RTEMS
6.3
Toggle main menu visibility
bsps
i386
include
bsp
realmode_int.h
1
13
14
15
* Copyright (C) 2014 Jan Doležal (dolezj21@fel.cvut.cz)
16
* CTU in Prague.
17
18
* The license and distribution terms for this file may be
19
* found in the file LICENSE in this distribution or at
20
* http://www.rtems.org/license/LICENSE.
21
22
23
#ifndef _REALMODE_INT_H
24
#define _REALMODE_INT_H
25
26
#include <rtems/score/cpu.h>
27
#include <stdint.h>
28
29
#ifndef ASM
/* ASM */
30
31
#ifdef __cplusplus
32
extern
"C"
33
#endif
/* __cplusplus */
34
35
/* --- BIOS service interrupt number --- */
36
/* number of interrupt servicing video functions */
37
#define INTERRUPT_NO_VIDEO_SERVICES 0x10
38
43
typedef
struct
44
uint32_t reg_eax;
45
uint32_t reg_ebx;
46
uint32_t reg_ecx;
47
uint32_t reg_edx;
48
uint32_t reg_esi;
49
uint32_t reg_edi;
50
uint16_t reg_ds;
51
uint16_t reg_es;
52
uint16_t reg_fs;
53
uint16_t reg_gs;
54
RTEMS_PACKED
i386_realmode_interrupt_registers;
55
70
extern
void
i386_get_default_rm_buffer
(uint16_t *size);
71
86
extern
int
i386_real_interrupt_call
87
uint8_t interrupt_number,
88
i386_realmode_interrupt_registers *ir
89
90
91
#ifdef __cplusplus
92
93
#endif
/* __cplusplus */
94
95
#endif
/* ASM */
96
97
#endif
/* _REALMODE_INT_H */
RTEMS_PACKED
#define RTEMS_PACKED
Instructs the compiler in a type definition to place members of a structure or union so that the memo...
Definition
basedefs.h:704
void * i386_get_default_rm_buffer(uint16_t *size)
Returns buffer and its size usable with real mode interrupt call.
Definition
realmode_int.c:237
int i386_real_interrupt_call(uint8_t interrupt_number, i386_realmode_interrupt_registers *ir)
Call to real mode interrupt with specified int NO and processor registers.
Definition
realmode_int.c:242
