RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
include
bsp
uart.h
1
2
3
* This software is Copyright (C) 1998 by T.sqware - all rights limited
4
* It is provided in to the public domain "as is", can be freely modified
5
* as far as this copyight notice is kept unchanged, but does not imply
6
* an endorsement by T.sqware of the product in which it is included.
7
8
9
#ifndef _BSPUART_H
10
#define _BSPUART_H
11
12
#include <bsp/irq.h>
13
14
#include <sys/ioctl.h>
15
rtems/libio.h
16
17
void
BSP_uart_init(
int
uart,
int
baud,
int
hwFlow);
18
void
BSP_uart_set_baud(
int
uart,
int
baud);
19
void
BSP_uart_intr_ctrl(
int
uart,
int
cmd);
20
void
BSP_uart_throttle(
int
uart);
21
void
BSP_uart_unthrottle(
int
uart);
22
int
BSP_uart_polled_status(
int
uart);
23
void
BSP_uart_polled_write(
int
uart,
int
val);
24
int
BSP_uart_polled_read(
int
uart);
25
void
BSP_uart_termios_set(
int
uart,
void
*ttyp);
26
ssize_t BSP_uart_termios_write_com(
int
minor,
const
char
*buf,
size_t
len);
27
int
BSP_uart_termios_read_com (
int
minor);
28
void
BSP_uart_termios_isr_com1(
void
*unused);
29
void
BSP_uart_termios_isr_com2(
void
*unused);
30
void
BSP_uart_dbgisr_com1(
void
31
void
BSP_uart_dbgisr_com2(
void
32
int
BSP_uart_install_isr(
int
uart, rtems_irq_hdl handler);
33
int
BSP_uart_remove_isr(
int
34
ssize_t BSP_uart_termios_write_polled(
int
minor,
const
char
*buf,
size_t
len);
35
int
BSP_uart_get_break_cb(
int
uart,
rtems_libio_ioctl_args_t
*arg);
36
int
BSP_uart_set_break_cb(
int
uart,
*arg);
37
38
extern
unsigned
BSP_poll_char_via_serial(
void
39
extern
void
BSP_output_char_via_serial(
const
char
val);
40
extern
int
BSPConsolePort;
41
extern
int
BSPBaseBaud;
42
43
/* Special IOCTLS to install a lowlevel 'BREAK' handler */
44
45
/* pass a BSP_UartBreakCb pointer to ioctl when retrieving
46
* or installing break callback
47
48
typedef
void (*BSP_UartBreakCbProc)(
49
int
uartMinor,
50
unsigned
uartRBRLSRStatus,
51
void
*termiosPrivatePtr,
52
void
*private
53
54
55
typedef
struct
BSP_UartBreakCbRec_
56
BSP_UartBreakCbProc handler;
/* NOTE: handler runs in INTERRUPT CONTEXT */
57
void
private
/* closure pointer which is passed to the callback */
58
} BSP_UartBreakCbRec, *BSP_UartBreakCb;
59
60
#define BIOCGETBREAKCB _IOR('b',1,sizeof(BSP_UartBreakCbRec))
61
#define BIOCSETBREAKCB _IOW('b',2,sizeof(BSP_UartBreakCbRec))
62
63
64
* Command values for BSP_uart_intr_ctrl(),
65
* values are strange in order to catch errors
66
* with assert
67
68
#define BSP_UART_INTR_CTRL_DISABLE (0)
69
#define BSP_UART_INTR_CTRL_GDB (0xaa)
/* RX only */
70
#define BSP_UART_INTR_CTRL_ENABLE (0xbb)
/* Normal operations */
71
#define BSP_UART_INTR_CTRL_TERMIOS (0xcc)
/* RX & line status */
72
73
/* Return values for uart_polled_status() */
74
#define BSP_UART_STATUS_ERROR (-1)
/* No character */
75
#define BSP_UART_STATUS_NOCHAR (0)
/* No character */
76
#define BSP_UART_STATUS_CHAR (1)
/* Character present */
77
#define BSP_UART_STATUS_BREAK (2)
/* Break point is detected */
78
79
/* PC UART definitions */
80
#define BSP_UART_COM1 (0)
81
#define BSP_UART_COM2 (1)
82
83
84
* Offsets from base
85
86
87
/* DLAB 0 */
88
#define RBR (0)
/* Rx Buffer Register (read) */
89
#define THR (0)
/* Tx Buffer Register (write) */
90
#define IER (1)
/* Interrupt Enable Register */
91
92
/* DLAB X */
93
#define IIR (2)
/* Interrupt Ident Register (read) */
94
#define FCR (2)
/* FIFO Control Register (write) */
95
#define LCR (3)
/* Line Control Register */
96
#define MCR (4)
/* Modem Control Register */
97
#define LSR (5)
/* Line Status Register */
98
#define MSR (6)
/* Modem Status Register */
99
#define SCR (7)
/* Scratch register */
100
101
/* DLAB 1 */
102
#define DLL (0)
/* Divisor Latch, LSB */
103
#define DLM (1)
/* Divisor Latch, MSB */
104
#define AFR (2)
/* Alternate Function register */
105
106
107
* Interrupt source definition via IIR
108
109
#define MODEM_STATUS 0
110
#define NO_MORE_INTR 1
111
#define TRANSMITTER_HODING_REGISTER_EMPTY 2
112
#define RECEIVER_DATA_AVAIL 4
113
#define RECEIVER_ERROR 6
114
#define CHARACTER_TIMEOUT_INDICATION 12
115
116
117
* Bits definition of IER
118
119
#define RECEIVE_ENABLE 0x1
120
#define TRANSMIT_ENABLE 0x2
121
#define RECEIVER_LINE_ST_ENABLE 0x4
122
#define MODEM_ENABLE 0x8
123
#define INTERRUPT_DISABLE 0x0
124
125
126
* Bits definition of the Line Status Register (LSR)
127
128
#define DR 0x01
/* Data Ready */
129
#define OE 0x02
/* Overrun Error */
130
#define PE 0x04
/* Parity Error */
131
#define FE 0x08
/* Framing Error */
132
#define BI 0x10
/* Break Interrupt */
133
#define THRE 0x20
/* Transmitter Holding Register Empty */
134
#define TEMT 0x40
/* Transmitter Empty */
135
#define ERFIFO 0x80
/* Error receive Fifo */
136
137
138
* Bits definition of the MODEM Control Register (MCR)
139
140
#define DTR 0x01
/* Data Terminal Ready */
141
#define RTS 0x02
/* Request To Send */
142
#define OUT_1 0x04
/* Output 1, (reserved on COMPAQ I/O Board) */
143
#define OUT_2 0x08
/* Output 2, Enable Asynchronous Port Interrupts */
144
#define LB 0x10
/* Enable Internal Loop Back */
145
146
147
* Bits definition of the Line Control Register (LCR)
148
149
#define CHR_5_BITS 0
150
#define CHR_6_BITS 1
151
#define CHR_7_BITS 2
152
#define CHR_8_BITS 3
153
154
#define WL 0x03
/* Word length mask */
155
#define STB 0x04
/* 1 Stop Bit, otherwise 2 Stop Bits */
156
#define PEN 0x08
/* Parity Enabled */
157
#define EPS 0x10
/* Even Parity Select, otherwise Odd */
158
#define SP 0x20
/* Stick Parity */
159
#define BCB 0x40
/* Break Control Bit */
160
#define DLAB 0x80
/* Enable Divisor Latch Access */
161
162
163
* Bits definition of the MODEM Status Register (MSR)
164
165
#define DCTS 0x01
/* Delta Clear To Send */
166
#define DDSR 0x02
/* Delta Data Set Ready */
167
#define TERI 0x04
/* Trailing Edge Ring Indicator */
168
#define DDCD 0x08
/* Delta Carrier Detect Indicator */
169
#define CTS 0x10
/* Clear To Send (when loop back is active) */
170
#define DSR 0x20
/* Data Set Ready (when loop back is active) */
171
#define RI 0x40
/* Ring Indicator (when loop back is active) */
172
#define DCD 0x80
/* Data Carrier Detect (when loop back is active) */
173
174
175
* Bits definition of the FIFO Control Register : WD16C552 or NS16550
176
177
178
#define FIFO_CTRL 0x01
/* Set to 1 permit access to other bits */
179
#define FIFO_EN 0x01
/* Enable the FIFO */
180
#define XMIT_RESET 0x02
/* Transmit FIFO Reset */
181
#define RCV_RESET 0x04
/* Receive FIFO Reset */
182
#define FCR3 0x08
/* do not understand manual! */
183
184
#define RECEIVE_FIFO_TRIGGER1 0x00
/* trigger RX interrupt after 1 byte */
185
#define RECEIVE_FIFO_TRIGGER4 0x40
/* trigger RX interrupt after 4 bytes */
186
#define RECEIVE_FIFO_TRIGGER8 0x80
/* trigger RX interrupt after 8 bytes */
187
#define RECEIVE_FIFO_TRIGGER12 0xc0
/* trigger RX interrupt after 12 bytes */
188
#define TRIG_LEVEL 0xc0
/* Mask for the trigger level */
189
190
#endif
/* _BSPUART_H */
libio.h
Basic IO API.
BSP_UartBreakCbRec_
Definition
uart.h:55
Parameter block for ioctl.
Definition
libio.h:1375
