RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
include
bsp
ppcbug-nvram-net-env.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* Copyright (c) 2026 Chris Johns <chrisj@rtems.org>. All rights reserved.
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
16
* ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
19
* FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
20
* DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
21
* OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
22
* HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
23
* LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
24
* OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
25
* SUCH DAMAGE.
26
27
28
29
* PPCBug RTEMS Network Environment Variables
30
31
* Set the environment variables based on the NVRAM data. The pattern
32
* for scanning follows the parsing that was in EPICS Base's
33
* `setBootConfigFromNVRAM.c`. The code was moved to RTEMS as part of
34
* a clean up of EPICS code.
35
36
37
#ifndef _POWERPC_PPCBUF_NVRAM_NET_ENV_h
38
#define _POWERPC_PPCBUF_NVRAM_NET_ENV_h
39
40
#include <stdbool.h>
41
#include <stddef.h>
42
#include <stdint.h>
43
44
#ifdef __cplusplus
45
extern
"C"
46
#endif
/* __cplusplus */
47
48
49
* Set the RTEMS network environment variables from NVRAM data for the
50
* specified network interface
51
52
* @param nvram_base Base address if the byte addressable NVRAM
53
* @param nvram_indirect Indirect access to the NVRAM
54
* @param unit Network interface unit number, ie `1` for `enet1`
55
* @param label Network interface unit label, ie `1` for `em0`
56
57
void
ppcbug_nvram_set_net_envs(uintptr_t nvram_base,
bool
indirect,
58
const
size_t
unit,
const
char
* label);
59
60
#ifdef __cplusplus
61
62
#endif
/* __cplusplus */
63
64
#endif
