RTEMS 6.3
mpc5xx.h
1/*
2 *
3 * MPC5xx Internal I/O Definitions
4 */
5
6/*
7 * MPC5xx port sponsored by Defence Research and Development Canada - Suffield
8 * Copyright (C) 2004, Real-Time Systems Inc. (querbach@realtime.bc.ca)
9 *
10 * Derived from c/src/lib/libcpu/powerpc/mpc8xx/include/mpc8xx.h:
11 *
12 * Submitted By: *
13 * *
14 * Eric Norum <eric@norum.ca> *
15 * *
16 * Modified for use with the MPC860 (original code was for MC68360) *
17 * by *
18 * Jay Monkman *
19 * Frasca International, Inc. *
20 * 906 E. Airport Rd. *
21 * Urbana, IL, 61801 *
22 * *
23 * jmonkman@frasca.com *
24 * *
25 * Modified further for use with the MPC821 by: *
26 * Andrew Bray <andy@chaos.org.uk> *
27 * *
28 * With some corrections/additions by: *
29 * Darlene A. Stewart and *
30 * Charles-Antoine Gauthier *
31 * Institute for Information Technology *
32 * National Research Council of Canada *
33 * Ottawa, ON K1A 0R6 *
34 * *
35 * Darlene.Stewart@iit.nrc.ca *
36 * charles.gauthier@iit.nrc.ca *
37 * *
38 * Corrections/additions: *
39 * Copyright (c) 1999, National Research Council of Canada *
40 *
41 * MPC5xx port sponsored by Defence Research and Development Canada - Suffield
42 * Copyright (C) 2004, Real-Time Systems Inc. (querbach@realtime.bc.ca)
43 *
44 * The license and distribution terms for this file may be
45 * found in the file LICENSE in this distribution or at
46 * http://www.rtems.org/license/LICENSE.
47 */
48
49#ifndef _MPC5XX_H
50#define _MPC5XX_H
51
52#include <libcpu/spr.h>
53
54
55#ifndef ASM
56
57#ifdef __cplusplus
58extern "C" {
59#endif
60
61/*
62 * Macros for accessing Special Purpose Registers (SPRs)
63 */
64
65#define _eieio __asm__ volatile ("eieio\n"::)
66#define _sync __asm__ volatile ("sync\n"::)
67#define _isync __asm__ volatile ("isync\n"::)
68
69/*
70 * Core Registers (SPRs)
71 */
72#define DER 149 /* Debug Enable Register */
73#define IMMR 638 /* Internal Memory Map Register */
74#define IMMR_FLEN (1<<11) /* Internal flash ROM enabled */
75
76/*
77 * Interrupt Control Registers (SPRs)
78 */
79#define EIE 80 /* External Interrupt Enable Register */
80#define EID 81 /* External Interrupt Disable Register */
81#define NRI 82 /* Non-Recoverable Interrupt Register */
82
83#define ECR 148 /* Exception Cause Register */
84
85/*
86 * Bus Control Registers (SPRs)
87 */
88#define LCTRL1 156 /* L-Bus Support Control Register 1 */
89#define LCTRL2 157 /* L-Bus Support Control Register 2 */
90#define ICTRL 158 /* I-Bus Support Control Register */
91
92/*
93 * Burst Buffer Control Registers (SPRs)
94 */
95#define BBCMCR 560 /* Burst Buffer Configuration Register */
96#define BBCMCR_BE (1<<13) /* Burst enable */
97#define BBCMCR_ETRE (1<<12) /* Exception table relocation enable */
98
99#define MI_RBA0 784 /* Region 0 Address Register */
100#define MI_RBA1 785 /* Region 1 Address Register */
101#define MI_RBA2 786 /* Region 2 Address Register */
102#define MI_RBA3 787 /* Region 3 Address Register */
103
104#define MI_RA0 816 /* Region 0 Attribute Register */
105#define MI_RA1 817 /* Region 1 Attribute Register */
106#define MI_RA2 818 /* Region 2 Attribute Register */
107#define MI_RA3 819 /* Region 3 Attribute Register */
108#define MI_GRA 528 /* Region Global Attribute Register */
109#define MI_RA_PP (3 << 10) /* Protection bits: */
110#define MI_RA_PP_SUPV (1 << 10) /* Supervisor */
111#define MI_RA_PP_USER (2 << 10) /* User */
112#define MI_RA_G (1 << 6) /* Guarded region */
113
114
115/*
116 * L-Bus to U-Bus Interface (L2U) Registers (SPRs)
117 */
118#define L2U_MCR 568 /* L2U Module Configuration Register */
119
120#define L2U_RBA0 792 /* L2U Region 0 Address Register */
121#define L2U_RBA1 793 /* L2U Region 1 Address Register */
122#define L2U_RBA2 794 /* L2U Region 2 Address Register */
123#define L2U_RBA3 795 /* L2U Region 3 Address Register */
124
125#define L2U_RA0 824 /* L2U Region 0 Attribute Register */
126#define L2U_RA1 825 /* L2U Region 1 Attribute Register */
127#define L2U_RA2 826 /* L2U Region 2 Attribute Register */
128#define L2U_RA3 827 /* L2U Region 3 Attribute Register */
129#define L2U_GRA 536 /* L2U Global Region Attribute Register */
130#define L2U_RA_PP (3 << 10) /* Protection bits: */
131#define L2U_RA_PP_SUPV (1 << 10) /* Supervisor */
132#define L2U_RA_PP_USER (2 << 10) /* User */
133#define L2U_RA_G (1 << 6) /* Guarded region */
134
135
136/*
137 *************************************************************************
138 * REGISTER SUBBLOCKS *
139 *************************************************************************
140 */
141
142/*
143 *************************************************************************
144 * System Protection Control Register (SYPCR) *
145 *************************************************************************
146 */
147#define USIU_SYPCR_SWTC(x) ((x)<<16) /* Software watchdog timer count */
148#define USIU_SYPCR_BMT(x) ((x)<<8) /* Bus monitor timing */
149#define USIU_SYPCR_BME (1<<7) /* Bus monitor enable */
150#define USIU_SYPCR_SWF (1<<3) /* Software watchdog freeze */
151#define USIU_SYPCR_SWE (1<<2) /* Software watchdog enable */
152#define USIU_SYPCR_SWRI (1<<1) /* Watchdog reset/interrupt sel. */
153#define USIU_SYPCR_SWP (1<<0) /* Software watchdog prescale */
154
155#define USIU_SYPCR_BMT(x) ((x)<<8) /* Bus monitor timing */
156#define USIU_SYPCR_BME (1<<7) /* Bus monitor enable */
157#define USIU_SYPCR_SWF (1<<3) /* Software watchdog freeze */
158#define USIU_SYPCR_SWE (1<<2) /* Software watchdog enable */
159#define USIU_SYPCR_SWRI (1<<1) /* Watchdog reset/interrupt sel. */
160#define USIU_SYPCR_SWP (1<<0) /* Software watchdog prescale */
161
162/*
163 *************************************************************************
164 * Software Service Register (SWSR) *
165 *************************************************************************
166 */
167#define TICKLE_WATCHDOG() \
168do { \
169 usiu.swsr = 0x556C; \
170 usiu.swsr = 0xAA39; \
171} while (0) \
172
173/*
174 *************************************************************************
175 * Memory Control Registers *
176 *************************************************************************
177 */
178#define USIU_MEMC_BR_BA(x) (((uint32_t)x)&0xffff8000)
179 /* Base address */
180#define USIU_MEMC_BR_AT(x) ((x)<<12) /* Address type */
181#define USIU_MEMC_BR_PS8 (1<<10) /* 8 bit port */
182#define USIU_MEMC_BR_PS16 (2<<10) /* 16 bit port */
183#define USIU_MEMC_BR_PS32 (0<<10) /* 32 bit port */
184#define USIU_MEMC_BR_WP (1<<8) /* Write protect */
185#define USIU_MEMC_BR_WEBS (1<<5) /* Write enable/byte select */
186#define USIU_MEMC_BR_TBDIP (1<<4) /* Toggle-Burst data in progress*/
187#define USIU_MEMC_BR_LBDIP (1<<3) /* Late-burst data in progress */
188#define USIU_MEMC_BR_SETA (1<<2) /* External transfer acknowledge */
189#define USIU_MEMC_BR_BI (1<<1) /* Burst inhibit */
190#define USIU_MEMC_BR_V (1<<0) /* Base/Option register are valid */
191
192#define USIU_MEMC_OR_32K 0xffff8000 /* Address range */
193#define USIU_MEMC_OR_64K 0xffff0000
194#define USIU_MEMC_OR_128K 0xfffe0000
195#define USIU_MEMC_OR_256K 0xfffc0000
196#define USIU_MEMC_OR_512K 0xfff80000
197#define USIU_MEMC_OR_1M 0xfff00000
198#define USIU_MEMC_OR_2M 0xffe00000
199#define USIU_MEMC_OR_4M 0xffc00000
200#define USIU_MEMC_OR_8M 0xff800000
201#define USIU_MEMC_OR_16M 0xff000000
202#define USIU_MEMC_OR_32M 0xfe000000
203#define USIU_MEMC_OR_64M 0xfc000000
204#define USIU_MEMC_OR_128 0xf8000000
205#define USIU_MEMC_OR_256M 0xf0000000
206#define USIU_MEMC_OR_512M 0xe0000000
207#define USIU_MEMC_OR_1G 0xc0000000
208#define USIU_MEMC_OR_2G 0x80000000
209#define USIU_MEMC_OR_4G 0x00000000
210#define USIU_MEMC_OR_ATM(x) ((x)<<12) /* Address type mask */
211#define USIU_MEMC_OR_CSNT (1<<11) /* Chip select is negated early */
212#define USIU_MEMC_OR_ACS_NORM (0<<9) /* *CS asserted with addr lines */
213#define USIU_MEMC_OR_ACS_QRTR (2<<9) /* *CS asserted 1/4 after addr */
214#define USIU_MEMC_OR_ACS_HALF (3<<9) /* *CS asserted 1/2 after addr */
215#define USIU_MEMC_OR_ETHR (1<<8) /* Extended hold time on reads */
216#define USIU_MEMC_OR_SCY(x) ((x)<<4) /* Cycle length in clocks */
217#define USIU_MEMC_OR_BSCY(x) ((x)<<1) /* Burst beat length in clocks */
218#define USIU_MEMC_OR_TRLX (1<<0) /* Relaxed timing in GPCM */
219
220/*
221 *************************************************************************
222 * Clocks and Reset Controlmer *
223 *************************************************************************
224 */
225
226#define USIU_SCCR_DBCT (1<<31) /* Disable backup clock for timers */
227#define USIU_SCCR_COM(x) ((x)<<29) /* Clock output mode */
228#define USIU_SCCR_RTDIV (1<<24) /* RTC, PIT divide by 256, not 4 */
229#define USIU_PRQEN (1<<21) /* MSR[POW] controls frequency */
230#define USIU_SCCR_EBDF(x) ((x)<<17) /* External bus division factor */
231#define USIU_LME (1<<16) /* Enable limp mode */
232#define USIU_ENGDIV(x) ((x)<<9) /* Set engineering clock divisor */
233
234#define USIU_PLPRCR_MF(x) (((x)-1)<<20) /* PLL mult. factor (true) */
235#define USIU_PLPRCR_SPLS (1<<16) /* System PLL locked */
236#define USIU_PLPRCR_TEXPS (1<<14) /* Assert TEXP always */
237
238/*
239 *************************************************************************
240 * Programmable Interval Timer *
241 *************************************************************************
242 */
243#define USIU_PISCR_PIRQ(x) (1<<(15-x)) /* PIT interrupt level */
244#define USIU_PISCR_PS (1<<7) /* PIT Interrupt state */
245#define USIU_PISCR_PIE (1<<2) /* PIT interrupt enable */
246#define USIU_PISCR_PITF (1<<1) /* Stop timer when freeze asserted */
247#define USIU_PISCR_PTE (1<<0) /* PIT enable */
248
249/*
250 *************************************************************************
251 * Time Base *
252 *************************************************************************
253 */
254#define USIU_TBSCR_TBIRQ(x) (1<<(15-x)) /* TB interrupt level */
255#define USIU_TBSCR_REFA (1<<7) /* TB matches TBREFF0 */
256#define USIU_TBSCR_REFB (1<<6) /* TB matches TBREFF1 */
257#define USIU_TBSCR_REFAE (1<<3) /* Enable ints for REFA */
258#define USIU_TBSCR_REFBE (1<<2) /* Enable ints for REFB */
259#define USIU_TBSCR_TBF (1<<1) /* TB stops on FREEZE */
260#define USIU_TBSCR_TBE (1<<0) /* enable TB and decrementer */
261
262/*
263 *************************************************************************
264 * SIU Interrupt Mask *
265 *************************************************************************
266 */
267#define USIU_SIMASK_IRM0 (1<<31)
268#define USIU_SIMASK_LVM0 (1<<30)
269#define USIU_SIMASK_IRM1 (1<<29)
270#define USIU_SIMASK_LVM1 (1<<28)
271#define USIU_SIMASK_IRM2 (1<<27)
272#define USIU_SIMASK_LVM2 (1<<26)
273#define USIU_SIMASK_IRM3 (1<<25)
274#define USIU_SIMASK_LVM3 (1<<24)
275#define USIU_SIMASK_IRM4 (1<<23)
276#define USIU_SIMASK_LVM4 (1<<22)
277#define USIU_SIMASK_IRM5 (1<<21)
278#define USIU_SIMASK_LVM5 (1<<20)
279#define USIU_SIMASK_IRM6 (1<<19)
280#define USIU_SIMASK_LVM6 (1<<18)
281#define USIU_SIMASK_IRM7 (1<<17)
282#define USIU_SIMASK_LVM7 (1<<16)
283
284/*
285 *************************************************************************
286 * SIU Module Control *
287 *************************************************************************
288 */
289#define USIU_SIUMCR_EARB (1<<31)
290#define USIU_SIUMCR_EARP0 (0<<28)
291#define USIU_SIUMCR_EARP1 (1<<28)
292#define USIU_SIUMCR_EARP2 (2<<28)
293#define USIU_SIUMCR_EARP3 (3<<28)
294#define USIU_SIUMCR_EARP4 (4<<28)
295#define USIU_SIUMCR_EARP5 (5<<28)
296#define USIU_SIUMCR_EARP6 (6<<28)
297#define USIU_SIUMCR_EARP7 (7<<28)
298#define USIU_SIUMCR_DSHW (1<<23)
299#define USIU_SIUMCR_DBGC0 (0<<21)
300#define USIU_SIUMCR_DBGC1 (1<<21)
301#define USIU_SIUMCR_DBGC2 (2<<21)
302#define USIU_SIUMCR_DBGC3 (3<<21)
303#define USIU_SIUMCR_DBPC (1<<20)
304#define USIU_SIUMCR_ATWC (1<<19)
305#define USIU_SIUMCR_GPC0 (0<<17)
306#define USIU_SIUMCR_GPC1 (1<<17)
307#define USIU_SIUMCR_GPC2 (2<<17)
308#define USIU_SIUMCR_GPC3 (3<<17)
309#define USIU_SIUMCR_DLK (1<<16)
310#define USIU_SIUMCR_SC0 (0<<13)
311#define USIU_SIUMCR_SC1 (1<<13)
312#define USIU_SIUMCR_SC2 (2<<13)
313#define USIU_SIUMCR_SC3 (3<<13)
314#define USIU_SIUMCR_RCTX (1<<12)
315#define USIU_SIUMCR_MLRC0 (0<<10)
316#define USIU_SIUMCR_MLRC1 (1<<10)
317#define USIU_SIUMCR_MLRC2 (2<<10)
318#define USIU_SIUMCR_MLRC3 (3<<10)
319#define USIU_SIUMCR_MTSC (1<<7)
320
321/*
322 * Value to write to a key register to unlock the corresponding SIU register
323 */
324#define USIU_UNLOCK_KEY 0x55CCAA33
325
326/*
327 *************************************************************************
328 * UIMB Module Control *
329 *************************************************************************
330 */
331#define UIMB_UMCR_STOP (1<<31)
332#define UIMB_UMCR_IRQMUX(x) ((x)<<29)
333#define UIMB_UMCR_HSPEED (1<<28)
334
335/*
336 *************************************************************************
337 * QSMCM Serial Communications Interface (SCI) *
338 *************************************************************************
339 */
340
341
342#define QSMCM_ILDSCI(x) ((x)<<8) /* SCI interrupt level */
343
344#define QSMCM_SCI_BAUD(x) ((x)&0x1FFF) /* Baud rate field */
345
346#define QSMCM_SCI_LOOPS (1<<14) /* Loopback test mode */
347#define QSMCM_SCI_WOMS (1<<13) /* Wire-or mode select */
348#define QSMCM_SCI_ILT (1<<12) /* Idle-line detect type */
349#define QSMCM_SCI_PT (1<<11) /* Parity type */
350#define QSMCM_SCI_PE (1<<10) /* Parity enable */
351#define QSMCM_SCI_M (1<<9) /* 11-bit mode */
352#define QSMCM_SCI_WAKE (1<<8) /* Wakeup mode */
353
354#define QSMCM_SCI_TIE (1<<7) /* Transmitter interrupt enable */
355#define QSMCM_SCI_TCIE (1<<6) /* Transmit complete intr. enable */
356#define QSMCM_SCI_RIE (1<<5) /* Receiver interrupt enable */
357#define QSMCM_SCI_ILIE (1<<4) /* Idle line interrupt enable */
358#define QSMCM_SCI_TE (1<<3) /* Transmitter enable */
359#define QSMCM_SCI_RE (1<<2) /* Receiver enable */
360#define QSMCM_SCI_RWU (1<<1) /* Receiver wake-up enable */
361#define QSMCM_SCI_SBK (1<<0) /* Send break */
362
363#define QSMCM_SCI_TDRE (1<<8) /* Transmit data register empty */
364#define QSMCM_SCI_TC (1<<7) /* Transmit complete */
365#define QSMCM_SCI_RDRF (1<<6) /* Receive data register full */
366#define QSMCM_SCI_RAF (1<<5) /* Receiver active flag */
367#define QSMCM_SCI_IDLE (1<<4) /* Idle line detected */
368#define QSMCM_SCI_OR (1<<3) /* Receiver overrun error */
369#define QSMCM_SCI_NF (1<<2) /* Receiver noise error flag */
370#define QSMCM_SCI_FE (1<<1) /* Receiver framing error */
371#define QSMCM_SCI_PF (1<<0) /* Receiver parity error */
372
373/*
374 *************************************************************************
375 * Unified System Interface Unit *
376 *************************************************************************
377 */
378
379/*
380 * Memory controller registers
381 */
382typedef struct m5xxMEMCRegisters_ {
383 uint32_t _br;
384 uint32_t _or; /* Used to be called 'or'; reserved ANSI C++ keyword */
385} m5xxMEMCRegisters_t;
386
387/*
388 * USIU itself
389 */
390typedef struct usiu_ {
391 /*
392 * SIU Block
393 */
394 uint32_t siumcr;
395 uint32_t sypcr;
396 uint32_t _pad70;
397 uint16_t _pad0;
398 uint16_t swsr;
399 uint32_t sipend;
400 uint32_t simask;
401 uint32_t siel;
402 uint32_t sivec;
403 uint32_t tesr;
404 uint32_t sgpiodt1;
405 uint32_t sgpiodt2;
406 uint32_t sgpiocr;
407 uint32_t emcr;
408 uint8_t _pad71[0x03C-0x034];
409 uint32_t pdmcr;
410 uint8_t _pad2[0x100-0x40];
411
412 /*
413 * MEMC Block
414 */
415 m5xxMEMCRegisters_t memc[4];
416 uint8_t _pad7[0x140-0x120];
417 uint32_t dmbr;
418 uint32_t dmor;
419 uint8_t _pad8[0x178-0x148];
420 uint16_t mstat;
421 uint8_t _pad9[0x200-0x17A];
422
423 /*
424 * System integration timers
425 */
426 uint16_t tbscr;
427 uint16_t _pad10;
428 uint32_t tbreff0;
429 uint32_t tbreff1;
430 uint8_t _pad11[0x220-0x20c];
431 uint16_t rtcsc;
432 uint16_t _pad12;
433 uint32_t rtc;
434 uint32_t rtsec;
435 uint32_t rtcal;
436 uint32_t _pad13[4];
437 uint16_t piscr;
438 uint16_t _pad14;
439 uint16_t pitc;
440 uint16_t _pad_14_1;
441 uint16_t pitr;
442 uint16_t _pad_14_2;
443 uint8_t _pad15[0x280-0x24c];
444
445 /*
446 * Clocks and Reset
447 */
448 uint32_t sccr;
449 uint32_t plprcr;
450 uint16_t rsr;
451 uint16_t _pad72;
452 uint16_t colir;
453 uint16_t _pad73;
454 uint16_t vsrmcr;
455 uint8_t _pad16[0x300-0x292];
456
457 /*
458 * System integration timers keys
459 */
460 uint32_t tbscrk;
461 uint32_t tbreff0k;
462 uint32_t tbreff1k;
463 uint32_t tbk;
464 uint32_t _pad17[4];
465 uint32_t rtcsk;
466 uint32_t rtck;
467 uint32_t rtseck;
468 uint32_t rtcalk;
469 uint32_t _pad18[4];
470 uint32_t piscrk;
471 uint32_t pitck;
472 uint8_t _pad19[0x380-0x348];
473
474 /*
475 * Clocks and Reset Keys
476 */
477 uint32_t sccrk;
478 uint32_t plprck;
479 uint32_t rsrk;
480 uint8_t _pad20[0x400-0x38c];
481} usiu_t;
482
483extern volatile usiu_t usiu; /* defined in linkcmds */
484
485/*
486 *************************************************************************
487 * Inter-Module Bus and Devices *
488 *************************************************************************
489 */
490
491/*
492 * Dual-Port TPU RAM (DPTRAM)
493 */
494typedef struct m5xxDPTRAMRegisters_ {
495 uint8_t pad[0x4000]; /* define later */
496} m5xxDPTRAMRegisters_t;
497
498/*
499 * Time Processor Unit (TPU)
500 */
501typedef struct m5xxTPU3Registers_ {
502 uint8_t pad[0x400]; /* define later */
503} m5xxTPU3Registers_t;
504
505/*
506 * Queued A/D Converter (QADC)
507 */
508typedef struct m5xxQADC64Registers_ {
509 uint8_t pad[0x400]; /* define later */
510} m5xxQADC64Registers_t;
511
512/*
513 * Serial Communications Interface (SCI)
514 */
515typedef struct m5xxSCIRegisters_ {
516 uint16_t sccr0;
517 uint16_t sccr1;
518 uint16_t scsr;
519 uint16_t scdr;
520} m5xxSCIRegisters_t;
521
522/*
523 * Serial Peripheral Interface (SPI)
524 */
525typedef struct m5xxSPIRegisters_ {
526 uint16_t spcr0;
527 uint16_t spcr1;
528 uint16_t spcr2;
529 uint8_t spcr3;
530 uint8_t spsr;
531} m5xxSPIRegisters_t;
532
533/*
534 * Queued Serial Multi-Channel Module (QSMCM)
535 */
536typedef struct m5xxQSMCMRegisters_ {
537 uint16_t qsmcmmcr;
538 uint16_t qtest;
539 uint16_t qdsci_il;
540 uint16_t qspi_il;
541
542 m5xxSCIRegisters_t sci1;
543
544 uint8_t _pad10[0x14-0x10];
545
546 uint16_t portqs;
547 uint16_t pqspar;
548 m5xxSPIRegisters_t spi;
549
550 m5xxSCIRegisters_t sci2;
551
552 uint16_t qsci1cr;
553 uint16_t qsci1sr;
554 uint16_t sctq[0x10];
555 uint16_t scrq[0x10];
556
557 uint8_t _pad6C[0x140-0x06C];
558
559 uint16_t recram[0x20];
560 uint16_t tranram[0x20];
561 uint16_t comdram[0x20];
562} m5xxQSMCMRegisters_t;
563
564/*
565 * Modular Input/Output System (MIOS)
566 */
567typedef struct m5xxMIOS1Registers_ {
568 uint8_t pad[0x1000]; /* define later */
569} m5xxMIOS1Registers_t;
570
571/*
572 * Can 2.0B Controller (TouCAN)
573 */
574typedef struct m5xxTouCANRegisters_ {
575 uint8_t pad[0x400]; /* define later */
576} m5xxTouCANRegisters_t;
577
578/*
579 * U-Bus to IMB3 Bus Interface Module (UIMB)
580 */
581typedef struct m5xxUIMBRegisters_ {
582 uint32_t umcr;
583 uint32_t utstcreg;
584 uint32_t uipend;
585} m5xxUIMBRegisters_t;
586
587/*
588 * IMB itself
589 */
590typedef struct imb_ {
591 m5xxDPTRAMRegisters_t dptram;
592 m5xxTPU3Registers_t tpu[2];
593 m5xxQADC64Registers_t qadc[2];
594 m5xxQSMCMRegisters_t qsmcm;
595 uint8_t _pad5200[0x6000-0x5200];
596 m5xxMIOS1Registers_t mios;
597 m5xxTouCANRegisters_t toucan[2];
598 uint8_t _pad7800[0x7F80-0x7800];
599 m5xxUIMBRegisters_t uimb;
600} imb_t;
601
602extern volatile imb_t imb; /* defined in linkcmds */
603
604
605/*
606 * Methods shared across libcpu and the BSP.
607 */
608void clockOn(void* unused);
609void clockOff(void* unused);
610int clockIsOn(void* unused);
611rtems_isr Clock_isr(rtems_vector_number vector);
612
613#ifdef __cplusplus
614}
615#endif
616
617#endif /* ASM */
618
619#endif /* _MPC5XX_H */
ISR_Handler rtems_isr
This type defines the return type of interrupt service routines.
Definition intr.h:123
ISR_Vector_number rtems_vector_number
This integer type represents interrupt vector numbers.
Definition intr.h:102
Definition mpc5xx.h:590
Definition mpc5xx.h:494
Definition mpc5xx.h:382
Definition mpc5xx.h:567
Definition mpc5xx.h:508
Definition mpc5xx.h:536
Definition mpc5xx.h:515
Definition mpc5xx.h:525
Definition mpc5xx.h:501
Definition mpc5xx.h:574
Definition mpc5xx.h:581
Definition mpc5xx.h:390
