RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
gen5200
include
tm27.h
1
2
* @file
3
* @ingroup powerpc_gen5200
4
* @brief Implementations for interrupt mechanisms for Time Test 27
5
6
7
8
* The license and distribution terms for this file may be
9
* found in the file LICENSE in this distribution or at
10
* http://www.rtems.org/license/LICENSE.
11
12
13
#ifndef _RTEMS_TMTEST27
14
#error "This is an RTEMS internal file you must not include directly."
15
#endif
16
17
#ifndef __tm27_h
18
#define __tm27_h
19
20
bsp/fatal.h
21
#include <bsp/irq.h>
22
23
24
* Stuff for Time Test 27
25
26
27
#define MUST_WAIT_FOR_INTERRUPT 1
28
29
static
void
nullFunc(
void
30
31
static
rtems_irq_connect_data clockIrqData = {BSP_DECREMENTER,
32
0,
33
(rtems_irq_enable) nullFunc,
34
(rtems_irq_disable) nullFunc,
35
(rtems_irq_is_enabled) nullFunc};
36
37
static
inline
void
Install_tm27_vector(
rtems_interrupt_handler
handler )
38
39
clockIrqData.hdl = handler;
40
if
(!BSP_install_rtems_irq_handler (&clockIrqData)) {
41
printk(
"Error installing clock interrupt handler!\n"
42
bsp_fatal(MPC5200_FATAL_TM27_IRQ_INSTALL);
43
44
45
46
#define Cause_tm27_intr() \
47
do { \
48
uint32_t _clicks = 8; \
49
__asm__ volatile( "mtdec %0" : "=r" ((_clicks)) : "r" ((_clicks)) ); \
50
} while (0)
51
52
#define Clear_tm27_intr() \
53
do { \
54
uint32_t _clicks = 0xffffffff; \
55
56
} while (0)
57
58
#define Lower_tm27_intr() \
59
do { \
60
uint32_t _msr = 0; \
61
_ISR_Set_level( 0 ); \
62
__asm__ volatile( "mfmsr %0 ;" : "=r" (_msr) : "r" (_msr) ); \
63
_msr |= 0x8002; \
64
__asm__ volatile( "mtmsr %0 ;" : "=r" (_msr) : "r" (_msr) ); \
65
} while (0)
66
67
#endif
fatal.h
This header file provides fatal codes for RTEMS_FATAL_SOURCE_BSP.
void(*) rtems_interrupt_handler(void *)
Interrupt handler routines shall have this type.
Definition
intr.h:1030
