RTEMS
6.3
Toggle main menu visibility
include
rtl
rap.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* COPYRIGHT (c) 2013, 2018 Chris Johns <chrisj@rtems.org>
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25
* POSSIBILITY OF SUCH DAMAGE.
26
36
37
#if !defined (_RAP_H_)
38
#define _RAP_H_
39
40
rtems.h
41
rtems/chain.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
62
66
typedef
bool (*
rtems_rap_iterator
void
* handle);
67
74
bool
rtems_rap_load
const
char
* name,
int
mode,
int
argc,
const
char
* argv[]);
75
83
bool
rtems_rap_unload
const
char
* name);
84
93
void
rtems_rap_find
const
char
* name);
94
102
bool
rtems_rap_iterate
rtems_rap_iterator
iterator);
103
111
const
char
rtems_rap_name
void
* handle);
112
119
void
rtems_rap_dl_handle
void
* handle);
120
130
int
rtems_rap_get_error
char
message
size_t
max_message);
131
132
#ifdef __cplusplus
133
134
#endif
/* __cplusplus */
135
136
#endif
chain.h
This header file provides the Chains API.
rtems_rap_name
const char * rtems_rap_name(void *handle)
Definition
rap.c:420
rtems_rap_iterator
bool(*) rtems_rap_iterator(void *handle)
Definition
rap.h:66
rtems_rap_load
bool rtems_rap_load(const char *name, int mode, int argc, const char *argv[])
Definition
rap.c:244
rtems_rap_unload
bool rtems_rap_unload(const char *name)
Definition
rap.c:330
rtems_rap_find
void * rtems_rap_find(const char *name)
Definition
rap.c:373
rtems_rap_get_error
int rtems_rap_get_error(char *message, size_t max_message)
Definition
rap.c:438
rtems_rap_dl_handle
void * rtems_rap_dl_handle(void *handle)
Definition
rap.c:429
rtems_rap_iterate
bool rtems_rap_iterate(rtems_rap_iterator iterator)
Definition
rap.c:397
rtems.h
message
Definition
media-server.c:46
