RTEMS
6.3
Toggle main menu visibility
bsps
arm
atsam
include
libchip
include
mpu.h
1
2
/* Atmel Microcontroller Software Support */
3
/* SAM Software Package License */
4
5
/* Copyright (c) 2015, Atmel Corporation */
6
7
/* All rights reserved. */
8
9
/* Redistribution and use in source and binary forms, with or without */
10
/* modification, are permitted provided that the following condition is met: */
11
12
/* - Redistributions of source code must retain the above copyright notice, */
13
/* this list of conditions and the disclaimer below. */
14
15
/* Atmel's name may not be used to endorse or promote products derived from */
16
/* this software without specific prior written permission. */
17
18
/* DISCLAIMER: THIS SOFTWARE IS PROVIDED BY ATMEL "AS IS" AND ANY EXPRESS OR */
19
/* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF */
20
/* MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT ARE */
21
/* DISCLAIMED. IN NO EVENT SHALL ATMEL BE LIABLE FOR ANY DIRECT, INDIRECT, */
22
/* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT */
23
/* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, */
24
/* OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF */
25
/* LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING */
26
/* NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, */
27
/* EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. */
28
29
30
#ifndef _MPU_H_
31
#define _MPU_H_
32
#ifdef __rtems__
33
#include <bsp.h>
34
#endif
/* __rtems__ */
35
36
37
* Definitions
38
39
#define ARM_MODE_USR 0x10
40
41
#define PRIVILEGE_MODE 0
42
#define USER_MODE 1
43
44
#define MPU_DEFAULT_ITCM_REGION (1)
45
#define MPU_DEFAULT_IFLASH_REGION (2)
46
#define MPU_DEFAULT_DTCM_REGION (3)
47
#define MPU_DEFAULT_SRAM_REGION_1 (4)
48
#define MPU_DEFAULT_SRAM_REGION_2 (5)
49
#define MPU_PERIPHERALS_REGION (6)
50
#define MPU_EXT_EBI_REGION (7)
51
#define MPU_DEFAULT_SDRAM_REGION (8)
52
#define MPU_QSPIMEM_REGION (9)
53
#define MPU_USBHSRAM_REGION (10)
54
#if defined MPU_HAS_NOCACHE_REGION
55
#define MPU_NOCACHE_SRAM_REGION (11)
56
#endif
57
#define MPU_SYSTEM_REGION (12)
58
#ifdef __rtems__
59
#define MPU_NULL_REGION (13)
60
/* Reserve the region with highest priority for user applications */
61
#define MPU_USER_DEFINED_REGION (15)
62
#endif
/* __rtems__ */
63
64
#define MPU_REGION_VALID (0x10)
65
#define MPU_REGION_ENABLE (0x01)
66
#define MPU_REGION_DISABLE (0x0)
67
68
#define MPU_ENABLE (0x1 << MPU_CTRL_ENABLE_Pos)
69
#define MPU_HFNMIENA (0x1 << MPU_CTRL_HFNMIENA_Pos)
70
#define MPU_PRIVDEFENA (0x1 << MPU_CTRL_PRIVDEFENA_Pos)
71
72
73
#define MPU_REGION_BUFFERABLE (0x01 << MPU_RASR_B_Pos)
74
#define MPU_REGION_CACHEABLE (0x01 << MPU_RASR_C_Pos)
75
#define MPU_REGION_SHAREABLE (0x01 << MPU_RASR_S_Pos)
76
77
#define MPU_REGION_EXECUTE_NEVER (0x01 << MPU_RASR_XN_Pos)
78
79
#define MPU_AP_NO_ACCESS (0x00 << MPU_RASR_AP_Pos)
80
#define MPU_AP_PRIVILEGED_READ_WRITE (0x01 << MPU_RASR_AP_Pos)
81
#define MPU_AP_UNPRIVILEGED_READONLY (0x02 << MPU_RASR_AP_Pos)
82
#define MPU_AP_FULL_ACCESS (0x03 << MPU_RASR_AP_Pos)
83
#define MPU_AP_RES (0x04 << MPU_RASR_AP_Pos)
84
#define MPU_AP_PRIVILEGED_READONLY (0x05 << MPU_RASR_AP_Pos)
85
#define MPU_AP_READONLY (0x06 << MPU_RASR_AP_Pos)
86
#define MPU_AP_READONLY2 (0x07 << MPU_RASR_AP_Pos)
87
88
#define MPU_TEX_B000 (0x01 << MPU_RASR_TEX_Pos)
89
#define MPU_TEX_B001 (0x01 << MPU_RASR_TEX_Pos)
90
#define MPU_TEX_B010 (0x01 << MPU_RASR_TEX_Pos)
91
#define MPU_TEX_B011 (0x01 << MPU_RASR_TEX_Pos)
92
#define MPU_TEX_B100 (0x01 << MPU_RASR_TEX_Pos)
93
#define MPU_TEX_B101 (0x01 << MPU_RASR_TEX_Pos)
94
#define MPU_TEX_B110 (0x01 << MPU_RASR_TEX_Pos)
95
#define MPU_TEX_B111 (0x01 << MPU_RASR_TEX_Pos)
96
97
/* Default memory map
98
Address range Memory region Memory type Shareability Cache policy
99
0x00000000- 0x1FFFFFFF Code Normal Non-shareable WT
100
0x20000000- 0x3FFFFFFF SRAM Normal Non-shareable WBWA
101
0x40000000- 0x5FFFFFFF Peripheral Device Non-shareable -
102
0x60000000- 0x7FFFFFFF RAM Normal Non-shareable WBWA
103
0x80000000- 0x9FFFFFFF RAM Normal Non-shareable WT
104
0xA0000000- 0xBFFFFFFF Device Device Shareable
105
0xC0000000- 0xDFFFFFFF Device Device Non Shareable
106
0xE0000000- 0xFFFFFFFF System - -
107
108
109
/********* IFLASH memory macros *********************/
110
#ifdef __rtems__
111
#define ITCM_START_ADDRESS ((uintptr_t) atsam_memory_itcm_begin)
112
#define ITCM_END_ADDRESS ((uintptr_t) atsam_memory_itcm_end - 1)
113
#define IFLASH_START_ADDRESS ((uintptr_t) atsam_memory_intflash_begin)
114
#define IFLASH_END_ADDRESS ((uintptr_t) atsam_memory_intflash_end - 1)
115
#else
/* !__rtems__ */
116
#define ITCM_START_ADDRESS 0x00000000UL
117
#define ITCM_END_ADDRESS 0x003FFFFFUL
118
#define IFLASH_START_ADDRESS 0x00400000UL
119
#define IFLASH_END_ADDRESS 0x005FFFFFUL
120
#endif
/* __rtems__ */
121
122
123
#define IFLASH_PRIVILEGE_START_ADDRESS (IFLASH_START_ADDRESS)
124
#define IFLASH_PRIVILEGE_END_ADDRESS (IFLASH_START_ADDRESS + 0xFFF)
125
126
#define IFLASH_UNPRIVILEGE_START_ADDRESS (IFLASH_PRIVILEGE_END_ADDRESS + 1)
127
#define IFLASH_UNPRIVILEGE_END_ADDRESS (IFLASH_END_ADDRESS)
128
129
/**************** DTCM *******************************/
130
#ifdef __rtems__
131
#define DTCM_START_ADDRESS ((uintptr_t) atsam_memory_dtcm_begin)
132
#define DTCM_END_ADDRESS ((uintptr_t) atsam_memory_dtcm_end - 1)
133
#else
/* !__rtems__ */
134
#define DTCM_START_ADDRESS 0x20000000UL
135
#define DTCM_END_ADDRESS 0x203FFFFFUL
136
#endif
/* __rtems__ */
137
138
139
/******* SRAM memory macros ***************************/
140
141
#ifdef __rtems__
142
#define SRAM_START_ADDRESS ((uintptr_t) atsam_memory_intsram_begin)
143
#define SRAM_END_ADDRESS ((uintptr_t) atsam_memory_intsram_end - 1)
144
#else
/* !__rtems__ */
145
#define SRAM_START_ADDRESS 0x20400000UL
146
#define SRAM_END_ADDRESS 0x2045FFFFUL
147
#endif
/* __rtems__ */
148
149
#ifndef __rtems__
150
151
#define NOCACHE_SRAM_REGION_SIZE 0x1000
152
#endif
153
#endif
/* __rtems__ */
154
155
/* Regions should be a 2^(N+1) where 4 < N < 31 */
156
#ifdef __rtems__
157
#define SRAM_FIRST_START_ADDRESS ((uintptr_t) atsam_memory_intsram_begin)
158
#define SRAM_FIRST_END_ADDRESS ((uintptr_t) atsam_memory_intsram_end - 1)
159
#else
/* !__rtems__ */
160
#define SRAM_FIRST_START_ADDRESS (SRAM_START_ADDRESS)
161
#define SRAM_FIRST_END_ADDRESS (SRAM_FIRST_START_ADDRESS + 0x3FFFF)
// (2^18) 256 KB
162
#endif
/* __rtems__ */
163
164
165
#ifdef __rtems__
166
#define SRAM_NOCACHE_START_ADDRESS ((uintptr_t) atsam_memory_nocache_begin)
167
#define SRAM_NOCACHE_END_ADDRESS ((uintptr_t) atsam_memory_nocache_end - 1)
168
#define NOCACHE_SRAM_REGION_SIZE (SRAM_NOCACHE_END_ADDRESS - SRAM_NOCACHE_START_ADDRESS)
169
#else
/* !__rtems__ */
170
#define SRAM_SECOND_START_ADDRESS (SRAM_FIRST_END_ADDRESS+1)
171
#define SRAM_SECOND_END_ADDRESS (SRAM_END_ADDRESS - NOCACHE_SRAM_REGION_SIZE)
// (2^17) 128 - 0x1000 KB
172
#define SRAM_NOCACHE_START_ADDRESS (SRAM_SECOND_END_ADDRESS + 1)
173
#define SRAM_NOCACHE_END_ADDRESS (SRAM_END_ADDRESS)
174
#endif
/* __rtems__ */
175
#else
176
#ifndef __rtems__
177
#define SRAM_SECOND_START_ADDRESS (SRAM_FIRST_END_ADDRESS + 1)
178
#define SRAM_SECOND_END_ADDRESS (SRAM_END_ADDRESS)
// (2^17) 128 KB
179
#endif
/* __rtems__ */
180
#endif
181
/************** Peripherals memory region macros ********/
182
#define PERIPHERALS_START_ADDRESS 0x40000000UL
183
#define PERIPHERALS_END_ADDRESS 0x5FFFFFFFUL
184
#ifdef __rtems__
185
#define SYSTEM_START_ADDRESS 0xE0000000UL
186
#define SYSTEM_END_ADDRESS 0xFFFFFFFFUL
187
#endif
/* __rtems__ */
188
189
/******* Ext EBI memory macros ***************************/
190
#define EXT_EBI_START_ADDRESS 0x60000000UL
191
#define EXT_EBI_END_ADDRESS 0x6FFFFFFFUL
192
193
/******* Ext-SRAM memory macros ***************************/
194
#ifdef __rtems__
195
#define SDRAM_START_ADDRESS ((uintptr_t) atsam_memory_sdram_begin)
196
#define SDRAM_END_ADDRESS ((uintptr_t) atsam_memory_sdram_end - 1)
197
#else
/* !__rtems__ */
198
#define SDRAM_START_ADDRESS 0x70000000UL
199
#define SDRAM_END_ADDRESS 0x7FFFFFFFUL
200
#endif
/* __rtems__ */
201
202
/******* QSPI macros ***************************/
203
#ifdef __rtems__
204
#define QSPI_START_ADDRESS ((uintptr_t) atsam_memory_qspiflash_begin)
205
#define QSPI_END_ADDRESS ((uintptr_t) atsam_memory_qspiflash_end - 1)
206
#else
/* !__rtems__ */
207
#define QSPI_START_ADDRESS 0x80000000UL
208
#define QSPI_END_ADDRESS 0x9FFFFFFFUL
209
#endif
/* __rtems__ */
210
211
/************** USBHS_RAM region macros ******************/
212
#define USBHSRAM_START_ADDRESS 0xA0100000UL
213
#define USBHSRAM_END_ADDRESS 0xA01FFFFFUL
214
215
216
* Export functions
217
218
void
MPU_Enable
(uint32_t dwMPUEnable);
219
void
MPU_SetRegion
(uint32_t dwRegionBaseAddr, uint32_t dwRegionAttr);
220
void
MPU_SetRegionNum
(uint32_t dwRegionNum);
221
void
MPU_DisableRegion
void
222
uint32_t
MPU_CalMPURegionSize
(uint32_t dwActualSizeInBytes);
223
void
MPU_UpdateRegions
(uint32_t dwRegionNum, uint32_t dwRegionBaseAddr,
224
225
226
#endif
/* #ifndef _MMU_ */
227
MPU_Enable
void MPU_Enable(uint32_t dwMPUEnable)
Enables the MPU module.
Definition
mpu.c:78
MPU_SetRegion
void MPU_SetRegion(uint32_t dwRegionBaseAddr, uint32_t dwRegionAttr)
Setup a memory region.
Definition
mpu.c:107
uint32_t MPU_CalMPURegionSize(uint32_t dwActualSizeInBytes)
Calculate region size for the RASR.
Definition
mpu.c:117
MPU_SetRegionNum
void MPU_SetRegionNum(uint32_t dwRegionNum)
Set active memory region.
Definition
mpu.c:88
MPU_UpdateRegions
void MPU_UpdateRegions(uint32_t dwRegionNum, uint32_t dwRegionBaseAddr, uint32_t dwRegionAttr)
Update MPU regions.
Definition
mpu.c:140
MPU_DisableRegion
void MPU_DisableRegion(void)
Disable the current active region.
Definition
mpu.c:96
