RTEMS 6.3
This header file provides STC interfaces. More...
#include <bsp/utility.h>Go to the source code of this file.
| struct | tms570_stc_t |
| #define | TMS570_STC_STCGCR0_INTCOUNT(val) |
| #define | TMS570_STC_STCGCR0_INTCOUNT_GET(reg) |
| #define | TMS570_STC_STCGCR0_INTCOUNT_SET(reg, val) |
| #define | TMS570_STC_STCGCR0_RS_CNT BSP_BIT32(0) |
| #define | TMS570_STC_STCGCR1_STC_ENA(val) |
| #define | TMS570_STC_STCGCR1_STC_ENA_GET(reg) |
| #define | TMS570_STC_STCGCR1_STC_ENA_SET(reg, val) |
| #define | TMS570_STC_STCCICR_N(val) |
| #define | TMS570_STC_STCCICR_N_GET(reg) |
| #define | TMS570_STC_STCCICR_N_SET(reg, val) |
| #define | TMS570_STC_STCGSTAT_TEST_FAIL BSP_BIT32(1) |
| #define | TMS570_STC_STCGSTAT_TEST_DONE BSP_BIT32(0) |
| #define | TMS570_STC_STCFSTAT_TO_ERR BSP_BIT32(2) |
| #define | TMS570_STC_STCFSTAT_CPU2_FAIL BSP_BIT32(1) |
| #define | TMS570_STC_STCFSTAT_CPU1_FAIL BSP_BIT32(0) |
| #define | TMS570_STC_STCSCSCR_FAULT_INS BSP_BIT32(4) |
| #define | TMS570_STC_STCSCSCR_SELF_CHECK_KEY(val) |
| #define | TMS570_STC_STCSCSCR_SELF_CHECK_KEY_GET(reg) |
| #define | TMS570_STC_STCSCSCR_SELF_CHECK_KEY_SET(reg, val) |
| #define TMS570_STC_STCCICR_N | ( | val | ) |
| #define TMS570_STC_STCCICR_N_GET | ( | reg | ) |
| #define TMS570_STC_STCCICR_N_SET | ( | reg, | |
| val ) |
| #define TMS570_STC_STCGCR0_INTCOUNT | ( | val | ) |
| #define TMS570_STC_STCGCR0_INTCOUNT_GET | ( | reg | ) |
| #define TMS570_STC_STCGCR0_INTCOUNT_SET | ( | reg, | |
| val ) |
| #define TMS570_STC_STCGCR1_STC_ENA | ( | val | ) |
| #define TMS570_STC_STCGCR1_STC_ENA_GET | ( | reg | ) |
| #define TMS570_STC_STCGCR1_STC_ENA_SET | ( | reg, | |
| val ) |
| #define TMS570_STC_STCSCSCR_SELF_CHECK_KEY | ( | val | ) |
| #define TMS570_STC_STCSCSCR_SELF_CHECK_KEY_GET | ( | reg | ) |
| #define TMS570_STC_STCSCSCR_SELF_CHECK_KEY_SET | ( | reg, | |
| val ) |
