RTEMS 6.3
reg_flash.h File Reference
This header file provides flash interfaces. More...
#include <bsp/utility.h>
struct  tms570_flash_t
#define TMS570_FLASH_FRDCNTL_RWAIT(val)
#define TMS570_FLASH_FRDCNTL_RWAIT_GET(reg)
#define TMS570_FLASH_FRDCNTL_RWAIT_SET(reg, val)
#define TMS570_FLASH_FRDCNTL_ASWSTEN   BSP_BIT32(4)
#define TMS570_FLASH_FRDCNTL_ENPIPE   BSP_BIT32(0)
#define TMS570_FLASH_FEDACTRL1_SUSP_IGNR   BSP_BIT32(24)
#define TMS570_FLASH_FEDACTRL1_EDACMODE(val)
#define TMS570_FLASH_FEDACTRL1_EDACMODE_GET(reg)
#define TMS570_FLASH_FEDACTRL1_EDACMODE_SET(reg, val)
#define TMS570_FLASH_FEDACTRL1_EOFEN   BSP_BIT32(10)
#define TMS570_FLASH_FEDACTRL1_EZFEN   BSP_BIT32(9)
#define TMS570_FLASH_FEDACTRL1_EPEN   BSP_BIT32(8)
#define TMS570_FLASH_FEDACTRL1_EDACEN(val)
#define TMS570_FLASH_FEDACTRL1_EDACEN_GET(reg)
#define TMS570_FLASH_FEDACTRL1_EDACEN_SET(reg, val)
#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD(val)
#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_GET(reg)
#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_SET(reg, val)
#define TMS570_FLASH_FCORERRCNT_FERRCNT(val)
#define TMS570_FLASH_FCORERRCNT_FERRCNT_GET(reg)
#define TMS570_FLASH_FCORERRCNT_FERRCNT_SET(reg, val)
#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD(val)
#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_GET(reg)
#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_SET(reg, val)
#define TMS570_FLASH_FCORERRADD_B_OFF(val)
#define TMS570_FLASH_FCORERRADD_B_OFF_GET(reg)
#define TMS570_FLASH_FCORERRADD_B_OFF_SET(reg, val)
#define TMS570_FLASH_FCORERRPOS_BUS2   BSP_BIT32(9)
#define TMS570_FLASH_FCORERRPOS_TYPE   BSP_BIT32(8)
#define TMS570_FLASH_FCORERRPOS_ERR_POS(val)
#define TMS570_FLASH_FCORERRPOS_ERR_POS_GET(reg)
#define TMS570_FLASH_FCORERRPOS_ERR_POS_SET(reg, val)
#define TMS570_FLASH_FEDACSTATUS_Reserved(val)
#define TMS570_FLASH_FEDACSTATUS_Reserved_GET(reg)
#define TMS570_FLASH_FEDACSTATUS_Reserved_SET(reg, val)
#define TMS570_FLASH_FEDACSTATUS_FSM_DONE   BSP_BIT32(24)
#define TMS570_FLASH_FEDACSTATUS_COMB2_MAL_G   BSP_BIT32(19)
#define TMS570_FLASH_FEDACSTATUS_ECC_B2_MAL_   BSP_BIT32(18)
#define TMS570_FLASH_FEDACSTATUS_B2_UNC_ERR   BSP_BIT32(17)
#define TMS570_FLASH_FEDACSTATUS_B2_COR_ERR   BSP_BIT32(16)
#define TMS570_FLASH_FEDACSTATUS_D_UNC_ERR   BSP_BIT32(12)
#define TMS570_FLASH_FEDACSTATUS_ADD_TAG_ERR   BSP_BIT32(11)
#define TMS570_FLASH_FEDACSTATUS_ADD_PAR_ERR   BSP_BIT32(10)
#define TMS570_FLASH_FEDACSTATUS_B1_UNC_ERR   BSP_BIT32(8)
#define TMS570_FLASH_FEDACSTATUS_D_CORR_ERR   BSP_BIT32(3)
#define TMS570_FLASH_FEDACSTATUS_ERR_ONE_FLG   BSP_BIT32(2)
#define TMS570_FLASH_FEDACSTATUS_ERR_ZERO__FLG   BSP_BIT32(1)
#define TMS570_FLASH_FEDACSTATUS_ERR_PRF_FLG   BSP_BIT32(0)
#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD(val)
#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_GET(reg)
#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_SET(reg, val)
#define TMS570_FLASH_FUNCERRADD_B_OFF(val)
#define TMS570_FLASH_FUNCERRADD_B_OFF_GET(reg)
#define TMS570_FLASH_FUNCERRADD_B_OFF_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse(val)
#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_GET(reg)
#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse(val)
#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_GET(reg)
#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS_BankID1(val)
#define TMS570_FLASH_FEDACSDIS_BankID1_GET(reg)
#define TMS570_FLASH_FEDACSDIS_BankID1_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS_SectorID1(val)
#define TMS570_FLASH_FEDACSDIS_SectorID1_GET(reg)
#define TMS570_FLASH_FEDACSDIS_SectorID1_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse(val)
#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_GET(reg)
#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse(val)
#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_GET(reg)
#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS_BankID0(val)
#define TMS570_FLASH_FEDACSDIS_BankID0_GET(reg)
#define TMS570_FLASH_FEDACSDIS_BankID0_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS_SectorID0(val)
#define TMS570_FLASH_FEDACSDIS_SectorID0_GET(reg)
#define TMS570_FLASH_FEDACSDIS_SectorID0_SET(reg, val)
#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG(val)
#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_GET(reg)
#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_SET(reg, val)
#define TMS570_FLASH_FPRIMADDTAG_0(val)
#define TMS570_FLASH_FPRIMADDTAG_0_GET(reg)
#define TMS570_FLASH_FPRIMADDTAG_0_SET(reg, val)
#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG(val)
#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_GET(reg)
#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_SET(reg, val)
#define TMS570_FLASH_FBPROT_PROTL1DIS   BSP_BIT32(0)
#define TMS570_FLASH_FBSE_BSE(val)
#define TMS570_FLASH_FBSE_BSE_GET(reg)
#define TMS570_FLASH_FBSE_BSE_SET(reg, val)
#define TMS570_FLASH_FBBUSY_BUSY(val)
#define TMS570_FLASH_FBBUSY_BUSY_GET(reg)
#define TMS570_FLASH_FBBUSY_BUSY_SET(reg, val)
#define TMS570_FLASH_FBAC_OTPPROTDIS(val)
#define TMS570_FLASH_FBAC_OTPPROTDIS_GET(reg)
#define TMS570_FLASH_FBAC_OTPPROTDIS_SET(reg, val)
#define TMS570_FLASH_FBAC_15_8(val)
#define TMS570_FLASH_FBAC_15_8_GET(reg)
#define TMS570_FLASH_FBAC_15_8_SET(reg, val)
#define TMS570_FLASH_FBAC_VREADST(val)
#define TMS570_FLASH_FBAC_VREADST_GET(reg)
#define TMS570_FLASH_FBAC_VREADST_SET(reg, val)
#define TMS570_FLASH_FBFALLBACK_BANKPWR7(val)
#define TMS570_FLASH_FBFALLBACK_BANKPWR7_GET(reg)
#define TMS570_FLASH_FBFALLBACK_BANKPWR7_SET(reg, val)
#define TMS570_FLASH_FBFALLBACK_BANKPWR1(val)
#define TMS570_FLASH_FBFALLBACK_BANKPWR1_GET(reg)
#define TMS570_FLASH_FBFALLBACK_BANKPWR1_SET(reg, val)
#define TMS570_FLASH_FBFALLBACK_BANKPWR0(val)
#define TMS570_FLASH_FBFALLBACK_BANKPWR0_GET(reg)
#define TMS570_FLASH_FBFALLBACK_BANKPWR0_SET(reg, val)
#define TMS570_FLASH_FBPRDY_BANKBUSY(val)
#define TMS570_FLASH_FBPRDY_BANKBUSY_GET(reg)
#define TMS570_FLASH_FBPRDY_BANKBUSY_SET(reg, val)
#define TMS570_FLASH_FBPRDY_PUMPRDY   BSP_BIT32(15)
#define TMS570_FLASH_FBPRDY_BANKRDY(val)
#define TMS570_FLASH_FBPRDY_BANKRDY_GET(reg)
#define TMS570_FLASH_FBPRDY_BANKRDY_SET(reg, val)
#define TMS570_FLASH_FPAC1_PSLEEP(val)
#define TMS570_FLASH_FPAC1_PSLEEP_GET(reg)
#define TMS570_FLASH_FPAC1_PSLEEP_SET(reg, val)
#define TMS570_FLASH_FPAC1_PUMPPWR   BSP_BIT32(0)
#define TMS570_FLASH_FPAC2_PAGP(val)
#define TMS570_FLASH_FPAC2_PAGP_GET(reg)
#define TMS570_FLASH_FPAC2_PAGP_SET(reg, val)
#define TMS570_FLASH_FMAC_BANK(val)
#define TMS570_FLASH_FMAC_BANK_GET(reg)
#define TMS570_FLASH_FMAC_BANK_SET(reg, val)
#define TMS570_FLASH_FMSTAT_ILA   BSP_BIT32(14)
#define TMS570_FLASH_FMSTAT_PGV   BSP_BIT32(12)
#define TMS570_FLASH_FMSTAT_EV   BSP_BIT32(10)
#define TMS570_FLASH_FMSTAT_BUSY   BSP_BIT32(8)
#define TMS570_FLASH_FMSTAT_ERS   BSP_BIT32(7)
#define TMS570_FLASH_FMSTAT_PGM   BSP_BIT32(6)
#define TMS570_FLASH_FMSTAT_INVDAT   BSP_BIT32(5)
#define TMS570_FLASH_FMSTAT_CSTAT   BSP_BIT32(4)
#define TMS570_FLASH_FMSTAT_VOLTSTAT   BSP_BIT32(3)
#define TMS570_FLASH_FMSTAT_ESUSP   BSP_BIT32(2)
#define TMS570_FLASH_FMSTAT_PSUSP   BSP_BIT32(1)
#define TMS570_FLASH_FMSTAT_SLOCK   BSP_BIT32(0)
#define TMS570_FLASH_FEMUECC_EMU_ECC(val)
#define TMS570_FLASH_FEMUECC_EMU_ECC_GET(reg)
#define TMS570_FLASH_FEMUECC_EMU_ECC_SET(reg, val)
#define TMS570_FLASH_FEMUADDR_EMU_ADDR(val)
#define TMS570_FLASH_FEMUADDR_EMU_ADDR_GET(reg)
#define TMS570_FLASH_FEMUADDR_EMU_ADDR_SET(reg, val)
#define TMS570_FLASH_FDIAGCTRL_DIAG_TRIG   BSP_BIT32(24)
#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY(val)
#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_GET(reg)
#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_SET(reg, val)
#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL(val)
#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_GET(reg)
#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_SET(reg, val)
#define TMS570_FLASH_FRAWECC_PIPE_BUF   BSP_BIT32(8)
#define TMS570_FLASH_FRAWECC_RAW_ECC(val)
#define TMS570_FLASH_FRAWECC_RAW_ECC_GET(reg)
#define TMS570_FLASH_FRAWECC_RAW_ECC_SET(reg, val)
#define TMS570_FLASH_FPAROVR_BNK_INV_PAR   BSP_BIT32(16)
#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS(val)
#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_GET(reg)
#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_SET(reg, val)
#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY(val)
#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_GET(reg)
#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_SET(reg, val)
#define TMS570_FLASH_FPAROVR_ADD_INV_PAR   BSP_BIT32(8)
#define TMS570_FLASH_FPAROVR_DAT_INV_PAR(val)
#define TMS570_FLASH_FPAROVR_DAT_INV_PAR_GET(reg)
#define TMS570_FLASH_FPAROVR_DAT_INV_PAR_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse(val)
#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_GET(reg)
#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse(val)
#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_GET(reg)
#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS2_BankID3(val)
#define TMS570_FLASH_FEDACSDIS2_BankID3_GET(reg)
#define TMS570_FLASH_FEDACSDIS2_BankID3_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS2_SectorID3(val)
#define TMS570_FLASH_FEDACSDIS2_SectorID3_GET(reg)
#define TMS570_FLASH_FEDACSDIS2_SectorID3_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse(val)
#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_GET(reg)
#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse(val)
#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_GET(reg)
#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS2_BankID2(val)
#define TMS570_FLASH_FEDACSDIS2_BankID2_GET(reg)
#define TMS570_FLASH_FEDACSDIS2_BankID2_SET(reg, val)
#define TMS570_FLASH_FEDACSDIS2_SectorID2(val)
#define TMS570_FLASH_FEDACSDIS2_SectorID2_GET(reg)
#define TMS570_FLASH_FEDACSDIS2_SectorID2_SET(reg, val)
#define TMS570_FLASH_FSMWRENA_WR_ENA(val)
#define TMS570_FLASH_FSMWRENA_WR_ENA_GET(reg)
#define TMS570_FLASH_FSMWRENA_WR_ENA_SET(reg, val)
#define TMS570_FLASH_FSMSECTOR_SECT_ERASED(val)
#define TMS570_FLASH_FSMSECTOR_SECT_ERASED_GET(reg)
#define TMS570_FLASH_FSMSECTOR_SECT_ERASED_SET(reg, val)
#define TMS570_FLASH_EEPROMCONFIG_EWAIT(val)
#define TMS570_FLASH_EEPROMCONFIG_EWAIT_GET(reg)
#define TMS570_FLASH_EEPROMCONFIG_EWAIT_SET(reg, val)
#define TMS570_FLASH_EEPROMCONFIG_AUTOSUSP_EN   BSP_BIT32(8)
#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE(val)
#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_GET(reg)
#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_SET(reg, val)
#define TMS570_FLASH_EECTRL1_EDACMODE(val)
#define TMS570_FLASH_EECTRL1_EDACMODE_GET(reg)
#define TMS570_FLASH_EECTRL1_EDACMODE_SET(reg, val)
#define TMS570_FLASH_EECTRL1_EE_EOFEN   BSP_BIT32(10)
#define TMS570_FLASH_EECTRL1_EE_EZFEN   BSP_BIT32(9)
#define TMS570_FLASH_EECTRL1_EE_EPEN   BSP_BIT32(8)
#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD(val)
#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_GET(reg)
#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_SET(reg, val)
#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT(val)
#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_GET(reg)
#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_SET(reg, val)
#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD(val)
#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_GET(reg)
#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_SET(reg, val)
#define TMS570_FLASH_EECORERRADD_B_OFF(val)
#define TMS570_FLASH_EECORERRADD_B_OFF_GET(reg)
#define TMS570_FLASH_EECORERRADD_B_OFF_SET(reg, val)
#define TMS570_FLASH_EECORERRPOS_TYPE   BSP_BIT32(8)
#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS(val)
#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_GET(reg)
#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_SET(reg, val)
#define TMS570_FLASH_EESTATUS_EE_D_UNC_ERR   BSP_BIT32(12)
#define TMS570_FLASH_EESTATUS_EE_UNC_ERR   BSP_BIT32(8)
#define TMS570_FLASH_EESTATUS_EE_CMG   BSP_BIT32(6)
#define TMS570_FLASH_EESTATUS_EE_CME   BSP_BIT32(4)
#define TMS570_FLASH_EESTATUS_EE_D_COR_ERR   BSP_BIT32(3)
#define TMS570_FLASH_EESTATUS_EE_ERR_ONE_FLG   BSP_BIT32(2)
#define TMS570_FLASH_EESTATUS_EE_ERR_ZERO_FLG   BSP_BIT32(1)
#define TMS570_FLASH_EESTATUS_EE_ERR_PRF_FLG   BSP_BIT32(0)
#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD(val)
#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_GET(reg)
#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_SET(reg, val)
#define TMS570_FLASH_EEUNCERRADD_B_OFF(val)
#define TMS570_FLASH_EEUNCERRADD_B_OFF_GET(reg)
#define TMS570_FLASH_EEUNCERRADD_B_OFF_SET(reg, val)
#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH(val)
#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_GET(reg)
#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_SET(reg, val)
#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH(val)
#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_GET(reg)
#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_SET(reg, val)
◆ TMS570_FLASH_EECORERRADD_B_OFF
#define TMS570_FLASH_EECORERRADD_B_OFF ( val)
Value:
BSP_FLD32(val,0, 2)
◆ TMS570_FLASH_EECORERRADD_B_OFF_GET
#define TMS570_FLASH_EECORERRADD_B_OFF_GET ( reg)
Value:
BSP_FLD32GET(reg,0, 2)
◆ TMS570_FLASH_EECORERRADD_B_OFF_SET
#define TMS570_FLASH_EECORERRADD_B_OFF_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,0, 2)
◆ TMS570_FLASH_EECORERRADD_COR_ERR_ADD
#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD ( val)
Value:
BSP_FLD32(val,3, 31)
◆ TMS570_FLASH_EECORERRADD_COR_ERR_ADD_GET
#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_GET ( reg)
Value:
BSP_FLD32GET(reg,3, 31)
◆ TMS570_FLASH_EECORERRADD_COR_ERR_ADD_SET
#define TMS570_FLASH_EECORERRADD_COR_ERR_ADD_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,3, 31)
◆ TMS570_FLASH_EECORERRCNT_EE_ERRCNT
#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT ( val)
Value:
BSP_FLD32(val,0, 15)
◆ TMS570_FLASH_EECORERRCNT_EE_ERRCNT_GET
#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_GET ( reg)
Value:
BSP_FLD32GET(reg,0, 15)
◆ TMS570_FLASH_EECORERRCNT_EE_ERRCNT_SET
#define TMS570_FLASH_EECORERRCNT_EE_ERRCNT_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,0, 15)
◆ TMS570_FLASH_EECORERRPOS_EE_ERR_POS
#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_FLASH_EECORERRPOS_EE_ERR_POS_GET
#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_GET ( reg)
Value:
BSP_FLD32GET(reg,0, 7)
◆ TMS570_FLASH_EECORERRPOS_EE_ERR_POS_SET
#define TMS570_FLASH_EECORERRPOS_EE_ERR_POS_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,0, 7)
◆ TMS570_FLASH_EECTRL1_EDACMODE
#define TMS570_FLASH_EECTRL1_EDACMODE ( val)
Value:
BSP_FLD32(val,16, 19)
◆ TMS570_FLASH_EECTRL1_EDACMODE_GET
#define TMS570_FLASH_EECTRL1_EDACMODE_GET ( reg)
Value:
BSP_FLD32GET(reg,16, 19)
◆ TMS570_FLASH_EECTRL1_EDACMODE_SET
#define TMS570_FLASH_EECTRL1_EDACMODE_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,16, 19)
◆ TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD
#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD ( val)
Value:
◆ TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_GET
#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_GET ( reg)
Value:
◆ TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_SET
#define TMS570_FLASH_EECTRL2_EE_SEC_THRESHOLD_SET ( reg,
val )
Value:
◆ TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE
#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_GET
#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_GET ( reg)
Value:
◆ TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_SET
#define TMS570_FLASH_EEPROMCONFIG_AUTOSTART_GRACE_SET ( reg,
val )
Value:
◆ TMS570_FLASH_EEPROMCONFIG_EWAIT
#define TMS570_FLASH_EEPROMCONFIG_EWAIT ( val)
Value:
◆ TMS570_FLASH_EEPROMCONFIG_EWAIT_GET
#define TMS570_FLASH_EEPROMCONFIG_EWAIT_GET ( reg)
Value:
◆ TMS570_FLASH_EEPROMCONFIG_EWAIT_SET
#define TMS570_FLASH_EEPROMCONFIG_EWAIT_SET ( reg,
val )
Value:
◆ TMS570_FLASH_EEUNCERRADD_B_OFF
#define TMS570_FLASH_EEUNCERRADD_B_OFF ( val)
Value:
BSP_FLD32(val,0, 2)
◆ TMS570_FLASH_EEUNCERRADD_B_OFF_GET
#define TMS570_FLASH_EEUNCERRADD_B_OFF_GET ( reg)
Value:
◆ TMS570_FLASH_EEUNCERRADD_B_OFF_SET
#define TMS570_FLASH_EEUNCERRADD_B_OFF_SET ( reg,
val )
Value:
◆ TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD
#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD ( val)
Value:
◆ TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_GET
#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_GET ( reg)
Value:
◆ TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_SET
#define TMS570_FLASH_EEUNCERRADD_UNC_ERR_ADD_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FBAC_15_8
#define TMS570_FLASH_FBAC_15_8 ( val)
Value:
BSP_FLD32(val,8, 15)
◆ TMS570_FLASH_FBAC_15_8_GET
#define TMS570_FLASH_FBAC_15_8_GET ( reg)
Value:
BSP_FLD32GET(reg,8, 15)
◆ TMS570_FLASH_FBAC_15_8_SET
#define TMS570_FLASH_FBAC_15_8_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,8, 15)
◆ TMS570_FLASH_FBAC_OTPPROTDIS
#define TMS570_FLASH_FBAC_OTPPROTDIS ( val)
Value:
BSP_FLD32(val,16, 23)
◆ TMS570_FLASH_FBAC_OTPPROTDIS_GET
#define TMS570_FLASH_FBAC_OTPPROTDIS_GET ( reg)
Value:
BSP_FLD32GET(reg,16, 23)
◆ TMS570_FLASH_FBAC_OTPPROTDIS_SET
#define TMS570_FLASH_FBAC_OTPPROTDIS_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,16, 23)
◆ TMS570_FLASH_FBAC_VREADST
#define TMS570_FLASH_FBAC_VREADST ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_FLASH_FBAC_VREADST_GET
#define TMS570_FLASH_FBAC_VREADST_GET ( reg)
Value:
◆ TMS570_FLASH_FBAC_VREADST_SET
#define TMS570_FLASH_FBAC_VREADST_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FBBUSY_BUSY
#define TMS570_FLASH_FBBUSY_BUSY ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_FLASH_FBBUSY_BUSY_GET
#define TMS570_FLASH_FBBUSY_BUSY_GET ( reg)
Value:
◆ TMS570_FLASH_FBBUSY_BUSY_SET
#define TMS570_FLASH_FBBUSY_BUSY_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FBFALLBACK_BANKPWR0
#define TMS570_FLASH_FBFALLBACK_BANKPWR0 ( val)
Value:
BSP_FLD32(val,0, 1)
◆ TMS570_FLASH_FBFALLBACK_BANKPWR0_GET
#define TMS570_FLASH_FBFALLBACK_BANKPWR0_GET ( reg)
Value:
BSP_FLD32GET(reg,0, 1)
◆ TMS570_FLASH_FBFALLBACK_BANKPWR0_SET
#define TMS570_FLASH_FBFALLBACK_BANKPWR0_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,0, 1)
◆ TMS570_FLASH_FBFALLBACK_BANKPWR1
#define TMS570_FLASH_FBFALLBACK_BANKPWR1 ( val)
Value:
BSP_FLD32(val,2, 3)
◆ TMS570_FLASH_FBFALLBACK_BANKPWR1_GET
#define TMS570_FLASH_FBFALLBACK_BANKPWR1_GET ( reg)
Value:
BSP_FLD32GET(reg,2, 3)
◆ TMS570_FLASH_FBFALLBACK_BANKPWR1_SET
#define TMS570_FLASH_FBFALLBACK_BANKPWR1_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,2, 3)
◆ TMS570_FLASH_FBFALLBACK_BANKPWR7
#define TMS570_FLASH_FBFALLBACK_BANKPWR7 ( val)
Value:
BSP_FLD32(val,14, 15)
◆ TMS570_FLASH_FBFALLBACK_BANKPWR7_GET
#define TMS570_FLASH_FBFALLBACK_BANKPWR7_GET ( reg)
Value:
BSP_FLD32GET(reg,14, 15)
◆ TMS570_FLASH_FBFALLBACK_BANKPWR7_SET
#define TMS570_FLASH_FBFALLBACK_BANKPWR7_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,14, 15)
◆ TMS570_FLASH_FBPRDY_BANKBUSY
#define TMS570_FLASH_FBPRDY_BANKBUSY ( val)
Value:
◆ TMS570_FLASH_FBPRDY_BANKBUSY_GET
#define TMS570_FLASH_FBPRDY_BANKBUSY_GET ( reg)
Value:
◆ TMS570_FLASH_FBPRDY_BANKBUSY_SET
#define TMS570_FLASH_FBPRDY_BANKBUSY_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FBPRDY_BANKRDY
#define TMS570_FLASH_FBPRDY_BANKRDY ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_FLASH_FBPRDY_BANKRDY_GET
#define TMS570_FLASH_FBPRDY_BANKRDY_GET ( reg)
Value:
◆ TMS570_FLASH_FBPRDY_BANKRDY_SET
#define TMS570_FLASH_FBPRDY_BANKRDY_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FBSE_BSE
#define TMS570_FLASH_FBSE_BSE ( val)
Value:
◆ TMS570_FLASH_FBSE_BSE_GET
#define TMS570_FLASH_FBSE_BSE_GET ( reg)
Value:
◆ TMS570_FLASH_FBSE_BSE_SET
#define TMS570_FLASH_FBSE_BSE_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH
#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH ( val)
Value:
BSP_FLD32(val,20, 31)
◆ TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_GET
#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_GET ( reg)
Value:
BSP_FLD32GET(reg,20, 31)
◆ TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_SET
#define TMS570_FLASH_FCFGBANK_EE_BANK_WIDTH_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,20, 31)
◆ TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH
#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH ( val)
Value:
BSP_FLD32(val,4, 15)
◆ TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_GET
#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_GET ( reg)
Value:
BSP_FLD32GET(reg,4, 15)
◆ TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_SET
#define TMS570_FLASH_FCFGBANK_MAIN_BANK_WIDTH_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,4, 15)
◆ TMS570_FLASH_FCORERRADD_B_OFF
#define TMS570_FLASH_FCORERRADD_B_OFF ( val)
Value:
BSP_FLD32(val,0, 2)
◆ TMS570_FLASH_FCORERRADD_B_OFF_GET
#define TMS570_FLASH_FCORERRADD_B_OFF_GET ( reg)
Value:
◆ TMS570_FLASH_FCORERRADD_B_OFF_SET
#define TMS570_FLASH_FCORERRADD_B_OFF_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FCORERRADD_COR_ERR_ADD
#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD ( val)
Value:
◆ TMS570_FLASH_FCORERRADD_COR_ERR_ADD_GET
#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_GET ( reg)
Value:
◆ TMS570_FLASH_FCORERRADD_COR_ERR_ADD_SET
#define TMS570_FLASH_FCORERRADD_COR_ERR_ADD_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FCORERRCNT_FERRCNT
#define TMS570_FLASH_FCORERRCNT_FERRCNT ( val)
Value:
◆ TMS570_FLASH_FCORERRCNT_FERRCNT_GET
#define TMS570_FLASH_FCORERRCNT_FERRCNT_GET ( reg)
Value:
◆ TMS570_FLASH_FCORERRCNT_FERRCNT_SET
#define TMS570_FLASH_FCORERRCNT_FERRCNT_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FCORERRPOS_ERR_POS
#define TMS570_FLASH_FCORERRPOS_ERR_POS ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_FLASH_FCORERRPOS_ERR_POS_GET
#define TMS570_FLASH_FCORERRPOS_ERR_POS_GET ( reg)
Value:
◆ TMS570_FLASH_FCORERRPOS_ERR_POS_SET
#define TMS570_FLASH_FCORERRPOS_ERR_POS_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL
#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL ( val)
Value:
BSP_FLD32(val,12, 14)
◆ TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_GET
#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_GET ( reg)
Value:
BSP_FLD32GET(reg,12, 14)
◆ TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_SET
#define TMS570_FLASH_FDIAGCTRL_DIAG_ECC_SEL_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,12, 14)
◆ TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY
#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY ( val)
Value:
◆ TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_GET
#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_GET ( reg)
Value:
◆ TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_SET
#define TMS570_FLASH_FDIAGCTRL_DIAG_EN_KEY_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG
#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG ( val)
Value:
BSP_FLD32(val,4, 31)
◆ TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_GET
#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_GET ( reg)
Value:
BSP_FLD32GET(reg,4, 31)
◆ TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_SET
#define TMS570_FLASH_FDUPADDTAG_DUP_ADD_TAG_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,4, 31)
◆ TMS570_FLASH_FEDACSDIS2_BankID2
#define TMS570_FLASH_FEDACSDIS2_BankID2 ( val)
Value:
BSP_FLD32(val,5, 7)
◆ TMS570_FLASH_FEDACSDIS2_BankID2_GET
#define TMS570_FLASH_FEDACSDIS2_BankID2_GET ( reg)
Value:
BSP_FLD32GET(reg,5, 7)
◆ TMS570_FLASH_FEDACSDIS2_BankID2_Inverse
#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse ( val)
Value:
BSP_FLD32(val,13, 15)
◆ TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_GET
#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_GET ( reg)
Value:
BSP_FLD32GET(reg,13, 15)
◆ TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_SET
#define TMS570_FLASH_FEDACSDIS2_BankID2_Inverse_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,13, 15)
◆ TMS570_FLASH_FEDACSDIS2_BankID2_SET
#define TMS570_FLASH_FEDACSDIS2_BankID2_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,5, 7)
◆ TMS570_FLASH_FEDACSDIS2_BankID3
#define TMS570_FLASH_FEDACSDIS2_BankID3 ( val)
Value:
BSP_FLD32(val,21, 23)
◆ TMS570_FLASH_FEDACSDIS2_BankID3_GET
#define TMS570_FLASH_FEDACSDIS2_BankID3_GET ( reg)
Value:
BSP_FLD32GET(reg,21, 23)
◆ TMS570_FLASH_FEDACSDIS2_BankID3_Inverse
#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse ( val)
Value:
BSP_FLD32(val,29, 31)
◆ TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_GET
#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_GET ( reg)
Value:
BSP_FLD32GET(reg,29, 31)
◆ TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_SET
#define TMS570_FLASH_FEDACSDIS2_BankID3_Inverse_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,29, 31)
◆ TMS570_FLASH_FEDACSDIS2_BankID3_SET
#define TMS570_FLASH_FEDACSDIS2_BankID3_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,21, 23)
◆ TMS570_FLASH_FEDACSDIS2_SectorID2
#define TMS570_FLASH_FEDACSDIS2_SectorID2 ( val)
Value:
BSP_FLD32(val,0, 3)
◆ TMS570_FLASH_FEDACSDIS2_SectorID2_GET
#define TMS570_FLASH_FEDACSDIS2_SectorID2_GET ( reg)
Value:
BSP_FLD32GET(reg,0, 3)
◆ TMS570_FLASH_FEDACSDIS2_SectorID2_inverse
#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse ( val)
Value:
BSP_FLD32(val,8, 11)
◆ TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_GET
#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_GET ( reg)
Value:
BSP_FLD32GET(reg,8, 11)
◆ TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_SET
#define TMS570_FLASH_FEDACSDIS2_SectorID2_inverse_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,8, 11)
◆ TMS570_FLASH_FEDACSDIS2_SectorID2_SET
#define TMS570_FLASH_FEDACSDIS2_SectorID2_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,0, 3)
◆ TMS570_FLASH_FEDACSDIS2_SectorID3
#define TMS570_FLASH_FEDACSDIS2_SectorID3 ( val)
Value:
◆ TMS570_FLASH_FEDACSDIS2_SectorID3_GET
#define TMS570_FLASH_FEDACSDIS2_SectorID3_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACSDIS2_SectorID3_inverse
#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse ( val)
Value:
BSP_FLD32(val,24, 27)
◆ TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_GET
#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_GET ( reg)
Value:
BSP_FLD32GET(reg,24, 27)
◆ TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_SET
#define TMS570_FLASH_FEDACSDIS2_SectorID3_inverse_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,24, 27)
◆ TMS570_FLASH_FEDACSDIS2_SectorID3_SET
#define TMS570_FLASH_FEDACSDIS2_SectorID3_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID0
#define TMS570_FLASH_FEDACSDIS_BankID0 ( val)
Value:
BSP_FLD32(val,5, 7)
◆ TMS570_FLASH_FEDACSDIS_BankID0_GET
#define TMS570_FLASH_FEDACSDIS_BankID0_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID0_Inverse
#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse ( val)
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID0_Inverse_GET
#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID0_Inverse_SET
#define TMS570_FLASH_FEDACSDIS_BankID0_Inverse_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID0_SET
#define TMS570_FLASH_FEDACSDIS_BankID0_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID1
#define TMS570_FLASH_FEDACSDIS_BankID1 ( val)
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID1_GET
#define TMS570_FLASH_FEDACSDIS_BankID1_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID1_Inverse
#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse ( val)
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID1_Inverse_GET
#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID1_Inverse_SET
#define TMS570_FLASH_FEDACSDIS_BankID1_Inverse_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACSDIS_BankID1_SET
#define TMS570_FLASH_FEDACSDIS_BankID1_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID0
#define TMS570_FLASH_FEDACSDIS_SectorID0 ( val)
Value:
BSP_FLD32(val,0, 3)
◆ TMS570_FLASH_FEDACSDIS_SectorID0_GET
#define TMS570_FLASH_FEDACSDIS_SectorID0_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID0_inverse
#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse ( val)
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID0_inverse_GET
#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID0_inverse_SET
#define TMS570_FLASH_FEDACSDIS_SectorID0_inverse_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID0_SET
#define TMS570_FLASH_FEDACSDIS_SectorID0_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID1
#define TMS570_FLASH_FEDACSDIS_SectorID1 ( val)
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID1_GET
#define TMS570_FLASH_FEDACSDIS_SectorID1_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID1_inverse
#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse ( val)
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID1_inverse_GET
#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID1_inverse_SET
#define TMS570_FLASH_FEDACSDIS_SectorID1_inverse_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACSDIS_SectorID1_SET
#define TMS570_FLASH_FEDACSDIS_SectorID1_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACSTATUS_Reserved
#define TMS570_FLASH_FEDACSTATUS_Reserved ( val)
Value:
BSP_FLD32(val,26, 31)
◆ TMS570_FLASH_FEDACSTATUS_Reserved_GET
#define TMS570_FLASH_FEDACSTATUS_Reserved_GET ( reg)
Value:
BSP_FLD32GET(reg,26, 31)
◆ TMS570_FLASH_FEDACSTATUS_Reserved_SET
#define TMS570_FLASH_FEDACSTATUS_Reserved_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,26, 31)
◆ TMS570_FLASH_FEDACTRL1_EDACEN
#define TMS570_FLASH_FEDACTRL1_EDACEN ( val)
Value:
BSP_FLD32(val,0, 3)
◆ TMS570_FLASH_FEDACTRL1_EDACEN_GET
#define TMS570_FLASH_FEDACTRL1_EDACEN_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACTRL1_EDACEN_SET
#define TMS570_FLASH_FEDACTRL1_EDACEN_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACTRL1_EDACMODE
#define TMS570_FLASH_FEDACTRL1_EDACMODE ( val)
Value:
◆ TMS570_FLASH_FEDACTRL1_EDACMODE_GET
#define TMS570_FLASH_FEDACTRL1_EDACMODE_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACTRL1_EDACMODE_SET
#define TMS570_FLASH_FEDACTRL1_EDACMODE_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD
#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD ( val)
Value:
◆ TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_GET
#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_GET ( reg)
Value:
◆ TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_SET
#define TMS570_FLASH_FEDACTRL2_SEC_THRESHOLD_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FEMUADDR_EMU_ADDR
#define TMS570_FLASH_FEMUADDR_EMU_ADDR ( val)
Value:
BSP_FLD32(val,3, 21)
◆ TMS570_FLASH_FEMUADDR_EMU_ADDR_GET
#define TMS570_FLASH_FEMUADDR_EMU_ADDR_GET ( reg)
Value:
BSP_FLD32GET(reg,3, 21)
◆ TMS570_FLASH_FEMUADDR_EMU_ADDR_SET
#define TMS570_FLASH_FEMUADDR_EMU_ADDR_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,3, 21)
◆ TMS570_FLASH_FEMUECC_EMU_ECC
#define TMS570_FLASH_FEMUECC_EMU_ECC ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_FLASH_FEMUECC_EMU_ECC_GET
#define TMS570_FLASH_FEMUECC_EMU_ECC_GET ( reg)
Value:
◆ TMS570_FLASH_FEMUECC_EMU_ECC_SET
#define TMS570_FLASH_FEMUECC_EMU_ECC_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FMAC_BANK
#define TMS570_FLASH_FMAC_BANK ( val)
Value:
BSP_FLD32(val,0, 2)
◆ TMS570_FLASH_FMAC_BANK_GET
#define TMS570_FLASH_FMAC_BANK_GET ( reg)
Value:
◆ TMS570_FLASH_FMAC_BANK_SET
#define TMS570_FLASH_FMAC_BANK_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FPAC1_PSLEEP
#define TMS570_FLASH_FPAC1_PSLEEP ( val)
Value:
BSP_FLD32(val,16, 26)
◆ TMS570_FLASH_FPAC1_PSLEEP_GET
#define TMS570_FLASH_FPAC1_PSLEEP_GET ( reg)
Value:
BSP_FLD32GET(reg,16, 26)
◆ TMS570_FLASH_FPAC1_PSLEEP_SET
#define TMS570_FLASH_FPAC1_PSLEEP_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,16, 26)
◆ TMS570_FLASH_FPAC2_PAGP
#define TMS570_FLASH_FPAC2_PAGP ( val)
Value:
◆ TMS570_FLASH_FPAC2_PAGP_GET
#define TMS570_FLASH_FPAC2_PAGP_GET ( reg)
Value:
◆ TMS570_FLASH_FPAC2_PAGP_SET
#define TMS570_FLASH_FPAC2_PAGP_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FPAROVR_BUS_PAR_DIS
#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS ( val)
Value:
BSP_FLD32(val,12, 15)
◆ TMS570_FLASH_FPAROVR_BUS_PAR_DIS_GET
#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_GET ( reg)
Value:
BSP_FLD32GET(reg,12, 15)
◆ TMS570_FLASH_FPAROVR_BUS_PAR_DIS_SET
#define TMS570_FLASH_FPAROVR_BUS_PAR_DIS_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,12, 15)
◆ TMS570_FLASH_FPAROVR_DAT_INV_PAR
#define TMS570_FLASH_FPAROVR_DAT_INV_PAR ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_FLASH_FPAROVR_DAT_INV_PAR_GET
#define TMS570_FLASH_FPAROVR_DAT_INV_PAR_GET ( reg)
Value:
◆ TMS570_FLASH_FPAROVR_DAT_INV_PAR_SET
#define TMS570_FLASH_FPAROVR_DAT_INV_PAR_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FPAROVR_PAR_OVR_KEY
#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY ( val)
Value:
BSP_FLD32(val,9, 11)
◆ TMS570_FLASH_FPAROVR_PAR_OVR_KEY_GET
#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_GET ( reg)
Value:
BSP_FLD32GET(reg,9, 11)
◆ TMS570_FLASH_FPAROVR_PAR_OVR_KEY_SET
#define TMS570_FLASH_FPAROVR_PAR_OVR_KEY_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,9, 11)
◆ TMS570_FLASH_FPRIMADDTAG_0
#define TMS570_FLASH_FPRIMADDTAG_0 ( val)
Value:
BSP_FLD32(val,0, 3)
◆ TMS570_FLASH_FPRIMADDTAG_0_GET
#define TMS570_FLASH_FPRIMADDTAG_0_GET ( reg)
Value:
◆ TMS570_FLASH_FPRIMADDTAG_0_SET
#define TMS570_FLASH_FPRIMADDTAG_0_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG
#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG ( val)
Value:
◆ TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_GET
#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_GET ( reg)
Value:
◆ TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_SET
#define TMS570_FLASH_FPRIMADDTAG_PRIM_ADD_TAG_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FRAWECC_RAW_ECC
#define TMS570_FLASH_FRAWECC_RAW_ECC ( val)
Value:
BSP_FLD32(val,0, 7)
◆ TMS570_FLASH_FRAWECC_RAW_ECC_GET
#define TMS570_FLASH_FRAWECC_RAW_ECC_GET ( reg)
Value:
◆ TMS570_FLASH_FRAWECC_RAW_ECC_SET
#define TMS570_FLASH_FRAWECC_RAW_ECC_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FRDCNTL_RWAIT
#define TMS570_FLASH_FRDCNTL_RWAIT ( val)
Value:
◆ TMS570_FLASH_FRDCNTL_RWAIT_GET
#define TMS570_FLASH_FRDCNTL_RWAIT_GET ( reg)
Value:
◆ TMS570_FLASH_FRDCNTL_RWAIT_SET
#define TMS570_FLASH_FRDCNTL_RWAIT_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FSMSECTOR_SECT_ERASED
#define TMS570_FLASH_FSMSECTOR_SECT_ERASED ( val)
Value:
BSP_FLD32(val,16, 31)
◆ TMS570_FLASH_FSMSECTOR_SECT_ERASED_GET
#define TMS570_FLASH_FSMSECTOR_SECT_ERASED_GET ( reg)
Value:
BSP_FLD32GET(reg,16, 31)
◆ TMS570_FLASH_FSMSECTOR_SECT_ERASED_SET
#define TMS570_FLASH_FSMSECTOR_SECT_ERASED_SET ( reg,
val )
Value:
BSP_FLD32SET(reg, val,16, 31)
◆ TMS570_FLASH_FSMWRENA_WR_ENA
#define TMS570_FLASH_FSMWRENA_WR_ENA ( val)
Value:
BSP_FLD32(val,0, 2)
◆ TMS570_FLASH_FSMWRENA_WR_ENA_GET
#define TMS570_FLASH_FSMWRENA_WR_ENA_GET ( reg)
Value:
◆ TMS570_FLASH_FSMWRENA_WR_ENA_SET
#define TMS570_FLASH_FSMWRENA_WR_ENA_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FUNCERRADD_B_OFF
#define TMS570_FLASH_FUNCERRADD_B_OFF ( val)
Value:
BSP_FLD32(val,0, 2)
◆ TMS570_FLASH_FUNCERRADD_B_OFF_GET
#define TMS570_FLASH_FUNCERRADD_B_OFF_GET ( reg)
Value:
◆ TMS570_FLASH_FUNCERRADD_B_OFF_SET
#define TMS570_FLASH_FUNCERRADD_B_OFF_SET ( reg,
val )
Value:
◆ TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD
#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD ( val)
Value:
◆ TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_GET
#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_GET ( reg)
Value:
◆ TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_SET
#define TMS570_FLASH_FUNCERRADD_UNC_ERR_ADD_SET ( reg,
val )
Value:
