#define | TMS570_SYS1_SYSPCx_ECPCLKFUN BSP_BIT32(0) |
| #define | TMS570_SYS1_CSDIS_CLKSROFF(val) |
| #define | TMS570_SYS1_CSDIS_CLKSROFF_GET(reg) |
| #define | TMS570_SYS1_CSDIS_CLKSROFF_SET(reg, val) |
#define | TMS570_SYS1_CSDIS_CLKSR_OSC_NUM 0 |
#define | TMS570_SYS1_CSDIS_CLKSROFF_OSC BSP_BIT32(0) |
#define | TMS570_SYS1_CSDIS_CLKSR_PLL1_NUM 1 |
#define | TMS570_SYS1_CSDIS_CLKSROFF_PLL1 BSP_BIT32(1) |
#define | TMS570_SYS1_CSDIS_CLKSR_EXTCLKIN_NUM 3 |
#define | TMS570_SYS1_CSDIS_CLKSROFF_EXTCLKIN BSP_BIT32(3) |
#define | TMS570_SYS1_CSDIS_CLKSR_LPO_NUM 4 |
#define | TMS570_SYS1_CSDIS_CLKSROFF_LPO BSP_BIT32(4) |
#define | TMS570_SYS1_CSDIS_CLKSR_HPO_NUM 5 |
#define | TMS570_SYS1_CSDIS_CLKSROFF_HPO BSP_BIT32(5) |
#define | TMS570_SYS1_CSDIS_CLKSR_PLL2_NUM 6 |
#define | TMS570_SYS1_CSDIS_CLKSROFF_PLL2 BSP_BIT32(6) |
#define | TMS570_SYS1_CSDIS_CLKSR_EXTCLKIN2_NUM 7 |
#define | TMS570_SYS1_CSDIS_CLKSROFF_EXTCLKIN2 BSP_BIT32(7) |
| #define | TMS570_SYS1_CSDISSET_SETCLKSR_OFF(val) |
| #define | TMS570_SYS1_CSDISSET_SETCLKSR_OFF_GET(reg) |
| #define | TMS570_SYS1_CSDISSET_SETCLKSR_OFF_SET(reg, val) |
| #define | TMS570_SYS1_CSDISCLR_CLRCLKSR_OFF(val) |
| #define | TMS570_SYS1_CSDISCLR_CLRCLKSR_OFF_GET(reg) |
| #define | TMS570_SYS1_CSDISCLR_CLRCLKSR_OFF_SET(reg, val) |
#define | TMS570_SYS1_CDDIS_VCLKAOFF4 BSP_BIT32(11) |
#define | TMS570_SYS1_CDDIS_VCLKAOFF3 BSP_BIT32(10) |
#define | TMS570_SYS1_CDDIS_VCLK3OFF BSP_BIT32(8) |
#define | TMS570_SYS1_CDDIS_RTICLK1OFF BSP_BIT32(6) |
#define | TMS570_SYS1_CDDIS_VCLKAOFF2 BSP_BIT32(5) |
#define | TMS570_SYS1_CDDIS_VCLKAOFF1 BSP_BIT32(4) |
#define | TMS570_SYS1_CDDIS_VCLK2OFF BSP_BIT32(3) |
#define | TMS570_SYS1_CDDIS_VCLKPOFF BSP_BIT32(2) |
#define | TMS570_SYS1_CDDIS_HCLKOFF BSP_BIT32(1) |
#define | TMS570_SYS1_CDDIS_GCLKOFF BSP_BIT32(0) |
| #define | TMS570_SYS1_CDDISSET_SETVCLKA_OFF(val) |
| #define | TMS570_SYS1_CDDISSET_SETVCLKA_OFF_GET(reg) |
| #define | TMS570_SYS1_CDDISSET_SETVCLKA_OFF_SET(reg, val) |
#define | TMS570_SYS1_CDDISSET_SETVCLK3OFF BSP_BIT32(8) |
#define | TMS570_SYS1_CDDISSET_SETRTI1CLKOFF BSP_BIT32(6) |
#define | TMS570_SYS1_CDDISSET_SETTVCLKA2OFF BSP_BIT32(5) |
#define | TMS570_SYS1_CDDISSET_SETVCLKA1OFF BSP_BIT32(4) |
#define | TMS570_SYS1_CDDISSET_SETVCLK2OFF BSP_BIT32(3) |
#define | TMS570_SYS1_CDDISSET_SETVCLKPOFF BSP_BIT32(2) |
#define | TMS570_SYS1_CDDISSET_SETHCLKOFF BSP_BIT32(1) |
#define | TMS570_SYS1_CDDISSET_SETGCLKOFF BSP_BIT32(0) |
| #define | TMS570_SYS1_CDDISCLR_CLRVCLKAOFF(val) |
| #define | TMS570_SYS1_CDDISCLR_CLRVCLKAOFF_GET(reg) |
| #define | TMS570_SYS1_CDDISCLR_CLRVCLKAOFF_SET(reg, val) |
#define | TMS570_SYS1_CDDISCLR_Reserved BSP_BIT32(9) |
#define | TMS570_SYS1_CDDISCLR_CLRVCLK3OFF BSP_BIT32(8) |
#define | TMS570_SYS1_CDDISCLR_CLRRTI1CLKOFF BSP_BIT32(6) |
#define | TMS570_SYS1_CDDISCLR_CLRTVCLKA2OFF BSP_BIT32(5) |
#define | TMS570_SYS1_CDDISCLR_CLRVCLKA1OFF BSP_BIT32(4) |
#define | TMS570_SYS1_CDDISCLR_CLRVCLK2OFF BSP_BIT32(3) |
#define | TMS570_SYS1_CDDISCLR_CLRVCLKPOFF BSP_BIT32(2) |
#define | TMS570_SYS1_CDDISCLR_CLRHCLKOFF BSP_BIT32(1) |
#define | TMS570_SYS1_CDDISCLR_CLRGCLKOFF BSP_BIT32(0) |
| #define | TMS570_SYS1_GHVSRC_GHVWAKE(val) |
| #define | TMS570_SYS1_GHVSRC_GHVWAKE_GET(reg) |
| #define | TMS570_SYS1_GHVSRC_GHVWAKE_SET(reg, val) |
| #define | TMS570_SYS1_GHVSRC_HVLPM(val) |
| #define | TMS570_SYS1_GHVSRC_HVLPM_GET(reg) |
| #define | TMS570_SYS1_GHVSRC_HVLPM_SET(reg, val) |
| #define | TMS570_SYS1_GHVSRC_GHVSRC(val) |
| #define | TMS570_SYS1_GHVSRC_GHVSRC_GET(reg) |
| #define | TMS570_SYS1_GHVSRC_GHVSRC_SET(reg, val) |
| #define | TMS570_SYS1_VCLKASRC_VCLKA2S(val) |
| #define | TMS570_SYS1_VCLKASRC_VCLKA2S_GET(reg) |
| #define | TMS570_SYS1_VCLKASRC_VCLKA2S_SET(reg, val) |
| #define | TMS570_SYS1_VCLKASRC_VCLKA1S(val) |
| #define | TMS570_SYS1_VCLKASRC_VCLKA1S_GET(reg) |
| #define | TMS570_SYS1_VCLKASRC_VCLKA1S_SET(reg, val) |
| #define | TMS570_SYS1_RCLKSRC_RTI1DIV(val) |
| #define | TMS570_SYS1_RCLKSRC_RTI1DIV_GET(reg) |
| #define | TMS570_SYS1_RCLKSRC_RTI1DIV_SET(reg, val) |
| #define | TMS570_SYS1_RCLKSRC_RTI1SRC(val) |
| #define | TMS570_SYS1_RCLKSRC_RTI1SRC_GET(reg) |
| #define | TMS570_SYS1_RCLKSRC_RTI1SRC_SET(reg, val) |
| #define | TMS570_SYS1_CSVSTAT_CLKSRV(val) |
| #define | TMS570_SYS1_CSVSTAT_CLKSRV_GET(reg) |
| #define | TMS570_SYS1_CSVSTAT_CLKSRV_SET(reg, val) |
| #define | TMS570_SYS1_CSVSTAT_CLKSR(val) |
| #define | TMS570_SYS1_CSVSTAT_CLKSR_GET(reg) |
| #define | TMS570_SYS1_CSVSTAT_CLKSR_SET(reg, val) |
| #define | TMS570_SYS1_MSTGCR_ROM_DIV(val) |
| #define | TMS570_SYS1_MSTGCR_ROM_DIV_GET(reg) |
| #define | TMS570_SYS1_MSTGCR_ROM_DIV_SET(reg, val) |
| #define | TMS570_SYS1_MSTGCR_MSTGENA(val) |
| #define | TMS570_SYS1_MSTGCR_MSTGENA_GET(reg) |
| #define | TMS570_SYS1_MSTGCR_MSTGENA_SET(reg, val) |
| #define | TMS570_SYS1_MINITGCR_MINITGENA(val) |
| #define | TMS570_SYS1_MINITGCR_MINITGENA_GET(reg) |
| #define | TMS570_SYS1_MINITGCR_MINITGENA_SET(reg, val) |
#define | TMS570_SYS1_MSTCGSTAT_MINIDONE BSP_BIT32(8) |
#define | TMS570_SYS1_MSTCGSTAT_MSTDONE BSP_BIT32(0) |
#define | TMS570_SYS1_PLLCTL1_ROS BSP_BIT32(31) |
| #define | TMS570_SYS1_PLLCTL1_BPOS(val) |
| #define | TMS570_SYS1_PLLCTL1_BPOS_GET(reg) |
| #define | TMS570_SYS1_PLLCTL1_BPOS_SET(reg, val) |
| #define | TMS570_SYS1_PLLCTL1_MASK_SLIP(val) |
| #define | TMS570_SYS1_PLLCTL1_MASK_SLIP_GET(reg) |
| #define | TMS570_SYS1_PLLCTL1_MASK_SLIP_SET(reg, val) |
| #define | TMS570_SYS1_PLLCTL1_PLLDIV(val) |
| #define | TMS570_SYS1_PLLCTL1_PLLDIV_GET(reg) |
| #define | TMS570_SYS1_PLLCTL1_PLLDIV_SET(reg, val) |
#define | TMS570_SYS1_PLLCTL1_ROF BSP_BIT32(23) |
| #define | TMS570_SYS1_PLLCTL1_REFCLKDIV(val) |
| #define | TMS570_SYS1_PLLCTL1_REFCLKDIV_GET(reg) |
| #define | TMS570_SYS1_PLLCTL1_REFCLKDIV_SET(reg, val) |
| #define | TMS570_SYS1_PLLCTL1_PLLMUL(val) |
| #define | TMS570_SYS1_PLLCTL1_PLLMUL_GET(reg) |
| #define | TMS570_SYS1_PLLCTL1_PLLMUL_SET(reg, val) |
#define | TMS570_SYS1_PLLCTL2_FMENA BSP_BIT32(31) |
| #define | TMS570_SYS1_PLLCTL2_SPREADINGRATE(val) |
| #define | TMS570_SYS1_PLLCTL2_SPREADINGRATE_GET(reg) |
| #define | TMS570_SYS1_PLLCTL2_SPREADINGRATE_SET(reg, val) |
| #define | TMS570_SYS1_PLLCTL2_MULMOD(val) |
| #define | TMS570_SYS1_PLLCTL2_MULMOD_GET(reg) |
| #define | TMS570_SYS1_PLLCTL2_MULMOD_SET(reg, val) |
| #define | TMS570_SYS1_PLLCTL2_ODPLL(val) |
| #define | TMS570_SYS1_PLLCTL2_ODPLL_GET(reg) |
| #define | TMS570_SYS1_PLLCTL2_ODPLL_SET(reg, val) |
| #define | TMS570_SYS1_PLLCTL2_SPR_AMOUNT(val) |
| #define | TMS570_SYS1_PLLCTL2_SPR_AMOUNT_GET(reg) |
| #define | TMS570_SYS1_PLLCTL2_SPR_AMOUNT_SET(reg, val) |
| #define | TMS570_SYS1_PLLCTL3_ODPLL2(val) |
| #define | TMS570_SYS1_PLLCTL3_ODPLL2_GET(reg) |
| #define | TMS570_SYS1_PLLCTL3_ODPLL2_SET(reg, val) |
| #define | TMS570_SYS1_PLLCTL3_PLLDIV2(val) |
| #define | TMS570_SYS1_PLLCTL3_PLLDIV2_GET(reg) |
| #define | TMS570_SYS1_PLLCTL3_PLLDIV2_SET(reg, val) |
| #define | TMS570_SYS1_PLLCTL3_REFCLKDIV2(val) |
| #define | TMS570_SYS1_PLLCTL3_REFCLKDIV2_GET(reg) |
| #define | TMS570_SYS1_PLLCTL3_REFCLKDIV2_SET(reg, val) |
| #define | TMS570_SYS1_PLLCTL3_PLLMUL2(val) |
| #define | TMS570_SYS1_PLLCTL3_PLLMUL2_GET(reg) |
| #define | TMS570_SYS1_PLLCTL3_PLLMUL2_SET(reg, val) |
#define | TMS570_SYS1_SYSPC10_ECPCLK_SLEW BSP_BIT32(0) |
| #define | TMS570_SYS1_DIEIDL_LOT(val) |
| #define | TMS570_SYS1_DIEIDL_LOT_GET(reg) |
| #define | TMS570_SYS1_DIEIDL_LOT_SET(reg, val) |
| #define | TMS570_SYS1_DIEIDL_WAFER(val) |
| #define | TMS570_SYS1_DIEIDL_WAFER_GET(reg) |
| #define | TMS570_SYS1_DIEIDL_WAFER_SET(reg, val) |
| #define | TMS570_SYS1_DIEIDL_Y_WAFER_COORDINATE(val) |
| #define | TMS570_SYS1_DIEIDL_Y_WAFER_COORDINATE_GET(reg) |
| #define | TMS570_SYS1_DIEIDL_Y_WAFER_COORDINATE_SET(reg, val) |
| #define | TMS570_SYS1_DIEIDL_X_WAFER_COORDINATE(val) |
| #define | TMS570_SYS1_DIEIDL_X_WAFER_COORDINATE_GET(reg) |
| #define | TMS570_SYS1_DIEIDL_X_WAFER_COORDINATE_SET(reg, val) |
| #define | TMS570_SYS1_DIEIDH_LOT(val) |
| #define | TMS570_SYS1_DIEIDH_LOT_GET(reg) |
| #define | TMS570_SYS1_DIEIDH_LOT_SET(reg, val) |
#define | TMS570_SYS1_LPOMONCTL_BIAS_ENABLE BSP_BIT32(24) |
#define | TMS570_SYS1_LPOMONCTL_OSCFRQCONFIGCNT BSP_BIT32(16) |
| #define | TMS570_SYS1_LPOMONCTL_HFTRIM(val) |
| #define | TMS570_SYS1_LPOMONCTL_HFTRIM_GET(reg) |
| #define | TMS570_SYS1_LPOMONCTL_HFTRIM_SET(reg, val) |
#define | TMS570_SYS1_CLKTEST_ALTLIMPCLOCKENABLE BSP_BIT32(26) |
#define | TMS570_SYS1_CLKTEST_RANGEDETCTRL BSP_BIT32(25) |
#define | TMS570_SYS1_CLKTEST_RANGEDETENASSEL BSP_BIT32(24) |
| #define | TMS570_SYS1_CLKTEST_CLK_TEST_EN(val) |
| #define | TMS570_SYS1_CLKTEST_CLK_TEST_EN_GET(reg) |
| #define | TMS570_SYS1_CLKTEST_CLK_TEST_EN_SET(reg, val) |
| #define | TMS570_SYS1_CLKTEST_SEL_GIO_PIN(val) |
| #define | TMS570_SYS1_CLKTEST_SEL_GIO_PIN_GET(reg) |
| #define | TMS570_SYS1_CLKTEST_SEL_GIO_PIN_SET(reg, val) |
| #define | TMS570_SYS1_CLKTEST_SEL_ECP_PIN(val) |
| #define | TMS570_SYS1_CLKTEST_SEL_ECP_PIN_GET(reg) |
| #define | TMS570_SYS1_CLKTEST_SEL_ECP_PIN_SET(reg, val) |
| #define | TMS570_SYS1_DFTCTRLREG1_DFTWRITE(val) |
| #define | TMS570_SYS1_DFTCTRLREG1_DFTWRITE_GET(reg) |
| #define | TMS570_SYS1_DFTCTRLREG1_DFTWRITE_SET(reg, val) |
| #define | TMS570_SYS1_DFTCTRLREG1_DFTREAD(val) |
| #define | TMS570_SYS1_DFTCTRLREG1_DFTREAD_GET(reg) |
| #define | TMS570_SYS1_DFTCTRLREG1_DFTREAD_SET(reg, val) |
| #define | TMS570_SYS1_DFTCTRLREG1_TEST_MODE_KEY(val) |
| #define | TMS570_SYS1_DFTCTRLREG1_TEST_MODE_KEY_GET(reg) |
| #define | TMS570_SYS1_DFTCTRLREG1_TEST_MODE_KEY_SET(reg, val) |
| #define | TMS570_SYS1_DFTCTRLREG2_IMPDF(val) |
| #define | TMS570_SYS1_DFTCTRLREG2_IMPDF_GET(reg) |
| #define | TMS570_SYS1_DFTCTRLREG2_IMPDF_SET(reg, val) |
| #define | TMS570_SYS1_DFTCTRLREG2_TEST_MODE_KEY(val) |
| #define | TMS570_SYS1_DFTCTRLREG2_TEST_MODE_KEY_GET(reg) |
| #define | TMS570_SYS1_DFTCTRLREG2_TEST_MODE_KEY_SET(reg, val) |
#define | TMS570_SYS1_GPREG1_EMIF_FUNC BSP_BIT32(31) |
| #define | TMS570_SYS1_GPREG1_PLL1_FBSLIP_FILTER__COUNT(val) |
| #define | TMS570_SYS1_GPREG1_PLL1_FBSLIP_FILTER__COUNT_GET(reg) |
| #define | TMS570_SYS1_GPREG1_PLL1_FBSLIP_FILTER__COUNT_SET(reg, val) |
| #define | TMS570_SYS1_GPREG1_PLL1_RFSLIP_FILTER__KEY(val) |
| #define | TMS570_SYS1_GPREG1_PLL1_RFSLIP_FILTER__KEY_GET(reg) |
| #define | TMS570_SYS1_GPREG1_PLL1_RFSLIP_FILTER__KEY_SET(reg, val) |
| #define | TMS570_SYS1_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE(val) |
| #define | TMS570_SYS1_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_GET(reg) |
| #define | TMS570_SYS1_GPREG1_OUTPUT_BUFFER_LOW_EMI_MODE_SET(reg, val) |
#define | TMS570_SYS1_IMPFASTS_ECPCLKFUN BSP_BIT32(0) |
| #define | TMS570_SYS1_SSIRx_SSKEY1(val) |
| #define | TMS570_SYS1_SSIRx_SSKEY1_GET(reg) |
| #define | TMS570_SYS1_SSIRx_SSKEY1_SET(reg, val) |
| #define | TMS570_SYS1_SSIRx_SSDATA1(val) |
| #define | TMS570_SYS1_SSIRx_SSDATA1_GET(reg) |
| #define | TMS570_SYS1_SSIRx_SSDATA1_SET(reg, val) |
| #define | TMS570_SYS1_RAMGCR_RAM_DFT_EN(val) |
| #define | TMS570_SYS1_RAMGCR_RAM_DFT_EN_GET(reg) |
| #define | TMS570_SYS1_RAMGCR_RAM_DFT_EN_SET(reg, val) |
#define | TMS570_SYS1_RAMGCR_WST_AENA0 BSP_BIT32(2) |
#define | TMS570_SYS1_RAMGCR_WST_DENA0 BSP_BIT32(0) |
| #define | TMS570_SYS1_BMMCR1_MEMSW(val) |
| #define | TMS570_SYS1_BMMCR1_MEMSW_GET(reg) |
| #define | TMS570_SYS1_BMMCR1_MEMSW_SET(reg, val) |
#define | TMS570_SYS1_CPURSTCR_CPU_RESET BSP_BIT32(0) |
| #define | TMS570_SYS1_CLKCNTL_VCLK2R(val) |
| #define | TMS570_SYS1_CLKCNTL_VCLK2R_GET(reg) |
| #define | TMS570_SYS1_CLKCNTL_VCLK2R_SET(reg, val) |
| #define | TMS570_SYS1_CLKCNTL_VCLKR(val) |
| #define | TMS570_SYS1_CLKCNTL_VCLKR_GET(reg) |
| #define | TMS570_SYS1_CLKCNTL_VCLKR_SET(reg, val) |
#define | TMS570_SYS1_CLKCNTL_PENA BSP_BIT32(8) |
#define | TMS570_SYS1_ECPCNTL_ECPSSEL BSP_BIT32(24) |
#define | TMS570_SYS1_ECPCNTL_ECPCOS BSP_BIT32(23) |
| #define | TMS570_SYS1_ECPCNTL_ECPINSEL(val) |
| #define | TMS570_SYS1_ECPCNTL_ECPINSEL_GET(reg) |
| #define | TMS570_SYS1_ECPCNTL_ECPINSEL_SET(reg, val) |
| #define | TMS570_SYS1_ECPCNTL_ECPDIV(val) |
| #define | TMS570_SYS1_ECPCNTL_ECPDIV_GET(reg) |
| #define | TMS570_SYS1_ECPCNTL_ECPDIV_SET(reg, val) |
| #define | TMS570_SYS1_DEVCR1_DEVPARSEL(val) |
| #define | TMS570_SYS1_DEVCR1_DEVPARSEL_GET(reg) |
| #define | TMS570_SYS1_DEVCR1_DEVPARSEL_SET(reg, val) |
| #define | TMS570_SYS1_SYSECR_RESET(val) |
| #define | TMS570_SYS1_SYSECR_RESET_GET(reg) |
| #define | TMS570_SYS1_SYSECR_RESET_SET(reg, val) |
#define | TMS570_SYS1_SYSESR_PORST BSP_BIT32(15) |
#define | TMS570_SYS1_SYSESR_OSCRST BSP_BIT32(14) |
#define | TMS570_SYS1_SYSESR_WDRST BSP_BIT32(13) |
#define | TMS570_SYS1_SYSESR_CPURST BSP_BIT32(5) |
#define | TMS570_SYS1_SYSESR_SWRST BSP_BIT32(4) |
#define | TMS570_SYS1_SYSESR_EXTRST BSP_BIT32(3) |
#define | TMS570_SYS1_SYSESR_MPMODE BSP_BIT32(0) |
| #define | TMS570_SYS1_SYSTASR_EFUSE_Abort(val) |
| #define | TMS570_SYS1_SYSTASR_EFUSE_Abort_GET(reg) |
| #define | TMS570_SYS1_SYSTASR_EFUSE_Abort_SET(reg, val) |
#define | TMS570_SYS1_GLBSTAT_FBSLIP BSP_BIT32(9) |
#define | TMS570_SYS1_GLBSTAT_RFSLIP BSP_BIT32(8) |
#define | TMS570_SYS1_GLBSTAT_OSCFAIL BSP_BIT32(0) |
#define | TMS570_SYS1_DEVID_CP15 BSP_BIT32(31) |
| #define | TMS570_SYS1_DEVID_TECH(val) |
| #define | TMS570_SYS1_DEVID_TECH_GET(reg) |
| #define | TMS570_SYS1_DEVID_TECH_SET(reg, val) |
#define | TMS570_SYS1_DEVID_I_O_VOLTAGE BSP_BIT32(12) |
#define | TMS570_SYS1_DEVID_PERIPHERAL_PARITY BSP_BIT32(11) |
| #define | TMS570_SYS1_DEVID_FLASH_ECC(val) |
| #define | TMS570_SYS1_DEVID_FLASH_ECC_GET(reg) |
| #define | TMS570_SYS1_DEVID_FLASH_ECC_SET(reg, val) |
#define | TMS570_SYS1_DEVID_RAM_ECC BSP_BIT32(8) |
| #define | TMS570_SYS1_DEVID_VERSION(val) |
| #define | TMS570_SYS1_DEVID_VERSION_GET(reg) |
| #define | TMS570_SYS1_DEVID_VERSION_SET(reg, val) |
| #define | TMS570_SYS1_DEVID_PLATFORM_ID(val) |
| #define | TMS570_SYS1_DEVID_PLATFORM_ID_GET(reg) |
| #define | TMS570_SYS1_DEVID_PLATFORM_ID_SET(reg, val) |
| #define | TMS570_SYS1_SSIVEC_SSIDATA(val) |
| #define | TMS570_SYS1_SSIVEC_SSIDATA_GET(reg) |
| #define | TMS570_SYS1_SSIVEC_SSIDATA_SET(reg, val) |
| #define | TMS570_SYS1_SSIVEC_SSIVECT(val) |
| #define | TMS570_SYS1_SSIVEC_SSIVECT_GET(reg) |
| #define | TMS570_SYS1_SSIVEC_SSIVECT_SET(reg, val) |
| #define | TMS570_SYS1_SSIF_SSI_FLAG(val) |
| #define | TMS570_SYS1_SSIF_SSI_FLAG_GET(reg) |
| #define | TMS570_SYS1_SSIF_SSI_FLAG_SET(reg, val) |
