RTEMS 6.3
mpu_armv7.h
1/******************************************************************************
2 * @file mpu_armv7.h
3 * @brief CMSIS MPU API for Armv7-M MPU
4 * @version V5.1.2
5 * @date 25. May 2020
6 ******************************************************************************/
7/*
8 * Copyright (c) 2017-2020 Arm Limited. All rights reserved.
9 *
10 * SPDX-License-Identifier: Apache-2.0
11 *
12 * Licensed under the Apache License, Version 2.0 (the License); you may
13 * not use this file except in compliance with the License.
14 * You may obtain a copy of the License at
15 *
16 * www.apache.org/licenses/LICENSE-2.0
17 *
18 * Unless required by applicable law or agreed to in writing, software
19 * distributed under the License is distributed on an AS IS BASIS, WITHOUT
20 * WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
21 * See the License for the specific language governing permissions and
22 * limitations under the License.
23 */
24
25#if defined ( __ICCARM__ )
26 #pragma system_include /* treat file as system include file for MISRA check */
27#elif defined (__clang__)
28 #pragma clang system_header /* treat file as system include file */
29#endif
30
31#ifndef ARM_MPU_ARMV7_H
32#define ARM_MPU_ARMV7_H
33
34#define ARM_MPU_REGION_SIZE_32B ((uint8_t)0x04U)
35#define ARM_MPU_REGION_SIZE_64B ((uint8_t)0x05U)
36#define ARM_MPU_REGION_SIZE_128B ((uint8_t)0x06U)
37#define ARM_MPU_REGION_SIZE_256B ((uint8_t)0x07U)
38#define ARM_MPU_REGION_SIZE_512B ((uint8_t)0x08U)
39#define ARM_MPU_REGION_SIZE_1KB ((uint8_t)0x09U)
40#define ARM_MPU_REGION_SIZE_2KB ((uint8_t)0x0AU)
41#define ARM_MPU_REGION_SIZE_4KB ((uint8_t)0x0BU)
42#define ARM_MPU_REGION_SIZE_8KB ((uint8_t)0x0CU)
43#define ARM_MPU_REGION_SIZE_16KB ((uint8_t)0x0DU)
44#define ARM_MPU_REGION_SIZE_32KB ((uint8_t)0x0EU)
45#define ARM_MPU_REGION_SIZE_64KB ((uint8_t)0x0FU)
46#define ARM_MPU_REGION_SIZE_128KB ((uint8_t)0x10U)
47#define ARM_MPU_REGION_SIZE_256KB ((uint8_t)0x11U)
48#define ARM_MPU_REGION_SIZE_512KB ((uint8_t)0x12U)
49#define ARM_MPU_REGION_SIZE_1MB ((uint8_t)0x13U)
50#define ARM_MPU_REGION_SIZE_2MB ((uint8_t)0x14U)
51#define ARM_MPU_REGION_SIZE_4MB ((uint8_t)0x15U)
52#define ARM_MPU_REGION_SIZE_8MB ((uint8_t)0x16U)
53#define ARM_MPU_REGION_SIZE_16MB ((uint8_t)0x17U)
54#define ARM_MPU_REGION_SIZE_32MB ((uint8_t)0x18U)
55#define ARM_MPU_REGION_SIZE_64MB ((uint8_t)0x19U)
56#define ARM_MPU_REGION_SIZE_128MB ((uint8_t)0x1AU)
57#define ARM_MPU_REGION_SIZE_256MB ((uint8_t)0x1BU)
58#define ARM_MPU_REGION_SIZE_512MB ((uint8_t)0x1CU)
59#define ARM_MPU_REGION_SIZE_1GB ((uint8_t)0x1DU)
60#define ARM_MPU_REGION_SIZE_2GB ((uint8_t)0x1EU)
61#define ARM_MPU_REGION_SIZE_4GB ((uint8_t)0x1FU)
62
63#define ARM_MPU_AP_NONE 0U
64#define ARM_MPU_AP_PRIV 1U
65#define ARM_MPU_AP_URO 2U
66#define ARM_MPU_AP_FULL 3U
67#define ARM_MPU_AP_PRO 5U
68#define ARM_MPU_AP_RO 6U
69
75#define ARM_MPU_RBAR(Region, BaseAddress) \
76 (((BaseAddress) & MPU_RBAR_ADDR_Msk) | \
77 ((Region) & MPU_RBAR_REGION_Msk) | \
78 (MPU_RBAR_VALID_Msk))
79
88#define ARM_MPU_ACCESS_(TypeExtField, IsShareable, IsCacheable, IsBufferable) \
89 ((((TypeExtField) << MPU_RASR_TEX_Pos) & MPU_RASR_TEX_Msk) | \
90 (((IsShareable) << MPU_RASR_S_Pos) & MPU_RASR_S_Msk) | \
91 (((IsCacheable) << MPU_RASR_C_Pos) & MPU_RASR_C_Msk) | \
92 (((IsBufferable) << MPU_RASR_B_Pos) & MPU_RASR_B_Msk))
93
103#define ARM_MPU_RASR_EX(DisableExec, AccessPermission, AccessAttributes, SubRegionDisable, Size) \
104 ((((DisableExec) << MPU_RASR_XN_Pos) & MPU_RASR_XN_Msk) | \
105 (((AccessPermission) << MPU_RASR_AP_Pos) & MPU_RASR_AP_Msk) | \
106 (((AccessAttributes) & (MPU_RASR_TEX_Msk | MPU_RASR_S_Msk | MPU_RASR_C_Msk | MPU_RASR_B_Msk))) | \
107 (((SubRegionDisable) << MPU_RASR_SRD_Pos) & MPU_RASR_SRD_Msk) | \
108 (((Size) << MPU_RASR_SIZE_Pos) & MPU_RASR_SIZE_Msk) | \
109 (((MPU_RASR_ENABLE_Msk))))
110
123#define ARM_MPU_RASR(DisableExec, AccessPermission, TypeExtField, IsShareable, IsCacheable, IsBufferable, SubRegionDisable, Size) \
124 ARM_MPU_RASR_EX(DisableExec, AccessPermission, ARM_MPU_ACCESS_(TypeExtField, IsShareable, IsCacheable, IsBufferable), SubRegionDisable, Size)
125
133#define ARM_MPU_ACCESS_ORDERED ARM_MPU_ACCESS_(0U, 1U, 0U, 0U)
134
144#define ARM_MPU_ACCESS_DEVICE(IsShareable) ((IsShareable) ? ARM_MPU_ACCESS_(0U, 1U, 0U, 1U) : ARM_MPU_ACCESS_(2U, 0U, 0U, 0U))
145
157#define ARM_MPU_ACCESS_NORMAL(OuterCp, InnerCp, IsShareable) ARM_MPU_ACCESS_((4U | (OuterCp)), IsShareable, ((InnerCp) >> 1U), ((InnerCp) & 1U))
158
162#define ARM_MPU_CACHEP_NOCACHE 0U
163
167#define ARM_MPU_CACHEP_WB_WRA 1U
168
172#define ARM_MPU_CACHEP_WT_NWA 2U
173
177#define ARM_MPU_CACHEP_WB_NWA 3U
178
179
183typedef struct {
184 uint32_t RBAR;
185 uint32_t RASR;
187
191__STATIC_INLINE void ARM_MPU_Enable(uint32_t MPU_Control)
192{
193 __DMB();
194 MPU->CTRL = MPU_Control | MPU_CTRL_ENABLE_Msk;
195#ifdef SCB_SHCSR_MEMFAULTENA_Msk
197#endif
198 __DSB();
199 __ISB();
200}
201
204__STATIC_INLINE void ARM_MPU_Disable(void)
205{
206 __DMB();
207#ifdef SCB_SHCSR_MEMFAULTENA_Msk
209#endif
210 MPU->CTRL &= ~MPU_CTRL_ENABLE_Msk;
211 __DSB();
212 __ISB();
213}
214
218__STATIC_INLINE void ARM_MPU_ClrRegion(uint32_t rnr)
219{
220 MPU->RNR = rnr;
221 MPU->RASR = 0U;
222}
223
228__STATIC_INLINE void ARM_MPU_SetRegion(uint32_t rbar, uint32_t rasr)
229{
230 MPU->RBAR = rbar;
231 MPU->RASR = rasr;
232}
233
239__STATIC_INLINE void ARM_MPU_SetRegionEx(uint32_t rnr, uint32_t rbar, uint32_t rasr)
240{
241 MPU->RNR = rnr;
242 MPU->RBAR = rbar;
243 MPU->RASR = rasr;
244}
245
251__STATIC_INLINE void ARM_MPU_OrderedMemcpy(volatile uint32_t* dst, const uint32_t* __RESTRICT src, uint32_t len)
252{
253 uint32_t i;
254 for (i = 0U; i < len; ++i)
255 {
256 dst[i] = src[i];
257 }
258}
259
264__STATIC_INLINE void ARM_MPU_Load(ARM_MPU_Region_t const* table, uint32_t cnt)
265{
266 const uint32_t rowWordSize = sizeof(ARM_MPU_Region_t)/4U;
267 while (cnt > MPU_TYPE_RALIASES) {
268 ARM_MPU_OrderedMemcpy(&(MPU->RBAR), &(table->RBAR), MPU_TYPE_RALIASES*rowWordSize);
269 table += MPU_TYPE_RALIASES;
270 cnt -= MPU_TYPE_RALIASES;
271 }
272 ARM_MPU_OrderedMemcpy(&(MPU->RBAR), &(table->RBAR), cnt*rowWordSize);
273}
274
275#endif
#define SCB
Definition core_cm4.h:1572
#define MPU
Definition core_cm4.h:1582
#define MPU_CTRL_ENABLE_Msk
Definition core_cm4.h:1260
#define SCB_SHCSR_MEMFAULTENA_Msk
Definition core_cm4.h:592
__STATIC_FORCEINLINE void __DSB(void)
Data Synchronization Barrier.
Definition cmsis_gcc.h:286
__STATIC_FORCEINLINE void __DMB(void)
Data Memory Barrier.
Definition cmsis_gcc.h:297
__STATIC_FORCEINLINE void __ISB(void)
Instruction Synchronization Barrier.
Definition cmsis_gcc.h:275
Definition mpu_armv7.h:239
Definition mpu_armv7.h:228
__STATIC_INLINE void ARM_MPU_Load(ARM_MPU_Region_t const *table, uint32_t cnt)
Definition mpu_armv7.h:264
Definition mpu_armv7.h:191
Definition mpu_armv7.h:204
Definition mpu_armv7.h:218
__STATIC_INLINE void ARM_MPU_OrderedMemcpy(volatile uint32_t *dst, const uint32_t *__RESTRICT src, uint32_t len)
Definition mpu_armv7.h:251
Definition mpu_armv7.h:183
uint32_t RASR
The region attribute and size register value (RASR) MPU_RASR.
Definition mpu_armv7.h:185
uint32_t RBAR
The region base address register value (RBAR).
Definition mpu_armv7.h:184
