RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
psim
include
tm27.h
1
2
* @file
3
* @ingroup powerpc_psim
4
* @brief Implementations for interrupt mechanisms for Time Test 27
5
6
7
8
* The license and distribution terms for this file may be
9
* found in the file LICENSE in this distribution or at
10
* http://www.rtems.org/license/LICENSE.
11
12
13
#ifndef _RTEMS_TMTEST27
14
#error "This is an RTEMS internal file you must not include directly."
15
#endif
16
17
#ifndef __tm27_h
18
#define __tm27_h
19
20
#include <bsp/irq.h>
21
22
23
* Stuff for Time Test 27
24
25
26
#define MUST_WAIT_FOR_INTERRUPT 1
27
28
static
void
nullFunc(
void
29
static
rtems_irq_connect_data clockIrqData = {BSP_DECREMENTER,
30
0,
31
(rtems_irq_enable)nullFunc,
32
(rtems_irq_disable)nullFunc,
33
(rtems_irq_is_enabled) nullFunc};
34
35
static
inline
void
Install_tm27_vector(
rtems_interrupt_handler
handler )
36
37
clockIrqData.hdl = handler;
38
if
(!BSP_install_rtems_irq_handler (&clockIrqData)) {
39
printk(
"Error installing clock interrupt handler!\n"
40
rtems_fatal_error_occurred
(1);
41
42
43
44
#define Cause_tm27_intr() \
45
do { \
46
uint32_t _clicks = 1; \
47
__asm__ volatile( "mtdec %0" : "=r" ((_clicks)) : "r" ((_clicks)) ); \
48
} while (0)
49
50
51
#define Clear_tm27_intr() \
52
do { \
53
uint32_t _clicks = 0xffffffff; \
54
55
} while (0)
56
57
#define Lower_tm27_intr() \
58
do { \
59
uint32_t _msr = 0; \
60
_ISR_Set_level( 0 ); \
61
__asm__ volatile( "mfmsr %0 ;" : "=r" (_msr) : "r" (_msr) ); \
62
_msr |= 0x8002; \
63
__asm__ volatile( "mtmsr %0 ;" : "=r" (_msr) : "r" (_msr) ); \
64
} while (0)
65
66
#endif
RTEMS_NO_RETURN void rtems_fatal_error_occurred(uint32_t fatal_code)
Invokes the fatal error handler.
Definition
fatal.c:47
void(*) rtems_interrupt_handler(void *)
Interrupt handler routines shall have this type.
Definition
intr.h:1030
