RTEMS
6.3
Toggle main menu visibility
bsps
powerpc
include
mpc83xx
mpc83xx_i2cdrv.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* RTEMS support for MPC83xx
5
6
* This file contains the MPC83xx I2C driver declarations.
7
8
9
10
* Copyright (c) 2007 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef _MPC83XX_I2CDRV_H
35
#define _MPC83XX_I2CDRV_H
36
37
rtems/libi2c.h
38
rtems/irq.h
39
40
#include <bsp.h>
41
42
#ifdef LIBBSP_POWERPC_GEN83XX_BSP_H
43
#include <mpc83xx/mpc83xx.h>
44
#endif
45
46
#ifdef __cplusplus
47
extern
"C"
48
#endif
49
50
#ifdef LIBBSP_POWERPC_MPC55XXEVB_BSP_H
51
typedef
struct
52
volatile
uint8_t i2cadr;
53
volatile
uint8_t i2cfdr;
54
volatile
uint8_t i2ccr;
55
volatile
uint8_t i2csr;
56
volatile
uint8_t i2cdr;
57
volatile
uint8_t i2cdfsrr;
58
} m83xxI2CRegisters_t;
59
#endif
60
61
typedef
struct
mpc83xx_i2c_softc
62
m83xxI2CRegisters_t *reg_ptr;
/* ptr to HW registers */
63
int
initialized;
/* TRUE: module is initialized */
64
rtems_irq_number irq_number;
/* IRQ number used for this module */
65
uint32_t base_frq;
/* input frq for baud rate divider */
66
rtems_id
irq_sema_id;
/* SEMA used for IRQ signalling */
67
void (*probe)(
struct
mpc83xx_i2c_softc
*self);
68
} mpc83xx_i2c_softc_t ;
69
70
typedef
struct
71
rtems_libi2c_bus_t bus_desc;
72
struct
mpc83xx_i2c_softc
softc;
73
mpc83xx_i2c_desc_t
74
75
76
extern
rtems_libi2c_bus_ops_t mpc83xx_i2c_ops;
77
78
#ifdef __cplusplus
79
80
#endif
81
82
83
#endif
/* _MPC83XX_I2CDRV_H */
irq.h
rtems_id
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition
types.h:94
libi2c.h
Legacy I2C Library.
mpc83xx_i2c_desc_t
Definition
mpc83xx_i2cdrv.h:70
mpc83xx_i2c_softc
Definition
mpc83xx_i2cdrv.h:61
