RTEMS
6.3
Toggle main menu visibility
include
posix
timerimpl.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
11
12
13
* COPYRIGHT (c) 1989-2013.
14
* On-Line Applications Research Corporation (OAR).
15
16
17
* modification, are permitted provided that the following conditions
18
* are met:
19
* 1. Redistributions of source code must retain the above copyright
20
* notice, this list of conditions and the following disclaimer.
21
* 2. Redistributions in binary form must reproduce the above copyright
22
* notice, this list of conditions and the following disclaimer in the
23
* documentation and/or other materials provided with the distribution.
24
25
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35
* POSSIBILITY OF SUCH DAMAGE.
36
37
38
#ifndef _RTEMS_POSIX_TIMERIMPL_H
39
#define _RTEMS_POSIX_TIMERIMPL_H
40
41
rtems/posix/timer.h
42
rtems/score/objectimpl.h
43
rtems/score/watchdogimpl.h
44
45
#ifdef __cplusplus
46
extern
"C"
47
#endif
48
50
#define POSIX_TIMER_STATE_FREE 0x01
51
53
#define POSIX_TIMER_STATE_CREATE_NEW 0x02
54
56
#define POSIX_TIMER_STATE_CREATE_RUN 0x03
57
59
#define POSIX_TIMER_STATE_CREATE_STOP 0x04
60
62
#define POSIX_TIMER_RELATIVE 0
63
64
65
* POSIX defines TIMER_ABSTIME but no constant for relative. So
66
* we have one internally but we need to be careful it has a different
67
* value.
68
69
#if (POSIX_TIMER_RELATIVE == TIMER_ABSTIME)
70
#error "POSIX_TIMER_RELATIVE == TIMER_ABSTIME"
71
#endif
72
79
static
inline
POSIX_Timer_Control
*_POSIX_Timer_Allocate(
void
80
81
return
POSIX_Timer_Control
_Objects_Allocate
_POSIX_Timer_Information
82
83
90
static
inline
void
_POSIX_Timer_Free (
91
POSIX_Timer_Control
*the_timer
92
93
94
_Objects_Free( &
, &the_timer->Object );
95
96
97
void
_POSIX_Timer_TSR(
Watchdog_Control
*the_watchdog );
98
108
static
inline
POSIX_Timer_Control
*_POSIX_Timer_Get (
109
timer_t
id
110
ISR_lock_Context
*lock_context
111
112
113
return
POSIX_Timer_Control
_Objects_Get
114
Objects_Id
id
115
lock_context,
116
117
118
119
120
static
inline
Per_CPU_Control
*_POSIX_Timer_Acquire_critical(
121
POSIX_Timer_Control
*ptimer,
122
ISR_lock_Context
*lock_context
123
124
125
Per_CPU_Control
*cpu;
126
127
cpu = _Watchdog_Get_CPU( &ptimer->Timer );
128
_Watchdog_Per_CPU_acquire_critical( cpu, lock_context );
129
130
return
cpu;
131
132
133
static
inline
void
_POSIX_Timer_Release(
134
Per_CPU_Control
*cpu,
135
ISR_lock_Context
*lock_context
136
137
138
_Watchdog_Per_CPU_release_critical( cpu, lock_context );
139
_ISR_lock_ISR_enable
( lock_context );
140
141
142
#ifdef __cplusplus
143
144
#endif
145
146
#endif
147
/* end of include file */
timer.h
POSIX Timers Internal Support.
Objects_Information _POSIX_Timer_Information
The POSIX Timer objects information.
#define _ISR_lock_ISR_enable(_context)
Restores the saved interrupt state of the ISR lock context.
Definition
isrlock.h:385
_Objects_Allocate
Objects_Control * _Objects_Allocate(Objects_Information *information)
Allocates an object.
Definition
objectallocate.c:43
Objects_Id
uint32_t Objects_Id
Definition
object.h:101
_Objects_Get
Objects_Control * _Objects_Get(Objects_Id id, ISR_lock_Context *lock_context, const Objects_Information *information)
Maps the specified object identifier to the associated local object control block.
Definition
objectgetlocal.c:43
objectimpl.h
This header file provides interfaces of the Object Handler which are only used by the implementation.
ISR_lock_Context
Local ISR lock context for acquire and release pairs.
Definition
isrlock.h:94
POSIX_Timer_Control
Definition
timer.h:60
Per_CPU_Control
Per CPU Core Structure.
Definition
percpu.h:384
Watchdog_Control
The control block used to manage each watchdog timer.
Definition
watchdog.h:109
watchdogimpl.h
This header file provides interfaces of the Watchdog Handler which are only used by the implementatio...
