
print_residual_device_info(
void
333
#ifndef __BOOT__
334
extern
PPC_DEVICE *residual_find_device(RESIDUAL *res,
unsigned
long
BusMask,
335
unsigned
char
* DevID,
int
BaseType,
336
int
SubType,
int
Interface,
int
n);
337
#else
338
extern
unsigned
long
BusMask,
339
unsigned
char
* DevID,
int
BaseType,
340
int
SubType,
int
Interface,
int
n);
341
#endif
342
extern
PnP_TAG_PACKET *PnP_find_packet(
unsigned
char
unsigned
packet_tag,
343
int
n);
344
extern
PnP_TAG_PACKET *PnP_find_small_vendor_packet(
unsigned
char
unsigned
packet_type,
346
int
n);
347
extern
PnP_TAG_PACKET *PnP_find_large_vendor_packet(
unsigned
char
unsigned
packet_type,
349
int
n);
350
351
* Prototypes for methods called only from .S for dependency tracking
352
353
uint32_t res_copy(
void
354
355
#endif
/* ASM */
356
#endif
/* ndef _RESIDUAL_ */
_BUS_ACCESS::_EISAAccess
Definition
residual.h:217
_BUS_ACCESS::_ISAAccess
Definition
residual.h:201
_BUS_ACCESS::_MCAAccess
Definition
residual.h:207
_BUS_ACCESS::_PCIAccess
Definition
residual.h:222
_BUS_ACCESS::_PCMCIAAccess
Definition
residual.h:212
_BUS_ACCESS::_PnPAccess
Definition
residual.h:196
_BUS_ACCESS::_ProcBusAccess
Definition
residual.h:227
_DEVICE_ID
Definition
residual.h:183
_MEM_MAP
Definition
residual.h:288
_PPC_CPU
Definition
residual.h:254
_PPC_DEVICE
Definition
residual.h:235
_PPC_MEM
Definition
residual.h:264
_RESIDUAL
Definition
residual.h:294
_VPD
Definition
residual.h:79
unsigned p
Definition
tte.h:17
_BUS_ACCESS
Definition
residual.h:195
