RTEMS
6.3
Toggle main menu visibility
include
posix
pthread.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* COPYRIGHT (c) 1989-2011.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_POSIX_PTHREAD_H
39
#define _RTEMS_POSIX_PTHREAD_H
40
41
rtems/posix/threadsup.h
42
rtems/score/thread.h
43
44
#ifdef __cplusplus
45
extern
"C"
46
#endif
47
57
62
typedef
struct
64
void
*(*thread_entry)(
void
66
int
stack_size
67
posix_initialization_threads_table
68
69
extern
const
size_t
_POSIX_Threads_Minimum_stack_size;
70
77
extern
const
78
_POSIX_Threads_User_thread_table
79
83
extern
void
_POSIX_Threads_Initialize_user_thread
void
84
89
extern
Thread_Information
_POSIX_Threads_Information
90
92
93
#ifdef __cplusplus
94
95
#endif
96
97
#endif
98
/* end of include file */
const posix_initialization_threads_table _POSIX_Threads_User_thread_table
Initialization table for the first user POSIX thread.
void _POSIX_Threads_Initialize_user_thread(void)
System initialization handler to create the first user POSIX thread.
Definition
pthreadinitthreads.c:49
Thread_Information _POSIX_Threads_Information
thread.h
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
Thread_Information
The thread object information.
Definition
thread.h:1133
Definition
pthread.h:62
posix_initialization_threads_table::stack_size
int stack_size
Definition
pthread.h:66
threadsup.h
POSIX Thread API Support.
