RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
include
libcpu
pgtable.h
1
2
* pgtable.h
3
4
* PowerPC memory management structures
5
6
* It is a stripped down version of linux ppc file...
7
8
* Copyright (C) 1999 Eric Valette (valette@crf.canon.fr)
9
* Canon Centre Recherche France.
10
11
* The license and distribution terms for this file may be
12
* found in the file LICENSE in this distribution or at
13
* http://www.rtems.org/license/LICENSE.
14
15
16
#ifndef _LIBCPU_PGTABLE_H
17
#define _LIBCPU_PGTABLE_H
18
19
20
* The PowerPC MMU uses a hash table containing PTEs, together with
21
* a set of 16 segment registers (on 32-bit implementations), to define
22
* the virtual to physical address mapping.
23
24
* We use the hash table as an extended TLB, i.e. a cache of currently
25
* active mappings. We maintain a two-level page table tree, much like
26
* that used by the i386, for the sake of the Linux memory management code.
27
* Low-level assembler code in head.S (procedure hash_page) is responsible
28
* for extracting ptes from the tree and putting them into the hash table
29
* when necessary, and updating the accessed and modified bits in the
30
* page table tree.
31
32
* The PowerPC MPC8xx uses a TLB with hardware assisted, software tablewalk.
33
* We also use the two level tables, but we can put the real bits in them
34
* needed for the TLB and tablewalk. These definitions require Mx_CTR.PPM = 0,
35
* Mx_CTR.PPCS = 0, and MD_CTR.TWAM = 1. The level 2 descriptor has
36
* additional page protection (when Mx_CTR.PPCS = 1) that allows TLB hit
37
* based upon user/super access. The TLB does not have accessed nor write
38
* protect. We assume that if the TLB get loaded with an entry it is
39
* accessed, and overload the changed bit for write protect. We use
40
* two bits in the software pte that are supposed to be set to zero in
41
* the TLB entry (24 and 25) for these indicators. Although the level 1
42
* descriptor contains the guarded and writethrough/copyback bits, we can
43
* set these at the page level since they get copied from the Mx_TWC
44
* register when the TLB entry is loaded. We will use bit 27 for guard, since
45
* that is where it exists in the MD_TWC, and bit 26 for writethrough.
46
* These will get masked from the level 2 descriptor at TLB load time, and
47
* copied to the MD_TWC before it gets loaded.
48
49
50
/* PMD_SHIFT determines the size of the area mapped by the second-level page tables */
51
#define PMD_SHIFT 22
52
#define PMD_SIZE (1UL << PMD_SHIFT)
53
#define PMD_MASK (~(PMD_SIZE-1))
54
55
/* PGDIR_SHIFT determines what a third-level page table entry can map */
56
#define PGDIR_SHIFT 22
57
#define PGDIR_SIZE (1UL << PGDIR_SHIFT)
58
#define PGDIR_MASK (~(PGDIR_SIZE-1))
59
60
61
* entries per page directory level: our page-table tree is two-level, so
62
* we don't really have any PMD directory.
63
64
#define PTRS_PER_PTE 1024
65
#define PTRS_PER_PMD 1
66
#define PTRS_PER_PGD 1024
67
#define USER_PTRS_PER_PGD (TASK_SIZE / PGDIR_SIZE)
68
69
/* Just any arbitrary offset to the start of the vmalloc VM area: the
70
* current 64MB value just means that there will be a 64MB "hole" after the
71
* physical memory until the kernel virtual memory starts. That means that
72
* any out-of-bounds memory accesses will hopefully be caught.
73
* The vmalloc() routines leaves a hole of 4kB between each vmalloced
74
* area for the same reason. ;)
75
76
* We no longer map larger than phys RAM with the BATs so we don't have
77
* to worry about the VMALLOC_OFFSET causing problems. We do have to worry
78
* about clashes between our early calls to ioremap() that start growing down
79
* from ioremap_base being run into the VM area allocations (growing upwards
80
* from VMALLOC_START). For this reason we have ioremap_bot to check when
81
* we actually run into our mappings setup in the early boot with the VM
82
* system. This really does become a problem for machines with good amounts
83
* of RAM. -- Cort
84
85
#define VMALLOC_OFFSET (0x4000000)
/* 64M */
86
#define VMALLOC_START ((((long)high_memory + VMALLOC_OFFSET) & ~(VMALLOC_OFFSET-1)))
87
#define VMALLOC_VMADDR(x) ((unsigned long)(x))
88
#define VMALLOC_END ioremap_bot
89
90
91
* Bits in a linux-style PTE. These match the bits in the
92
* (hardware-defined) PowerPC PTE as closely as possible.
93
94
#define _PAGE_PRESENT 0x001
/* software: pte contains a translation */
95
#define _PAGE_USER 0x002
/* matches one of the PP bits */
96
#define _PAGE_RW 0x004
/* software: user write access allowed */
97
#define _PAGE_GUARDED 0x008
98
#define _PAGE_COHERENT 0x010
/* M: enforce memory coherence (SMP systems) */
99
#define _PAGE_NO_CACHE 0x020
/* I: cache inhibit */
100
#define _PAGE_WRITETHRU 0x040
/* W: cache write-through */
101
#define _PAGE_DIRTY 0x080
/* C: page changed */
102
#define _PAGE_ACCESSED 0x100
/* R: page referenced */
103
#define _PAGE_HWWRITE 0x200
/* software: _PAGE_RW & _PAGE_DIRTY */
104
#define _PAGE_SHARED 0
105
106
#define _PAGE_CHG_MASK (PAGE_MASK | _PAGE_ACCESSED | _PAGE_DIRTY)
107
108
#define _PAGE_BASE _PAGE_PRESENT | _PAGE_ACCESSED
109
#define _PAGE_WRENABLE _PAGE_RW | _PAGE_DIRTY | _PAGE_HWWRITE
110
111
#define PAGE_NONE __pgprot(_PAGE_PRESENT | _PAGE_ACCESSED)
112
113
#define PAGE_SHARED __pgprot(_PAGE_BASE | _PAGE_RW | _PAGE_USER | \
114
_PAGE_SHARED)
115
#define PAGE_COPY __pgprot(_PAGE_BASE | _PAGE_USER)
116
#define PAGE_READONLY __pgprot(_PAGE_BASE | _PAGE_USER)
117
#define PAGE_KERNEL __pgprot(_PAGE_BASE | _PAGE_WRENABLE | _PAGE_SHARED)
118
#define PAGE_KERNEL_CI __pgprot(_PAGE_BASE | _PAGE_WRENABLE | _PAGE_SHARED | \
119
_PAGE_NO_CACHE )
120
121
122
* The PowerPC can only do execute protection on a segment (256MB) basis,
123
* not on a page basis. So we consider execute permission the same as read.
124
* Also, write permissions imply read permissions.
125
* This is the closest we can get..
126
127
#define __P000 PAGE_NONE
128
#define __P001 PAGE_READONLY
129
#define __P010 PAGE_COPY
130
#define __P011 PAGE_COPY
131
#define __P100 PAGE_READONLY
132
#define __P101 PAGE_READONLY
133
#define __P110 PAGE_COPY
134
#define __P111 PAGE_COPY
135
136
#define __S000 PAGE_NONE
137
#define __S001 PAGE_READONLY
138
#define __S010 PAGE_SHARED
139
#define __S011 PAGE_SHARED
140
#define __S100 PAGE_READONLY
141
#define __S101 PAGE_READONLY
142
#define __S110 PAGE_SHARED
143
#define __S111 PAGE_SHARED
144
#endif
/* _LIBCPU_PGTABLE_H */
