RTEMS
6.3
Toggle main menu visibility
bsps
arm
gumstix
include
pxa255.h
1
2
* By Yang Xi <hiyangxi@gmail.com>.
3
4
* The license and distribution terms for this file may be
5
* found in the file LICENSE in this distribution or at
6
* http://www.rtems.org/license/LICENSE.
7
8
9
#ifndef __PXA_255_H__
10
#define __PXA_255_H__
11
12
typedef
unsigned
int
word_t;
13
14
/*Interrupt*/
15
16
#define PRIMARY_IRQS 32
17
#define GPIO_IRQS (85 - 2)
/* The first two IRQs have level
18
one interrupts */
19
#define GPIO_IRQ 10
20
21
#define IRQS (PRIMARY_IRQS + GPIO_IRQS)
22
23
/* Interrupt Controller */
24
#define INTERRUPT_OFFSET 0xd00000
25
#define XSCALE_IRQ_OS_TIMER 26
26
#define XSCALE_IRQ_PMU 12
27
#define XSCALE_IRQ_STUART 20
28
#define XSCALE_IRQ_NETWORK 16
29
30
#define PMU_IRQ 12
31
#define CCNT_IRQ_ENABLE 1UL << 6
32
#define PMN1_IRQ_ENABLE 1UL << 5
33
#define PMN0_IRQ_ENABLE 1UL << 4
34
35
#define IODEVICE_VADDR 0x40000000
36
#define XSCALE_INT (IODEVICE_VADDR + INTERRUPT_OFFSET)
37
38
#define XSCALE_INT_ICMR (*(volatile word_t *)(XSCALE_INT + 0x04))
/* Mask register */
39
#define XSCALE_INT_ICLR (*(volatile word_t *)(XSCALE_INT + 0x08))
/* FIQ / IRQ selection */
40
#define XSCALE_INT_ICCR (*(volatile word_t *)(XSCALE_INT + 0x14))
/* Control register */
41
#define XSCALE_INT_ICIP (*(volatile word_t *)(XSCALE_INT + 0x00))
/* IRQ pending */
42
#define XSCALE_INT_ICFP (*(volatile word_t *)(XSCALE_INT + 0x0c))
/* FIQ pending */
43
#define XSCALE_INT_ICPR (*(volatile word_t *)(XSCALE_INT + 0x10))
/* Pending (unmasked) */
44
45
/* GPIO */
46
#define GPIO_OFFSET 0xe00000
47
#define PXA_GPIO (IODEVICE_VADDR + GPIO_OFFSET)
48
49
#define PXA_GEDR0 (*(volatile word_t *)(PXA_GPIO + 0x48))
/* GPIO edge detect 0 */
50
#define PXA_GEDR1 (*(volatile word_t *)(PXA_GPIO + 0x4C))
/* GPIO edge detect 1 */
51
#define PXA_GEDR2 (*(volatile word_t *)(PXA_GPIO + 0x50))
/* GPIO edge detect 2 */
52
53
54
/* PXA2XX Timer */
55
56
#define TIMER_OFFSET 0x0a00000
57
#define CLOCKS_OFFSET 0x1300000
58
/*I change the TIMER_RATE to 36864,because when I use 3686400, the period will be calculate
59
to 30000*/
60
#define TIMER_RATE 36864
61
62
#define XSCALE_TIMERS (IODEVICE_VADDR + TIMER_OFFSET)
63
64
/* Match registers */
65
#define XSCALE_OS_TIMER_MR0 (*(volatile word_t *)(XSCALE_TIMERS + 0x00))
66
#define XSCALE_OS_TIMER_MR1 (*(volatile word_t *)(XSCALE_TIMERS + 0x04))
67
#define XSCALE_OS_TIMER_MR2 (*(volatile word_t *)(XSCALE_TIMERS + 0x08))
68
#define XSCALE_OS_TIMER_MR3 (*(volatile word_t *)(XSCALE_TIMERS + 0x0c))
69
70
/* Interrupt enable register */
71
#define XSCALE_OS_TIMER_IER (*(volatile word_t *)(XSCALE_TIMERS + 0x1c))
72
/* Watchdog match enable register */
73
#define XSCALE_OS_TIMER_WMER (*(volatile word_t *)(XSCALE_TIMERS + 0x18))
74
/* Timer count register */
75
#define XSCALE_OS_TIMER_TCR (*(volatile word_t *)(XSCALE_TIMERS + 0x10))
76
/* Timer status register */
77
#define XSCALE_OS_TIMER_TSR (*(volatile word_t *)(XSCALE_TIMERS + 0x14))
78
79
#define XSCALE_CLOCKS (IODEVICE_VADDR + CLOCKS_VOFFSET)
80
81
#define XSCALE_CLOCKS_CCCR (*(volatile word_t *)(XSCALE_CLOCKS + 0x00))
82
83
/*Use ffuart port as the console*/
84
#define FFUART_BASE 0x40100000
85
86
/*Write to SKYEYE_MAGIC_ADDRESS to make SKYEYE exit*/
87
88
#define SKYEYE_MAGIC_ADDRESS (*(volatile word_t *)(0xb0000000))
89
#define SKYEYE_MAGIC_NUMBER (0xf0f0f0f0)
90
91
/*PMC*/
92
#define PMC_PMNC 0
93
#define PMC_CCNT 1
94
#define PMC_INTEN 2
95
#define PMC_FLAG 3
96
#define PMC_EVTSEL 4
97
#define PMC_PMN0 5
98
#define PMC_PMN1 6
99
#define PMC_PMN2 7
100
#define PMC_PMN3 8
101
102
#define PMC_PMNC_E (0x01)
103
#define PMC_PMNC_PCR (0x01 << 1)
104
#define PMC_PMNC_CCR (0x01 << 2)
105
#define PMC_PMNC_CCD (0x01 << 3)
106
#define PMC_PMNC_PCD (0x01 << 4)
107
108
/*LCD*/
109
#define LCCR0 (*(volatile word_t *)(0x44000000))
110
#define LCCR1 (*(volatile word_t *)(0x44000004))
111
#define LCCR2 (*(volatile word_t *)(0x44000008))
112
#define LCCR3 (*(volatile word_t *)(0x4400000C))
113
114
#define FDADR0 (*(volatile word_t *)(0x44000200))
115
#define FSADR0 (*(volatile word_t *)(0x44000204))
116
#define FIDR0 (*(volatile word_t *)(0x44000208))
117
#define LDCMD0 (*(volatile word_t *)(0x4400020C))
118
119
#define FDADR1 (*(volatile word_t *)(0x44000210))
120
#define FSADR1 (*(volatile word_t *)(0x44000214))
121
#define FIDR1 (*(volatile word_t *)(0x44000218))
122
#define LDCMD1 (*(volatile word_t *)(0x4400021C))
123
124
#define LCCR0_ENB 0x00000001
125
#define LCCR1_PPL 0x000003FF
126
#define LCCR2_LPP 0x000003FF
127
#define LCCR3_BPP 0x07000000
128
#endif
