RTEMS 6.3
reg_sci.h File Reference
This header file provides SCI interfaces. More...
#include <bsp/utility.h>
struct  tms570_sci_t
#define TMS570_SCI_GCR0_Reserved(val)
#define TMS570_SCI_GCR0_Reserved_GET(reg)
#define TMS570_SCI_GCR0_Reserved_SET(reg, val)
#define TMS570_SCI_GCR0_RESET   BSP_BIT32(0)
#define TMS570_SCI_GCR1_TXENA   BSP_BIT32(25)
#define TMS570_SCI_GCR1_RXENA   BSP_BIT32(24)
#define TMS570_SCI_GCR1_CONT   BSP_BIT32(17)
#define TMS570_SCI_GCR1_LOOP_BACK   BSP_BIT32(16)
#define TMS570_SCI_GCR1_POWERDOWN   BSP_BIT32(9)
#define TMS570_SCI_GCR1_SLEEP   BSP_BIT32(8)
#define TMS570_SCI_GCR1_SWnRST   BSP_BIT32(7)
#define TMS570_SCI_GCR1_CLOCK   BSP_BIT32(5)
#define TMS570_SCI_GCR1_STOP   BSP_BIT32(4)
#define TMS570_SCI_GCR1_PARITY   BSP_BIT32(3)
#define TMS570_SCI_GCR1_PARITY_ENA   BSP_BIT32(2)
#define TMS570_SCI_GCR1_TIMING_MODE   BSP_BIT32(1)
#define TMS570_SCI_GCR1_COMM_MODE   BSP_BIT32(0)
#define TMS570_SCI_GCR2_CC   BSP_BIT32(17)
#define TMS570_SCI_GCR2_SC   BSP_BIT32(16)
#define TMS570_SCI_GCR2_GEN_WU   BSP_BIT32(8)
#define TMS570_SCI_GCR2_POWERDOWN   BSP_BIT32(0)
#define TMS570_SCI_SETINT_SET_FE_INT   BSP_BIT32(26)
#define TMS570_SCI_SETINT_SET_OE_INT   BSP_BIT32(25)
#define TMS570_SCI_SETINT_SET_PE_INT   BSP_BIT32(24)
#define TMS570_SCI_SETINT_SET_RX_DMA_ALL   BSP_BIT32(18)
#define TMS570_SCI_SETINT_SET_RX_DMA   BSP_BIT32(17)
#define TMS570_SCI_SETINT_SET_TX_DMA   BSP_BIT32(16)
#define TMS570_SCI_SETINT_SET_RX_INT   BSP_BIT32(9)
#define TMS570_SCI_SETINT_SET_TX_INT   BSP_BIT32(8)
#define TMS570_SCI_SETINT_SET_WAKEUP_INT   BSP_BIT32(1)
#define TMS570_SCI_SETINT_SET_BRKDT_INT   BSP_BIT32(0)
#define TMS570_SCI_CLEARINT_CLR_FE_INT   BSP_BIT32(26)
#define TMS570_SCI_CLEARINT_CLR_CE_INT   BSP_BIT32(25)
#define TMS570_SCI_CLEARINT_CLR_PE_INT   BSP_BIT32(24)
#define TMS570_SCI_CLEARINT_CLR_RX_DMA_ALL   BSP_BIT32(18)
#define TMS570_SCI_CLEARINT_CLR_RX_DMA   BSP_BIT32(17)
#define TMS570_SCI_CLEARINT_CLR_TX_DMA   BSP_BIT32(16)
#define TMS570_SCI_CLEARINT_CLR_RX_INT   BSP_BIT32(9)
#define TMS570_SCI_CLEARINT_CLR_TX_INT   BSP_BIT32(8)
#define TMS570_SCI_CLEARINT_CLR_WAKEUP_INT   BSP_BIT32(1)
#define TMS570_SCI_CLEARINT_CLR_BRKDT_INT   BSP_BIT32(0)
#define TMS570_SCI_SETINTLVL_SET_FE_INT_LVL   BSP_BIT32(26)
#define TMS570_SCI_SETINTLVL_SET_CE_INT_LVL   BSP_BIT32(25)
#define TMS570_SCI_SETINTLVL_SET_PE_INT_LVL   BSP_BIT32(24)
#define TMS570_SCI_SETINTLVL_SET_RX_DMA_ALL_LVL   BSP_BIT32(18)
#define TMS570_SCI_SETINTLVL_SET_RX_INT_LVL   BSP_BIT32(9)
#define TMS570_SCI_SETINTLVL_SET_TX_INT_LVL   BSP_BIT32(8)
#define TMS570_SCI_SETINTLVL_SET_WAKEUP_INT_LVL   BSP_BIT32(1)
#define TMS570_SCI_SETINTLVL_SET_BRKDT_INT_LVL   BSP_BIT32(0)
#define TMS570_SCI_CLEARINTLVL_CLR_FE_INT_LVL   BSP_BIT32(26)
#define TMS570_SCI_CLEARINTLVL_CLR_CE_INT_LVL   BSP_BIT32(25)
#define TMS570_SCI_CLEARINTLVL_CLR_PE_INT_LVL   BSP_BIT32(24)
#define TMS570_SCI_CLEARINTLVL_CLR_RX_DMA_ALL_LVL   BSP_BIT32(18)
#define TMS570_SCI_CLEARINTLVL_CLR_RX_INT_LVL   BSP_BIT32(9)
#define TMS570_SCI_CLEARINTLVL_8   BSP_BIT32(8)
#define TMS570_SCI_CLEARINTLVL_CLR_WAKEUP_INT_LVL   BSP_BIT32(1)
#define TMS570_SCI_CLEARINTLVL_CLR_BRKDT_INT_LVL   BSP_BIT32(0)
#define TMS570_SCI_FLR_FE   BSP_BIT32(26)
#define TMS570_SCI_FLR_OE   BSP_BIT32(25)
#define TMS570_SCI_FLR_PE   BSP_BIT32(24)
#define TMS570_SCI_FLR_RXWAKE   BSP_BIT32(12)
#define TMS570_SCI_FLR_TX_EMPTY   BSP_BIT32(11)
#define TMS570_SCI_FLR_TXWAKE   BSP_BIT32(10)
#define TMS570_SCI_FLR_RXRDY   BSP_BIT32(9)
#define TMS570_SCI_FLR_TXRDY   BSP_BIT32(8)
#define TMS570_SCI_FLR_BUSY   BSP_BIT32(3)
#define TMS570_SCI_FLR_IDLE   BSP_BIT32(2)
#define TMS570_SCI_FLR_WAKEUP   BSP_BIT32(1)
#define TMS570_SCI_FLR_BRKDT   BSP_BIT32(0)
#define TMS570_SCI_INTVECT0_INVECT0(val)
#define TMS570_SCI_INTVECT0_INVECT0_GET(reg)
#define TMS570_SCI_INTVECT0_INVECT0_SET(reg, val)
#define TMS570_SCI_INTVECT1_INVECT1(val)
#define TMS570_SCI_INTVECT1_INVECT1_GET(reg)
#define TMS570_SCI_INTVECT1_INVECT1_SET(reg, val)
#define TMS570_SCI_FORMAT_CHAR(val)
#define TMS570_SCI_FORMAT_CHAR_GET(reg)
#define TMS570_SCI_FORMAT_CHAR_SET(reg, val)
#define TMS570_SCI_BRS_BAUD(val)
#define TMS570_SCI_BRS_BAUD_GET(reg)
#define TMS570_SCI_BRS_BAUD_SET(reg, val)
#define TMS570_SCI_ED_ED(val)
#define TMS570_SCI_ED_ED_GET(reg)
#define TMS570_SCI_ED_ED_SET(reg, val)
#define TMS570_SCI_RD_RD(val)
#define TMS570_SCI_RD_RD_GET(reg)
#define TMS570_SCI_RD_RD_SET(reg, val)
#define TMS570_SCI_TD_TD(val)
#define TMS570_SCI_TD_TD_GET(reg)
#define TMS570_SCI_TD_TD_SET(reg, val)
#define TMS570_SCI_PIO0_TX_FUNC   BSP_BIT32(2)
#define TMS570_SCI_PIO0_RX_FUNC   BSP_BIT32(1)
#define TMS570_SCI_PIO1_TX_DIR   BSP_BIT32(2)
#define TMS570_SCI_PIO1_RX_DIR   BSP_BIT32(1)
#define TMS570_SCI_PIO2_TX_IN   BSP_BIT32(2)
#define TMS570_SCI_PIO2_RX_IN   BSP_BIT32(1)
#define TMS570_SCI_PIO3_TX_OUT   BSP_BIT32(2)
#define TMS570_SCI_PIO3_RX_OUT   BSP_BIT32(1)
#define TMS570_SCI_PIO4_TX_SET   BSP_BIT32(2)
#define TMS570_SCI_PIO4_RX_SET   BSP_BIT32(1)
#define TMS570_SCI_PIO5_TX_CLR   BSP_BIT32(2)
#define TMS570_SCI_PIO5_RX_CLR   BSP_BIT32(1)
#define TMS570_SCI_PIO6_TX_PDR   BSP_BIT32(2)
#define TMS570_SCI_PIO6_RX_PDR   BSP_BIT32(1)
#define TMS570_SCI_PIO7_TX_PD   BSP_BIT32(2)
#define TMS570_SCI_PIO7_RX_PD   BSP_BIT32(1)
#define TMS570_SCI_PIO8_TX_PSL   BSP_BIT32(2)
#define TMS570_SCI_PIO8_RX_PSL   BSP_BIT32(1)
#define TMS570_SCI_IODFTCTRL_FEN   BSP_BIT32(26)
#define TMS570_SCI_IODFTCTRL_PEN   BSP_BIT32(25)
#define TMS570_SCI_IODFTCTRL_BRKD_TENA   BSP_BIT32(24)
#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK(val)
#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_GET(reg)
#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_SET(reg, val)
#define TMS570_SCI_IODFTCTRL_TX_SHIFT(val)
#define TMS570_SCI_IODFTCTRL_TX_SHIFT_GET(reg)
#define TMS570_SCI_IODFTCTRL_TX_SHIFT_SET(reg, val)
#define TMS570_SCI_IODFTCTRL_IODFTENA(val)
#define TMS570_SCI_IODFTCTRL_IODFTENA_GET(reg)
#define TMS570_SCI_IODFTCTRL_IODFTENA_SET(reg, val)
#define TMS570_SCI_IODFTCTRL_LPBENA   BSP_BIT32(1)
#define TMS570_SCI_IODFTCTRL_RXPENA   BSP_BIT32(0)
◆ TMS570_SCI_BRS_BAUD
#define TMS570_SCI_BRS_BAUD ( val)
Value:
BSP_FLD32(val,0, 23)
◆ TMS570_SCI_BRS_BAUD_GET
#define TMS570_SCI_BRS_BAUD_GET ( reg)
Value:
BSP_FLD32GET(reg,0, 23)
◆ TMS570_SCI_BRS_BAUD_SET
#define TMS570_SCI_BRS_BAUD_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,0, 23)
◆ TMS570_SCI_ED_ED
#define TMS570_SCI_ED_ED ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_SCI_ED_ED_GET
#define TMS570_SCI_ED_ED_GET ( reg)
Value:
BSP_FLD32GET(reg,0, 7)
◆ TMS570_SCI_ED_ED_SET
#define TMS570_SCI_ED_ED_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,0, 7)
◆ TMS570_SCI_FORMAT_CHAR
#define TMS570_SCI_FORMAT_CHAR ( val)
Value:
BSP_FLD32(val,0, 2)
◆ TMS570_SCI_FORMAT_CHAR_GET
#define TMS570_SCI_FORMAT_CHAR_GET ( reg)
Value:
BSP_FLD32GET(reg,0, 2)
◆ TMS570_SCI_FORMAT_CHAR_SET
#define TMS570_SCI_FORMAT_CHAR_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,0, 2)
◆ TMS570_SCI_GCR0_Reserved
#define TMS570_SCI_GCR0_Reserved ( val)
Value:
BSP_FLD32(val,1, 31)
◆ TMS570_SCI_GCR0_Reserved_GET
#define TMS570_SCI_GCR0_Reserved_GET ( reg)
Value:
BSP_FLD32GET(reg,1, 31)
◆ TMS570_SCI_GCR0_Reserved_SET
#define TMS570_SCI_GCR0_Reserved_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,1, 31)
◆ TMS570_SCI_INTVECT0_INVECT0
#define TMS570_SCI_INTVECT0_INVECT0 ( val)
Value:
BSP_FLD32(val,0, 3)
◆ TMS570_SCI_INTVECT0_INVECT0_GET
#define TMS570_SCI_INTVECT0_INVECT0_GET ( reg)
Value:
BSP_FLD32GET(reg,0, 3)
◆ TMS570_SCI_INTVECT0_INVECT0_SET
#define TMS570_SCI_INTVECT0_INVECT0_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,0, 3)
◆ TMS570_SCI_INTVECT1_INVECT1
#define TMS570_SCI_INTVECT1_INVECT1 ( val)
Value:
BSP_FLD32(val,0, 3)
◆ TMS570_SCI_INTVECT1_INVECT1_GET
#define TMS570_SCI_INTVECT1_INVECT1_GET ( reg)
Value:
◆ TMS570_SCI_INTVECT1_INVECT1_SET
#define TMS570_SCI_INTVECT1_INVECT1_SET ( reg,
val )
Value:
◆ TMS570_SCI_IODFTCTRL_IODFTENA
#define TMS570_SCI_IODFTCTRL_IODFTENA ( val)
Value:
BSP_FLD32(val,8, 11)
◆ TMS570_SCI_IODFTCTRL_IODFTENA_GET
#define TMS570_SCI_IODFTCTRL_IODFTENA_GET ( reg)
Value:
BSP_FLD32GET(reg,8, 11)
◆ TMS570_SCI_IODFTCTRL_IODFTENA_SET
#define TMS570_SCI_IODFTCTRL_IODFTENA_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,8, 11)
◆ TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK
#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK ( val)
Value:
BSP_FLD32(val,19, 20)
◆ TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_GET
#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_GET ( reg)
Value:
BSP_FLD32GET(reg,19, 20)
◆ TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_SET
#define TMS570_SCI_IODFTCTRL_PIN_SAMPLE_MASK_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,19, 20)
◆ TMS570_SCI_IODFTCTRL_TX_SHIFT
#define TMS570_SCI_IODFTCTRL_TX_SHIFT ( val)
Value:
BSP_FLD32(val,16, 18)
◆ TMS570_SCI_IODFTCTRL_TX_SHIFT_GET
#define TMS570_SCI_IODFTCTRL_TX_SHIFT_GET ( reg)
Value:
BSP_FLD32GET(reg,16, 18)
◆ TMS570_SCI_IODFTCTRL_TX_SHIFT_SET
#define TMS570_SCI_IODFTCTRL_TX_SHIFT_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,16, 18)
◆ TMS570_SCI_RD_RD
#define TMS570_SCI_RD_RD ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_SCI_RD_RD_GET
#define TMS570_SCI_RD_RD_GET ( reg)
Value:
◆ TMS570_SCI_RD_RD_SET
#define TMS570_SCI_RD_RD_SET ( reg,
val )
Value:
◆ TMS570_SCI_TD_TD
#define TMS570_SCI_TD_TD ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_SCI_TD_TD_GET
#define TMS570_SCI_TD_TD_GET ( reg)
Value:
◆ TMS570_SCI_TD_TD_SET
#define TMS570_SCI_TD_TD_SET ( reg,
val )
Value:
